EM7028
EM7028
    EPTICORE(艾普柯)
    SEN_4X2.4MM_SM
    艾普柯微心率血氧传感器EM7028
EM7028 数据手册
I2C interface Heart Rate Sensors©2016 EM7028 Datasheet Heart Rate Sensor with I2C Interface Revision V 1.0 2016-05-03 Updated EM7028 Datasheet Page 1 I2C interface Heart Rate Sensors©2016 CONTENTS 1. Description .............................................................................................................................6 2. Features .................................................................................................................................6 3. Functional Block Diagram ....................................................................................................... 7 4. PIN Configuration ...................................................................................................................8 5. Functional Description ............................................................................................................8 5.1 HRS in continuous mode .......................................................................................................................... 8 5.2 HRS in pulse mode .................................................................................................................................... 9 5.3 Typical performance chart ........................................................................................................................ 9 6. Parameters ........................................................................................................................... 10 7. Spectral Response Range .................................................................................................... 12 8. Absolute Maximum Ratings .................................................................................................. 12 9. I2C State Machine ................................................................................................................. 13 10. Timing ............................................................................................................................. 13 11. Registers Operation......................................................................................................... 14 12. Registers Definition ......................................................................................................... 14 13. Sample Application .......................................................................................................... 20 14. PCB Design ..................................................................................................................... 21 15. Package Outline Dimensions ........................................................................................... 22 EM7028 Datasheet Page 2 I2C interface Heart Rate Sensors©2016 16. Packing ........................................................................................................................... 24 17. Recommended Reflow Profile ......................................................................................... 25 EM7028 Datasheet Page 3 I2C interface Heart Rate Sensors©2016 FIGURE LIST Fig. 1 EM7028 Functional Block Diagram .................................................................................................7 Fig. 2 EM7028 HRS value vs. receiving light lux ....................................................................................9 Fig. 3 EM7028 HRS wave............................................................................................................................9 Fig. 4 Operation current vs. supply voltage in continuous mode w/o current-limiting resistor, and the current is controlled by VDD_LED and current-limiting resistor. Typical operation current for heart rate detection is around 