CW CBLPM1.S1-MZNY-K-0-A00-R18-XX 数据手册
www.osram-os.com
Produktdatenblatt | Version 1.1
CW CBLPM1.S1
CW CBLPM1.S1
CERAMOS ® Gen 4.H
Highly efficient lightsource, slim package design
Applications
——Flash & Autofocus
Features:
——Package: SMD ceramic package with diffused silicone resin
——Chip technology: UX:3
——Typ. Radiation: 120° (Lambertian emitter)
——Color: Cx = 0.33, Cy = 0.34 acc. to CIE 1931 (● white)
——Corrosion Robustness Class: 3B
——ESD: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2); 8 kV acc. to IEC 61000-4-2, level 4
(contact discharge)
Discontinued
1 Version 1.7 | 2020-03-09
CW CBLPM1.S1
Ordering Information
Type
Luminous Flux 1)
IF = 1000 mA
ΦV
CW CBLPM1.S1-MZNY-HL
240 ... 390 lm
Discontinued
2 Version 1.7 | 2020-03-09
Ordering Code
Q65112A0303
CW CBLPM1.S1
Maximum Ratings
Parameter
Symbol
Operating Temperature
Top
min.
max.
-40 °C
85 °C
Storage Temperature
Tstg
min.
max.
-40 °C
85 °C
Junction Temperature 2)
Tj
max.
150 °C
Junction Temperature Pulse 3)
Tj
max.
175 °C
Forward Current 2)
TS = 25 °C
IF
min.
max.
30 mA
500 mA
Forward Current pulsed 3)
D = 0.016 ; TS = 25 °C
IF pulse
max.
2000 mA
Reverse current 4)
IR
max.
200 mA
Discontinued
3 Version 1.7 | 2020-03-09
Values
CW CBLPM1.S1
Characteristics
IF = 1000 mA; TS = 25 °C
Parameter
Symbol
Chromaticity Coordinate 5)
Cx
Cy
typ.
typ.
0.33
0.34
Viewing angle at 50% IV
2φ
typ.
120 °
Forward Voltage 6)
IF = 1000 mA
VF
min.
typ.
max.
2.95 V
3.05 V
3.70 V
Reverse voltage (ESD device)
VR ESD
min.
5V
Reverse voltage
IR = 20 mA
VR
max.
1.2 V
Electrical thermal resistance junction/solderpoint 7)
with efficiency ηe = 27 %
RthJS elec.
typ.
4)
Discontinued
4 Version 1.7 | 2020-03-09
Values
8.0 K / W
CW CBLPM1.S1
Brightness Groups
Group
Luminous Flux 1)
IF = 1000 mA
min.
ΦV
Luminous Flux 1)
IF = 1000 mA
max.
ΦV
MZ
240 lm
280 lm
NX
280 lm
330 lm
NY
330 lm
390 lm
Discontinued
5 Version 1.7 | 2020-03-09
CW CBLPM1.S1
Chromaticity Coordinate Groups
0,900
Cy
Cy
0,800
4500 K
0,380
5000 K
0,700
0,600
0,360
5500 K
0,500
6000 K
0,400
K
0,340
6500 K
0,300
CW CBLPM1.S1
0,200
L
H
CW CBLPM1.S1
0,320
0,100
0,000
0,000
0,100
0,200
0,300
0,400
0,500
0,600
Coordinates in reference to CIE 1931 (cx cy)
0,300
0,305
0,700
Cx
0,325
0,345
0,365
Cx
Chromaticity Coordinate Groups 5)
Group
Cx
Cy
Group
Cx
Cy
Group
Cx
Cy
H
0.3262
0.3617
K
0.3397
0.3736
L
0.3566
0.3883
0.3277
0.3135
0.3373
0.3229
0.3495
0.3349
0.3199
0.3058
0.3277
0.3135
0.3373
0.3229
0.3150
0.3520
0.3262
0.3617
0.3397
0.3736
Discontinued
6 Version 1.7 | 2020-03-09
CW CBLPM1.S1
Group Name on Label
Example: MZ-H
Brightness
Color Chromaticity
MZ
H
Discontinued
7 Version 1.7 | 2020-03-09
CW CBLPM1.S1
Relative Spectral Emission
8)
Irel = f (λ); IF = 1000 mA; TJ = 25 °C
Φrel
CW CBLPM1.S1
1.0
: Vλ
: white
0.8
0.6
0.4
0.2
0.0
350
400
450
500
550
600
650
700
750
800
λ [nm]
Radiation Characteristics
8)
Irel = f (ϕ); TJ = 25 °C
40˚
30˚
20˚
10˚
0˚
ϕ
50˚
OHL01660
1.0
0.8
0.6
60˚
0.4
70˚
0.2
80˚
Discontinued
90˚
100˚
1.0
0.8
8 Version 1.7 | 2020-03-09
0.6
0.4
0˚
20˚
40˚
60˚
80˚
100˚
120˚
CW CBLPM1.S1
Forward current
Relative Luminous Flux
8), 9)
IF = f(VF); TJ = 25 °C
IF [mA]
2000
8), 9)
Φv/Φv(1000 mA) = f(IF); TJ = 25 °C
ΦV
CW CBLPM1.S1
CW CBLPM1.S1
ΦV(1000 mA ) 1,6
1800
1,4
1600
1,2
1400
1200
1,0
1000
0,8
800
0,6
600
0,4
400
0,2
200
0,0
2.8
3.0
3.2
3.4
VF [V]
Chromaticity Coordinate Shift
Cx, Cy = f(IF); TJ = 25 °C
Cx
Cy 0,36
