LR W5SM-JXJZ-1-1-400-R18-Z-XIN 数据手册
www.osram-os.com
Produktdatenblatt | Version 1.1
LR W5SM
LR W5SM
Golden DRAGON ®
Applications
——Signalling
Features:
——Package: white SMD package, colorless clear silicone resin
——Chip technology: Thinfilm
——Typ. Radiation: 120° (Lambertian emitter)
——Color: λdom = 628 nm (● red)
——Optical efficacy: 65 lm/W
——Corrosion Robustness Class: 3B
——ESD: 8 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B)
Discontinued
1 Version 1.3 | 2019-07-16
LR W5SM
Ordering Information
Type
LR W5SM-HZJZ-1-1
Discontinued
2 Version 1.3 | 2019-07-16
Luminous Flux 1)
IF = 400 mA
ΦV
Ordering Code
39 ... 71 lm
Q65111A2604
LR W5SM
Maximum Ratings
Parameter
Symbol
Operating Temperature
Top
min.
max.
-40 °C
125 °C
Storage Temperature
Tstg
min.
max.
-40 °C
125 °C
Junction Temperature
Tj
max.
135 °C
Junction Temperature for short time applications*
Tj
max.
175 °C
Forward current
TS = 25 °C
IF
min.
max.
100 mA
1000 mA
Surge Current
t ≤ 10 µs; D = 0.005 ; TS = 25 °C
IFS
max.
2500 mA
ESD withstand voltage
VESD
Reverse current 2)
IR
* The median lifetime (L70/B50) for Tj = 175°C is 100h.
Discontinued
3 Version 1.3 | 2019-07-16
Values
8 kV
max.
200 mA
LR W5SM
Characteristics
IF = 400 mA; TS = 25 °C
Parameter
Symbol
Peak Wavelength
λpeak
typ.
632 nm
Dominant Wavelength 3)
IF = 400 mA
λdom
min.
typ.
max.
620 nm
628 nm
632 nm
Spectral Bandwidth at 50% Irel,max
∆λ
typ.
18 nm
Viewing angle at 50% IV
2φ
typ.
120 °
Forward Voltage 4)
IF = 400 mA
VF
min.
typ.
max.
2.00 V
2.20 V
2.60 V
Reverse voltage (ESD device)
VR ESD
min.
45 V
Reverse voltage 2)
IR = 20 mA
VR
max.
1.2 V
Real thermal resistance junction/solderpoint 5)
RthJS real
typ.
max.
6.5 K / W
11.0 K / W
Discontinued
4 Version 1.3 | 2019-07-16
Values
LR W5SM
Brightness Groups
Group
Luminous Flux 1)
IF = 400 mA
min.
ΦV
Luminous Flux 1)
IF = 400 mA
max.
ΦV
Luminous Intensity 6)
IF = 400 mA
typ.
Iv
HZ
39 lm
45 lm
14 cd
JX
45 lm
52 lm
16 cd
JY
52 lm
61 lm
19 cd
JZ
61 lm
71 lm
22 cd
Forward Voltage Groups
Group
Forward Voltage 4)
IF = 400 mA
min.
VF
Forward Voltage 4)
IF = 400 mA
max.
VF
J3
2.00 V
2.15 V
M3
2.15 V
2.30 V
Q3
2.30 V
2.45 V
T3
2.45 V
2.60 V
Discontinued
5 Version 1.3 | 2019-07-16
LR W5SM
Group Name on Label
Example: HZ-1-J3
Brightness
Wavelength
HZ
1
Discontinued
6 Version 1.3 | 2019-07-16
Forward Voltage
J3
LR W5SM
Relative Spectral Emission
6)
Irel = f (λ); IF = 400 mA; TS = 25 °C
Irel
LR W5SM
1,0
: Vλ
: red
0,8
0,6
0,4
0,2
0,0
350
400
450
500
550
600
650
700
750
800
λ [nm]
Radiation Characteristics
6)
Irel = f (ϕ); TS = 25 °C
LR W5SM
ϕ [°]
-40°
-50°
-20°
-10°
0°
10°
20°
30°
40°
50°
60°
70°
80°
90°
1,0
-30°
0,8
0,6
-60°
-70°
-80°
Discontinued
-90°
-100°
7 Version 1.3 | 2019-07-16
0,4
0,2
0,0
Irel
LR W5SM
Forward current
Relative Luminous Flux
6), 7)
IF = f(VF); TS = 25 °C
IF [mA]
6), 7)
Φv/Φv(400 mA) = f(IF); TS = 25 °C
LR W5SM
1000
ΦV
LR W5SM
2,5
ΦV(400mA)
: red
: red
2,0
800
1,5
600
1,0
400
0,5
200
Discontinued
8 Version 1.3 | 2019-07-16
10
00
2,75
VF [V]
80
60
40
10
100
1,85
IF [mA]
LR W5SM
Forward Voltage
6)
ΔVF = VF - VF(25 °C) = f(Tj); IF = 400 mA
∆VF [V]
Φv/Φv(25 °C) = f(Tj); IF = 400 mA
LR W5SM
0,3
6)
Φv
LR W5SM
