2012-05-23
OSRAM OSTAR Projection Cube
Datasheet
Version 1.0
LCG H9RM
OSRAM OSTAR Projection Cube is a new high flux
LED for slim designs especially for Projection
applications
OSRAM OSTAR Projection Cube ist eine neue, hoch
effiziente Lichtquelle für platzsparende Designs
speziell für Projektionsanwendungen
Features:
• Package: SMD epoxy package
• Technology: ThinGaN (UX:3)
• Color: Cx = 0.318, Cy = 0.642 acc. to CIE 1931
Besondere Merkmale:
• Gehäusetyp: SMD Epoxid Gehäuse
• Technologie: ThinGaN (UX:3)
• Farbe: Cx = 0.318, Cy = 0.642 acc. to CIE 1931
(konvertiertes grün) im Bereich Ȝ = 500 ... 600 nm;
0.32 / 0.54 für den gesamten Spektralbereich
• ESD-Festigkeit: 8 kV nach JESD22-A114-F
(converted green) within Ȝ = 500 ... 600 nm; 0.32 /
0.54 for full spectral range
• ESD-withstand voltage: 8 kV acc. to
JESD22-A114-F
• Viewing angle at 50 % IV: 120°
• Abstrahlwinkel bei 50 % IV: 120°
Applications
Anwendungen
• Projection
• Projektion
2012-05-23
1
Version 1.0
LCG H9RM
Ordering Information
Bestellinformation
Luminous Flux 1) page
Type
Typ
Lichtstrom
1) Seite 22
22
Ordering Code
Bestellnummer
IF = 350 mA
ĭV [lm]
LCG H9RM-KZLZ-1
Note:
97 ... 180
Q65111A1779
The above Type Numbers represent the order groups which include only a few brightness groups (see page 5 for explanation). Only one group will
be shipped on each packing unit (there will be no mixing of two groups on each packing unit). E. g. LCG H9RM-KZLZ-1 means that only one group
KZ, LX, LY, LZ will be shippable for any packing unit. In order to ensure availability, single brightness groups will not be orderable.
In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing
unit. LCG H9RM-KZLZ-1 means that the device will be shipped within the specified limits as stated on page 6 In order to ensure availability, single
color chromaticity groups groups will not be orderable (see page 6 for explanation).
Anm.:
Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5 für
nähere Informationen). Es wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. LCG H9RM-KZLZ-1 bedeutet, dass in einer
Verpackungseinheit nur eine der Helligkeitsgruppen KZ, LX, LY, LZ enhalten ist. Um die Liefersicherheit zu gewährleisten, können einzelne
Helligkeitsgruppen nicht bestellt werden.
Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe
geliefert. Z.B. LCG H9RM-KZLZ-1 bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist (siehe Seite 6 für nähere
Informationen). LCG H9RM-KZLZ-1 bedeutet, dass das Bauteil innerhalb der auf Seite 6 spezifizierten Grenzen geliefert wird. Um die Liefersicherheit
zu gewährleisten, können einzelne Farbortgruppen nicht bestellt werden.
2012-05-23
2
Version 1.0
LCG H9RM
Maximum Ratings
Grenzwerte
Parameter
Symbol Values
Bezeichnung
Symbol Werte
Unit
Einheit
Operating temperature range
Betriebstemperatur
Top
-40 ... 100
°C
Storage temperature range
Lagertemperatur
Tstg
-40 ... 100
°C
Junction temperature
Sperrschichttemperatur
Tj
150
°C
Forward current
Durchlassstrom
(TS = 25 °C)
IF
100 ... 500
mA
Forward current pulsed
Durchlassstrom gepulst
(D = 0.5; f = 120 Hz; TS = 25 °C)
IF pulse
1000
mA
Reverse voltage
Sperrspannung
(TS = 25 °C)
VR
2012-05-23
not designed for reverse operation V
3
Version 1.0
LCG H9RM
Characteristics (TS = 25 °C; IF = 350 mA)
Kennwerte
Parameter
Symbol Values
Bezeichnung
Symbol Werte
Chromaticity coordinates acc. to
CIE 1931 2) page 22
Farbkoordinaten nach CIE 1931 2)
Unit
Einheit
(typ.)