0,34
CW CBLPM1.S1
: Cx
: Cy
0,32
00
Discontinued
0,30
IF [mA ]
9 Version 1.7 | 2020-03-09
8)
30
00
12
00
18
00
30
2.5 2.6
IF [mA ]
CW CBLPM1.S1
Forward Voltage
8)
ΔVF = VF - VF(25 °C) = f(Tj); IF = 1000 mA
∆VF [V]
Φv/Φv(25 °C) = f(Tj); IF = 1000 mA
Φv
CW CBLPM1.S1
0.3
Φv(25 °C )
1,0
0.1
0,8
0.0
0,6
-0.1
0,4
-0.2
0,2
60
80 100 120 140
Tj [°C]
Cx, Cy = f(Tj); IF = 1000 mA
Cx 0,350
Cy
0,345
0,340
CW CBLPM1.S1
: Cx
: Cy
0,335
0,330
Discontinued
0,325
-40 -20
1,2
0.2
-0.3
-40 -20
0 20 40 60 80 100 120
Tj [°C]
10 Version 1.7 | 2020-03-09
8)
8)
0,0
-40 -20
CW CBLPM1.S1
Tj [°C]
CW CBLPM1.S1
Max. Permissible Forward Current
IF = f(T)
Deratings strongly relate on the boundary conditions of
each individual device:
• The DC-derating on the left represents several thermal
resistance values Rth JA (Junction/Ambient) as
examples.
• The shown pulse-deratings represent just one of
alterative options for use. For further information please
refer to application note „Thermal Management of Flash
LEDs“.
Permissible Pulse Handling Capability
Rth JA el = 160 K/W; TA = 25 °C; still air; FR4
Rth JA el = 160 K/W; TA = 85 °C; still air; FR4
CW CBLPM1.S1
IF [A]
2,0
0,0 -5
10
: D = 0.2
: D = 0.1
: D = 0.05
: D = 0.02
: D = 0.01
: D = 0.005
1,5
1,0
0,5
CW CBLPM1.S1
IF [A]
2,0
1,5
Discontinued
Note:
1,0
: D = 0.2
: D = 0.1
: D = 0.05
: D = 0.02
: D = 0.01
: D = 0.005
10-4
10-3
0,5
0,01
0,1
11 Version 1.7 | 2020-03-09
1
10
Pulsetime
[s]
0,0 -5 -4 -3
10 10 10 0,01 0,1 1 10
Pulsetime
[s]
CW CBLPM1.S1
Dimensional Drawing
10)
Further Information:
Approximate Weight:
8.2 mg
Corrosion test:
Class: 3B
Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC
60068-2-43)
ESD advice:
The device is protected by ESD device which is connected in parallel to the
Chip.
Discontinued
12 Version 1.7 | 2020-03-09
CW CBLPM1.S1
Electrical Internal Circuit
Recommended Solder Pad
10)
Discontinued
For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not
suitable for ultra sonic cleaning.
13 Version 1.7 | 2020-03-09
CW CBLPM1.S1
Reflow Soldering Profile
Product complies to MSL Level 2 acc. to JEDEC J-STD-020E
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
tL
150
tS
100
50
25 ˚C
100
150
200
250
s 300
t
Profile Feature
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Recommendation Maximum
Ramp-up rate to preheat*)
25 °C to 150 °C
tS
Time tS
TSmin to TSmax
Ramp-up rate to peak*)
TSmax to TP
Liquidus temperature
60
2
3
100
120
2
3
K/s
s
K/s
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
3
6
Ramp-down rate*
TP to 100 °C
10
Time
25 °C to TP
Discontinued
Unit
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
14 Version 1.7 | 2020-03-09
°C
480
s
K/s
s
CW CBLPM1.S1
Taping
10)
Discontinued
15 Version 1.7 | 2020-03-09
CW CBLPM1.S1
Tape and Reel
11)
Reel Dimensions
A
180 mm
W
Nmin
8 + 0.3 / - 0.1 mm
Discontinued
16 Version 1.7 | 2020-03-09
W1
60 mm
W2 max
8.4 + 2 mm
14.4 mm
Pieces per PU
4000
CW CBLPM1.S1
Barcode-Product-Label (BPL)
Dry Packing Process and Materials
10)
Moisture-sensitive label or print
L
E
E
V
l
e be
sela
k,
H
de
L
If
an
bl r co
ba
(R
id
m
ity
H
R
hu
0%
e
e
/6
tiv
˚C
la ared ag
ck
re
fr
30
_
in pa
k
of
to
90
rs
ea
s
d
rs
ou
or
te (p
on
rs
H
de
ou
iti
H
an bjec ng
ou rs
co
˚C
72
si
nd
H ou
5
te
48
˚C su es
e
H
co
24 6
da
e
y
40 be oc
tim
˚C
e
or
ith
tim
ill pr).
or
ct
w
O
w nt
23
tim e
at
lo
or
fa
M TO
F
s
al
tim
at le ˚C at
lo
at
or
e.
