CUSTOMER: 深圳市海德容科技有限公司
DATE: July 05,2023
SPECIFICATION
DESCRIPTION: Aluminium Electrolytic Capacitors
AISHI P/N:
ERJ1HM100D11OT
SERIES:
RJ
ITEM:
50 V
10
μF (Φ
5
× 11 )
CUSTOMER P/N:
No.:
CRS-ZD-23060412
APPROVED BY
Please Return One Copy with Your Approval
承认后请寄回一份
PREPARED BY
CHECKED BY
APPROVED BY
变更记录 Change Records
编号 No.
更改原因
Explanation of changes
更改内容 Content
修订人
Reviser
生效日期
Effective date
CRS-ZD-23060412
新建 New
新建 New
黄瑶
2023-07-05
CUSTOMER
SERIES
深圳市海德容科技有限公司
RJ
DATE
2023-07-05
FIG-1
TABLE-1
No.
1
Customer
Part No.
Aishi Part No.
ERJ1HM100D11OT
Capacitance Rated
Surge
Capacitance
Tolerance
Voltage Voltage
(μF)
(Vdc)
(Vdc)
10
-20,+20
50
63
Operating
Temp.
Range
Tanδ
(120Hz)
(Max)
Leakage
Current
(μA)(2min.)
-40~+105
0.10
5.0
Max Ripple
Impedance Endurance
Current
Dimensions (mm)
(Ω)Max
(mArms)
at 105℃
at 20℃
at 105℃
(Hours)
100kHz
ΦD L α
d
F
100kHz
120
0.62
8000
5
11
2
0.5 2.0
Appearance
Drawing No.
FIG-1
1 概述 SCOPE
本承认书规定了RJ系列径向引线引出铝电解电容器的技术规范,本技术规范条文解释权归本公司所有。
This specification covers“RJ series” miniature single-ended aluminium electrolytic capacitors,AISHI
reserves the right of final interpretation for this technical specification.
2 参考标准 APPLICABLE SPECIFICATION
本承认书参考IEC 60384-1、IEC 60384-4、GB/T 2693和GB/T 5993制定。
This specification consulted the institute of IEC 60384-1,IEC 60384-4,GB/T 2693 and GB/T 5993.
3 工作温度范围 OPERATING TEMPERATURE RANGE
工作温度范围是电容器在施加额定工作电压条件下,可以长期可靠工作的环境温度范围。
-40℃~+105℃(6.3 VDC~100 VDC)
Operating temperature range is the range of ambient temperature at which the capacitor can be operated
continuously at rated voltage.
-40℃~+105℃
6.3V.DC~120V.DC
4 测试环境 CONDITION OF TEST
如果没有其他规定,标准的测试、检验环境条件如下所示:
环境温度:15℃~35℃
相对湿度:45%~75%
大气压力:86kPa~106kPa
如果对测试结果有异议,可以在以下条件测试:
环境温度:20±1℃
相对湿度:60%~67%
大气压力:86kPa~106kPa
Unless otherwise specified, the standard range of atmospheric conditions for making
measurements and tests are as follows:
Ambient temperature :15℃ to 35℃
Relative humidity :45% to 75%
Air pressure:86kPa to 106kPa
If there may be doubt on the results, measurements shall be made within the following limits:
Ambient temperature :20±1℃
Relative humidity :60% to 67%
Air pressure :86kPa to 106kPa
File Description
Component P/N
Approval Sheet
RJ
Version
01
STANDARD MANUAL
Page
1
5 产品特性 PRODUCT CHARACTERISTICS
5.1电气特性 Electrical Characteristics
序号 No.
5.1.1
5.1.2
5.1.3
项目 Item
测试方法 Test method
性能 Performance
电压:直流电压值+交流电压峰值≤额定电压 见表1
额定工作电压 Voltage: DC voltage + peak ripple voltage ≤
See TABLE-1
Rated voltage
Rated voltage
测试频率:120Hz(±20%)
测试电路:串联等效
测试电压:0.5Vrms以下+1.5~ 2.0VDC
电容量 Measuring frequency: 120Hz±20%
Measuring circuit:
Capacitance
Series equivalent circuit
Measuring voltage:
0.5Vrms or less +1.5 to 2.0 VDC
测试条件与5.1.2电容量测试相同。
损失角正切值
Testing conditions are the same as 5.1.2 for
Dissipation factor
capacitance.
容量偏差 : -20%~+20%
Capacitance tolerance:
-20%~+20%
DF见表1
DF: See TABLE-1
10V~120V:
在电容器两端施加额定工作电压,并串联
I≤0.01CV或3μA,
1000±100Ω电阻,在施加规定时间电压后,测 取较大值(2分钟后)。
量漏电流。
10V~120V:
I≤0.01CV or 3μA Whichever is
测试电路如下图: greater ( after 2 min).