1mA. ...........................................................................................10 Fig. 5 Operation current vs. supply voltage in pulse mode w/i current controlled by resisters. .....10 Fig. 6 LED1/LED2 Spectral Response Range (The peak wavelength may change without notification) ...........................................................................................................................................12 Fig. 7 Slave State Machine ........................................................................................................................13 Fig. 8 Data Structure...................................................................................................................................13 Fig. 9 Write waveform.................................................................................................................................13 Fig. 10 Read waveform ..............................................................................................................................14 Fig. 11 Register random write operation .................................................................................................14 Fig. 12 Register page write operation ......................................................................................................14 Fig. 13 Register random read operation ..................................................................................................14 Fig. 14 Typical Application Circuit in pulse mode of HRS2 ((VDD 2.6~3.6V, VDD_I2C 1.6~3.6V, VDD_LED 2.6~4.5V) ...........................................................................................................................20 Fig. 15 Typical Application Circuit in continuous mode of HRS1 .........................................................21 Fig. 16 PCB layout design guide (all linear dimensions are in mm) ....................................................22 Fig. 17 Side view of package ...................................................................................................................22 Fig. 18 Package Outline Dimensions .......................................................................................................23 Fig. 19 Tape & Reel Information ..............................................................................................................24 Fig. 20 Recommended Reflow Profile for SMT .....................................................................................25 EM7028 Datasheet Page 4 I2C interface Heart Rate Sensors©2016 TABLE LIST Table. 1 Pin Configuration ...........................................................................................................................8 Table. 2 I2C bus timing characteristics ..................................................................................................10 Table. 3 Electrical Characteristics ............................................................................................................ 11 Table. 4 Optical Characteristics ................................................................................................................ 11 Table. 5 Absolute Maximum Ratings .......................................................................................................12 Table. 6 REGISTER DESCRIPTION .......................................................................................................15 Table. 7 REGISTER 0x00 (RESERVED) ................................................................................................15 Table. 8 REGISTER 0x01 (CONFIGURE) - PROX/HRS CONFIGURATION ..................................15 Table. 9 REGISTER 0x02 (INTERRUPT) - PROX/GES/HRS INTERRUPT CONTROL .................16 Table. 10 REGISTER 0x03 (HRS_LT) - INTERRUPT LOW THRESHOLD FOR HRS2/HRS1.....16 Table. 