(typ.)
Cx
Cy
0.318
0.642
(typ.)
2ϕ
120
(min.)
(typ.)
(max.)
VF
VF
VF
3.00
3.30
4.00
V
V
V
IR
Seite 22
(within Ȝ = 500 ... 600 nm)
Forward voltage 3) page 22
Durchlassspannung 3) Seite
22
Reverse current
Sperrstrom
Partial Flux acc. CIE 127:2007
Partieller Fluss
(typ.)
ĭE/V, 120°
Radiating surface
Abstrahlende Fläche
(typ.)
Acolor
Real thermal resistance junction /
solder point 4) page 22
Realer Wärmewiderstand
Sperrschicht / Lötpad 4) Seite 22
(typ.)
(max.)
"Electrical" thermal resistance
junction / solder point 4) page 22
"Elektrischer" Wärmewiderstand
(with efficiency Șe = 29 %)
(typ.)
(max.)
2012-05-23
0.77
0.72 x 0.72
mm2
Rth JS real
Rth JS real
K/W
K/W
Rth JS el
Rth JS el
14
18
K/W
K/W
4
Version 1.0
LCG H9RM
Brightness Groups
Helligkeits-Gruppierungsschema
Group
Luminous Intensity 5)
22
22
page 22
Gruppe
Lichtstrom 1) Seite
22
Lichtstrom 1) Seite
22
Lichtstärke 5) Seite
(min.) ĭV [lm]
(max.) ĭV [lm]
(typ.) IV [cd]
KZ
97
112
35
LX
112
130
40
LY
130
150
45
LZ
150
180
55
22
Note:
The standard shipping format for serial types includes either a lower family group, an upper family group or a grouping of all individual brightness
groups of only a few brightness groups. Individual brightness groups cannot be ordered.
Anm.:
Die Standardlieferform von Serientypen beinhaltet entweder eine untere Familiengruppe, eine obere Familiengruppe oder eine Sammelgruppe, die
aus nur wenigen Helligkeitsgruppen bestehen. Einzelne Helligkeitsgruppen sind nicht bestellbar.
Chromaticity coordinate groups 2) page
Farbortgruppen 2) Seite 22
22
0,650
0,90
Cy
Cy
0,80
0,70
0,60
0,50
0,640
0,40
0,30
0,20
0,10
0,00
0,00
2012-05-23
0,10
0,20
0,30
0,40
0,50
0,60
Cx
0,630
0,310
0,70
Coordinates in reference to CIE 1931 (cx cy)
5
0,320
0,330
Cx
Version 1.0
LCG H9RM
Color Chromaticity Groups 2) page
Group
Gruppe
1
Cx
22
Cy
0.3123
0.6378
0.3190
0.6478
0.3223
0.6311
0.3290
0.6411
Group Name on Label
Gruppenbezeichnung auf Etikett
Example: KZ-1
Beispiel: KZ-1
Brightness
Helligkeit
Wavelength
Wellenlänge
KZ
1
Note:
No packing unit / tape ever contains more than one group for each selection.
Anm.:
In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten.
