2016-09-26
Narrow beam LED in MIDLED package (850 nm)
Version 1.5
SFH 4651
Features:
High Power Infrared LED (40 mW)
Short switching times
Narrow halfangle (± 10°)
The product qualification test plan is based on the guidelines of AEC-Q101-REV-C, Stress Test Qualification
for Automotive Grade Discrete Semiconductors.
Taping as Toplooker
Also available as Sidelooker (SFH4656)
Applications
Infrared Illumination for cameras
IR data transmission
Remote control
Automotive sensors
Notes
Depending on the mode of operation, these devices emit highly concentrated non visible infrared light which
can be hazardous to the human eye. Products which incorporate these devices have to follow the safety
precautions given in IEC 60825-1 and IEC 62471.
Ordering Information
Type:
Radiant Intensity
Ordering Code
Ie [mW/sr]
IF = 70 mA, tp = 20 ms
SFH 4651
60 (≥ 25)
Q65110A8396
SFH 4651-UV
40 ... 125
Q65111A4394
Note:
Measured at a solid angle of Ω = 0.01 sr
2016-09-26
1
Version 1.5
SFH 4651
Maximum Ratings (TA = 25 °C)
Parameter
Symbol
Values
Operation and storage temperature range
Top; Tstg
-40 ... 100
°C
Reverse voltage
VR
5
V
Forward current
IF
70
mA
Surge current
(tp = 20 µs, D = 0)
IFSM
0.7
A
Power consumption
Ptot
140
mW
ESD withstand voltage
(acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM)
VESD
2
Thermal resistance junction - ambient 1) page 12
RthJA
380
K/W
Thermal resistance junction - soldering point
RthJS
220
K/W
2) page 12
Unit
kV
Characteristics (TA = 25 °C)
Parameter
Symbol
Values
Unit
Peak wavelength
(IF = 70 mA, tp = 20 ms)
(typ)
λpeak
860
nm
Centroid wavelength
(typ)
λcentroid
850
nm
Spectral bandwidth at 50% of Imax
(typ)
∆λ
30
nm
Half angle
(typ)
ϕ
± 10
Dimensions of active chip area
(typ)
LxW
Rise and fall time of Ie ( 10% and 90% of Ie max)
(IF = 70 mA, RL = 50 Ω)
(typ)
tr, tf
Forward voltage
Forward voltage
(IF = 500 mA, tp = 100 µs)
2016-09-26
mm x
mm
12
ns
(typ (max)) VF
1.6 (≤ 2)
V
(typ (max)) VF
2.4 (≤ 3)
V
Reverse current
(VR = 5 V)
Total radiant flux
(IF=70 mA, tp=20 ms)
0.2 x 0.2
(typ)
2
IR
not designed for
reverse operation
µA
Φe
40
mW
Version 1.5
SFH 4651
Parameter
Symbol
Values
Unit
Temperature coefficient of Ie or Φe
(typ)
TCI
-0.5
%/K
Temperature coefficient of VF
(typ)
TCV
-0.7
mV / K
Temperature coefficient of wavelength
(typ)
TCλ
0.3
nm / K
Grouping (TA = 25 °C)
Group
Min Radiant Intensity
Max Radiant Intensity
Typ Radiant Intensity
IF = 500 mA, tp = 25 µs
Ie, min [mW / sr]
Ie, max [mW / sr]
Ie, typ [mW / sr]
SFH 4651-T
25
50
220
SFH 4651-U
40
80
360
SFH 4651-V
63
125
560
SFH 4651-AW
100
200
900
Note:
measured at a solid angle of Ω = 0.01 sr
Only one group in one packing unit (variation lower 2:1).
