8
7
4
5
6
1
2
3
REVISIONS
E
D
B
A
F
2X .125 3.18
THRU
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2411
INITIAL RELEASE
7/27/2011
JH
F
+0.13
+.005
9.40
.370
- 0.38
- .015
.075 1.91
CARDSLOT
C
.030±.010 0.75±0.25
A
E
E
.180 4.57
.297 7.54
INSERTION DEPTH
.025 0.64
.250 6.35
.610 15.49
.190±.025 4.83±0.64
D
.060 1.52
A
.156 3.96 TYP
D
.025 [0.64] POST
.200 5.08
SECTION A-A
F
MP_ _-_156-_ _-DR-5(E)H_ _Z_
MP_ _-_156-_ _-DR-5(E)H_ _ _
CONTACT MARKINGS
(LETTERS G, I, O, & Q NOT USED)
SIZES 06 THRU 25 & 30:
1 2 ... 13 24 ... 29 30
A B ... A B ... H J
D
C
2X .125 3.18
FOR MOUNTING STYLE
'1', '2', '5' OR '6'
A
.200 5.08
.156 3.96 PCB LAYOUT RECOMMENDED
B
A
7
6
SIZES 36 THRU 43
A B ... A B ... X Y
1 2 ... 23 24 ... 42 43
CONTACT ID.
SCALE 4 : 1
CONTACTS NOT
SHOWN FOR CLARITY
B
REF: _ _M_ _DTK_ - S_ _ _
CUSTOMER COPY
DRAWN
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
Pb
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
SIZES 28 & 31:
1 2 .. 23 24 ... 30 31
A B ... A B ... J K
.033 0.84 MIN
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. DIELECTRIC WITHSTANDING VOLTAGE: 950 VAC MINIMUM AT SEA LEVEL.
8. CURRENT RATING: 3 AMP PER CONTACT
9. CONTACT RESISTANCE: 30 MILLI OHM MAX
10. INSULATION RESISTANCE: 5000 MEGA OHM MIN
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008"
14. INSERTION FORCE: 8 OZ MAX PER CONTACT PAIR WHEN USING A .062" TEST BLADE.
15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062" PCB
5
C
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
INTERPRET DIMENSIONS AND
TOLERANCING
PER: ASME Y14.5M-2009
3
DATE
NAME
7/24/2011
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
A
EDGECARD, .156 CC, HP
PART NUMBER
SIZE
C
MP_ _ - _156-_ _- DR-_ _ H_ _(Z)_
CAGE CODE
54453
SCALE: 3:1
2
DWG. NO.
C11848
SHEET 1 OF 3
1
REV
A
FILE NAME: C11848, MP_ _-_156-_ _-DR-_ (E) H _ _ (Z)_ (_ _M_ _DTK_- (OMIT, S38, S81, S328)
8
7
4
5
6
1
2
3
2X .125 3.18
THRU
D
F
F
C
.250 6.35
E
E
MP_ _-_156-_ _-DR-4(E)H_ _Z_
MP_ _-_156-_ _-DR-4(E)H_ _ _
MP_ _-_156-_ _-DR-1(E)H_ _Z_
MP_ _-_156-_ _-DR-1(E)H_ _ _
D
2X #4-40
THREADED INSERT
D
D
2X #4-40
THREADED INSERT
D
MP_ _-_156-_ _-DR-6(E)H_ _Z_
MP_ _-_156-_ _-DR-6(E)H_ _ _
C
2X .125 3.18
THRU
C
.250 6.35
MP_ _-_156-_ _-DR-2(E)H_ _Z_
MP_ _-_156-_ _-DR-2(E)H_ _ _
D
2X .125 3.18
THRU
B
B
.245 6.22
MP_ _-_156-_ _-DR-8(E)H_ _Z_
MP_ _-_156-_ _-DR-8(E)H_ _ _
CUSTOMER COPY
DRAWN
Pb
A
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
TOLERANCING
3
DATE
NAME
7/24/2011
JH
TITLE
A
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
2
DWG. NO.
C11848
SHEET 2 OF 3
1
REV
A
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
DRAWN
Pb
A
TOLERANCES:
.XX=
.XXX=
.XXXX=
RoHS COMPLIANT
8
7
6
5
4
ANGULAR: 30'
.02 [.5]
.005 [.13]
.0005 [.013]
TOLERANCING
3
DATE
NAME
7/24/2011
JH
TITLE
A
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
2
DWG. NO.
C11848
SHEET 3 OF 3
1
REV
A
很抱歉,暂时无法提供与“MP-2156-12-DR-1H”相匹配的价格&库存,您可以联系我们找货
