4-Pin Super Flux Red/Green LED Lamp
Orca R Series (Flat Face)
R50RG2-F-0160
RoHS Compliant
Low Profile Dome Lens
Automatic Insertion Compatible — Tubular Packaging
Automatic Placement Compatible
High Intensity Output
High Power Efficiency
Bivar R50RG2-F-0160 comes with low profile package design incorporating higher forward current to maximize intensity while minimizing the number of LEDs required to achieve uniform and enhanced light distribution. Low power consumption with quick response time means savings in electricity.
Bivar R50RG2-F-0160 can be coupled with reflectors or lenses for optimal light distribution needs. Typical
applications are automotive exterior lighting, decorative interior or exterior lighting, specialty stage lighting,
and electronic signage.
Part Number
R50RG2-F-0160
Material
Emitted Color
Intensity Typ. mcd
AlGaInP/GaAs
Red
600
GaN/SiC
Green
800
Outline Drawings Notes:
1. All dimensions are in inches [millimeters].
2. Standard tolerance: ±0.010" unless otherwise noted.
3. Tolerance of overall epoxy outline: ±0.020" unless otherwise noted.
4. Epoxy meniscus may extend to 0.060" max.
ATTENTION
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
RoHS Compliant
Lens Color
Viewing Angle
Water Clear
160°
Moisture
Sensitivity
Levels 1
CAUTION: LOOKING DIRECTLY AT
LED WITHOUT SHIELDED EYES
MAY CAUSE DAMAGE TO RETINA.
Bivar reserves the right to make changes at any time.
Bivar, Inc. — 4 Thomas, Irvine, California 92618, U.S.A.
Phone: (949) 951-8808 Fax: (949) 951-3974 E-mail: bivar@bivar.com Web: www.bivar.com
Revision D 09/11
Page 1 of 4
R50RG2-F-0160
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
R - 150 mW
G - 220 mW
Power Dissipation
Forward Current ( DC )
80 mA
Peak Forward Current 1
R - 160 mA
G - 150 mA
Electrostatic Discharge ( Class1 )
R - 1000 V
G - 1000 V
Reverse Voltage
5V
Operating Temperature Range
-25 ~ +80°C
Storage Temperature Range
-30 ~ +80°C
Lead Soldering Temperature ( 3 mm from the base of the epoxy bulb ) 2
Notes: 1. 10% Duty Cycle, Pulse Width ≤ 0.1 msec.
260°C
2. Solder time less than 5 seconds at temperature extreme.
Electrical Characteristics
TA = 25°C & I F = 50 mA unless otherwise noted
Emitting
Color
Forward
Voltage (V)1
MIN
TYP MAX
Red
2.2
2.6
Green
3.4
3.8
Recommend
Reverse
Dominant
Forward
Current (µA)
Wavelength (nm)2
Current (mA)
VR=5V
Luminous
Intensity (mcd)3
Viewing
Angle
2 Ө ½ (deg)
TYP
MAX
MIN
MAX
MIN
TYP
TYP
3.0
50
10
620
635
400
600
160
4.4
50
10
515
525
600
800
160
Notes: 1. Tolerance of Forward Voltage : ±0.05V.
2. Tolerance of Dominant Wavelength : ±0.1nm.
3. Tolerance of Luminous Intensity : ±15%.
Directivity Radiation
Relative Luminous Intensity vs. Radiation Angle
Revision D 09/11
Page 2 of 4
R50RG2-F-0160
Typical Electrical / Optical Characteristics Curves
Fig.5 Relative Luminous Intensity vs. Ambient Temperature
Revision D 09/11
Page 3 of 4
R50RG2-F-0160
Recommended Soldering Conditions
Recommended Lead Free Wave Soldering Profile
Preheat Temperature: 100ºC Max.
Peak Temperature: 260ºC Max.
Preheat Time: 20 ~ 50 Seconds
Solder Time Above 217ºC: 5 Seconds Max.
Note: Turn off top heater at preheat to prevent the lamp body directly exposed to the heat source.
Packaging and Labeling Plan
Bivar Orca R series Super Flux LEDs are packaged in tubes, each of which contains 60 LEDs; and each tube contains
a rubber stopper at each end.
Revision D 09/11
Page 4 of 4
很抱歉,暂时无法提供与“R50RG2-F-0160”相匹配的价格&库存,您可以联系我们找货