The rated voltage shall be applied across the
capacitor and its protective resistor shall be I:漏电流(μA)
1000±100Ω. The leakage current shall then be C:容量(μF)
measured after an electrification period of
V:额定工作电压(V)
schedule time.Measurement circuit:
I:Leakage current(μA)
C:Capacitance(μF)
V:Rated voltage (V)
5.1.4
漏电流
Leakage current
Rs: Protective resistor(1000±100Ω)
DC ammeter
DC voltmeter
S1: Switch
S2: Protective switch for an ammeter
File Description
Component P/N
Approval Sheet
RJ
Version
01
STANDARD MANUAL
Page
2
5.1.5
阶段
温度
时间
1
20±2℃
2
+0
-25,-40 -3 ℃
2h
3
20±2℃
15min.
4
105 ℃
-0
+3
2h
阶段1:测量容量和阻抗 (|z| 20℃ 120Hz±20%);
阶段2:电容器恒温贮存2小时,在热平衡状态测阻抗
(|z|- 25, -40℃ 120Hz±20%);
温度特性 阶段4:电容器恒温贮存2小时,在热平衡状态测电容量
Temperature
characteristic
Step 1: Capacitance and impedance shall be
measured. (|z| 20℃ 120Hz±20%);
Step 2: After the capacitor being stored for 2
hours,impedance shall be measured at thermal stability.
(|z|-25,-40℃ 120Hz±20%);
Step 4:After the capacitor being stored for 105℃2
hours, capacitance shall be measured. The
measurement shall be made at thermal stability.
阶段2:
阻抗值与阶段1阻抗值相比,不大于表2要求;
阶段4:
容量变化应在初值的±20%范围内。
Step 2:
Impedance value ratio to the value at step 1 shall be
not more than the value given in TABLE-2.
Step 4:
Variation of capacitance Within ±20% of the initial
value.
施加表1所列浪涌电压,充电30±5秒,放电5.5±0.5分钟 容量变化:在初始值的±20%以内。
损耗角正切值:不大于表1规定值的200%。
作为一个周期,共进行1000次。
漏电流:满足5.1.4要求。
测试温度:15℃-35℃
Capacitance change:
然后在标准大气条件下放置达到热稳定,测试各参数
Within±20% of the initial value .
Application of DC surge Voltage stated at TABLE-1.
Dissipation factor:
1000 times of charging for 30±5 sec., discharging with a Not more than 200% of the specified value in TABLE-1.
period of 5.5±0.5 min..
Leakage current:
Test temperature: 15℃-35℃
To satisfy No. 5.1.4 .
And the capacitor shall be stored under standard
atmospheric conditions to obtain thermal stability, after
which measurements shall be made.
Test circuit
5.1.6
耐浪涌电压
Surge test
Note: This requirement is applicable only to instantaneous over voltage which may be applied to terminals of
capacitor, therefore, not applicable to such over voltages as often applied.
File Description
Component P/N
Approval Sheet
RJ
Version
01
STANDARD MANUAL
Page
3
5.2 机械特性 Mechanical Performance
序号 No.
项目 Item
测试方法 Test method
特性 Performance
端子抗拉强度:
沿电容器端子引线方向施加拉力(如下表),10±1秒。
引线直径Φ
0.45
0.5
拉力N
0.6
5
0.8
10
1.0
端子抗弯强度:
在电容器引线施加固定重力(如下表),然后将电容体弯折90°后回到原
位,再向相反方向弯折90°后回到原位。
测量电容器应无接触不良、开
路或短路,无可见机械损伤。
When the capacitor is
measured, there shall be no
intermittent contacts, or open
or short-circuiting.
There shall be no visible
mechanical damage.
上述过程在5秒内完成。
5.2.1
端子强度
Terminal
strength
引线直径Φ
拉力N
0.45
0.5
0.6
2.5
0.8
5
1.0
10
Tensile strength of terminal:
A static load (stated in the table above) shall be applied to the terminal
in the axial direction and acting in a direction away from the body for
10±1 sec..
Bending strength of terminal:
Hang the specified dead weight (stated in the table above), then bend
the body through 90°, return to the original position.
Next bend it in opposite direction through 90° with the same speed,
again return to the original position.
Complete this operation in about 5 sec..
5.2.2
5.2.3
在3个互相垂直的方向分别施加2小时振动,共6小时。
测量电容器应无接触不良开路
频率:10-55Hz
或短路,无可见机械损伤。
振幅峰-峰值:1.5mm.
振速:1分钟内振速10~55~10Hz
measured there shall be no
Direction and duration of vibration: intermittent contacts, or open
振动试验
3 orthogonal directions mutually each for 2h , Total 6h. or short circuiting。There
Resistance
Vibration frequency range :10-55Hz. shall be no visible mechanical
to vibration
Peak to peak amplitude: 1.5mm damage.