2012-05-23
6
Version 1.0
LCG H9RM
Relative Spectral Emission - V(Ȝ) = Standard eye response curve 5) page 22 , 1) page 22
Relative spektrale Emission - V(Ȝ) = spektrale Augenempfindlichkeit 5) Seite 22 , 1) Seite
22
ĭrel = f (Ȝ); TJ = 25 °C; IF = 350 mA
Φrel
1,0
: Vλ
: converted green
0,9
0,8
0,7
0,6
0,5
0,4
0,3
0,2
0,1
0,0
400
450
Radiation Characteristics 5) page
Abstrahlcharakteristik 5) Seite 22
500
550
600
650
700
750
800
λ [nm]
22
Irel = f (ϕ); TJ = 25 °C
40˚
30˚
20˚
10˚
0˚
ϕ
50˚
OHL01660
1.0
0.8
0.6
60˚
0.4
70˚
0.2
80˚
90˚
100˚
1.0
2012-05-23
0.8
0.6
0.4
0˚
20˚
7
40˚
60˚
80˚
100˚
120˚
Version 1.0
LCG H9RM
Relative partial flux 5) page 22
Relativer zonaler Lichtstromanteil 5) Seite
22
ĭV(2ϕ)/ĭV(180°) = f (ϕ); TJ = 25 °C
ΦV(2ϕ) 1,0
ΦV(180°)
0,9
0,8
0,7
0,6
0,5
0,4
0,3
0,2
0,1
0,0
40
50
60
70
80
90 100 110 120 130 140 150 160 170 180
2*ϕ [°]
Relative cumulated Luminous flux 5) page 22 , 1) page 22
Relativer kummulierter Lichtstrom 5) Seite 22 , 1) Seite 22
Rel. cum. flux Φvrel-cum
ĭVrel - cum = f(Ȝ), TJ = 25 °C, IF = 350 mA
1,0
0,9
0,8
0,7
0,6
0,5
0,4
0,3
0,2
0,1
0,0
2012-05-23
400
450
500
550
600
8
650
700
750
800
λ [nm]
Version 1.0
LCG H9RM
Forward Current 5) page 22
Durchlassstrom 5) Seite 22
Relative Luminous Flux 5) page 22 , 6) page
Relativer Lichtstrom 5) Seite 22 , 6) Seite 22
IF = f (VF); TJ = 25 °C
ĭV/ĭV(350 mA) = f(IF); TJ = 25 °C
IF [mA]
Φv
2.5
Φv(350 mA )
18UI10010004
1000
22
18IB210010004
900
2.0
800
700
1.5
600
500
1.0
400
300
0.5
200
100
2.6
2.8
3.0
3.2
3.4
3.6
0.0
3.8
UF [V]
2012-05-23
200
400
600
800
1000
IF [mA]
9
Version 1.0
LCG H9RM
Chromaticity Coordinate Shift 5) page
Farbortverschiebung 5) Seite 22
22
ǻCx, ǻCy = f(IF); TJ = 25 °C
full spectral range
18IDC10010004
ΔCx 0.03
ΔCy
0.02
0.01
0.01
0.00
0.00
-0.01
-0.01
-0.02
-0.02
200
400
600
800
-0.03
1000
IF [mA]
2012-05-23
18IDC10010004
ΔCx 0.03
ΔCy
: ΔCx
: ΔCy
0.02
-0.03
22
: ΔCx
: ΔCy
200
400
600
800
1000
IF [mA]
10
Version 1.0
LCG H9RM
Relative Forward Voltage 5) page 22
Relative Vorwärtsspannung 5) Seite
Relative Lichtstrom 5) Seite 22
22
ǻVF = VF - VF(25°C) = f(Tj); IF = 350 mA
ΔUF [V]
ĭV/ĭV(25 °C) = f(Tj); IF = 350 mA
ΦV
ΦV (25°C)
18UT-40120
0.3
22
1,0
0.2
0,8
0.1
0,6
0.0
0,4
-0.1
-0.2
-0.3
-40 -20
0,2
-40 -20
20 40 60 80 100 120
Tj [°C]
2012-05-23
60
80 100 120
Tj [°C]
11
Version 1.0
LCG H9RM
22
ǻCx, ǻCy = f(Tj); IF = 350 mA
full spectral range
0,03
ΔCx; ΔCy
ΔCx 0.03
ΔCy
: Cx
: Cy
0,02
0.02
0,01
0.01
0,00
0.00
-0,01
-0.01
-0,02
-0.02
-0,03
-40 -20
60
80
LCG H9RM
: Δ Cx
: Δ Cy
-0.03
-40 -20 0 20 40 60 80 100 120
100 120
Tj [°C]
Tj [°C]
2012-05-23
22
12
Version 1.0
LCG H9RM
Max. Permissible Forward Current 7) page 22
Maximal zulässiger Durchlassstrom 7) Seite 22
IF = f (T)
IF [mA]
500
400
300
200
100
60
80
100 120
TS [°C]
13
Version 1.0
LCG H9RM
Package Outline 8) page 22
Maßzeichnung 8) Seite 22
Note
For dimension „A“ please refer to page 4
Anm.