2016-09-26
3
Version 1.5
SFH 4651
Relative Spectral Emission 3) page 12
Irel = f(λ), TA = 25°C
Radiant Intensity 3) page 12
Ie / Ie(70 mA) = f(IF), single pulse, tp = 25 µs,
TA= 25°C
OHF04132
100
OHF04406
101
I rel %
Ie
I e (70 mA)
80
100
5
60
10-1
40
5
10-2
750
800
850
10-3 0
10
nm 950
λ
IF
5 10 2 mA
10 3
IF
Forward Current 3) page 12
IF = f(VF), single pulse, tp = 100 µs, TA= 25°C
Max. Permissible Forward Current
IF, max = f(TA), RthJA = 380 K/W
OHF04057
80
mA
5 10 1
IF
70
OHF03826
100
A
10-1
60
5
50
10-2
40
5
30
10-3
10
60
80
10-4
100 ˚C 120
2016-09-26
1
1.5
2
2.5 V 3
VF
TA
4
Version 1.5
SFH 4651
Permissible Pulse Handling Capability
IF = f(tp), TA = 25 °C, duty cycle D = parameter
IF
IF = f(tp), T A = 85 °C, duty cycle D = parameter
OHF04058
0.7
A
t
tP
0.6
0.5
IF
IF
D = TP
T
0.6
D=
0.5
0.005
0.01
0.02
0.05
0.1
0.2
0.3
0.5
1
0.4
0.3
0.2
OHF04059
0.7
A
t
D = TP
IF
T
D=
0.005
0.01
0.02
0.05
0.1
0.2
0.3
0.5
1
0.4
0.3
0.2
0.1
tP
0.1
0 -5
10 10-4 10-3 10-2 10-1 100 101 s 102
0 -5
tp
tp
Radiation Characteristics 3) page 12
Irel = f(ϕ), TA= 25°C
40˚
30˚
20˚
10˚
ϕ
0˚
OHF05593
1.0
50˚
0.8
60˚
0.6
70˚
0.4
80˚
0.2
90˚
100˚
2016-09-26
1.0
0.8
0.6
0.4
0˚
5
20˚
40˚
60˚
80˚
100˚
120˚
Version 1.5
SFH 4651
Package Outline
Dimensions in mm.
Pad
Description
1
Anode
2
Cathode
Package
MIDLED, Silicone, colourless, clear
Approximate Weight:
23 mg
2016-09-26
6
Version 1.5
SFH 4651
Recommended Solder Pad
Dimensions in mm.
Reflow Soldering Profile
Product complies to MSL Level 2 acc. to JEDEC J-STD-020D.01
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
tL
150
tS
100
50
25 ˚C
100
150
200
250
s 300
t
2016-09-26
7
Version 1.5
SFH 4651
OHA04612
Profile Feature
Profil-Charakteristik
Symbol
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Ramp-up rate to preheat*
25 °C to 150 °C
Time tS
TSmin to TSmax
tS
60
Ramp-up rate to peak*)
TSmax to TP
Recommendation
Maximum
2
3
100
120
2
3
Unit
Einheit
K/s
s
K/s
Liquidus temperature
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
s
3
6
K/s
10
Ramp-down rate*
TP to 100 °C
480
Time
25 °C to TP
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
Taping
Dimensions in mm (inch).
Note:
Pad 1 = Anode
2016-09-26
°C
8
s
Version 1.5
SFH 4651
Tape and Reel
8 mm tape with 2000 pcs. on ∅ 180 mm reel
W1
D0
P0
A
N
F
W
E
13.0 ±0.25
P2
Label
P1
Direction of unreeling
W2
Leader: min. 400 mm *
Trailer: min. 160 mm *
*) Dimensions acc. to IEC 60286-3; EIA 481-D
OHAY0324
Tape dimensions [mm]
Tape dim ensions in m m
W
P0
P1
P2
D0
E
F
8 + 0.3 / -0.1
4 ± 0.1
2 ± 0.05
or
4 ± 0.1
2 ± 0.05
1.5 ± 0.1
1.75 ± 0.1
3.5 ± 0.05
Reel dimensions [mm]
Reel dim ensions in m m
A
W
Nmin
W1
W2max
180
8
60
8.4 + 2
14.4
Barcode-Product-Label (BPL)
OSRAM Opto
EX
A
RoHS Compliant
(6P) BATCH NO: 1234567890
(1T) LOT NO: 1234567890
BIN1: XX-XX-X-XXX-X
LX XXXX
Semiconductors
MP
ML Temp ST
X XXX °C X
(9D) D/C: 1234
Pack: RXX
LE
DEMY
XXX
X_X123_1234.1234 X
(X) PROD NO: 123456789(Q)QTY:
9999
(G) GROUP:
XX-XX-X-X
OHA04563
2016-09-26
9
Version 1.5
SFH 4651
Dry Packing Process and Materials
Moisture-sensitive label or print
Barcode label
L
VE
el
LE
see
lab
e
If
nk,
bla cod
bar
y
H)
(R
dit
mi
hu
e
ve
ed ag
ati
RH
/60
˚C
rar ck
rel
30
N s VE RS
inf pa
ainITI TO
of
to ak
90
d
ntNSUC
ns
(pe
TIO
or
d
cte
itio
U g coSEND
an bje ing
˚C
nd
5
˚C su ss
CO
Ais baRE
co
ce
y
40 be
TU MI
CThIS
˚C
tor
ll pro
SE
_
urs
urs
Ho
de
urs
Ho
co
72
Ho urs
te
48
e
Ho
24 6
da
e
tim
e
th
tim
or
23
tim e
at t wi nt˚C
or
l wi
fac
Flo
tim
s
at
or
ca
at
re.
