| 11'1 II~ Ir!'t .'I~):I'':].川UM ELECTROLYTIC CAPACITORS
RRseri
AiSH~
E111
• High frequency,low impedance,high reliability
• Endurance: +1 05.C 2 , 000 hours
• Suitable for switching power, UPS , power sources , etc.
• RoHS Compliant
SPECIFICATIONS
lωm.
Charactørlatlca
ca脑gory Temperature
Ra nge
-40同时 05.C
RatedVol恒ge Range
6.3-50 Vdc
CapacilanωToleranω
士 20%(M)
lea阳ge Current
1.:50.01 CVor 3μA , whiche内,er is greater.
Whe障, 1:Max.leakage current (IIA), C:Nominal capacitance
(at20'C ,120Hz)
RatadVollaga(Vdc)
Dissipation Factor (恼nð)
回 nð (max.)
6.3
10
16
25
35
(~F),V:
Raled voltage (V)
(at 20.C afler2 minules)
50
: 0.22 : 0.18 : 0.14 : 0.12 : 0.10 : 0.08 :
When nomlnal capacltance e明eeds 1,OOO Il F, add 0.02 tolhevalue aÞoveforeach 1 ,000 1l F Increase.
low Tømperatura
Rated Vollage(Vdc)
6.3
10
16
25
35
(at20'C , 120Hz)
50
Characteri6回c6
(Max.lmp创ence
Ratio)
Z(-25'C)/Z( +20'C)
2
(al120Hz)
Tha spaclflcallons IIsled Þelow sha 11 Þa mat whan Ihe capaclt口rs ara raslorad to 20'C after DC voltaga plus ralad rl pple
currant is appl ied for 2 ,000 hours at 105 'C.
Enduranω
Capacllance Change
量土 20%
D.F. (tanð)
s200% ofthe inilialspeci而edvalue
ofthe Inlllal value (6.3 , 10V: 孟士 30%)
Leakage Currenl
量The initielspecifiad
value
The following specificøtion8 8høll be 8ali8fied when the capacitors are re8t口呻 d 1020.C a'匍.er leaving them under no load øt
105.C for 1,000 h口urs.
ShelfLife
量土20%
:S: 200% ofthe Inlllal spaclfled value
Leakage Cu rrenl
:S:200% 口fthe
initial 8pecified value
DIMENSIONS[mm]
@ak
←A
-g可
-帽但
of thø initial value (6.3 ,1OV: 企30%)
Capacitance Changø
D.F. (Ianð)
4min.
(ØS唱 18)
PART NUMBERING SYSTEM
E
RR 1H
o
D11 吃
Tt
Sleeve Code: 'c" for PVC, 'r for PET
Tønmlnal code
Sizeoc回e
capeci恒n田∞de
capaci回nce tolaranceα>de
vo阳唱e ∞de
Sertes ∞de
caωgory ∞de
RATED RIPPLE CURRENT MULTIP Ll ERS
Frequency correction factor for ri pple current
cap.(\
MF}恼
\.飞{H\
Z1
120
1k
10k
100k
Cap.
很抱歉,暂时无法提供与“ERR1CM222W20OT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.07774
- 50+0.86714
- 150+0.77696
- 国内价格
- 5+0.84149
- 20+0.76725
- 100+0.69300
- 500+0.61875
- 1000+0.58410
- 2000+0.55935
