CABLE ASSEMBLY
Overmoulded Cable Assembly Selector Guide
Cable Assembly |
SOURIAU Services
An availability around the world
Reliable solutions
- Global manufacturing locations
- Vast network of authorised distribution partners.
Certification for all major high speed protocols: CAT 5, 5E, RS-485
Electrical control of each harness
Test capabilities: vibration, temperature, flexing and sealing
Wires encapsulated within the potting: sealing is maintened if the cable
sheath is breached.
Your Custom Interconnect Capabilities
Custom Overmould
Optical Cable Assembly
Overmould on Two Cables
Overmould on Curly Cable
PCB Connection
Y or T Shape Connection
Cable Assembly |
Features & Benefits
READY
TO
INSTALL
Full Interconnect Solution
SOURIAU overmould harness is composed of connectors,
overmould (straight or right angle) and cable according
to your requirements (length, environmental constraints)
for an easy and secured installation.
IP68/69K Mated and Unmated
WATER
PROOF
LONG
LIFE
DURATION
Water and dust protection, secure for outdoor and indoor
applications.
UV Resistant
No mechanical deterioration or important variation of
colour after 5 years of exposure in natural environment
(equivalence exposure to sun and moisture as per ISO4892).
Halogen Free
HUMAN
FRIENDLY
Non-hazardous to members of the public in case of fire.
Shielding
SIGNAL
INTEGRITY
Can be used when signals have to be transmitted in EMC area.
Cable Assembly | Description
Robust Metal & Shielding Overmould (UTO Series)
3 standard layouts: 4 pos, 8 pos, 12 pos. Other layouts on request, please consult us.
Connector
• Metal connector with Nickel plating
• Rapid 1/3 turn connection
Cable
TPE outer sheath (black color)
300V
Flammability rating UL 94V0 Sec.1080 (VW-1)
Resistant to a wide range of chemical fluids
MIL DTL 26482 Overmould (851 Series)
4 standard layouts: 4 pos, 6 pos, 10 pos, 19 pos. Other layouts on request, please consult us.
Connector
• Metal connector
• Conforms to the international standard
MIL-DTL-26482G series 1
Cable
Connector
UTO
851
Plating
Salt spray
Black anodized
96 H
Nickel
48 H
Black Zinc nickel
or Cadmium
or Black anodized
500 H
Nickel
With appropriate cable and overmould
48 H
300V
Flammability rating UL 1581 Sec.1080 (VW-1)
Temperature
Sealing
Mechanical
Shielding
-40° C up to + 105° C
IP68/69K mated
500 matings/
unmatings
65 dB
-55° C up to + 125° C
IP68
500 matings/
unmatings
IP68
500 matings/
unmatings
70 dB
UL/IEC Power Supply Overmould (UTL Series)
1 standard layout: 4 pos.
Connector
• Plastic connector
• Push pull locking mechanism
Cable
H07RN-F: 750V
Outer sheath: rubber compound EM2
Colour outer sheath (black color)
Core section: 2.5mm²
Flame retardant in acc. to IEC 60332-1-2 resp.
VDE 0482 part 332-1-2
• Resistant to Oil, Solvents, Water, Ozone, aging
and abrasion
Waterproof IP67/IP68/IP69K Overmould (UTS Series)
Connector
• Plastic connector
• Rapid 1/3 turn
Cable
PVC outer sheath (grey color)
1.5 mm2 conductor
300V
Flammability rating IEC (UL1581 Sec.1160)
High flexibility
Small cable diameter
Connector
Plating
Salt spray
Temperature
Sealing
Mechanical
UTL
No plating
≥1000 H
IP68/69K mated
500 matings/unmatings
UTS
No plating
500 H
IP68/69K mated
Cable Assembly | Applications
Recommended Applications
Renewable
Energy
Connector
Cable
UTS
Low Smoke
Halogen Free
UTL
UTS
UTL
PVC Outer
Sheath
UTO
UTO
851
PUR or TPE
Outer Sheath
UTS
UTL
UTS
UTS
UTO
851
Shielding
HII
HHI
III
HII
HHI
III
HII
HHH
III
HII
HHH
III
HII
HHH
HHH
HHH
HHI
HHH
HHH
HHI
HHH
HHH
HHI
III
HHH
HHI
III
HII
HHI
III
HII
HHI
III
HII
HHH
III
HII
HHH
III
HHH
HHH
III
HHH
HHH
III
HHH
HHH
III
HHH
HHH
III
H07RN8F
UTL
UTL
Flexing
H07RNF
UTL
UTS
UV
resistant
Curly Structure
Pur Sheath
Road
Infrastructure
3
3
Portable
Energy
Civil
Marine
Power Generation
/ Energy
Factory
Automation &
Control
Off-Road
Instrumentation /
Measurement
Telecom /
Datacom
Infrastructure
Stage Light
& Sound
Why use this
configuration?
3
3
Can be used in
public facilities
The best proposal
for indoor
applications
Proven
all-weather
harnesses
resistant against a
variety of
chemical fluids
Heavy-duty and very
well known cable for
usage both in and
outdoor
applications
The right choice
for immerged
applications
Perfect solution
for telescopic
applications
www.souriau-industrial.com
contactindustry@souriau.com
Our contribution to environmental
protection:
This catalog is printed on PEFC
certified paper
Advancement of sustainable
wood cultivation. www.pefc.org
All information in this document presents only general particulars and shall not form part of any contract. All rights reserved to SOURIAU for changes without prior notification or public announcement. Any duplication is prohibited, unless approved in writing. Photos: Fotolia.com, SOURIAU
CPHARNESSEUUSEN01 © Copyright SOURIAU Dec 2013 - SOURIAU is a registered trademark
Your local contact
很抱歉,暂时无法提供与“UT06V1208P12FT00”相匹配的价格&库存,您可以联系我们找货