Flo
d
tha ale el
or
nth
nti
Flo
uiv
du
if: rea
es
l 4 5
Flo
lab
mo
ide
ce
eq
low
g,
l
ve
vic
5a
is
be
or
de
24
tin en
pro
ve l
6
Le
de ,
e
te
co
g:
un wh
Le ve l
ke
r
se
da
ure
ba ed low ba
Le ve
mo %
ba
e
al
d
ure
Le
ist
en ref e
e 10
tim
se
for
ist ure
ale op se
for >
Mo
se
ure
3
is
or .
is ha
se
Mo istist
nk
be
nk
rd
g
-03
Mo
in
n Flo
r-p
RH g,
bla
Mo
ba
TD
po If blathi
kin Ca
life s
(if
ar
t.
wi
10 ba tor
J-S
thi, va p.
elf
Ye ar ks
_
e icat me , C
1
Ye ee urs
Sh terlow tem ted at
ed
uir
1
W Ho
un
Af
Indno uir DE
1.
d
e
4 8
ref dy
reqy is
2.
JE
bo
e
Mo ore
tim
16
req
C/
e
es dit2b
a)
St
tim
or
mi
IP
ed
or g is
tim e
vic
b)
or
e
Hu
Flo
en
tim
or
De
2a kin nc
te
Flo
a)
op
or
3.
b) baere
Flo
da
e
l 1 2
Flo
If
al
ref
tim ve
l
4.
se
d
l 2a3
ve
Le
g
an
ve l
Le
Ba
te
ure
Le ve
ure
Le
ist
Da
ure
ist
Mo
ist ure
Mo
ist
Mo
Mo
MO
TO
OP
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
AM
OSR
Desiccant
OHA00539
Note:
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card.
Regarding dry pack you will find further information in the internet. Here you will also find the normative
references like JEDEC.
Transportation Packing and Materials
Barcode label
Y
M
DE
18
R
-1
Q
-1
P
P:
OU
GR
01
C:
99
8
D/
21
D)
00
(9
00
(Q
14
2
5
TY
A
21
11
00
R
ic
S
NO
O
12
H
em
H
S
TC
BA
3G
P)
: 12
(6
NO
T
LO
T)
(1
(X
DE
M
R
18
-1
Q
-1
P
RO
UP
G
(G
u L
lt S
iT Y
O T
P 67
L 6
44
M
D/
(9
D)
00
: 20
)Q
TY
C:
01
Y
E Bi
D Bi n1
Bi n2 : Pn3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R0 ditio 0 C R
PA 77 na RT
l TE
CK
VA
XT
R:
Muster
34
NO
PR
O
(X
Packing
Sealing label
Dimensions of transportation box in mm
Width
Length
Height
200 ± 5
195 ± 5
30 ± 5
2016-09-26
M
RA
OS
D
5
14 2
110 0
(Q
O
12
3G
TC
(6
P)
NO
: 12
LO
(1
T)
T
BA
8
H
S S
em R
ic AM
o
n O
d
u p
ct to
o
H
rs
NO
2199
NO
PR
OD
at
2100
34
on M
du O
p
ct to
or
s
44
el
L
)Q
E
V
LE
see
lab
e
H)
nk,
cod
(R
bla
r
If
ty
ba
idi
RH
m
hu
0%
e
/6
ive d
˚C
re ag
lat
ra ck
re
30
_
inf pa
k
s
of
to
90
ea
ur
s
d
ns
(p
or
ur
s
d
Ho
de
cteg
itio
ur s
Ho
an bje
co
˚C
72
sin
nd
Ho ur
5
te
48
˚C su es
e
Ho
co
24 6
da
e
40 be oc
ry
tim
˚C
e
r
th
ll pr
tim
cto
r
oo
23
wi nt
tim e
l wi
fa
r
Fl
oo
tim
s
at
at ale ˚C at
e.