11 REGISTER 0x04 (HRS _LT) - INTERRUPT LOW THRESHOLD FOR HRS2/HRS1 ...16 Table. 12 REGISTER 0x05 (HRS _HT) - INTERRUPT LOW THRESHOLD FOR HRS2/HRS1 ...17 Table. 13 REGISTER 0x06 (HRS _HT) - INTERRUPT LOW THRESHOLD FOR HRS2/HRS1 ...17 Table. 14 REGISTER 0x07 (LED_CURRENT) – HRS2 LED CURRENT FOR HRS2 ....................17 Table. 15 REGISTER 0x08 (HRS2_DATA_OFFSET) – HRS2 DATA OFFSET ..............................17 Table. 16 REGISTER 0x09 (HRS2_CTRL) - HRS2 CONTROL ..........................................................17 Table. 17 REGISTER 0x0A (HRS2_GAIN_CTRL) - PROXIMITY SENSOR GAIN CONTROL ......18 Table. 18 REGISTER 0x0B (Reserved) ..................................................................................................18 Table. 19 REGISTER 0x0C (Reserved) ..................................................................................................18 Table. 20 REGISTER 0x0D (HRS1_CTRL) – HRS1 CONTROL .........................................................18 Table. 21 REGISTER 0x0E (INT_CTRL) –INTERRUPT CONTROL ..................................................19 EM7028 Datasheet Page 5 I2C interface Heart Rate Sensors©2016 1. Description EM7028 is a low-power I2C interface module includes Heart Rate Sensor(HRS) and internal LED Current Drivers with 2 Green LED. It can work in both continuous mode and pulse mode. It is designed for applications of Heart Beat Rate detection esp. such as smart watch etc. Heart Rate Sensor in continuous mode is designed to monitor heart rate by optical detection. A 16-bit ADC detects the result constantly with adjustable gain and resolution. Heart Rate Sensor in pulse mode is designed to monitor heart rate by optical detection in low-power. It also acts as a proximity sensor with rejection of ambient light noise. In order to removing component variations and eliminate offset caused by IR reflection, 2 registers were specially defined for compensation and high dynamic range of detection. HRS in continuous mode stores ADC output result into HRS1 registers, while HRS in pulse mode stores ADC output result into HRS2 registers. All pixels are controlled by analog-MUX in different modes. 2. Features  Heart-Rate Sensors(HRS) with built-in 2 LED of 525nm wavelength integrated in a single Optical Module  50Hz/60Hz Flicker Noise Rejection  Temperature Compensation  Higher Sensitivity of Proximity Sensing  HRS in continuous mode with higher detection rate  HRS in pulse mode with Ambient Light Rejection  HRS detect rates is up to 1000/s  2048 Steps Programmable LED current driver for flexibility and part-to-part calibration  16bits ADC of Heart Rate Sensor  Offset register adjustment for compensation of DC noise  Programmable Interrupt modes  Low Average Operation Power consumption  Output Type: I2C Bus (HRS2) up to 400K Hz  Operation Voltage 2.5V ~ 3.6V  Logic Interface Voltage VBUS=1.8V or VBUS=VDD  Minimum External Components  Package: (4.0mmX2.4mmX1.35mm)  RoHS package EM7028 Datasheet Page 6 I2C interface Heart Rate Sensors©2016 3. Functional Block Diagram VDD_LED LEDA VDD VDD Reference Current/Voltage Source Oscillator Temperature Compensation SCL Registers & I2C Read/Write Power-On-Reset SDA Clock HRS2 offset calibration HRS2 Gain Ctrl HRS2 timing Ctrl LED2 LED 525nm LED 525nm HRS2 Counter PS Data Threshold Compare & Interrupt Ctrl INT HRS 2 Noise Cancellation HRS1 timing ctrl LED1 LED Array Programmable Constant Current Driver HRS1 Programmable ADC Data PD Array GND RED/IR Light Object Fig. 1 EM7028 Functional Block Diagram EM7028 Datasheet Page 7 I2C interface Heart Rate Sensors©2016 4. PIN Configuration VDD 8 1 SDA SDA 1 8 VDD SCL 7 2 INT INT 2 7 SCL 6 3 LED1 LED1 3 6 GND LEDA 5 4 LED2 LED2 4 5 LEDA GND Top View Bottom View Table. 1 Pin Configuration Pin No. Pin Name Type Description 1 SDA I/O(Open Drain) I2C Serial data I/O terminal -serial data I/O for I2C 2 INT O(Open Drain) Interrupt. 