BT158W-1200T
SCR
20 April 2017
Product data sheet
1. General description
Planar passivated Silicon Controlled Rectifier in a SOT429N (TO247) plastic package intended
for use in applications requiring very high inrush current capability and high thermal cycling
performance.
2. Features and benefits
High thermal cycling performance
Planar passivated for voltage ruggedness and reliability
High voltage capacity
Very high current surge capability
3. Applications
Line rectifying 50/60 Hz
Softstart AC motor control
DC Motor control
Power converter
AC power control
Lighting and temperature control
Uninterruptible Power Supply (UPS)
Solid State Relay (SSR)
Traction battery charging
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
VDRM
Conditions
Min
Typ
Max
Unit
repetitive peak offstate voltage
1200
V
VRRM
repetitive peak reverse
voltage
1200
V
ITSM
non-repetitive peak on- half sine wave; Tj(init) = 25 °C;
state current
tp = 10 ms; Fig. 4; Fig. 5
1100
A
tp = 8.3 ms
1210
A
150
°C
Tj
junction temperature
IT(AV)
average on-state
current
half sine wave; Tmb ≤ 117 °C
80
A
IT(RMS)
RMS on-state current
half sine wave; Tmb ≤ 117 °C; Fig. 1;
Fig. 2; Fig. 3
126
A
BT158W-1200T
WeEn Semiconductors
SCR
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VD = 12 V; IT = 0.1 A; Tj = 25 °C; Fig. 7;
Fig. 8
70
mA
VDM = 800 V; Tj = 125 °C; RGK = 100 Ω;
(VDM = 67% of VDRM); exponential
waveform
1500
V/µs
Static characteristics
IGT
gate trigger current
Dynamic characteristics
dVD/dt
rate of rise of off-state
voltage
5. Pinning information
Table 2. Pinning information
Pin
Symbol Description
1
K
Simplified outline
Graphic symbol
cathode
A
K
G
2
A
anode
3
G
gate
mb
A
mounting base; connected to
anode
sym037
1
2
3
TO-247 (SOT429N)
6. Ordering information
Table 3. Ordering information
Type number
BT158W-1200T
BT158W-1200T
Product data sheet
Package
Name
Description
Version
TO-247
Plastic single-ended through-hole package; heatsink mounted; 1 SOT429N
mounting hole; 3-lead TO-247
All information provided in this document is subject to legal disclaimers.
20 April 2017
WeEn Semiconductors Co., Ltd. 2017. All rights reserved
2 / 13
BT158W-1200T
WeEn Semiconductors
SCR
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VDRM
Min
Max
Unit
repetitive peak off-state
voltage
1200
V
VRRM
voltage
1200
V
IT(AV)
average on-state current half sine wave; Tmb ≤ 117 °C
80
A
IT(RMS)
Fig. 2; Fig. 3
126
A
ITSM
non-repetitive peak onstate current
half sine wave; Tj(init) = 25 °C; tp = 10 ms;
Fig. 4; Fig. 5
1100
A
half sine wave; Tj(init) = 25 °C; tp = 8.3 ms
1210
A
2
Conditions
2
I t
I t for fusing
tp = 10 ms; sine-wave pulse;
Tj(init) = 25 °C; no voltage reapplied
6115
A²s
dIT/dt
rate of rise of on-state
current
IG = 200 mA
150
A/µs
IGM
peak gate current
8
A
VRGM
peak reverse gate
voltage
5
V
PGM
peak gate power
W
PG(AV)
average gate power
1
W
Tstg
storage temperature
-40
150
°C
Tj
150
°C
over any 20 ms period
aaf122-001
160
IT(RMS)
(A)
140
aaf122-002
200
IT(RMS)
(A)
180
117°C
120
160
100
80
140
60
120
40
100
100
80
10-2
150
Tmb (°C)
Fig. 1. RMS on-state current as a function of mounting
base temperature; maximum values
BT158W-1200T
Product data sheet
10-1
1
10
surge duration (s)
f = 50 Hz; Tmb = 117 °C
Fig. 2. RMS on-state current as a function of surge
duration; maximum values
20 April 2017
3 / 13
BT158W-1200T
WeEn Semiconductors
SCR
aaf122-003
160
Ptot
(W)
2.8
1.9
2.2
120
4
80
130
conduction form
angle
factor
(degrees)
α
30
60
90
120
180
40
Tmb(max)
(°C)
a = 1.57
120
110
60
4
2.8
2.2
1.9
1.57
140
α
80
150
100
IT(AV) (A)
α = conduction angle
a = form factor = IT(RMS) / IT(AV)
Fig. 3. Total power dissipation as a function of average on-state current; maximum values
aaf122-004
1200
ITSM
(A)
1000
IT
ITSM
t
tp
Tj(init) = 25 °C max
800
600
400
200
102
10
number of cycles (n)
