IX Series
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
IEC Standard Compliant
Next-Generation Ethernet Connector for Industrial Equipment
Product page
https://www.hirose.com/product/en/products/IX/
Special features page
https://www.hirose.com/product/en/pr/ix_industrial/
May 2021 ⑤
IX Series/IEC Standard Compliant Next-Generation Ethernet Connector for Industrial Equipment
Advance with ix Industrial
TM
Overview
・Multi- purpose, compact I/ O connector for industrial machinery.
・IEC Standard IEC 61076- 3- 124 complaint
・Compact, robust and supports high speeds
・High EMC resistance
Features
1. Contributes to Size Reduction
75%
The ix IndustrialTM offers a size reduction of 75%
compared to conventional RJ45 modular solutions.
The reduced mounting space enables a high
degree of board design freedom.
The ix IndustrialTM also supports 10mm pitch
parallel mounting.
Compact size
RJ45
reduced size
compared to
RJ45
ix Industrial TM
2. Single Action Lock Design
Click
Locking is completed simply by inserting the plug
into the receptacle. The audio click indicates
mating completion. The lock can be released
easily by pushing on the plug buttons while
pulling out.
Single Action Lock for Easy Operation
Clear Tactile Click Prevents Incomplete Mating
2
3. Robust design resistant to
prying
The PCB- mounted receptacle shell is designed to
minimize the influence of prying forces from the
plug side on the mated surface. Additionally, the
through- holes prevent peeling of the mounted
portion of the contact. Stainless steel is used to
enhance the mechanical strength of the metal
parts.
4. High EMC Resistance
The optimized shielding design guarantees high
EMC resistance for secure data transmission.
5. High Speed Transmission
Supports Cat. 5e ( 1Gbps) and Cat. 6A( 10Gbps)
high speed Ethernet performance
6. THR ( Through- Hole Mounting)
Compatible
The receptacle shell is mounted in the throughholes for enhanced PCB mounting strength. THR
mounting enables simultaneous reflow mounting
with the signal contact SMT, for reduced board
mounting time.
3
Product Specifications
Rated Current
Rated Voltage
All Pins
4 Pins : Pin No.1, 2, 6 and 7
Operating Temperature (Note 1)
-40 to +85℃
1.5A
3A
Storage Temperature Range
-30 to +60℃
50V AC / 60V DC
Item
Specification
Conditions
Contact Resistance
Signal : 30m Ω Max. (Note 2)
Shield : 100m Ω Max. (Note 2)
Measured at 100mA
Insulation Resistance
500M Ω Min.
Measured at 500V DC
Withstanding Voltage
No flashover or breakdown
Voltage of 500V DC applied for 1 min.
Mating Durability
Signal : 80m Ω Max. (Note 2)
5,000 insertion/extraction cycles
Vibration Resistance
No electrical discontinuity of 1μ s Min.
No damage, crack or loosened parts
10 to 500Hz, Half Amplitude 0.35mm,
Acceleration of 50m/s2.
Shock Resistance
300m/s2, 11ms Duration, 3 Axis in Both Directions,
3 Times Each
Fretting Corrosion Resistance
490m/s2, 30 times/min, 1000 times
Note 1 : Includes temperature rise due to current flow.
Note 2 : Conductor resistance of the cable is not included.
Materials / Finish
● Receptacle
Component
Materials
Color/Finish
Remarks
Insulator
Liquid Crystal Polymer
Gray
UL94V-0
Contact
Copper Alloy
Partially Gold Plated
Shielding Plate
Stainless Steel
Shell
Stainless Steel
Tin Plated
Polyamide Resin
Black
UL94V-0
Suction Cap
● Plug
Component
Material
Color/Finish
Remarks
Contact
Copper Alloy
Insulator
Polyamide Resin
Black, Dark Gray
UL94V-0
Shielding Plate
Stainless Steel
Insulator Case
Polyamide Resin
Black
UL94V-0
Polycarbonate Resin
Transparent, Transparent Yellow, Transparent Blue
UL94V-0
Shield Case
Stainless Steel
Nickel Plated
Shield Shell
Stainless Steel
Nickel Plated
Cover Case
Polycarbonate Resin
Dark Gray
UL94V-0
Guide
4
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
■ Receptacle
IX 61 G - A - 10 P (##)
❶
❷
❸
❹
❺
❻
❾
❶
Series Name
IX Series
❹
Mating Key
❷
Mounting/
Assembly Method
61 : Upright Right Angle SMT
60 : Right Angle SMT
80 : Vertical SMT
❺
Maximum Number 10 : 10pos.
of Usable
8 : 8pos.