Die Angabe des Maßes „A“ bezieht sich auf die
Angabe auf Seite 4.
Approximate Weight:
22 mg
Gewicht:
22 mg
ESD information:
LED is protected by ESD device which is connected
in parallel to LED-Chip.
ESD Information:
Die LED enthält ein ESD-Bauteil, das parallel zum
Chip geschalten ist.
2012-05-23
14
Version 1.0
LCG H9RM
Recommended Solder Pad 8) page 22
Empfohlenes Lötpaddesign 8) Seite 22
2012-05-23
Reflow soldering
Reflow-Löten
15
Version 1.0
LCG H9RM
Reflow Soldering Profile
Reflow Lötprofil
Preconditioning: JEDEC Level 2 acc. to J-STD-020D.01
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
tL
150
tS
100
50
25 ˚C
150
200
250
s 300
t
OHA04612
Profil-Charakteristik
Profile Feature
Symbol
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Ramp-up Rate to Preheat*)
25 °C to 150 °C
tS
Time tS
TSmin to TSmax
60
Ramp-up Rate to Peak*
TSmax to TP
Recommendation
Maximum
2
3
100
120
2
3
Einheit
Unit
K/s
s
K/s
Liquidus Temperature
TL
217
Time above Liquidus temperature
tL
80
100
s
Peak Temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
s
3
6
K/s
10
Ramp-down Rate*
TP to 100 °C
480
Time
25 °C to TP
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
2012-05-23
°C
16
s
Version 1.0
Method of Taping 8) page
Gurtung 8) Seite 22
2012-05-23
LCG H9RM
22
17
Version 1.0
LCG H9RM
Tape and Reel
Gurtverpackung
8 mm tape with 2000 pcs. on ∅ 180 mm reel
W1
D0
P0
A
N
F
W
E
13.0 ±0.25
P2
Label
P1
Direction of unreeling
W2
Gurtvorlauf: 400 mm
400 mm
Leader:
Gurtende:
Trailer:
160 mm
160 mm
OHAY0324
Tape dimensions in mm (inch)
W
P0
P1
P2
D0
E
F
8 +0.3/-0.1
4 ± 0.1
(0.157 ±
0.004)
2 ± 0.05
(0.079 ±
0.002)
or
4 ± 0.1
(0.157 ±
0.004)
2 ± 0.05
(0.079 ±
0.002)
1.5 ± 0.1
(0.059 +
0.004)
1.75 ± 0.1
(0.069 ±
0.004)
3.5 ± 0.05
(0.217 ±
0.002)
Reel dimensions in mm (inch)
A
W
Nmin
W1
W2max
180 (7)
8 (0.315)
60 (2.362)
8.4 + 2 (0.331 +
0.079)
14.4 (0.567)
2012-05-23
18
Version 1.0
LCG H9RM
Barcode-Product-Label (BPL)
Barcode-Produkt-Etikett (BPL)
OSRAM Opto
BIN1: XX-XX-X-XXX-X
LX XXXX
Semiconductors
RoHS Compliant
(6P) BATCH NO: 1234567890
ML Temp ST
2 260 °C R
(1T) LOT NO: 1234567890
(9D) D/C: 1234
Pack: R18
DEMY
022
B_R999_1880.1642 R
(X) PROD NO: 123456789(Q)QTY:
9999
(G) GROUP:
XX-XX-X-X
OHA04563
Dry Packing Process and Materials
Trockenverpackung und Materialien
Moisture-sensitive label or print
L
VE
LE
l
k,
If
see
labe
code
blan
bar
(RH
idity
hum
0%
e
tive
˚C/6
red
kag
S
rela
30
s
pac
_
infra
IVE
of
TOR
rs
tain
90% to ak
SIT
rs
ns
ed (pe
UC
e).