ica
Fl
th
oo r
th
ur
el
nt
Fl oo
on es uiv
if: read
ed
l 4 5
Fl
lab
m
ide
eq
low
l
oc
ve
vic
is
ingen
be
or
de
24
l 5a6
pr
ve
Le
de
nt wh
e
te
co
, w,
g:
ve l
Le
ke
r
re
ou
se
da
ba ed flo
Le ve
tu
re
m %
ba
e
ba
al
d
Le
r
en re
tu
re
e
re 10
ois
tim
se
fo
tu re
ale op se
fo >
M
r
se
ois
3
is
is ha
se
M
ois tu
nk
be
oo .
03
nk
g
rd
M ois
in
r-p
bla
in Fl RH g,
DM
ba
po If blath
kin Ca
life is
(if
ar
ST
p.
wi
10 baator et
Jelf r th va
Ye ar ks s
m
_
m
ed
1
Ye ee ur
d, C
iredic t
Sh te w, te
at
nt
1
W Ho
Af flody
qu In no ire DE
1.
e
4 8
ou
re
ed re ty is
qu JE
2.
bo
e
M
or
tim
16
re C/
e
es idi 2b
r
a)
St
tim
mor
is IP
e
ed
r
oo
tim
vic
b)
g e
r
Hu
Fl
en
oo
tim
De
2a kin nc
te
Fl
oo r
a)
op
3.
b) ba re
Fl oo
da
e
fe
l 1 2
Fl
If
al
re
tim ve
l
4.
se
d
l 2a3
ve
Le
g
an
ve l
Le
re
Ba
te
Le ve
tu
re
Le
tu
Da ois
re
tu re
M
ois
M
ois tu
M ois
M
Nns IVEORS
ai IT
ntNS CT
TIO
DU
U g EcoSE
ON
A ba
IC
UR
M
CThisSTSE
OI
M TO
OP
(G
M
u L
lt S
iT Y
O T67
P
L 6
Muster
E Bi
D Bi n1
Bi n2 : Pn3 : Q- 1: 1- 20
M
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
0 C
R0 dit
ion C R
PA 77 al RT
CK
TE
VA
XT
R:
Barcode label
10
OHA02044
Version 1.5
SFH 4651
Disclaimer
Language english will prevail in case of any discrepancies or deviations between the two language wordings.
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may contain
dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version in the Internet.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office.
By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing
material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any
costs incurred.
Components used in life-support devices or systems must be expressly authorized for such purpose!
Critical components* may only be used in life-support devices** or systems with the express written approval of
OSRAM OS.
*) A critical component is a component used in a life-support device or system whose failure can reasonably be
expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that
device or system.
**) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or
maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be
endangered.
2016-09-26
11
Version 1.5
SFH 4651
Glossary
1)
Thermal resistance: junction -ambient, mounted on PC-board (FR4), padsize 16 mm2 each
2)
Thermal resistance: junction - soldering point, of the device only, mounted on an ideal heatsink (e.g. metal block)
3)
Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or
calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily
correspond to the actual parameters of each single product, which could differ from the typical data and calculated
correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data
will be changed without any further notice.
2016-09-26
12
Version 1.5
SFH 4651
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
2016-09-26
13