Positions
❻
Contact Gender
P : Male Contact
S : Female Contact
❾
Plating
Specifications
Blank : Gold Plated
(01) : Palladium-Nickel Plated+Gold Plated
❸
Gigabit Ethernet
Support
G
A : Type A
B : Type B
■ Plug
IX 40 G - A - 10 S - CV (7.0) (##)
❶
❷
❸
❹
❺
❻
❼
❽
❾
❶
Series Name
IX Series
❺
of Usable
8 (Note) : 8pos.
Positions
❷
Mounting/
Assembly Method
40 : Hand Solder
30 : IDC (26 to 28 AWG, Insulator Outer
Diameter φ 0.95 to 1.05)
31 : IDC (24 to 25 AWG, Insulator Outer
Diameter φ 1.1 to 1.25)
32 : IDC (22 AWG, Insulator Outer Diameter
φ 1.4 to 1.6)
❻
Contact Gender
P : Male Contact
S : Female Contact
❼
Plug Cover
Cabling Direction
CV : Straight
CVL1 : Downward Cabling
CVL2 : Upward Cabling
❸
Gigabit Ethernet
Support
G
❽
Applicable Cable
Diameter
(7.0) : Sheath Outer Diameter φ 6.3 to 7.2
❹
Mating Key
A : Type A
B : Type B
❾
Plating
Specifications
Blank : Gold Plated
Note : Contacts No.3 and 8 do not have a hole to pass the wire through the IDC guide.
5
Connector Mating Combination Diagram
●Receptacle
●Plug
Upward Right Angle
Straight
IX30G-#-10S-CV(7.0)(##)
IX31G-#-10S-CV(7.0)(##)
IX32G-#-8S-CV(7.0)(##)
IX40G-#-10S-CV(7.0)(##)
IX61G-#-10P(##)
Right Angle
Right Angle, Downward Cabling
IX30G-#-10S-CVL1(7.0)(##)
IX31G-#-10S-CVL1(7.0)(##)
IX32G-#-8S-CVL1(7.0)(##)
IX40G-#-10S-CVL1(7.0)(##)
IX60G-#-10P(##)
Vertical
Right Angle, Upward Cabling
IX30G-#-10S-CVL2(7.0) (##)
IX31G-#-10S-CVL2(7.0) (##)
IX32G-#-8S-CVL2(7.0) (##)
IX40G-#-10S-CVL2(7.0) (##)
IX80G-#-10P(##)
Note : Please use the same mating key (Type A, B) for both the plug and receptacle.
6
Receptacle
Upward Right Angle
Contact
No.1
Contact
No.10
Mating Key Design
Type A
0.4
0.4
1.5
Contact No.10
HRS No.
0.4 1.0
1.5
2.75
5.75
1.9
9.75
3.05
10×0.25
3.75
4.75
5.75
6.75
Contact Area Plating
Purchase Unit
IX61G-A-10P
CL0251-0021-0-00
Gold Plated 0.2μ m
IX61G-A-10P(01)
CL0251-0021-0-01
Palladium-Nickel Plated 0.75μ m + Gold Plated 0.05μ m
IX61G-B-10P
CL0251-0026-0-00
Gold plated 0.2μ m
IX61G-B-10P(01)
CL0251-0026-0-01
Right Angle
400pcs
per reel
Mating Key Design
Type A
Type B
9.4
(10.0)
Contact
No.10
Contact Contact Contact Contact
No.5
No.10
No.6
No.1
6
Contact
No.1
0.4
0.4
2.75
Contact
No.5
9
10.4
1.5
11.65
1.5
3.15
4.15
5.15
6.15
7.15
10×0.25
8.0
8.9
2.4
1.5
0.9
5.7
Contact
No.6
4.05
4.2
2×φ1.2
0.4
3.5
5.8
(6.2)
8.4
(8.8)
1.5
Contact
No.1
Part No.