Sweep rate :10 to 55 to 10Hz in about 1 min.
浸入焊锡的引线表面积约90%
焊锡温度:235±5℃
以上应附着新锡。
浸入时间:2±0.5秒
At least 90% of
Temperature of solder: 235±5℃
circumferential surface of the
Dipping time: 2±0.5sec.
可焊性
dipping portion of terminal
Solderability This specification shall be met after the capacitors are stored under
shall be covered with new
standard atmospheric conditions for 6 months.
solder.
File Description
Component P/N
Approval Sheet
RJ
Version
01
STANDARD MANUAL
Page
4
5.3 耐久性测试 Endurance Performance
序号 No.
5.3.1
项目 Item
测试方法 Test method
特性 Performance
焊槽法:
容量变化:在初始值±10%范围内。
焊锡温度:260±5℃
损失角正切值:不大于表1规定值。
浸入时间:10±1秒
漏电流:满足5.1.4要求。
电 路 板 :1.6mm
外观:无异状。
Solder bath method
Variation of capacitance:
Solder bath temperature : 260±5℃
Within ±10% of the initial value.
Immersion time : 10±1sec.
耐焊接热
Dissipation factor:
Resistance to soldering Printed wiring board: 1.6mm
Not more than the specified value in TABLE-1.
heat
Leakage current:
Appearance:
No remarkable abnormality.
试验温度:40±2℃
试验时间:240±8h
相对湿度:90~95%
试验后,电容器在标准大气条件下1~2
小时,然后测试参数。
5.3.2
5.3.3
容量变化:在初始值±10%范围内。
损失角正切值:不大于表1规定值。
漏电流:满足5.1.4要求。
外观:无异状。
Dissipation factor:
稳态湿热
Resistance to damp Test temperature : 40±2℃
Leakage current:
Test time : 240±8h To satisfy No. 5.1.4 .
heat (steady state)
Relative humidity: 90~95%
Appearance:
After completion of test, the capacitor No remarkable abnormality.
shall be subjected to standard
atmospheric conditions for 1 to 2
hours, after which measurements shall
be made.
高温负荷试验
Load life test
1. 试验温度:105±2℃,施加额定电压和 容量变化:在初始值±25%范围内。(10V:≤±30%)
额定纹波电流。 损耗角正切值:不大于表1规定值的200%。
Application of the rated voltage and the 漏电流:满足5.1.4要求。
rated ripple current, Test
外观:无异状。
temperature:105±2℃. Variation of capacitance:
Within ±25% of the initial value. (10V:≤±30%)
2. 试验时间:参照TABLE-1寿命要求。 Dissipation factor:
Testing time: refer to TABLE-1 life
Not more than 200% of the specified value in TABLErequirements.
1.
Leakage current:
Appearance:
File Description
Component P/N
Approval Sheet
RJ
Version
01
STANDARD MANUAL
Page
5
容量变化:初始值±25%范围内。
+48
在105±2℃环境下无负荷贮存1000 -0 h,至少恢复16小时后。 (10V:≤±30%)
The capacitors are stored without voltage load at 105±2℃
+48
for 1000 h and then resumed 16 hours.
-0
高温贮存试验
Shelf life test
5.3.4
漏电流:满足5.1.4规定值的200%。
外观:无异状。
Within ±25% of the value before test.
(10V:≤±30%)
Dissipation factor: Not more than 200% of the
Leakage current:
Not more than 200% of the specified value in No.
5.1.4 .
Appearance:
以下试验只适用于铝壳直径≥Φ8产品。 上述过程中应无引线、铝箔等散射,无火花产生。
The safety vent is actuated under the test
The following tests only apply to those products with vent
conditions, thereby preventing terminals, metal
products at diameter≥Φ8 with vent.
pieces, etc, of the capacitor from scattering due
在电容器两极施加反向直流电压,其中通过的电流为1A,在测 to burst, the case from separating from the seal
防爆试验 试时防爆装置应能在30分钟内动作。 packing, or the capacitor from producing flame.
Safety vent DC Application test:
The capacitor shall be subjected to a reverse DC voltage.
The current flowing through the capacitor shall be 1A. If the
vent does work with the voltage applied for 30 minutes, the test
is considered to be passed.
5.3.5
※ TABLE-2:阻抗比 Max. Impedance Ratio
额定电压
Rated
voltage
(Vdc)
10
16
25
35
|z|-25℃
/|z|20℃
|z|-40℃
/|z|20℃
50
63
80
100
120
2
4
3
3
6
※ TABLE-3:纹波电流频率因子 RIPPLE CURRENT FREQUENCY COEFFICIENT
Freq.(Hz)
Cap(μF)
120
1k
10k
100k
Cap.
很抱歉,暂时无法提供与“ERJ1HM100D11OT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.09620
- 200+0.08970
- 600+0.08320
- 3000+0.07670