3 LED1 O(Open Drain) LED Current Driver for LED1 - up to 200mA 4 LED2 O(Open Drain) LED Current Driver for LED2 - up to 12mA 5 LEDA I LED Anode, connect to VDD_LED on PCB 6 7 8 Power supply ground. All voltages are referenced to GND SCL GND I(Open Drain) VDD I2C serial clock input terminal — clock signal for I2C serial data. Power Supply voltage 5. Functional Description 5.1 HRS in continuous mode In Normal HRS mode, one of the LED turns on, and HRS Sensor detects both ambient light and light from green LED. The sensitivity of light is 1 lux/count, and totally 65536lux in full range; The typical resolution of ADC is 16bits and 25ms conversion time. In low-lux mode, 8 times of ADC gain is chosen for receiving light. The detect range is 0.125lux to 8192lux. EM7028 Datasheet Page 8 I2C interface Heart Rate Sensors©2016 200 EM7028 180 160 140 120 LUX 100 80 60 40 20 0 0 500 1000 1500 2000 2500 3000 3500 4000 4500 HRS1 ADC DATA Fig. 2 EM7028 HRS value vs. receiving light lux 5.2 HRS in pulse mode The Heart Rate Sensor in pulse mode detects reflected light with LED turned on in pulse. 5.3 Typical performance chart HRS value typically reflect heart beat status as illustrated in Fig.3 Fig. 3 EM7028 HRS wave EM7028 Datasheet Page 9 I2C interface Heart Rate Sensors©2016 operation current vs supply voltage 4 3.5 VDD (V) 3 2.5 2 1.5 1 0.5 0 0 2 4 6 8 10 12 14 current (mA) Fig. 4 Operation current vs. supply voltage in continuous mode w/o current-limiting resistor, and the current is controlled by VDD_LED and current-limiting resistor. Typical operation current for heart rate detection is around 1mA. TBD Fig. 5 Operation current vs. supply voltage in pulse mode w/i current controlled by resisters. 6. Parameters Table. 2 I2C bus timing characteristics Symbol Parameters fclk SCL clock frequency tSUDAT data set up time tHDDAT trise tfall tLOW tHIGH tBUF tHDSTA Minimum Maximum Units Condition 10k 100k Hz Normal Mode 10k 400k Hz Fast Mode 250 ns Normal Mode 100 ns Fast Mode 300 ns Normal Mode 90 ns Fast Mode 1000 ns Normal Mode 300 ns Fast Mode 300 ns Normal Mode 300 ns Fast Mode 4.7 μs Normal Mode 1.3 μs Fast Mode 4.0 μs Normal Mode 0.6 μs Fast Mode Bus free time between the start 4.7 μs Normal Mode and stop state 1.3 μs Fast Mode (repeat) started state holding time 4.0 μs Normal Mode data hold time clock/data rise time clock/data fall time I2C clock (SCL) low cycle I2C clock (SCL) high cycle EM7028 Datasheet Typical Page 10 I2C interface Heart Rate Sensors©2016 after this period produce the first 0.6 μs Fast Mode 4.7 μs Normal Mode 0.6 μs Fast Mode 4.0 μs Normal Mode 0.6 μs Fast Mode ms Normal Mode ms Fast Mode clock tSUSTA tSUSTO tTIMEOUT Repeat the start state set up time Stop state set up time Low detection clock/data timeout 25 35 time Cload The capacitive load for each bus 400 pF - KΩ line RBUS Pull up resistors SDA and SCL 1 system bus tVD Data valid time 0.9 μs tVDACK Data valid acknowledge time 0.9 μs Table. 3 Electrical Characteristics Symbol Min Typ VDD 2.6 Max 3.6 IDD Unit s V Introductions Supply voltage μA DC power supply current (with LED turned off) VDD_I2C 1.6 3.6 V I2C power supply voltage VDD_LED 2.6 4.5 V LED power supply voltage nA Shut Down Current 85 °C Recommended operating temperature 0.54 V SCL/SDA Input low voltage V SCL/SDA Input high voltage IDD_SD TA -40 VIL VIH 1.25 Table. 