103
f = 50 Hz
Fig. 4. Non-repetitive peak on-state current as a function of the number of sinusoidal current cycles; maximum
values
BT158W-1200T
Product data sheet
20 April 2017
4 / 13
BT158W-1200T
WeEn Semiconductors
SCR
aaf122-005
104
ITSM
(A)
(1)
103
IT
ITSM
t
102
10-5
tp
10-4
10-3
tp (s)
10-2
tp ≤ 10 ms
(1) dIT/dt limit
Fig. 5. Non-repetitive peak on-state current as a function of pulse width; maximum values
BT158W-1200T
Product data sheet
20 April 2017
5 / 13
BT158W-1200T
WeEn Semiconductors
SCR
8. Thermal characteristics
Table 5. Thermal characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance
from junction to
mounting base
full cycle; Fig. 6
0.25
K/W
Rth(j-a)
thermal resistance
from junction to
ambient free air
in free air
50
K/W
aaf122-006
1
Zth(j-mb)
(K/W)
10-1
10-2
P
δ=
10-3
tp
10-4
10-6
10-5
10-4
10-3
10-2
10-1
tp
T
t
T
1
tp (s)
10
Fig. 6. Transient thermal impedance from junction to mounting base as a function of pulse duration
BT158W-1200T
Product data sheet
20 April 2017
6 / 13
BT158W-1200T
WeEn Semiconductors
SCR
9. Characteristics
Table 6. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
IGT
Fig. 8
70
mA
IL
latching current
VD = 12 V; IG = 0.1 A; Tj = 25 °C; Fig. 9
300
mA
IH
holding current
VD = 12 V; Tj = 25 °C; Fig. 10
200
mA
VT
on-state voltage
IT = 80 A; Tj = 25 °C; Fig. 11
1.35
V
IT = 160 A; Tj = 25 °C; Fig. 11
1.65
V
Fig. 12
0.7
1
V
VD = 800 V; IT = 0.1 A; Tj = 125 °C;
Fig. 12
0.25
0.4
V
VGT
gate trigger voltage
ID
off-state current
VD = 1200 V; Tj = 125 °C
3
mA
IR
reverse current
VR = 1200 V; Tj = 125 °C
3
mA
waveform
1500
V/µs
VDM = 800 V; Tj = 150 °C; RGK = 100 Ω;
waveform
1000
V/µs
dVD/dt
voltage
tgt
gate-controlled turn-on ITM = 40 A; VD = 800 V; IG = 0.1 A; dIG/
time
dt = 5 A/µs; Tj = 25 °C
2
µs
tq
commutated turn-off
time
150
µs
BT158W-1200T
Product data sheet
VDM = 804 V; Tj = 125 °C; ITM = 20 A;
VR = 25 V; (dIT/dt)M = 30 A/µs; dVD/
dt = 50 V/µs; RGK(ext) = 100 kΩ; (VDM =
67% of VDRM)
20 April 2017
7 / 13
BT158W-1200T
WeEn Semiconductors
SCR
aaf122-007
3
10
IGT
IGT(25°C)
VG
(V)
aaf122-008
a: Tj = 150°C
b: Tj = 125°C
c: Tj = 25°C
d: Tj = -40°C
2
c
b
1
d
(1)
a
1
(1):
(2):
(3):
(4):
100
Tj (°C)
0.1
0.001
150
Fig. 7. Normalized gate trigger current as a function of
0.1
1
IG (A)
(3)
(4)
PGM = 10W, tp = 5ms
PGM = 20W, tp = 2.5ms
PGM = 50W, tp = 1ms
PGM = 100W, tp = 500us
10
100
1000
Fig. 8. Gate voltage as a function of gate current
aaf122-009
3
0.01
(2)
aaf122-010
3
IH
IL
IH(25°C)
IL(25°C)
2
2
1
1
100
Tj (°C)
Fig. 9. Normalized latching current as a function of
BT158W-1200T
Product data sheet
150
100
Tj (°C)
150
Fig. 10. Normalized holding current as a function of
20 April 2017
8 / 13
BT158W-1200T
WeEn Semiconductors
SCR
aaf122-011
160
IT
(A)
aaf122-012
1.6
VGT
VGT(25°C)
120
1.2
80
(1)
(2)
(3)
0.8
40
VT (V)
Vo = 0.984 V; Rs = 0.0033 Ω
(1) Tj = 150 °C; typical values
(2) Tj = 150 °C; maximum values
(3) Tj = 25 °C; maximum values
0.4
-50
2
100
Tj (°C)
150
Fig. 12. Normalized gate trigger voltage as a function of
Fig. 11. On-state current as a function of on-state
voltage
BT158W-1200T
Product data sheet
20 April 2017
9 / 13
BT158W-1200T
WeEn Semiconductors
SCR
10. Package outline
Fig. 13. Package outline TO-247 (SOT429N)
BT158W-1200T
Product data sheet
20 April 2017
10 / 13
BT158W-1200T
WeEn Semiconductors
SCR
Right to make changes — WeEn Semiconductors reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
11. Legal information
Suitability for use — WeEn Semiconductors products are not designed,
authorized or warranted to be suitable for use in life support, life-critical
or safety-critical systems or equipment, nor in applications where failure
or malfunction of an WeEn Semiconductors product can reasonably
be expected to result in personal injury, death or severe property or