or
rs
con
Hou
SEN
rs
Hou
ND
and ject
ditio
cod
˚C,
72
sing
Hou
e
5
bag E
48
˚C sub
Hou
con
s UR ICO
ces
24 6
dat
40 be
time
˚C
ory
ThiISTSEM
pro
or r time
23
will
time
at
l with
fact
ent˚C).
MO
Flo
time
TO
at
at
Floo or r
l
ths that
tica
d
ival
ure
OP
Flo
4
if: rea
w
Floo
labe
mon
iden
5
ced
equ
el
ices
e
ng, n
5a
is
el
belo
or
24
pro
6
Lev
e
dev
el
cod
e
, w,
untiwhe
Lev
el
re
see
e
bag
Lev
l dat
mo
bak
bar
ned
e
Lev
reflo
istu
re> 10%
led
stur
time
sea
for
ope e
Mo
r
see
stur re
k,
is
sea is has k,
Moi
befo
istu
d
033
Moi
in
Floo
RH
blan
Mo
or-p blan in
bag
Car
ing,
r
TD(if
life
r
If with
r
lf
10%bak
J-S
thisvapp.
Yea
_
eks rs
r w,
met
cato
1
Yea
tem
d,
She
nted at
uire not
y
1
WeHou
DEC
Afte
Indi
4
uire
reflo
is
bod Mou red req
/JE
time
168
req
2b
r
a)
Sto ices idity
time
is IPC
r
or
time
b)
ned Floo
r
Hum ing ce
time
Dev 2a
e
Floo
a)
ope
or
3.
b) bakren
Floo
1
l dat
Flo
If
2
refe
time el
4.
2a
el
sea
3
Lev
el
and
Lev
el
re
Bag
e
e
Lev
Lev
istu
Dat
stur rere
Mo
Moi istu
istu
Mo
Mo
C
1.
RH
A
TI
U
Barcode label
N
O
O
S
R
A
M
2.
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
AM
Desiccant
OSR
OHA00539
Note:
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card.
Regarding dry pack you will find further information in the internet and in the Short Form Catalog in
chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references
like JEDEC.
Anm.:
Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem
Trockenmittel und einer Feuchteindikatorkarte.
Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form
Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind
Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten.
2012-05-23
19
Version 1.0
LCG H9RM
Transportation Packing and Materials
Kartonverpackung und Materialien
Barcode label
DE
MY
Q-
1
R1
8
lti LS
TO Y
T6
PL 76
1+
POU
GR
(G)
44
Mu
23
4
H1
TC
3G
BA
: 12
(6P
T
LO
(1T
5
14 2
110 0
(X)
PR
OD
NO
Y:
(9D
D/C
: 01
998
021
210
O
Se SR
mi AM
co
nd O
uc pt
to o
H
rs
NO
NO
see
labe
l
k,
N
O
TI
U
A
C
(Q)
QT
L
VE
LE
code (RH
blan
If
y
bar
idit
RH
hum
60%
e
tive d
˚C/
kag
rela are
30
E S
s
_
infr pac
OR
of
tainITIV
90% to ak
urs
CT
e).