4 Optical Characteristics Parameters Full scale HRS1 ADC count value HRS detect range Full scale HRS2 ADC count value EM7028 Datasheet Min Typ Max Units 65536 counts 65536 lux 65536 counts Descriptions (Ta = +25 ℃) HRS register maximum count in continuous mode HRS detection range HRS ADC maximum count in pulse mode Page 11 I2C interface Heart Rate Sensors©2016 HRS2 LED drive 2.5 200 HRS2 LED duty cycle mA LED duty cycle, cycle of HRS2 at 100 1/500 ms VF TBD V LED Forward Voltage, IF =20 mA V LED Reverse Voltage, IR =1 μA mW LED Radiant Power, IF =20 mA LED Peak Wavelength, IF =100 mA VR Po HRS2 LED drive current 0.8 λp 525 nm Δλ 30 nm Spectrum Width of Half Value, IF =20 mA TR ns LED Optical Rise Time, IF =20 mA TF ns LED Optical Fall Time, IF =20 mA 7. Spectral Response Range 1 0.9 Normalize Response 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 400 450 500 550 wavelength (nm) 600 650 700 Fig. 6 LED1/LED2 Spectral Response Range (The peak wavelength may change without notification) LED2 has the same spectral response as LED1 8. Absolute Maximum Ratings Table. 5 Absolute Maximum Ratings Parameters Symbol Min. Max. Units Storage Temperature TS -40 85 °C Operation Temperature TA -40 85 °C Supply Voltage VDD 2.25 3.6 V EM7028 Datasheet Condition Page 12 I2C interface Heart Rate Sensors©2016 ESD VESD 2K V HBM ESD VESD 200 V MM 9. I2C State Machine IDLE Address Dec ACK TRANS REV Fig. 7 Slave State Machine 10.Timing MSB 6 5 4 3 W A 2 1 LSB Fig. 8 Data Structure SCL SDA DATA S Slave Address W A DATA DATA A/!A P A/!A P Fig. 9 Write waveform EM7028 Datasheet Page 13 I2C interface Heart Rate Sensors©2016 SCL SDA DATA S R Slave Address A R DATA A !A DATA P !A P Fig. 10 Read waveform 11.Registers Operation S W A REG_ADDR A REG_WDATA W A REG_ADDR A REG_WDATA1 A Slave Address A/!A P Fig. 11 Register random write operation S Slave Address A REG_WDATA0 REG_WDATAn A/!A P Fig. 12 Register page write operation S Slave Address W S A REG_ADDR Slave Address R A/!A P A REG_RDATA A/!A P Fig. 13 Register random read operation 12.Registers Definition Function Modes: 1. HRS1 (Heart Rate Measurement in Continuous Mode) 2. HRS2 (Heart Rate Measurement in Pulse Mode) EM7028 Datasheet Page 14 I2C interface Heart Rate Sensors©2016 Table. 6 REGISTER DESCRIPTION Address R/W 0(0x00) R Bit7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Default 1(0x01) R/W Reserved HRS1_EN Reserved Reserved Reserved 2(0x02) R/W HRS2_FLAG 0x00 Reserved HRS1_FLAG INT_CTRL 3(0x03) R/W HRS_LT[7:0] 0x00 4(0x04) R/W HRS _LT[15:8] 0x00 5(0x05) R/W HRS _HT[7:0] 0xFF 6(0x06) R/W HRS _HT[15:8] 0xFF 7(0x07) R/W LED_CAL[7:0] 0x80 8(0x08) R/W HRS2_DATA_OFFSET[7:0] 0x00 9(0x09) R/W PID HRS2_EN Reserved 10(0x0A) R/W HRS2_GAIN Reserved Reserved HRS2_PRST[1:0] 0x36 HRS1_PRST[1:0] 0x00 HRS2_TIME[2] HRS2_TIME[1] HRS2_TIME[0] LED_WIDTH[1] LED_WIDTH[0] LED_CNT[1] LED_CNT[0] 0x40 HRS2_POS[6] HRS2_POS[5] HRS2_POS[4] HRS2_POS[3] HRS2_POS[2] HRS2_POS[1] HRS2_POS[0] 0x01 11(0x0B) R SIGN Reserved 12(0x0C) R SIGN Reserved 13(0x0D) R/W HRS_GAIN HRS_RANGE 14(0x0E) R/W INT_EN INT_MODE1 HRS_FREQ[2:0], 40960Hz to 2.62144MHz INT_MODE2 INT_MODE3 0x00 0x00 HRS_RES[1:0], 10b, 12b, 14b, 16b Reserved IR_MODE HRS2_DR[2:0], Programmed LED Current 0x32 0x90 15(0x0F) R/W SOFT_RESET[7:0] 0x00 32(0x20) R HRS2_DATA0[7:0], 0x00 33(0x21) R HRS2_DATA0[15:8] 0x00 34(0x22) R HRS2_DATA1[7:0] 0x00 35(0x23) R HRS2_DATA1[15:8] 0x00 36(0x24) R HRS21_DATA2[7:0] 0x00 37(0x25) R HRS2_DATA2[15:8] 0x00 38(0x26) R HRS2_DATA3[7:0] 0x00 39(0x27) R HRS2_DATA3[15:8] 0x00 40(0x28) R HRS1_DATA0[7:0] 0x00 41(0x29) R HRS1_DATA0[15:8 0x00 42(0x2A) R HRS1_DATA1[7:0] 0x00 43(0x2B) R HRS1_DATA1[15:8] 0x00 44(0x2C) R HRS1_DATA2[7:0] 0x00 45(0x2D) R HRS1_DATA2[15:8] 0x00 46(0x2E) R HRS1_DATA3[7:0] 0x00 47(0x2F) R HRS1_DATA3[15:8] 0x00 48(0x30) R HRS1_DATA0[7:0] 0x00 49(0x31) R HRS1_DATA0[15:8] 0x00 Table. 7 REGISTER 0x00 (RESERVED) BIT # ACCESS Default Name FUNCTION/OPERATION 7:0 RO 0x36 PID Product ID - readable Table. 