V15
EC2SBW SERIES
10 WATT 4:1 INPUT
DC-DC CONVERTERS
FEATURES
* 10W Isolated Output
* 1”×1”×0.4” Shielded Metal Case
* Efficiency to 86%
* 4:1 Input Range
* Regulated Outputs
* Input Under Voltage Protection
* Remote On/Off
* Continuous Short Circuit Protection
* Without Tantalum Capacitors Inside
* Safety Meets IEC/EN/UL 62368-1
MODEL
INPUT
OUTPUT
NUMBER
VOLTAGE
VOLTAGE
OUTPUT
INPUT
CURRENT
CURRENT
MIN.
MAX.
3.3 VDC
0 mA
2500 mA
EC2SBW-24S33
9-36 VDC
EC2SBW-24S05
9-36 VDC
5 VDC
0 mA
EC2SBW-24S12
9-36 VDC
12 VDC
0 mA
EC2SBW-24S15
9-36 VDC
15 VDC
EC2SBW-24D05
9-36 VDC
EC2SBW-24D12
NO LOAD
% CAPACITOR
EFF. LOAD MAX.
FULL LOAD
5 mA
425 mA
81
3300uF
2000 mA
5 mA
496 mA
84
2200uF
835 mA
10 mA
486 mA
86
1000uF
0 mA
666 mA
10 mA
486 mA
86
680uF
± 5 VDC
0 mA
±1000 mA
10 mA
496 mA
84
1200uF
9-36 VDC
± 12 VDC
0 mA
±416 mA
10 mA
486 mA
86
470uF
EC2SBW-24D15
9-36 VDC
± 15 VDC
0 mA
±333 mA
10 mA
486 mA
86
330uF
EC2SBW-48S33
18-75 VDC
3.3 VDC
0 mA
2500 mA
5 mA
210 mA
82
3300uF
EC2SBW-48S05
18-75 VDC
5 VDC
0 mA
2000 mA
5 mA
248 mA
84
2200uF
EC2SBW-48S12
18-75 VDC
12 VDC
0 mA
835 mA
5 mA
243 mA
86
1000uF
EC2SBW-48S15
18-75 VDC
15 VDC
0 mA
666 mA
5 mA
243 mA
86
680uF
EC2SBW-48D05
18-75 VDC
± 5 VDC
0 mA
±1000 mA
5 mA
248 mA
84
1200uF
EC2SBW-48D12
18-75 VDC
± 12 VDC
0 mA
±416 mA
8 mA
243 mA
86
470uF
EC2SBW-48D15
18-75 VDC
± 15 VDC
0 mA
±333 mA
8 mA
243 mA
86
330uF
NOTE: 1. Nominal Input Voltage 24 or 48 VDC
1
V15
SPECIFICATIONS
All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
GENERAL SPECIFICATIONS:
Input Voltage Range ....……………..................…. 24V ....................... 9 – 36V
48V ….…..….... 18 – 75V
Input Surge Voltage (100ms max.) ……….……24V ……...... 50Vdc max.
48V .............. 100Vdc max.
Efficiency ...........................................………..………............ See Table
Isolation Voltage .................................……..………......... 1500 VDC min.
Isolation Resistance .....................…….……………..……… 109 ohm min.
Isolation Capacitance …………………..……………….…… 1000pF typ.
Switching Frequency ............................……...................... 100KHz min.
Under Voltage Lockout ………..….. 24Vin power up ….…...………. 8.8V typ.
24Vin power down …..…....…. 8.0V typ.
48Vin power up …………...….. 17V typ.
48Vin power down .……..……. 16V typ.
Input Filter ………………………………..……….……………. LC Type
Positive Logic Remote on/off Control (note3):
Logic Compatibility ……… CMOS or Open Collector TTL, Ref. to -Vin
Module On …………………………. >+3.5V to 36VDC or Open Circuit
Module Off ……………………………….……………. 0 to
很抱歉,暂时无法提供与“EC2SBW-24S15”相匹配的价格&库存,您可以联系我们找货