1,6
Φv(25°C)
: red
: red
1,4
0,2
1,2
0,1
1,0
0,0
0,8
0,6
-0,1
0,4
-0,2
0,2
-0,3
-40 -20
60
80 100 120
Tj [°C]
Dominant Wavelength
6)
Δλdom = λdom - λdom(25 °C) = f(Tj); IF = 400 mA
∆λ dom [nm]
LR W5SM
8
: red
6
4
2
-4
-6
Discontinued
-8
-40 -20
40
60
80 100 120
Tj [°C]
9 Version 1.3 | 2019-07-16
0,0
-40 -20
60
80 100 120
Tj [°C]
LR W5SM
Max. Permissible Forward Current
IF = f(T)
OHL02947
1100
mA
IF
900
800
700
600
500
400
300
200
100
Do not use current below 100 mA
60
80 100
˚C 140
T
Permissible Pulse Handling Capability
IF = f(tp); D: Duty cycle; TS = 25 °C
2.6
A
IF
2.4
OHL04373
t
D = TP
2.2
2.0
1.8
1.6
1.4
1.2
D=
tP
IF
T
0.005
0.01
0.02
0.05
0.1
0.2
0.5
1
Discontinued
1.0
0.8 -5
10 10-4 10-3 10-2 10-1 100 101 s 102
tp
10 Version 1.3 | 2019-07-16
LR W5SM
Dimensional Drawing
8)
Further Information
Approximate Weight:
218.0 mg
Corrosion test:
Class: 3B
Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC
60068-2-43)
ESD advice:
The device is protected by ESD device which is connected in parallel to the
Chip.
Discontinued
11 Version 1.3 | 2019-07-16
LR W5SM
Recommended Solder Pad
1.6 (0.063)
1.6 (0.063)
Kupfer
Copper
10 (0.394)
2.3 (0.091)
11.6 (0.457)
2.3 (0.091)
11.6 (0.457)
0.3 (0.012)
12.0 (0.472)
ø2.5 (0.098)
ø4.0 (0.157)
8)
ø4.0 (0.157)
Heatsink attach
3 Lötstellen
3 solder points
Thermisch optimiertes PCB
Thermal enhanced PCB
Lötstopplack
Solder resist
Lötpasten Schablone
Solder paste stencil
Bare Copper
Freies Kupfer
OHAY0681
For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not
suitable for ultra sonic cleaning.
Discontinued
12 Version 1.3 | 2019-07-16
LR W5SM
Reflow Soldering Profile
Product complies to MSL Level 2 acc. to JEDEC J-STD-020E
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
tL
150
tS
100
50
25 ˚C
100
150
200
250
s 300
t
Profile Feature
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Recommendation Maximum
Ramp-up rate to preheat*)
25 °C to 150 °C
tS
Time tS
TSmin to TSmax
Ramp-up rate to peak*)
TSmax to TP
Liquidus temperature
60
2
3
100
120
2
3
K/s
s
K/s
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
3
6
Ramp-down rate*
TP to 100 °C
10
Time
25 °C to TP
Discontinued
Unit
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
13 Version 1.3 | 2019-07-16
°C
480
s
K/s
s
LR W5SM
Taping
8)
6.35 (0.250)
8 (0.315)
Discontinued
14 Version 1.3 | 2019-07-16
7.35 (0.289)
0.3 (0.012)
24 (0.945)
2 (0.079)
0.3 (0.012)
12.4 (0.488)
1.55 (0.061)
11.5 (0.453)
4 (0.157)
1.75 (0.069)
Cathode/Collector Side
1.9 (0.075)
OHAY0508
LR W5SM
Tape and Reel
9)
Reel Dimensions
A
180 mm
W
Nmin
24 + 0.3 / - 0.1 mm
Discontinued
15 Version 1.3 | 2019-07-16
60/100 mm
W1
W2 max
24.4 + 2 mm
30.4 mm
Pieces per PU
800
LR W5SM
Barcode-Product-Label (BPL)
Dry Packing Process and Materials
8)
Moisture-sensitive label or print
L
E
E
V
l
e be
sela
k,
H
de
L
If
an
bl r co
ba
(R
id
m
ity
H
R
hu
0%
e
e
/6
tiv
˚C
la ared ag
ck
re
fr
30
_
in pa
k
of
to
90
rs
ea
s
d
rs
ou
or
te (p
on
rs
H
de
ou
iti
H
an bjec ng
ou rs
co
˚C
72
si
nd
H ou
5
te
48
˚C su es
e
H
co
24 6
da
e
y
40 be oc
tim
˚C
e
or
ith
tim
ill pr).
or
ct
w
O
w nt
23
tim e
at
lo
or
fa
M TO
F
s
al
tim
at le ˚C at
lo
at
or
e.