8 REGISTER 0x01 (CONFIGURE) - PROX/HRS CONFIGURATION BIT# R/W 7 RW Default Value Name Name/operation description When= 0, heart rate sensing in pulse mode is disabled; 0 HRS2_EN When= 1, heart rate sensing in pulse mode is enabled; The enabled HRS2 pixels are defined by HRS2_POS, and HRS2 ADC gain is defined by HRS2_GAIN; 6 RW 0 Reserved Reserved 5 RW 0 Reserved Reserved EM7028 Datasheet Page 15 I2C interface Heart Rate Sensors©2016 4 RW 0 Reserved Reserved When= 0, Heart Beat Measurement is disabled; 3 RW 0 HRS1_EN When= 1, Heart Beat Measurement is enabled with LED1 turned on and only Red Light Sensor and IR sensor enabled. When LED1 turned on, the result stores to HRS_DATA0; 2 RW 1 Reserved Reserved 1 RW 1 Reserved Reserved 0 RW 1 Reserved Reserved Only one of HRS1/HRS2 modes is enabled in a time Table. 9 REGISTER 0x02 (INTERRUPT) - PROX/GES/HRS INTERRUPT CONTROL BIT # ACCESS Default BIT Name Function/Operation When=0, no proximity interrupt event has occurred since power- 7 FLAG 0 HRS2_FLAG on or last “clear” When=1, a proximity interrupt event occurred. Clearable by writing “0” When=00, 1 times of HRS2 value transfer threshold value; 6:5 RW 00 HRS2 Persist When=01, 2 times of HRS2 value transfer threshold value; When=10, 4 times of HRS2 value transfer threshold value; When=11, 8 times of HRS2 value transfer threshold value; 4 FLAG 0 Reserved Reserved When=0, no HRS1 interrupt event has occurred since power-on 3 FLAG 0 HRS1_FLAG or last “clear” ; When=1, an HRS1 interrupt event occurred. Clearable by writing “0” When=00, 1 times of HRS1 value transfer threshold value; 2:1 RW 00 HRS1 Persist When=01, 2 times of HRS1 value transfer threshold value; When=10, 4 times of HRS1 value transfer threshold value; When=11, 8 times of HRS1 value transfer threshold value; 0 RW 0 INT_CTRL When=0, only HRS2 interrupt is enabled, unless INT_EN=0; When=1, only HRS interrupt is enabled, unless INT_EN=0; Table. 10 REGISTER 0x03 (HRS_LT) - INTERRUPT LOW THRESHOLD FOR HRS2/HRS1 BIT # ACCESS Default BIT Name Function/operation HRS_LT 7:0 RW 0x00 (HRS2/HRS1 Low 8-bit interrupt low threshold for HRS sensing. Low Threshold) Table. 11 REGISTER 0x04 (HRS _LT) - INTERRUPT LOW THRESHOLD FOR HRS2/HRS1 BIT # ACCESS Default BIT Name Function/operation 7:0 RW 0x00 HRS_LT High 8-bit interrupt low threshold for HRS sensing. EM7028 Datasheet Page 16 I2C interface Heart Rate Sensors©2016 (HRS2/HRS1 Low Threshold) Table. 12 REGISTER 0x05 (HRS _HT) - INTERRUPT LOW THRESHOLD FOR HRS2/HRS1 BIT # ACCESS Default BIT Name Function/operation HRS_HT 7:0 RW 0xFF (HRS2/HRS1 Low 8-bit interrupt high threshold for HRS sensing. High Threshold) Table. 13 REGISTER 0x06 (HRS _HT) - INTERRUPT LOW THRESHOLD FOR HRS2/HRS1 BIT # ACCESS Default BIT Name Function/operation HRS_HT 7:0 RW 0xFF (HRS2/HRS1 High 8-bit interrupt high threshold for HRS sensing. High Threshold) Table. 14 REGISTER 0x07 (LED_CURRENT) – HRS2 LED CURRENT FOR HRS2 BIT # ACCESS Default BIT Name Function/operation When=0x00, LED current is 256/512 of full range; When=0x01, LED current is 257/512 of full range; 7:0 RW 0x80 LED CAL When=0x02, LED current is 258/512 of full range; ... When=0xff, LED current is of full range to maximum; This function serves for LED calibration; Table. 15 REGISTER 0x08 (HRS2_DATA_OFFSET) – HRS2 DATA OFFSET BIT # ACCESS Default BIT Name Function/operation 7 RW 0X0 Reserved N/A When=0x00, no offset; When=0x01, HRS2 data subtract by 8 counts(6.25n); 6:0 RW 0x00 HRS2_ OFFSET When=0x02, HRS2 data subtract by 16 counts(12.5n); ... When=0x8f, HRS2 data subtract by 1016 counts (793.75n); Table. 16 REGISTER 0x09 (HRS2_CTRL) - HRS2 CONTROL BIT # ACCESS Default BIT Name Function/operation When=0, HRS2 conversion is continuous; 7 RW 0x0 Reserved When=1, HRS2 conversion is divided by WAIT time specified in HRS2_TIME; When=000, HRS2 WAIT TIME = 0, continuous 6:4 RW 0b100 HRS2_WAIT_TIME detect; When=001, HRS2 WAIT TIME = 1.5625ms.; EM7028 Datasheet Page 17 I2C interface Heart Rate Sensors©2016 When=010, HRS2 WAIT TIME = 6.25ms; When=011, HRS2 WAIT TIME = 25ms; When=100, HRS2 WAIT TIME = 100ms; When=101, HRS2 WAIT TIME =400ms ; When=110, HRS2 WAIT TIME = 1.6s; When=111, HRS2 WAIT TIME = 6.4s; When=00, LED WIDTH = 8 counts; 3:2 RW 0b10 LED_WIDTH When=01, LED WIDTH = 32 counts; When=10, LED WIDTH = 128 counts; When=11, LED WIDTH = 512 counts; When=00, LED COUNT = 1; 1:0 RW 0b00 LED_CNT When=01, LED COUNT =4; When=10, LED COUNT = 16; When=11, LED COUNT = 64; Table. 