DATA SHEET
CARBON FILM RESISTORS
Professional, Flameproof
FC0 Series
±2%, ±5%
0.4W AND 0.6W
Product specification – September 27, 2023 V.1
RoHS compliant & Halogen Free
Through Hole Resistors
Carbon Film Resistors
Product Specification
ORDERING INFORMATION
Part number of the professional, flameproof carbon film resistor are
identified by the series, power rating, tolerance, packing, temperature
coefficient, forming and resistance value.
PART NUMBER
FC0
204
J
T
(1)
(2)
(3)
(4)
(5)
52-
100R
(6)
(7)
APPLICATIONS
All general purpose
applications
(1) SERIES
FC0 Series
Power applications
(2) POWER RATING
204 = 0.4W
207 = 0.6W
(3) TOLERANCE
FEATURES
G = ±2%
J = ±5%
Wide resistance range
Miniature & high power rating
(4) PACKAGING
High stability
R = Reel Pack
Flameproof coating equivalent
to UL-94V-0
T = Box Pack
RoHS compliant &
halogen-free
B = Bulk
(5) TEMPERATURE COEFFICIENT OF RESISTANCE
- = Based on spec , See page 3 Table 2
(6) FORMING
26- = 26mm
FT = FT Type Forming
52- = 52.4mm
PN = PANAsert
M = M-Type Forming
AV = AVIsert
MT = MT Type Forming
(7) RESISTANCE VALUE
E24 Series
Example:
100R = 100Ω, 10K = 10,000Ω, 1M = 1,000,000Ω
www.yageo.com
Sep. 27, 2023 V.1
2
12
FC0
DIMENSIONS
Unit: mm
Miniature
L
ψD
H
ψd
FC0204
3.4 ± 0.3
1.9 ± 0.2
28 ± 2.0
0.45 ± 0.05
FC0207
6.3 ± 0.5
2.4 ± 0.2
28 ± 2.0
0.55 ± 0.05
DERATING CURVE
Rated Power (%) 100
80
60
40
70
100
155
Ambient Temperature (°C)
ELECTRICAL CHARACTERISTICS
TABLE 1
CHARACTERISTICS
FC0204
FC0207
Power Rating at 70 °C
0.4W
0.6W
Maximum Working Voltage
200V
300V
Maximum Overload Voltage
400V
600V
Voltage Proof on Insulation
300V
500V
Resistance Range
1Ω ~10M for E24 series value
Operating Temp. Range
- 55°C to +155°C
Temperature Coefficient
See table 2
Note: For resistance value out of above range is by request.
www.yageo.com
Sep. 27, 2023 V.1
3
12
FC0
TABLE 2 TEMPERATURE COEFFICIENT
Temp. Coefficient ppm/°C
TYPE
FC0204
FC0207
Under 100KΩ
100K ~ 1MΩ
1M ~ 10MΩ
-500 ~ +300
-700~0
-1500~0
TEST AND REQUIRMENTS
TEST
TEST METHOD
Short Time Overload
IEC 60115-1 4.13
PROCEDURE
APPRAISE
2.5 times RCWV for 5 sec.(Not more than
±0.75%+0.05Ω
maximum overload voltage)
Voltage Proof on
IEC 60115-1 4.7
Insulation
In V-Block for 60 sec. test voltage as
No Breakdown
above table
IEC 60115-1 4.8
Between -55°C to +155°C
By Type
Insulation Resistance
IEC 60115-1 4.6
>1,000MΩ
Solderability
IEC 60115-1 4.17
245±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of
Marking
Robustness of
coatings and markings
IEC 60115-1 4.16
Terminations
Periodic-pulse Overload
Direct load for 10 Sec. in the direction of
≥2.5Kg(24.5N)
the terminal leads
IEC 60115-1 4.39
4 times RCWV(or Umax., whichever less)
±1.0%+0.05Ω
10,000 cycles (1 Sec. on, 25 Sec.off)
Damp Heat Steady State
IEC 60115-1 4.24
40±2°C,90-95% RH for 56 days, loaded
±3.0%+0.05Ω
with 0.1 times RCWV(or Umax.,
whichever less)
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV(or Umax., whichever
±3.0%+0.05Ω
less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off)
Temperature Cycling
IEC 60115-1 4.19
-55°C
➔ Room Temp.
+155°C
±1.0%+0.05Ω
➔ Room Temp.(5 cycles)
Resistance to Soldering
IEC 60115-1 4.18
Heat
Accidental Overload Test
260±3°C for 10±1 Sec., immersed to a
±1.0%+0.05Ω
point 3±0.5mm from the body
IEC 60115-1 4.26
No evidence of flaming
for 1 Min.
or arcing
www.yageo.com
Sep. 27, 2023 V.1
4
12
FC0
Note:
RCWV (Rated Continuous Working Voltage ):
The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following
formula:
V=√(P X R)
or max. working voltage whichever is less
Where
V=Continuous rated DC or
AC (rms) working voltage (V)
P=Rated power (W)
R=Resistance value (Ω)
AXIAL / REEL TAPE SPECIFICATION
Unit: mm
Miniature
a
FC0204
6 ± 0.5
FC0207
A
B1-B2 (Max.)
