engineered to light up your design
www.vcclite.com
1.800.522.5546
CMD11504 Series Bright Angle™ Right Angle Surface Mount LED
Description and Features
All dimensions
in mm.
• Right angle mounting.
• Compact size: 3.00mm x 1.00mm x 2.00mm
• High brightness
LED DIE
1.00
Surface Mount Technology
• Tape and reel packaged for high-speed autoinsertion.
• Convection and vapor-phase reflow compatible.
• Compact form enables high density placement.
• Packaged 3000 pieces per reel.
• RoHS Compliant
0.30
TYP.(2)
3.00
LIGHT
OUTPUT
2.00
PLASTIC
Leading Edge LED Optoelectronic Performance
• Consistent high brightness.
2.00
SUBSTRATE
PIN CONNECTION
MARK
CATHODE
1.00
SOLDER PAD FOR
REINFORCEMENT
ANODE(+)
Exceptional Reliability
• Stringent process controls assure quality.
• Extensive qualification testing to meet strictest requirements.
• Designed to permit easy post-reflow solder joint inspection.
• Refer to “Solder Pad Geometry 3.pdf”
0.30
TYP.(2)
0.45
1.00
Electro-Optical Characteristics and Ratings
Part Number
CMD11504UR
CMD11504Y
CMD11504G
Source
(Dice)
Red
Yellow
Green
Package
Color
Water Clear
Water Clear
Water Clear
Luminous Intensity @20ma
Min.
(mcd)
6.6
1.6
3.0
Forward Voltage
Typ.
(mcd)
Typ.
(V)
Max.
(V)
Viewing
Angle
(degrees)
Peak
Wavelength
(nm)
13.2
3.2
16.0
1.7
2.2
2.1
2.0
2.5
2.5
100
100
100
660
580
560
CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
VCC:
CMD11504G CMD11504UR CMD11504Y CMD11504R/G
很抱歉,暂时无法提供与“CMD11504UR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+2.494863000+0.30103
- 6000+2.405756000+0.29028
- 15000+2.3701115000+0.28598
- 30000+2.3166530000+0.27953
- 国内价格 香港价格
- 1+7.939021+0.95793
- 10+5.1691910+0.62372
- 100+3.38586100+0.40854
- 1000+2.673061000+0.32253