P
th
F
l
tic
th va
lo or
ur
O
F lo
s ui
on
be
if: read
en
w
ed
l 4 5
F
m
la
ce eq
id
lo
g, n
oc
l
ve
vi
5a
is
in
or
be
24
de
pr
ve l
6
Le
de ,
nt whe
e
te
co
g:
, w
e
Le ve l
ke
r
ou
se
da
ba ed flo
ur
e
Le ve
m %
ba
e
ba
al
st
ur e
Le
r
en re
ed
e
re> 10
oi
st
e
e
fo
tim
ur
se
al
op
fo
M
se
oi st ur
as
k,
is
or .
33
se
is
M oi st
bed
k,
lo H
an
g ph
-0
M oi
in
an in F R ng ar
rbl
D
M
e
ba
T
r
po If bl ith
lif
ki r C.
(if
S
is
p.
w
ea r ks
lf
J10 ba to et
th va
Y ea
m
rs
m
_
r w,
he
ed
1
ee
te
Y
d, EC
iredicat
S
fte
at
nt
1
W Hou
D
A flody
qu In no ire
1.
d
e
ou
4 8
re
reity is
qu/JE
re
2.
bo
e
M
tim
to es id 2b
re C
16
e
a)
S
tim
is IP
ic
ed loor
tim e
b) ev Humor
or
e
en
F
tim
lo
or
D
2a king
nc
te
F
op
a)
lo or
3.
b) ba re
F lo
da
e
fe
l 1 2
F
If
al
re
tim ve
l
4.
se
d
l 2a
ve
Le
3
an
ve l
ag
e
Le
e
B
ve
ur
e
Le
at
st
ur
e
Le
D
oi
st
ur e
M
oi
st ur
M
oi st
M oi
M
N
E RS
s
in IV O
IT T
S C
nta
N U
TIO
U coSEND
Ais bUagRMEICO
T E
CThIS
S
d
Barcode label
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
Discontinued
Desiccant
AM
OSR
OHA00539
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033.
16 Version 1.3 | 2019-07-16
LR W5SM
Schematic Transportation Box
8)
Barcode label
N
O
(Q
)Q
TY
:2
00
D
D
/C
:0
(X
Packing
Sealing label
Length
195 ± 5 mm
195 ± 5 mm
Discontinued
17 Version 1.3 | 2019-07-16
M
Y
DE
-1
+Q
-1
R
18
P
OHA02044
Dimensions of Transportation Box
Width
RO
UP
M
RA
OS
PR
O
D
5
14 2
110 0
G
4
01
4
C:
D/
(9
D)
(Q
)Q
TY
O
TC
P)
(6
T
LO
(1
T)
O
D
PR
D
EM
Y
18
R
-1
Q
P
-1
G
R
O
U
P:
u L
lt S
iT Y
O T6
P 7
L 6
M
14
4
(G
E Bi
D Bi n1
Bi n2 : Pn3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R ditio 0 C R
07
PA 7 na RT
l TE
C
KV
XT
AR
Muster
A
o M
n O
d
u p
cto to
rs
R
34
ic
N
O
O
S
H
12
G
BA
TC
H
(1
T)
LO
T
N
O
:1
(6
P)
23
em
8
2199
2100
5
14 2
110 0
(X
O
M O
PT
O
M
998
NO
CThISTU
SE
S
21
2100
BA
_
s
ur s
Ho ururs s
de
Ho
co
72
Ho ur
te
48
e
Ho
24 6
da
40 be
tim e e
˚C
or
th
r
pr
ll
tim
ct
23
oo r
wi nt
tim e
at
l wi
fa
r
Fl oo
tim
s
at
at le ˚C at
e.
ica
l
Fl
th
oo r
th va
ur
nt
Fl oo
s ui
be
on
if: read
w
ed
l 4 5
Fl
la
m
ide
ce eq
lo
g,
oc
ve l
vi
is
in en
de
be
24 de or
l 5a6
pr
Le ve
nt wh
e
te
co
, w,
g:
ve l
Le
ke
r
re
ou
se
da
ba ed flo ba
Le ve
tu re
m %
ba
e
al
e
Le
r
en re
e
ed
re 10
ois stu ur e
tim
se
fo
al
op se
fo >
M oi
r
se
st ur
3
is
is ha
se
M
oi st
nk
be
k,
oo .