or
urs
ted (pe
ons
con NS
Ho
g
urs
SE DU
Ho
and jec
diti
cod
˚C,
72
sin
Ho urs
e
5
bag E ON
48
˚C sub
e
Ho
con
s UR
ces
24 6
dat
MIC
40 be
tim e e
˚C
ThiISTSE
pro
tory
tim
or
t
with
23
tim e
at t will ˚C)
or
fac
MO
Flo
al
len
tim
TO
s
at
or
at
Flo
d
or
iva
ure
el
nth s tha
OP
ntic
Flo
4
if: rea
Flo
lab
ow
mo ice equ
ide
5
ced
el
e
5a
is
el
ingen
bel
or
24
pro
6
Lev
e
dev,
el
cod
e
unt wh
Lev
el
re
ow
see
bag
Lev
l dat
re
mo
bak
e
bar
ned
Lev
refl
istu
10%
re
led
tim
sea
for
istu
ore>
re
ope e
Mo
see
3
istu
is
or .
sea is has
Mo
nk,
bef
istu
nk, Flo
rd
-03
Mo
RH
bla
in
Mo
or-p bla
bag
ingCa
r
TD
life
(if
If with
t.
r
vapp.
10%baktor
J-S
elf r this
Yea
_
eks
ed
ica med, C
1
urs
Yea
tem
Sh
ow
at
uire not
y
1
WeHo
unt
DE
Afte
Ind
1.
e
4
uire
refl
red req
2.
bod Mo
e
ity is
/JE
tim
s
168
req
e
2b
a)
Sto
tim
or
mid
is IPC
tim e
vice or
b)
or
ned Flo
Hu
tim
ing ce
or
De
e
2a
Flo
a)
ope
or
3.
b) bakren
Flo
e
1
l dat
Flo
If
2
el
refe
tim
2a
4.
el
sea
3
Lev
g
el
and
Lev
el
re
Ba
te
Lev
re
Lev
istu
Da
re
istu
re
Mo
Mo istu
istu
Mo
Mo
P:
Muster
ED Bin
Bin 1:
Bin 2: P-1
3: Q-1 -20
ML
-20
2
Tem
2a
220
3
240 p ST
Ad 260 C R
C
R0 diti
R
ona C RT
PA 77
l TE
CK
VA
XT
R:
Barcode label
MY
DE
8
P-
1+
Q-
1
R1
Mu
lti LS
TO Y T6
PL 76
99
8
D/C
: 01
O
SR
AM
21
00
(9D
00
21
4
(Q)
O
TC
H
3G
H1
BA
(6P
5
(X)
PR
OD
NO
(1T
11
00
LO
T
14
2
NO
: 12
QT
Y:
Se SR
m A
ico M
nd O
uc pt
to o
rs
NO
44
(G)
GR
OU
P:
Muster
ED Bin
Bin 1:
Bin 2: P-1
3: Q-1 -20
ML
-20
2
Te
2a
220 mp
3
240
ST
Ad 260 C R
C
R0 diti
R
ona C RT
PA 77
l TE
CK
VA
XT
R:
in
Packing
Sealing label
OHA02044
Dimensions of transportation box in mm (inch)
Width / Breite
Length / Länge
Height / Höhe
200 ±5 (7,874 ±0,196)
195 ±5 (7,677 ±0,1968)
30 ±5 (1,181 ±0,196)
Notes
Hinweise
The evaluation of eye safety occurs according to the
standard IEC 62471:2006 ("photobiological safety
of lamps and lamp systems"). Within the risk
grouping system of this CIE standard, the LED
specified in this data sheet fall into the class Low
risk (exposure time 100 s). Under real
circumstances (for exposure time, eye pupils,
observation distance), it is assumed that no
endangerment to the eye exists from these devices.
As a matter of principle, however, it should be
mentioned that intense light sources have a high
secondary exposure potential due to their blinding
effect. As is also true when viewing other bright light
sources (e.g. headlights), temporary reduction in
visual acuity and afterimages can occur, leading to
irritation, annoyance, visual impairment, and even
accidents, depending on the situation.
