Technical Data 10520
Effective April 2017
FP1008R5 and FP1008R6
High frequency, high current power inductors
Applications
Product features
High current carrying capacity
Low core loss
Magnetically shielded
Tight tolerance DCR for sensing circuits
Inductance Range from 100 nH to 300 nH
Current range from 36 A to 103 A
10.8 mm x 8.0 mm footprint surface mount
package in an 8.0 mm height
Moisture Sensitivity Level: 1
Ferrite core material
Multi-phase and Vcore regulators
Voltage Regulator Modules (VRMs) and high
power density VRMs
• Server and desktop
Central processing unit (CPU)
Graphics processing unit (GPU)
Application specific integrated circuit (ASIC)
Data networking and storage systems
Graphics cards and battery power systems
Point-of-Loadmodules (POL)
DCR sensing circuits
Environmental data
Storage temperature range (Component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
Halogen free, lead free, RoHS compliant
HALOGEN
Pb HF
FREE
Product specifications
OCL1
(nH) ±10%
FLL2
(nH) minimum
Irms3
(A)
Isat14
(A)
Isat25
(A)
Isat36
(A)
DCR (mΩ)
±5% @ 20 °C
K-factor7
FP1008R5-R120-R
120
86
79
103
90
84
0.170
342
FP1008R5-R150-R
150
108
79
85
68
64
0.170
342
FP1008R5-R180-R
180
130
79
70
56
53
0.170
342
FP1008R5-R220-R
220
158
79
58
44
42
0.170
342
FP1008R5-R270-R
270
194
79
44
34
32
0.170
342
FP1008R5-R300-R
300
216
79
36
28
26
0.170
342
FP1008R6-R100-R
100
72
74
103
86
81
0.180
342
FP1008R6-R120-R
120
86
74
103
90
84
0.180
342
FP1008R6-R150-R
150
108
74
85
68
64
0.180
342
Part Number8
R5 version
R6 version
FP1008R6-R180-R
180
130
74
70
56
53
0.180
342
FP1008R6-R220-R
220
158
74
58
44
42
0.180
342
FP1008R6-R270-R
270
194
74
44
34
32
0.180
342
FP1008R6-R300-R
300
216
74
36
28
26
0.180
342
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.1 Vrms, 0.0 Adc, +25 °C
2. Full Load Inductance (FLL) Test Parameters: 100 kHz, 0.1 Vrms, Isat1, +25 °C
3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is
necessary for AC currents. PCB layout, trace thickness and width, air-flow, and proximity of
other heat generating components will affect the temperature rise. It is recommended that the
temperature of the part not exceed 125 °C under worst case operating conditions verified in the
end application.
4. Isat1: Peak current for approximately 20% rolloff @ +25 °C
5. Isat2: Peak current for approximately 20% rolloff @ +100 °C
6. Isat3: Peak current for approximately 20% rolloff @ +125 °C
7. K-factor: Used to determine Bp-p for core loss (see graph).
Bp-p = K * L * ∆I * 10-3. Bp-p:(Gauss), K: (K-factor from table), L:
(Inductance in nH), ∆I (Peak to peak ripple current in Amps).
8. Part Number Definition: FP1008Rx-Rxxx-R
FP1008R= Product code and size
x= Version indicator
-Rxxx= Inductance value in uH, R= decimal point
-R suffix = RoHS compliant
Dimensions (mm)
Part marking: FP1008Rx (x = Version), Rxxx= Inductance value in uH (R= decimal point) xxxx = Lot code
Tolerances are ±0.15 millimeters unless stated otherwise
Pad layout tolerances are ±0.1 millimeters unless stated otherwise
All soldering surfaces to be coplanar within 0.1 millimeter
DCR measured from point “A” to point “B”
Do not route traces or vias underneath the inductor
2
www.eaton.com/electronics
Packaging information (mm)
Supplied in tape-and-reel packaging, 500 parts on a 13” diameter reel.
Temperature rise vs total loss
FP1008R6
60
60
50
50
Temperature Rise (°C)
FP1008R5
40
30
10
0.0
0.2
0.4
0.6
0.8
Total Loss (W)
1.0
1.2
1.4
1.6
0.2
0.4
0.6
0.8
Total Loss (W)
1.0
1.2
1.4
1.6
3
Core loss vs. Bp-p
FP1008R5
1
0.1
Core Loss (W)
Core Loss (W)
0.1
0.01
0.001
0.0001
FP1008R6
1
0.01
0.001
100
1000
0.0001
10000
Bp-p (Gauss)
100
1000
10000
Bp-p (Gauss)
Inductance characteristics
FP1008R5-R120-R
140
140
120
120
Inductance (nH)
Inductance (nH)
100
80
60
-40 °C
40
+25 °C
4
80
60
-40 °C
+25 °C
+100 °C
+125 °C
40
+100 °C
FP1008R5-R150-R
160
60
Idc (A)
80
100
120
140
+125 °C
60
Idc (A)
80
100
120
FP1008R5-R180-R
200
FP1008R5-R220-R
240
180
200
160
Inductance (nH)
Inductance (nH)
140
120
100
80
80
+25 °C
+100 °C
+100 °C
+125 °C
+125 °C
30
40
50
Idc (A)
60
70
80
90
FP1008R5-R270-R
320
Idc (A)
50
60
70
80
FP1008R5-R300-R
300
240
250
Inductance (nH)
200
160
120
-40 °C
80
200
150
-40 °C
100
+25 °C
+100 °C
40
+25 °C
+100 °C
50
+125 °C
+125 °C
Idc (A)
40
50
60
FP1008R6-R100-R
120.0
Idc (A)
40
50
60
FP1008R6-R120-R
140
120
100.0
Inductance (nH)
100
Inductance (nH)
80.0
60.0
40.0
80
60
-40 °C
40
-40 °C
+25 °C
+25 °C
20.0
+100 °C
+100 °C
+125 °C
+125 °C
0.0
30
350
280
Inductance (nH)
-40 °C
+25 °C
40
-40 °C
60
60
80
Idc (A)
100
120
140
160
60
Idc (A)
80
100
120
140
5
FP1008R6-R150-R
160
FP1008R6-R180-R
200
180
140
160
Inductance (nH)
Inductance (nH)
120
100
80
60
40
120
100
60
+25 °C
40
60
80
Idc (A)
100
FP1008R6-R220-R
240
-40 °C
+25 °C
+100 °C
+125 °C
-40 °C
+100 °C
+125 °C
40
50
Idc (A)
60
70
80
90
100
FP1008R6-R270-R
320
280
200
160
Inductance (nH)
Inductance (nH)
240
120
80
+100 °C
40
Idc (A)
50
60
70
80
FP1008R6-R300-R
250
200
150
-40 °C
100
+25 °C
+100 °C
50
+125 °C
+25 °C
+100 °C
+125 °C
300
Inductance (nH)
-40 °C
40
+125 °C
350
6
120
80
+25 °C
-40 °C
40
30
Idc (A)
40
50
60
Idc (A)
40
50
60
70
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“FP1008R5-R120-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 500+1.04016
- 1000+0.97077
