JIANGSU CHANGJIANG ELECTRONICS TECHNOLOGY CO., LTD
SOT-363 Plastic-Encapsulate Diodes
BAV99S
HIGH-SPEED SWITCHING DIODE
SOT-363
FEATURES
Small Plastic Package
High Switching Speed
Low Capacitance
Two Electrically Isolated Series Configuration Arrays
MARKING: K1
K1
Solid dot = Pin1 indicate.
MAXIMUM RATINGS @( Ta=25℃ unless otherwise noted )
Symbol
Limits
Unit
Repetitive Peak Reverse Voltage
85
V
VR
Reverse Voltage
75
V
IF
VRRM
Parameter
Forward Current
150
IFRM
Repetitive Peak Forward Current
450
IFSM
Non-Repetitive Peak Forward Surge Current @ t = 8.3ms
2.5
A
PD
Power Dissipation
200
mW
Thermal Resistance from Junction to Ambient
625
℃/W
RΘJA
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
mA
ELECTRICAL CHARACTERISTICS(Ta=25℃ unless otherwise specified)
Parameter
Symbol
Reverse voltage
V(BR)
Reverse current
IR
Forward voltage
Total capacitance
Reverse recovery time
www.cj-elec.com
VF
Ctot
trr
Test conditions
Max
Unit
VR=75V
1
μA
IF=1mA
0.715
IF=10mA
0.855
IF=50mA
1
IF=150mA
1.25
VR=0,f=1MHz
1.5
pF
6
ns
IR=100μA
Min
Typ
75
IF= IR=10mA, Irr=0.1×IR, RL=100Ω
1
V
V
C,Mar,2016
Typical Characteristics
Forward Characteristics
Reverse Characteristics
10000
(nA)
100
REVERSE CURRENT IR
T=
a 2
5℃
T=
a 1
00
FORWARD CURRENT
IF
(mA)
300
10
1
0.0
Ta=100℃
1000
100
Ta=25℃
10
1
0.2
0.4
0.6
0.8
1.0
FORWARD VOLTAGE
1.2
1.4
1.6
VF (V)
40
60
REVERSE VOLTAGE
80
VR
100
(V)
Power Derating Curve
Capacitance Characteristics
1.1
250
f=1MHz
200
PD
(mW)
1.0
0.9
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
Ta=25℃
0.8
0.7
150
100
50
0.6
8
12
REVERSE VOLTAGE
www.cj-elec.com
16
VR
(V)
25
50
75
AMBIENT TEMPERATURE
2
100
125
150
Ta (℃)
C,Mar,2016
SOT-363 Package Outline Dimensions
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
Dimensions In Millimeters
Min
Max
0.900
1.100
0.000
0.100
0.900
1.000
0.150
0.350
0.100
0.150
2.000
2.200
1.150
1.350
2.150
2.400
0.650 TYP
1.200
1.400
0.525 REF
0.260
0.460
0°
8°
Dimensions In Inches
Min
Max
0.035
0.043
0.000
0.004
0.035
0.039
0.006
0.014
0.004
0.006
0.079
0.087
0.045
0.053
0.085
0.094
0.026 TYP
0.047
0.055
0.021 REF
0.010
0.018
0°
8°
SOT-363 Suggested Pad Layout
www.cj-elec.com
3
C,Mar,2016
SOT-363 Tape and Reel
www.cj-elec.com
4
C,Mar,2016
很抱歉,暂时无法提供与“BAV99S”相匹配的价格&库存,您可以联系我们找货