17 REGISTER 0x0A (HRS2_GAIN_CTRL) - PROXIMITY SENSOR GAIN CONTROL BIT # ACCESS Default BIT Name 7 RW 0b0 HRS2_GAIN 6:0 RW 0x01 HRS2_POS[6:0] Function/operation When=0, HRS2 GAIN = 1; When=1, HRS2 GAIN = 10; Each bit mark one pixel; Table. 18 REGISTER 0x0B (Reserved) Table. 19 REGISTER 0x0C (Reserved) Table. 20 REGISTER 0x0D (HRS1_CTRL) – HRS1 CONTROL BIT # ACCESS Default BIT Name 7 RW 0x1 HRS_GAIN 6 RW 0x1 HRS_RANGE Function/operation When = 0, HRS1 GAIN =1; When =1, HRS1 GAIN =5;: When = 0, HRS1 RANGE =1; When =1, HRS1 RANGE =8; When=000, HRS1 FREQ = 2.62144MHz (1.5625ms); When=001, HRS1 FREQ = 1.31072MHz(3.125 ms); When=010, HRS1 FREQ = 655,360Hz(6.25 ms); 5:3 RW 0b110 HRS_FREQ When=011, HRS1 FREQ = 327,680Hz(12.5ms); When=100, HRS1 FREQ = 163,840Hz(25ms); When=101, HRS1 FREQ = 81,920Hz(50ms); When=110, HRS1 FREQ = 40,960Hz(100ms); When=111, HRS1 FREQ = 20,480Hz(200ms) ; When=00, HRS1 RES = 10 bits; 2:1 RW 0b01 HRS_RES When=01, HRS1 RES = 12 bits; When=10, HRS1 RES = 14 bits; EM7028 Datasheet Page 18 I2C interface Heart Rate Sensors©2016 When=11, HRS1 RES = 16 bits; 0 RW 0b1 IR_MODE When=0, IR mode; When=1, HRS1 mode; Table. 21 REGISTER 0x0E (INT_CTRL) –INTERRUPT CONTROL BIT # 7 ACCES S RW Default BIT Name Function/operation 0b1 INT_EN When=1, INT mode is enabled When=0, INT_MODE1 is disabled; When=1, INT pin is drive “low” and interrupt flag is 6 RW 0b0 INT_MODE1 set to “1” when register value up transfer the high threshold, and INT pin is pulled “high” and interrupt flag reset “0” when register value down transfer the low threshold. When=0, INT_MODE2 is disabled; When=1, INT pin is drive “low” and interrupt flag is 5 RW 0b0 INT_MODE2 set to “1” when register value larger than the high threshold, and INT pin is pulled “high” and interrupt flag reset “0” when register value is lower than the low threshold. When=0, INT_MODE3 is disabled; When=1, INT pin is drive “low” and interrupt flag is 4 RW 0b1 INT_MODE3 set to “1” when register value is larger than the high threshold or lower than the low threshold, otherwise INT pin is pulled “high” and interrupt flag reset “0” . 3 RW 0b0 Reserved Reserved Peak current for LED1 of IR light, the average current for LED1 is 1/500 of programmed current configured, while the internal duty cycle is 1/500 When=000, LED programmed current = 2.5mA; When=001, LED programmed current = 5.0mA; 2:0 RW 0b000 HRS2_DR[2:0] When=010, LED programmed current = 7.5mA; When=011, LED programmed current = 12.5mA; When=100, LED programmed current = 25mA; When=101, LED programmed current = 50mA; When=110, LED programmed current = 100mA; When=111, LED programmed current = 200mA; Table. 22 REGISTER 0x0F (SOFT_RESET) – SOFT RESET BIT Write any data to the SOFT_RESET register will reset the chip. No need to set a real register. Table. 23 I2C Device address EM7028 Datasheet Page 19 I2C interface Heart Rate Sensors©2016 operation I2C Device address 7 6 5 4 3 2 1 0 address Write Register 0 1 0 0 1 0 0 0 0x48H Read Register 0 1 0 0 1 0 0 1 0x49H The I2C Interface and 7-bit slave address is 0x24. 