(10.0)
Contact
No.6
9.4
Contact
No.5
Type B
Part No.
HRS No.
IX60G-A-10P
CL0251-0016-0-00
Gold Plated 0.2μ m
IX60G-A-10P(01)
CL0251-0016-0-01
IX60G-B-10P
CL0251-0017-0-00
Gold Plated 0.2μ m
IX60G-B-10P(01)
CL0251-0017-0-01
7
Purchase
Unit
550pcs
per reel
Vertical
Mating Key Design
Type A
Type B
2×1.4
Contact No.6
(R0.2)
φ1.2
Contact No.6
3.075
Contact No.10
10×0.25(Lead Width)
0.25(Lead)
Assembled
Product Overview
(7.1)
(5.7)
Contact No.1
7.8(Lead)
Contact No.5
1.2
Contact No.10
0.25
2.0
0.25(Lead)
2.1
7.8
2×0.6
Contact No.5
3×R0.5
4.0(Lead)
2.0(Lead)
1.5
1.5
(C
0.
3)
0.25
Contact No.1
C1
9.0
3.5
0.4
1.75
6.6
5
(R0.2)
11
4.8
4.0
2.0
Suction Area
Suction Cap
2.0(Lead)
4.0(Lead)
4.0
5.5
10.0
0.4
9.0
Part No.
HRS No.
IX80G-A-10P
CL0251-0018-0-00
Gold Plated 0.2μ m
IX80G-A-10P(01)
CL0251-0018-0-01
IX80G-B-10P
CL0251-0019-0-00
Gold Plated 0.2μ m
IX80G-B-10P(01)
CL0251-0019-0-01
Note : This product is delivered with a cap for Pick & Place mounting.
Please remove the cap before use.
8
Purchase
Unit
450pcs
per reel
Plug
Contact No.10
Contact No.6
9.2
(φ
7.
2)
Straight
Contact No.1
Contact No.5
17.5
Mating Key Design
Type A
Type B
22.9
5.7
16.3
16.3
Part No.
HRS No.
IX40G-A-10S-CV(7.0)
CL0251-0022-0-00
Gold Plated 0.2μ m
IX40G-A-10S-CV(7.0)(01)
CL0251-0022-0-01
IX40G-B-10S-CV(7.0)
CL0251-0032-0-00
Gold Plated 0.2μ m
IX40G-B-10S-CV(7.0)(01)
CL0251-0032-0-01
IX30G-A-10S-CV(7.0)
CL0251-0020-0-00
Gold Plated 0.2μ m
IX30G-A-10S-CV(7.0)(01)
CL0251-0020-0-01
IX30G-B-10S-CV(7.0)
CL0251-0025-0-00
Gold Plated 0.2μ m
IX30G-B-10S-CV(7.0)(01)
CL0251-0025-0-01
IX31G-A-10S-CV(7.0)
CL0251-0023-0-00
Gold Plated 0.2μ m
IX31G-A-10S-CV(7.0)(01)
CL0251-0023-0-01
IX31G-B-10S-CV(7.0)
CL0251-0024-0-00
Gold Plated 0.2μ m
IX31G-B-10S-CV(7.0)(01)
CL0251-0024-0-01
IX32G-A-8S-CV(7.0) (Note)
CL0251-0042-0-00
Gold Plated 0.2μ m
IX32G-A-8S-CV(7.0)(01) (Note)
CL0251-0042-0-01
IX32G-B-8S-CV(7.0) (Note)
CL0251-0043-0-00
Gold Plated 0.2μ m
IX32G-B-8S-CV(7.0)(01) (Note)
CL0251-0043-0-01
Note : Cable assembly for IX32G is possible up to 8 positions.
Contacts No. 3 and 8 do not have a hole to pass the wire though the IDC guide.
9
Purchase
Unit
100pcs
per tray
Contact
No.6
9.2
(φ
7.
2)
Contact
No.10
Contact
No.1
5.7
16.3
14.4
8.75
24.0
13.5
Contact
No.5
Mating Key Design
Type A
Part No.
HRS No.