03
rd
g
M oi
in
an in Fl RH g,
r-p
bla
DM
ba
Ca
po If bl th
kinr
life is
(if
ar
ST
f
p.
wi
10 ba to et
Jel r th va
Ye ar ks s
m
_
cat m d, C
ed
1
Ye ee ur
ire
Sh te w, te
di
at
nt
1
W Ho
Af flody
qu In no ire DE
1.
e
ou
4 8
re
ed re
qu JE
2.
bo
ity is
M
or
tim e e
16
re C/
es id 2b
r
a)
St
tim
mor
is IP
ed
oo r
tim e
vic
b)
g e
r
Hu
Fl oo
en
tim
De
2a kin nc
te
Fl oo r
a)
op
3.
b) ba re
Fl oo
da
e
fe
l 1
Fl
If
al
re
tim ve l 2
4.
se
d
l 2a3
Le ve
g
an
ve l
e
Le
Ba
te
ur e
Le ve
Le
Da oist stur e
ur e
M
oi
st ur
M
oi st
M oi
H
12
34
RH
0%
/6
˚C
L
e el
selab
H)
nk de
co
(R
bla
r
S S
em R
ic AM
o
n O
d
u p
ct to
o
H
rs
NO
If
23
G
E
V
E
ba
ity
id
m
hu
e
e
d
tiv
re ag
NO
:1
L
la
re
fra ck
30
Nns IVE RS
in pa
k
of
ai IT TO
to
90
ea
d
ntNS
ns
UC
or
TIO
te (p
d
g
itio
ND
U g coSE
an bjec
˚C
sin
nd
O
5
˚C su es
Ais baRE
co
IC
y
M
oc
(G
M
u L
lt S
iT Y
O T6
P 7
L 6
E
D
Muster
Bi
Bi n1
Bi n2 : P-
n3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R0 ditio 0 C R
PA 77 na RT
l TE
CK
VA
XT
R:
Barcode label
Height
42 ± 5 mm
LR W5SM
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this
data sheet falls into the class exempt group (exposure time 10000 s). Under real circumstances (for exposure time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the
eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light
sources have a high secondary exposure potential due to their blinding effect. When looking at bright light
sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation.
Subcomponents of this device contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage,
production, and use. Devices that showed visible discoloration when tested using the described tests above
did show no performance deviations within failure limits during the stated test duration. Respective failure
limits are described in the IEC60810.
For further application related information please visit www.osram-os.com/appnotes
Discontinued
18 Version 1.3 | 2019-07-16
LR W5SM
Disclaimer
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on the OSRAM OS website.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of
transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we
shall have to invoice you for any costs incurred.
Product and functional safety devices/applications or medical devices/applications
OSRAM OS components are not developed, constructed or tested for the application as safety relevant
component or for the application in medical devices.
OSRAM OS products are not qualified at module and system level for such application.
In case buyer – or customer supplied by buyer – considers using OSRAM OS components in product safety
devices/applications or medical devices/applications, buyer and/or customer has to inform the local sales
partner of OSRAM OS immediately and OSRAM OS and buyer and /or customer will analyze and coordinate the customer-specific request between OSRAM OS and buyer and/or customer.
Discontinued
19 Version 1.3 | 2019-07-16
LR W5SM
Glossary
1)
Brightness: Brightness values are measured during a current pulse of typically 25 ms, with an internal
reproducibility of ±8 % and an expanded uncertainty of ±11 % (acc. to GUM with a coverage factor of
k = 3).
2)
Reverse Operation: Reverse Operation of 10 hours is permissible in total. Continuous reverse operation is not allowed.
3)
Wavelength: The wavelength is measured at a current pulse of typically 25 ms, with an internal reproducibility of ±0.5 nm and an expanded uncertainty of ±1 nm (acc. to GUM with a coverage factor of k =
3).
4)
Forward Voltage: The forward voltage is measured during a current pulse of typically 8 ms, with an
internal reproducibility of ±0.05 V and an expanded uncertainty of ±0.1 V (acc. to GUM with a coverage
factor of k = 3).
5)
Thermal Resistance: Rth max is based on statistic values (6σ).
6)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
7)
Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit.
8)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
9)
Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.
Discontinued
20 Version 1.3 | 2019-07-16
LR W5SM
Revision History
Version
Date
Change
1.3
2019-07-16
Discontinued
Discontinued
21 Version 1.3 | 2019-07-16
LR W5SM
Discontinued
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
22 Version 1.3 | 2019-07-16