13.Sample Application VDD_I2C VDD VDD_LED R0 10Ω 2kΩ 8 VDD 5 LEDA 4 LED2 3 SCL EM7028 LED1 SDA INT 7 SCL 1 SDA 2 MicroProcessor INT GND 6 Ambient Light Detecting Surface Fig. 14 Typical Application Circuit in pulse mode of HRS2 ((VDD 2.6~3.6V, VDD_I2C 1.6~3.6V, VDD_LED 2.6~4.5V) EM7028 Datasheet Page 20 I2C interface Heart Rate Sensors©2016 VDD3.3V R0 100Ω 8 VDD 5 LEDA 4 LED2 3 SCL EM7028 LED1 SDA INT 7 1 I2C BUS SCL I2C BUS SDA 2 GND 6 GND Fig. 15 Typical Application Circuit in continuous mode of HRS1 VDD, VDD_I2C, VDD_LED can be connected together as VDD3.3V to 3.3V voltage. VDD3.3V should connect 0.1uF capacitor to ground. INT can be disconnected if no need of interrupt mode. R0 is LED2 adjust resistor, and the typical value of R0 is 100Ω. 14.PCB Design Suggested PCB pad layout guidelines for the Dual Flat No-Lead surface mount package are shown below. EM7028 Datasheet Page 21 I2C interface Heart Rate Sensors©2016 0.25±0.05 0.72±0.05 0.55±0.05 0.95±0.05 Fig. 16 PCB layout design guide (all linear dimensions are in mm) 15.Package Outline Dimensions Fig. 17 Side view of package EM7028 Datasheet Page 22 I2C interface Heart Rate Sensors©2016 Fig. 18 Package Outline Dimensions EM7028 Datasheet Page 23 I2C interface Heart Rate Sensors©2016 16.Packing Tape and reel dimensions is compliant to JEDEC MSL 3 Ordering Information Q'TY/REEL Q'TY/inside box Q'TY/outside box EM7028 1000EA 2000EA 20000EA (7’ reel) Remark MBB/Label/Temperature Card/Silica gel Fig. 19 Tape & Reel Information EM7028 Datasheet Page 24 I2C interface Heart Rate Sensors©2016 17.Recommended Reflow Profile PARAMETER REFERENCE Average temperature gradient in preheating Soak time DEVICE 2.5°C/sec tsoak 2 to 3 minutes Time above 217°C(T1) T1 Max 60 sec Time above 230°C(T2) T2 Max 50 sec Time above Tpeak-10°C(T3) T3 Max 10 sec Peak temperature in reflow Tpeak 260°C Temperature gradient in cooling Max-5°C/sec Fig. 20 Recommended Reflow Profile for SMT The product require to control strictly to prevent moisture absorption into unit. The recommend control is as following. Rebaking of the reel will be required if the devices is unpack from the MBB bag more than 24 hours. If rebaking is required, it should be done at 50℃ for 12 hours. EM7028 Datasheet Page 25 I2C interface Heart Rate Sensors©2016 History Date Author Modification NOTICE: 1. The information here contained could be changed without notice owing to product and/or technical improvements. Please make sure before using the product that the information you are referring to is up-to-date. 2. No responsibilities are assumed by us for any consequence resulting from any wrong or improper operation, etc. of the product. Epticore Microelectronics Co. Ltd. For product information and a complete list of distributors, please contact sales@epticore.com or go to our web site: http://www.epticore.com Copyright © 2016 by Epticore Microelectronics The information appearing in this Data Sheet is believed to be accurate at the time of publication. However, Epticore Microelectronics assumes no responsibility arising from the using of the specification described. The applications mentioned herein are used solely for the purpose of illustration and Epticore Microelectronics makes no warranty or representation that such application will be suitable without further modification, nor recommends the use of its product for application that may present a risk to human life due to malfunction or otherwise. Epticore Microelectronics reserves the right to alter its product without prior notification. For the most up-to-date information, please contact sales representatives. EM7028 Datasheet Page 26
EM7028
物料型号:EM7028
器件简介: EM7028是一款低功耗的I2C接口模块,集成了心率传感器(HRS)和内部LED电流驱动器,配备有两个525nm波长的绿色LED。它可以在连续模式和脉冲模式下工作,专为心率检测设计,例如智能手表等应用。
引脚分配: - SDA:I2C串行数据输入/输出端 - INT:中断输出 - LED1/LED2:LED电流驱动器,LED1最大200mA,LED2最大12mA - LEDA:LED阳极,连接到PCB上的VDD_LED - GND:电源地 - SCL:I2C串行时钟输入端 - VDD:电源供电电压
参数特性: - 工作电压:2.5V至3.6V - 逻辑接口电压:1.8V或等于VDD - 操作电流:连续模式下典型操作电流约为1mA - 环境光抑制:在脉冲模式下作为接近传感器使用,具有抑制环境光噪声的能力 - 温度补偿:具有温度补偿功能 - 接近感应灵敏度高 - 可编程中断模式 - 低平均操作功耗 - I2C总线输出类型:HRS2,最高400kHz
功能详解: - 在连续模式下,通过光学检测监测心率,16位ADC不断检测结果,具有可调节的增益和分辨率。 - 在脉冲模式下,设计用于低功耗下的心率监测,同时作为接近传感器使用,具有抑制环境光噪声的能力。
应用信息: - 适用于心率检测,如智能手表等。 - 具有50Hz/60Hz闪烁噪声抑制功能。
封装信息: - 封装尺寸:4.0mm x 2.4mm x 1.35mm - RoHS兼容封装
EM7028 价格&库存
很抱歉,暂时无法提供与“EM7028”相匹配的价格&库存,您可以联系我们找货