Type B
IX30G-A-10S-CVL1(7.0)
CL0251-0063-0-00
Gold Plated 0.2μ m
IX30G-A-10S-CVL1(7.0)(01)
CL0251-0063-0-01
Palladium-Nickel Plated 0.75μ m+ Gold Plated 0.05μ m
IX30G-B-10S-CVL1(7.0)
CL0251-0064-0-00
Gold Plated 0.2μ m
IX30G-B-10S-CVL1(7.0)(01)
CL0251-0064-0-01
IX31G-A-10S-CVL1(7.0)
CL0251-0067-0-00
Gold Plated 0.2μ m
IX31G-A-10S-CVL1(7.0)(01)
CL0251-0067-0-01
IX31G-B-10S-CVL1(7.0)
CL0251-0068-0-00
Gold Plated 0.2μ m
IX31G-B-10S-CVL1(7.0)(01)
CL0251-0068-0-01
IX32G-A-8S-CVL1(7.0)
CL0251-0071-0-00
Gold Plated 0.2μ m
IX32G-A-8S-CVL1(7.0)(01)
CL0251-0071-0-01
IX32G-B-8S-CVL1(7.0)
CL0251-0072-0-00
Gold Plated 0.2μ m
IX32G-B-8S-CVL1(7.0)(01)
CL0251-0072-0-01
IX40G-A-10S-CVL1(7.0)
CL0251-0075-0-00
Gold Plated 0.2μ m
IX40G-A-10S-CVL1(7.0)(01)
CL0251-0075-0-01
IX40G-B-10S-CVL1(7.0)
CL0251-0076-0-00
Gold Plated 0.2μ m
IX40G-B-10S-CVL1(7.0)(01)
CL0251-0076-0-01
10
Purchase
Unit
100pcs
per tray
Contact
No.6
Contact
No.1
Contact
No.5
9.2
2)
7.
(φ
Contact
No.10
16.3
13.5
5.7
14.4
24
8.75
Mating Key Design
Type A
Part No.
HRS No.
Type B
IX30G-A-10S-CVL2(7.0)
CL0251-0065-0-00
Gold Plated 0.2μ m
IX30G-A-10S-CVL2(7.0)(01)
CL0251-0065-0-01
IX30G-B-10S-CVL2(7.0)
CL0251-0066-0-00
Gold Plated 0.2μ m
IX30G-B-10S-CVL2(7.0)(01)
CL0251-0066-0-01
IX31G-A-10S-CVL2(7.0)
CL0251-0069-0-00
Gold Plated 0.2μ m
IX31G-A-10S-CVL2(7.0)(01)
CL0251-0069-0-01
IX31G-B-10S-CVL2(7.0)
CL0251-0070-0-00
Gold Plated 0.2μ m
IX31G-B-10S-CVL2(7.0)(01)
CL0251-0070-0-01
IX32G-A-8S-CVL2(7.0)
CL0251-0073-0-00
Gold Plated 0.2μ m
IX32G-A-8S-CVL2(7.0)(01)
CL0251-0073-0-01
IX32G-B-8S-CVL2(7.0)
CL0251-0074-0-00
Gold Plated 0.2μ m
IX32G-B-8S-CVL2(7.0)(01)
CL0251-0074-0-01
IX40G-A-10S-CVL2(7.0)
CL0251-0077-0-00
Gold Plated 0.2μ m
IX40G-A-10S-CVL2(7.0)(01)
CL0251-0077-0-01
IX40G-B-10S-CVL2(7.0)
CL0251-0078-0-00
Gold Plated 0.2μ m
IX40G-B-10S-CVL2(7.0)(01)
CL0251-0078-0-01
11
Purchase
Unit
100pcs
per tray
Recommended Land Pattern Dimensions
● IX61G-#-10P
Recommended Metal Mask Pattern
(t=0.15)
Reference Board Mounting Dimensions
(From Mounting Side) (t=1.6)
6.0
5.8
7.2
8.4
9.8
5.75
7.5
4×1.4
(LAND)
Pattern Prohibited Area
Note : Dimension tolerances not listed are ±0.02.
● IX60G-#-10P
(t=0.15)
7.15
7.15
6.15
6.15
5.15
3.15
Contact No.5
5.15
10×0.19
3.15
Contact No.6
Contact No.10
10.4
10.6
12.0
Edge of
PCB
8.0
9.4
15.0
16.4
Pattern Prohibited
Area
Note : Dimension tolerances not listed are ±0.05.
