LED LAMP
VAOL-10GCE4
Feature
Package Dimension
Low Power Consumption
High Intensity
I.C. compatible
Applications
Commercial Outdoor Sign Board
Front Panel Indicator
Dot-Matrix Module
LED Bulb
Description
These High Intensity LEDs are Based on
GaAsP/GaP Material Technology
Emitted color:Yellow
Water Transparent Lens
*Tolerance:± 0.01
0.25
Unit:±
inch
mm
Absolute Maximum Ratings at Ta=25℃
Symbol
Parameter
Max.
Unit
100
mW
PD
Power Dissipation
VR
Reverse Voltage
5
V
IAF
Average Forward Current
25
mA
IPF
Peak Forward Current(Duty=0.1,1kHz)
85
mA
Derating Linear Form 25℃
0.4
mA∕℃
Topr
Operating Temperature Range
–40 to + 80
Tstg
Storage Temperature Range
–40 to + 100
Lead Soldering Temperature [1.6mm(0.063inch)From Body] 260℃ For 5 Seconds.
Electrical / Optical Characteristics and Curves at Ta=25℃
Symbol
Parameter
VF
Forward Voltage
IR
Reverse Current
△θ
IV
Half Intensity Angle
Luminous Intensity
Test Condition
IF= 20
mA
Min.
Typ.
Max.
Unit
2.0
2.4
V
100
μA
VR=
5
V
IF=
mA
30
Deg.
IF= 20
mA
200
mcd.
λp
Peak Wavelength
IF= 20
mA
593
nm
λd
Dominant Wavelength
IF= 20
mA
590
nm
Electrical Characteristics at Ta=25℃
Symbol
Iv
VF
λD
Parameter
Luminous Intensity
Forward Voltage
Dominant Wavelength
Condition
IF=20mA
IF=20mA
IF=20mA
Unit
mcd
V
nm
Grade
Binning
Range
Grade
Range
Grade
Range
B
1.8~1.9
Y3
589~591
C
1.9~2.0
Y4
591~593
D
2.0~2.1
Y5
593~595
E
2.1~2.2
F
2.2~2.3
G
2.3~2.4
Intensity: Tolerance of minimum and maximum = ± 15%
Vf: Tolerance of minimum and maximum = ± 0.05v
NOTE:
1. Static electricity and surge damages the LED. It is recommend to use a anti-static wrist
band or anti-electrostatic glove when handing the LEDs. All devices, equipment and machinery
must be properly grounded.
2. Specific binning requirements –please contact our home office
Radiation Diagram
IF=20 mA 50% Power Angle
Angle =30∘
YELLOW
Y: Yellow
(GaAsP/GaP)
Typical Electro-optical Characteristic Curves
(25°C Free Air Temperature Unless O therwise Specified)
λ
很抱歉,暂时无法提供与“VAOL-10GCE4”相匹配的价格&库存,您可以联系我们找货