52.4 ± 1.5
1.2
26.0 ± 1.5
1
52.4 ± 1.5
1.2
26.0 ± 1.5
1
S (spacing)
T (max. deviation of spacing)
5
6 ± 0.5
1 mm per 10 spacing,
0.5 mm per 5 spacing
5
www.yageo.com
Sep. 27, 2023 V.1
5
12
FC0
TAPE ON REEL PACKING
TYPE
Unit: mm/piece
Miniature
Across Flange(A)
B
Quantity Per Reel
FC0204
66.5
75.5
5,000
FC0207
66.5
75.5
5,000
www.yageo.com
Sep. 27, 2023 V.1
6
12
FC0
TAPE ON BOX PACKING
TYPE
DIMENSIONS
Miniature
A
B
C
Quantity Per Box
FC0204
48
102
255
5,000
FC0204
81
70
260
5,000
FC0207
48
102
255
5,000
FC0207
81
104
260
5,000
Unit: mm/piece
BULK PACKING
Miniature
Piece/Per Inner Box
Bag/Per Inner Box
Piece Per Bag
FC0204
10,000
10
1,000
FC0207
10,000
10
1,000
www.yageo.com
Sep. 27, 2023 V.1
7
12
FC0
FORMING
M TYPE
TYPE
DIMENSIONS
Miniature
L
ψD
ψd
FC0204
3.4± 0.3
1.9 ± 0.2
0.45 ± 0.05
6.0 ± 1
10.0 ±1
FC0207
6.3 ± 0.5
2.4 ± 0.2
0.55 ± 0.05
10.0 ± 1
10.0 ± 1
Unit: mm
P
H
www.yageo.com
Sep. 27, 2023 V.1
8
12
FC0
FT TYPE (Taping Pack)
MT TYPE (Taping Pack)
Rated Watts : 0.4W
TYPE
DIMENSIONS
Unit: mm
Miniature
H1
Max.
H2
Max.
H3
Max.
FC0207
10
18.5
8.5
PN TYPE ( Taping Pack )
AV TYPE ( Taping Pack )
TYPE
DIMENSIONS
Unit: mm
TYPE
DIMENSIONS
Miniature
H1
Max.
H2
Max.
H3
Max.
Miniature
H1
Max.
H2
Max.
H3
Max.
FC0207
13
21.5
8.5
FC0207
11.5
Unit: mm
www.yageo.com
Sep. 27, 2023 V.1
9
12
FC0
MARKING
4-BAND-CODE
±2%, ±5%
COLOR
BLACK
BROWN
RED
ORANGE
YELLOW
GREEN
BLUE
VIOLET
GREY
WHITE
GOLD
SILVER
1st BAND
2
3
4
5
6
7
8
9
2nd BAND
2
3
4
5
6
7
8
9
3rd BAND
2
3
4
5
6
7
8
9
MULTIPLIER
1Ω
10Ω
100Ω
1KΩ
10KΩ
100K
1MΩ
10MΩ
0.001Ω
0.0001Ω
0.1Ω
0.01Ω
TOLERANCE
± 2%
(G)
±5%
(J)
www.yageo.com
Sep. 27, 2023 V.1
10
12
FC0
REVISION HISTORY
REVISION
DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 1
Aug.31, 2023
- Updated legal disclaimer
Version 0
Aug.2, 2021
- First issue of this specification
“ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as
the products itse lf are unchanged. Any product change will be announced by PCN.”
www.yageo.com
Sep. 27, 2023 V.1
11
12
FC0
LEGAL DISCLAIMER
YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any
errors, inaccuracies or incompleteness contained in any product related information, including but not
limited to product specifications, datasheets, pictures and/or graphics. YA GEO may make changes,
modifications and/or improvements to product related information at any time and without notice.
YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any
particular purpose or the continuing production of any of its products. To the maximum extent permitted
by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product,
(ii) any and all liability, including without limitation special, consequenti al or incidental damages, and (iii)
any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement
and merchantability.
YAGEO products are designed for general purpose applications under normal operation and usage
conditions. Please contact YAGEO for the applications listed below which require especially high
reliability for the prevention of defects which might directly ca use damage to the third party's life, body or
property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment,
Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating
apparatus, burning equipment, Highly public information network equipment, data -processing equipment ,
Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic
signal equipment, Transportation equipment and Undersea equipment, or for any other application or use
in which the failure of YAGEO products could result in personal injury or death, or serious property damage.
Particularly YAGEO Corporation and its affiliates do not recommend the use of commercial or
automotive grade products for high reliability applications or manned space flight.
Information provided here is intended to indicate product specifications only. YAGEO reserves all the
rights for revising this content without further notification, as long as products are u nchanged. Any product
www.yageo.com
Sep. 27, 2023 V.1
12
12
FC0