P
th
F
l
tic
th va
lo or
ur
O
F lo
s ui
on
be
if: read
en
w
ed
l 4 5
F
m
la
ce eq
id
lo
g, n
oc
l
ve
vi
5a
is
in
or
be
24
de
pr
ve l
6
Le
de ,
nt whe
e
te
co
g:
, w
e
Le ve l
ke
r
ou
se
da
ba ed flo
ur
e
Le ve
m %
ba
e
ba
al
st
ur e
Le
r
en re
ed
e
re> 10
oi
st
e
e
fo
tim
ur
se
al
op
fo
M
se
oi st ur
as
k,
is
or .
33
se
is
M oi st
bed
k,
lo H
an
g ph
-0
M oi
in
an in F R ng ar
rbl
D
M
e
ba
T
r
po If bl ith
lif
ki r C.
(if
S
is
p.
w
ea r ks
lf
J10 ba to et
th va
Y ea
m
rs
m
_
r w,
he
ed
1
ee
te
Y
d, EC
iredicat
S
fte
at
nt
1
W Hou
D
A flody
qu In no ire
1.
d
e
ou
4 8
re
reity is
qu/JE
re
2.
bo
e
M
tim
to es id 2b
re C
16
e
a)
S
tim
is IP
ic
ed loor
tim e
b) ev Humor
or
e
en
F
tim
lo
or
D
2a king
nc
te
F
op
a)
lo or
3.
b) ba re
F lo
da
e
fe
l 1 2
F
If
al
re
tim ve
l
4.
se
d
l 2a
ve
Le
3
an
ve l
ag
e
Le
e
B
ve
ur
e
Le
at
st
ur
e
Le
D
oi
st
ur e
M
oi
st ur
M
oi st
M oi
M
N
E RS
s
in IV O
IT T
S C
nta
N U
TIO
U coSEND
Ais bUagRMEICO
T E
CThIS
S
d
Barcode label
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
Discontinued
Desiccant
AM
OSR
OHA00539
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033.
17 Version 1.7 | 2020-03-09
CW CBLPM1.S1
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this
data sheet falls into the class moderate risk (exposure time 0.25 s). Under real circumstances (for exposure
time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources
have a high secondary exposure potential due to their blinding effect. When looking at bright light sources
(e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation.
Subcomponents of this device contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage,
production, and use. Devices that showed visible discoloration when tested using the described tests above
did show no performance deviations within failure limits during the stated test duration. Respective failure
limits are described in the IEC60810.
For further application related information please visit www.osram-os.com/appnotes
Discontinued
18 Version 1.7 | 2020-03-09
CW CBLPM1.S1
Disclaimer
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on the OSRAM OS website.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of
transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we
shall have to invoice you for any costs incurred.
Product and functional safety devices/applications or medical devices/applications
OSRAM OS components are not developed, constructed or tested for the application as safety relevant
component or for the application in medical devices.
OSRAM OS products are not qualified at module and system level for such application.
In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety
devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales
partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.
Discontinued
19 Version 1.7 | 2020-03-09
CW CBLPM1.S1
Glossary
1)
Brightness: Brightness values are measured during a current pulse of typically 25 ms, with an internal
reproducibility of ±8 % and an expanded uncertainty of ±11 % (acc. to GUM with a coverage factor of
k = 3).
2)
Operating Conditions: Operating conditions according DC-derating (Max. Permissible Forward Current)
3)
Operating Conditions: Operating conditions according Pulse-derating (Permissible Pulse Handling
Capability)
4)
Reverse Operation: Reverse Operation of 10 hours is permissible in total. Continuous reverse operation is not allowed.
5)
Chromaticity coordinate groups: Chromaticity coordinates are measured during a current pulse of
typically 25 ms, with an internal reproducibility of ±0.005 and an expanded uncertainty of ±0.01 (acc. to
GUM with a coverage factor of k = 3).
6)
Forward Voltage: The forward voltage is measured during a current pulse of typically 8 ms, with an
internal reproducibility of ±0.05 V and an expanded uncertainty of ±0.1 V (acc. to GUM with a coverage
factor of k = 3).
7)
Thermal Resistance: The typical Rth value is the average of a distribution. The value was determined
on a sample basis and is not monitored.
8)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
9)
Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit.
10)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
11)
Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.
Discontinued
20 Version 1.7 | 2020-03-09
CW CBLPM1.S1
Discontinued
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
21 Version 1.7 | 2020-03-09