Die Bewertung der Augensicherheit erfolgt nach
dem Standard IEC 62471:2006 ("photobiological
safety of lamps and lamp systems"). Im
Risikogruppensystem dieser CIE- Norm erfüllen die
in diesem Datenblatt angegebenen LEDs folgende
Gruppenanforderung - Low risk (Expositionsdauer
100s). Unter realen Umständen (für
Expositionsdauer, Augenpupille,
Betrachtungsabstand) geht damit von diesen
Bauelementen keinerlei Augengefährdung aus.
Grundsätzlich sollte jedoch erwähnt werden, dass
intensive Lichtquellen durch ihre Blendwirkung ein
hohes sekundäres Gefahrenpotenzial besitzen.
Nach einem Blick in eine helle Lichtquelle (z.B.
Autoscheinwerfer), kann ein temporär
eingeschränktes Sehvermögen oder auch
Nachbilder zu Irritationen, Belästigungen,
Beeinträchtigungen oder sogar Unfällen führen.
2012-05-23
Version 1.0
LCG H9RM
Disclaimer
Disclaimer
Attention please!
The information describes the type of component and
shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved.
Due to technical requirements components may contain
dangerous substances.
For information on the types in question please contact
our Sales Organization.
If printed or downloaded, please find the latest version
in the Internet.
Packing
Please use the recycling operators known to you. We
can also help you – get in touch with your nearest sales
office.
By agreement we will take packing material back, if it is
sorted. You must bear the costs of transport. For
packing material that is returned to us unsorted or which
we are not obliged to accept, we shall have to invoice
you for any costs incurred.
Components used in life-support devices or
systems must be expressly authorized for such
purpose!
Critical components* may only be used in life-support
devices** or systems with the express written approval
of OSRAM OS.
Bitte beachten!
Lieferbedingungen und Änderungen im Design
vorbehalten. Aufgrund technischer Anforderungen
können die Bauteile Gefahrstoffe enthalten. Für weitere
Informationen zu gewünschten Bauteilen, wenden Sie
sich bitte an unseren Vertrieb.Falls Sie diese Datenblatt
ausgedruckt oder heruntergeladen haben, finden Sie
die aktuellste Version im Internet.
Verpackung
Benutzen
Sie
bitte
die
Ihnen
bekannten
Recyclingwege. Wenn diese nicht bekannt sein sollten,
wenden Sie sich bitte an das nächstgelegene
Vertriebsbüro. Wir nehmen das Verpackungsmaterial
zurück, falls dies vereinbart wurde und das Material
sortiert ist. Sie tragen die Transportkosten. Für
Verpackungsmaterial,
das
unsortiert
an
uns
zurückgeschickt wird oder das wir nicht annehmen
müssen, stellen wir Ihnen die anfallenden Kosten in
Rechnung.
Bauteile, die in lebenserhaltenden Apparaten und
Systemen eingesetzt werden, müssen für diese
Zwecke ausdrücklich zugelassen sein!
Kritische Bauteile* dürfen in lebenserhaltenden
Apparaten und Systemen nur dann eingesetzt werden,
wenn ein schriftliches Einverständnis von OSRAM OS
vorliegt.
*) A critical component is a component used in a
life-support device or system whose failure can
reasonably be expected to cause the failure of that
life-support device or system, or to affect its safety or
the effectiveness of that device or system.
**) Life support devices or systems are intended(a) to
be implanted in the human body,or(b) to support and/or
maintain and sustain human life.If they fail, it is
reasonable to assume that the health and the life of the
user may be endangered.
2012-05-23
*) Ein kritisches Bauteil ist ein Bauteil, das in
lebenserhaltenden
Apparaten
oder
Systemen
eingesetzt wird und dessen Defekt voraussichtlich zu
einer Fehlfunktion dieses lebenserhaltenden Apparates
oder Systems führen wird oder die Sicherheit oder
Effektivität
dieses
Apparates
oder
Systems
beeinträchtigt.