environmental damage. WeEn Semiconductors and its suppliers accept no
liability for inclusion and/or use of WeEn Semiconductors products in such
equipment or applications and therefore such inclusion and/or use is at the
customer’s own risk.
Data sheet status
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. WeEn Semiconductors makes
no representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.ween-semi.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. WeEn Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local WeEn
Semiconductors sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
WeEn Semiconductors and its customer, unless WeEn Semiconductors and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the WeEn Semiconductors product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, WeEn Semiconductors does not
give any representations or warranties, expressed or implied, as to the
accuracy or completeness of such information and shall have no liability for
the consequences of use of such information. WeEn Semiconductors takes
no responsibility for the content in this document if provided by an information
source outside of WeEn Semiconductors.
In no event shall WeEn Semiconductors be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, WeEn Semiconductors’ aggregate and cumulative liability
towards customer for the products described herein shall be limited in
accordance with the Terms and conditions of commercial sale of WeEn
Semiconductors.
BT158W-1200T
Product data sheet
Customers are responsible for the design and operation of their applications
and products using WeEn Semiconductors products, and WeEn
Semiconductors accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the WeEn Semiconductors product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
WeEn Semiconductors does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using WeEn
Semiconductors products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). WeEn does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific WeEn Semiconductors product is automotive
qualified, the product is not suitable for automotive use. It is neither qualified
nor tested in accordance with automotive testing or application requirements.
WeEn Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without WeEn Semiconductors’ warranty
of the product for such automotive applications, use and specifications, and
(b) whenever customer uses the product for automotive applications beyond
WeEn Semiconductors’ specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies WeEn Semiconductors for
any liability, damages or failed product claims resulting from customer
design and use of the product for automotive applications beyond WeEn
Semiconductors’ standard warranty and WeEn Semiconductors’ product
specifications.
20 April 2017
11 / 13
BT158W-1200T
WeEn Semiconductors
SCR
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
BT158W-1200T
Product data sheet
20 April 2017
12 / 13
BT158W-1200T
WeEn Semiconductors
SCR
12. Contents
1. General description......................................................1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Limiting values............................................................. 3
8. Thermal characteristics............................................... 6
9. Characteristics..............................................................7
10. Package outline........................................................ 10
11. Legal information..................................................... 11
For more information, please visit: http://www.ween-semi.com
For sales office addresses, please send an email to: salesaddresses@ween-semi.com
Date of release: 20 April 2017
BT158W-1200T
Product data sheet
20 April 2017
13 / 13
