1000 Eaton Boulevard
Cleveland, OH 44122
United States
Easy Pull Long-Run Display Cable - Type-B
Digital PVC Trunk Cable, 100 ft. (30.5 m)
MODEL NUMBER: EZB-100
Highlights
Versatile trunk cable allows for a
variety of connection options
Easily pulls through conduit or
confined spaces with included
end caps with integrated pull
tabs
UL20276 Digital Video Cable
supports 1080i
Requires a signal booster, such
as Tripp Lite’s B120-000 (DVI)
or B122-000-60 (HDMI)
Package Includes
Description
Tripp Lite's EZB-100 100-ft. (30.5 m) Easy Pull Digital Trunk cable makes pulling video cable through
conduit or confined areas a breeze. Threaded ends feature screw on pull-caps, which can be attached to
fish tape. Choose from HDMI and DVI termination kits that easily screw on to the threaded ends of the
trunk cable. Trunk cables are available in 50-ft. (15.24 m) and 100-ft. (30.5 m) PVC (Plenum available as
custom item). Cable ends are colored-coded yellow to denote Digital applications (VGA trunk cables are
green). Cable features 4pr UL20276 individually shielded twisted pairs, one twisted pair and five signal
conductors. UL20276 Digital Video Cable supports 1080i.
Features
Eliminates the need to field terminate HDMI and DVI connectors
Detachable, screw-on connectors
Allows cable to be run according to code - inside conduit, drop ceilings, etc.
Makes pulling long cables fast and easy
Protects entire cable from strain, dirt, debris and damage
Choose from a variety of connector combinations for the perfect fit
Available in 50-ft. (15.24 m) and 100-ft. (30.5 m) PVC lengths (Plenum cables available upon request)
Requires a signal booster, such as Tripp Lite's B120-000 (DVI) or B122-000-60 (HDMI)
Specifications
OVERVIEW
UPC Code
037332141859
1/2
Easy Pull Type-B Digital PVC
Trunk Cable, 100-ft. (30.5 m)
Cleveland, OH 44122
United States
Technology
DVI; HDMI
PHYSICAL
Color
Black; Yellow
Cable Length (ft.)
100
Cable Length (m)
30.49
Shipping Dimensions (hwd / in.)
17.00 x 14.00 x 0.50
Shipping Dimensions (hwd / cm)
43.18 x 35.56 x 1.27
Shipping Weight (lbs.)
4.64
Shipping Weight (kg)
2.11
CONNECTIONS
Side A - Connector 1
DIN 19 PIN (FEMALE)
Side B - Connector 1
DIN 19 PIN (FEMALE)
Latching or Gripping Connector
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“EZB-100”相匹配的价格&库存,您可以联系我们找货