12
3.4
6.8
2.0
2.5
4×3.05 (LAND)
9.0
(TH)
4×1.6 (LAND)
+0.1
+0.1
4×2.45
4×1.0
(TH)
1.2
4.05
16×R0.3
4.45
2.4
16×R0.6
6.4
2×φ1.45 (HOLE)
3.8
2.5
2.4
4.15
10×0.3 (LAND)
0.4
4.15
Mating Position
3.35
4.0
4.5
5.0
2.5
4.4
7.0
11.4
14.0
4×0.8±0.1
0(TH)
Edge of PCB
1.0
5.75
7.5
Edge of
PCB
1.2±0.1
0(HOLE)
Contact No.1
1.95
4×2.7
(LAND)
1.9
2.5
2.95
16×R0.3
4×R0.5
Mating Position
10×0.19
16×R0.6
7.05±0.1
4×2.1±0.10 (TH)
10×0.3
(LAND)
Contact No.10
3.35
1.95
4×R0.3
5.75
4.75
3.75
2.75
1.6
Edge of
PCB
(8.9)
6.75
0.8±0.1
0(TH)
0.6±0.10(TH)
2.0(LAND)
1.4 +0.1
0(TH)
4×R0.6
Contact
No.1
6.75
5.75
4.75
3.75
2.75
2.0(LAND)
● IX80G-#-10P
(t=0.15)
9.0
11.0
4.0
4.0
2.0
4.0
0.25
2.0
10×0.6(LAND)
Contact No.1
0.25
Contact No.5
10×0.5
2×1.4(LAND)
2×0.8(TH)
4.37
2.1±0.05
2×1.9(TH)
4.37
Contact No.6
2×2.5(LAND)
φ1.35(HOLE)
Mounting Area
Contact No.10
2.69
2.5
2.69
4.8
2.45
8×R0.3(TH)
2.45
4.4
4.4
7.8
8×R0.6(LAND)
0.25
2.0
3.075±0.05
4.0
0.25
2.0
4.0
7.5
11.0
13
Panel Mounting Dimensions Diagram
IX61G-#-10P
Mated Condition
Reference Panel Cut-out Dimensions
Note : Dimensions are for reference.
Housing Panel
IX##G-#-#S-CV(7.0)
7.0
10.2
4×R1
IX61G-#-10P
PCB
Mounting Side
(2.0)
(0.55)
(9.75)
IX60G-#-10P
Mated Condition
Housing Panel
IX#G-#-#S-CV(7.0)
IX60G-#-10P
11.0
4xR1
PCB
Mounting Side
1.3
PCB
6.1
(2.0)
(0.55)
(8.9)
IX80G-#-10P
Mated Condition
IX##G-#-#S-CV(7.0)
PCB
(2.0)
Housing Panel
IX80G-#-10P
8×R0.3
4×R1
6.2
(0.55)
6.0
14
7.8
11.0
(9.0)
0.8
PCB
Cable Assembly Tools
Part No.
HRS No.
Applicable Connector
HT803/IXG-8/10S-63-72
CL0902-2218-0-00
IX##G-#-##S-CV(7.0)
HT803/IXG-10S-CVL-70
CL0902-2223-0-00
IX##G-#-##S-CVL1(7.0)
IX##G-#-##S-CVL2(7.0)
Adapter for Cabling Certification Testing
This adapter requires the DSX CableAnalyzerTM from Fluke Networks for use.
Part No.
HRS No.
DSX-CHA-5-IX-S
CL0251-1001-0-00
(Note) DSX CableAnalyzerTM is a registered trademark of Fluke Networks.
Applicable Cables List
A list of applicable cables is available on the Hirose website.
( https: / / www. hirose. com/ product/ en/ pr/ ix_ industrial/ applicable_ cable_ list/ )
While Taking into Consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the Drawing and Product Specifications sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non- specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given.
If considering usage for below mentioned applications, please contact your sales representative.
In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public
infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
※ The contents of this catalog are current as of date of 5/ 2021. Contents are subject to change without notice for the purpose of improvements.
15