**) Lebenserhaltende Apparate oder Systeme sind für
(a) die Implantierung in den menschlichen Körper oder
(b) für die Lebenserhaltung bestimmt. Falls Sie
versagen, kann davon ausgegangen werden, dass die
Gesundheit und das Leben des Patienten in Gefahr ist.
21
Version 1.0
LCG H9RM
Glossary
Glossar
1)
1)
Brightness: Brightness values are measured
during a current pulse of typical 25 ms, with an
internal reproducibility of +/- 8 % and an expanded
uncertainty of +/- 11 % (acc. to GUM with a coverage
factor of k = 3).
2)
Strompulses einer typischen Dauer von 25 ms, mit
einer internen Reproduzierbarkeit von +/- 8 % und
einer erweiterten Messunsicherheit von +/- 11 %
gemessen (gemäß GUM mit Erweiterungsfaktor k =
3).
2)
Chromaticity coordinate groups:
Chromaticity coordinates are measured during a
current pulse of typical 25 ms, with an internal
reproducibility of +/- 0,005 and an expanded
uncertainty of +/- 0,01 (acc. to GUM with a coverage
factor of k = 3).
3)
4)
Farbortgruppen:
Farbkoordinaten
werden
während
eines
einer internen Reproduzierbarkeit von +/- 0,005 und
einer erweiterten Messunsicherheit von +/- 0,01
3).
forward voltage is
measured during a current pulse of typical 8 ms, with
an internal reproducibility of +/- 0,05 V and an
expanded uncertainty of +/- 0,1 V (acc. to GUM with
a coverage factor of k=3).
3)
Thermal Resistance: Rth max based on statistic
4)
Forward Voltage: The
Durchlassspannung: Vorwärtsspannungen
werden während eines Strompulses einer typischen
Dauer
von
8
ms,
mit
einer
internen
Reproduzierbarkeit von +/- 0,05 V und einer
erweiterten Messunsicherheit von +/- 0,1 V
k=3).
values (6ó)
5)
Helligkeit: Helligkeitswerte werden während eines
Wärmewiderstand: Rth
max
Typical Values: Due to the special conditions of
5)
Typische Werte: Wegen
the manufacturing processes of LED, the typical
data or calculated correlations of technical
parameters can only reflect statistical figures. These
do not necessarily correspond to the actual
parameters of each single product, which could
differ from the typical data and calculated
correlations or the typical characteristic line. If
requested, e.g. because of technical improvements,
these typ. data will be changed without any further
notice.
auf
der
besonderen
Prozessbedingungen bei der Herstellung von LED
können typische oder abgeleitete technische
Parameter nur aufgrund statistischer Werte
wiedergegeben werden. Diese stimmen nicht
notwendigerweise mit den Werten jedes einzelnen
Produktes überein, dessen Werte sich von
typischen und abgeleiteten Werten oder typischen
Kennlinien unterscheiden können. Falls erforderlich,
z.B. aufgrund technischer Verbesserungen, werden
diese typischen Werte ohne weitere Ankündigung
geändert.
6)
Relative Brightness Curve: In
the
range
where the line of the graph is broken, you must
expect higher brightness differences between single
LEDs within one packing unit.
6)
Relative Helligkeitskurve: Im
7)
Thermal Resistance: RthJA
results
from
mounting on PC board FR 4 (pad size 16mm2 per
pad)
7)
Wärmewiderstand: RthJA
8)
Tolerance of Measure: Dimensions
8)
Maßtoleranz: Maße
are
specified as follows: mm (inch).
2012-05-23
basiert
statistischen Werten (6ó)
gestrichelten
Bereich der Kennlinien muss mit erhöhten
Helligkeitsunterschieden zwischen Leuchtdioden
innerhalb einer Verpackungseinheit gerechnet
werden.
ergibt sich bei
Montage auf PC-Board FR 4 (Padgröße 16mm2 je
pad)
angegeben: mm (inch).
22
werden
wie
folgt
Version 1.0
LCG H9RM
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
2012-05-23
23
