FC0204JT-52-100K
FC0204JT-52-100K
    YAGEO(国巨)
    AXIAL-D1.9X3.4MM
    RES 0.4W 5% AXIAL
FC0204JT-52-100K 数据手册
DATA SHEET CARBON FILM RESISTORS Professional, Flameproof FC0 Series ±2%, ±5% 0.4W AND 0.6W Product specification – September 27, 2023 V.1 RoHS compliant & Halogen Free Through Hole Resistors Carbon Film Resistors Product Specification ORDERING INFORMATION Part number of the professional, flameproof carbon film resistor are identified by the series, power rating, tolerance, packing, temperature coefficient, forming and resistance value. PART NUMBER FC0 204 J T - (1) (2) (3) (4) (5) 52- 100R (6) (7) APPLICATIONS  All general purpose applications (1) SERIES FC0 Series  Power applications (2) POWER RATING 204 = 0.4W 207 = 0.6W (3) TOLERANCE FEATURES G = ±2% J = ±5%  Wide resistance range  Miniature & high power rating (4) PACKAGING  High stability R = Reel Pack  Flameproof coating equivalent to UL-94V-0 T = Box Pack  RoHS compliant & halogen-free B = Bulk (5) TEMPERATURE COEFFICIENT OF RESISTANCE - = Based on spec , See page 3 Table 2 . (6) FORMING 26- = 26mm FT = FT Type Forming 52- = 52.4mm PN = PANAsert M = M-Type Forming AV = AVIsert MT = MT Type Forming (7) RESISTANCE VALUE E24 Series Example: 100R = 100Ω, 10K = 10,000Ω, 1M = 1,000,000Ω www.yageo.com Sep. 27, 2023 V.1 2 12 FC0 Through Hole Resistors Carbon Film Resistors Product Specification DIMENSIONS Unit: mm Miniature L ψD H ψd FC0204 3.4 ± 0.3 1.9 ± 0.2 28 ± 2.0 0.45 ± 0.05 FC0207 6.3 ± 0.5 2.4 ± 0.2 28 ± 2.0 0.55 ± 0.05 DERATING CURVE Rated Power (%) 100 80 60 40 20 20 40 70 100 155 Ambient Temperature (°C) ELECTRICAL CHARACTERISTICS TABLE 1 CHARACTERISTICS FC0204 FC0207 Power Rating at 70 °C 0.4W 0.6W Maximum Working Voltage 200V 300V Maximum Overload Voltage 400V 600V Voltage Proof on Insulation 300V 500V Resistance Range 1Ω ~10M for E24 series value Operating Temp. Range - 55°C to +155°C Temperature Coefficient See table 2 Note: For resistance value out of above range is by request. www.yageo.com Sep. 27, 2023 V.1 3 12 FC0 Through Hole Resistors Carbon Film Resistors Product Specification TABLE 2 TEMPERATURE COEFFICIENT Temp. Coefficient ppm/°C TYPE FC0204 FC0207 Under 100KΩ 100K ~ 1MΩ 1M ~ 10MΩ -500 ~ +300 -700~0 -1500~0 TEST AND REQUIRMENTS TEST TEST METHOD Short Time Overload IEC 60115-1 4.13 PROCEDURE APPRAISE 2.5 times RCWV for 5 sec.(Not more than ±0.75%+0.05Ω maximum overload voltage) Voltage Proof on IEC 60115-1 4.7 Insulation In V-Block for 60 sec. test voltage as No Breakdown above table Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +155°C By Type Insulation Resistance IEC 60115-1 4.6 In V-Block for 60 sec. >1,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of Marking Robustness of coatings and markings IEC 60115-1 4.16 Terminations Periodic-pulse Overload Direct load for 10 Sec. in the direction of ≥2.5Kg(24.5N) the terminal leads IEC 60115-1 4.39 4 times RCWV(or Umax., whichever less) ±1.0%+0.05Ω 10,000 cycles (1 Sec. on, 25 Sec.off) Damp Heat Steady State IEC 60115-1 4.24 40±2°C,90-95% RH for 56 days, loaded ±3.0%+0.05Ω with 0.1 times RCWV(or Umax., whichever less) Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV(or Umax., whichever ±3.0%+0.05Ω less) for 1,000 Hr.(1.5 Hr.on,0.5 Hr. off) Temperature Cycling IEC 60115-1 4.19 -55°C ➔ Room Temp. ➔ +155°C ±1.0%+0.05Ω ➔ Room Temp.(5 cycles) Resistance to Soldering IEC 60115-1 4.18 Heat Accidental Overload Test 260±3°C for 10±1 Sec., immersed to a ±1.0%+0.05Ω point 3±0.5mm from the body IEC 60115-1 4.26 4 times RCWV(or Umax., whichever less) No evidence of flaming for 1 Min. or arcing www.yageo.com Sep. 27, 2023 V.1 4 12 FC0 Through Hole Resistors Carbon Film Resistors Product Specification Note: RCWV (Rated Continuous Working Voltage ): The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V=√(P X R) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω) AXIAL / REEL TAPE SPECIFICATION Unit: mm Miniature a FC0204 6 ± 0.5 FC0207 A B1-B2 (Max.) 52.4 ± 1.5 1.2 26.0 ± 1.5 1 52.4 ± 1.5 1.2 26.0 ± 1.5 1 S (spacing) T (max. deviation of spacing) 5 6 ± 0.5 1 mm per 10 spacing, 0.5 mm per 5 spacing 5 www.yageo.com Sep. 27, 2023 V.1 5 12 FC0 Through Hole Resistors Carbon Film Resistors Product Specification TAPE ON REEL PACKING TYPE Unit: mm/piece Miniature Across Flange(A) B Quantity Per Reel FC0204 66.5 75.5 5,000 FC0207 66.5 75.5 5,000 www.yageo.com Sep. 27, 2023 V.1 6 12 FC0 Through Hole Resistors Carbon Film Resistors Product Specification TAPE ON BOX PACKING TYPE DIMENSIONS Miniature A B C Quantity Per Box FC0204 48 102 255 5,000 FC0204 81 70 260 5,000 FC0207 48 102 255 5,000 FC0207 81 104 260 5,000 Unit: mm/piece BULK PACKING Miniature Piece/Per Inner Box Bag/Per Inner Box Piece Per Bag FC0204 10,000 10 1,000 FC0207 10,000 10 1,000 www.yageo.com Sep. 27, 2023 V.1 7 12 FC0 Through Hole Resistors Carbon Film Resistors Product Specification FORMING M TYPE TYPE DIMENSIONS Miniature L ψD ψd FC0204 3.4± 0.3 1.9 ± 0.2 0.45 ± 0.05 6.0 ± 1 10.0 ±1 FC0207 6.3 ± 0.5 2.4 ± 0.2 0.55 ± 0.05 10.0 ± 1 10.0 ± 1 Unit: mm P H www.yageo.com Sep. 27, 2023 V.1 8 12 FC0 Through Hole Resistors Product Specification Carbon Film Resistors FT TYPE (Taping Pack) MT TYPE (Taping Pack) Rated Watts : 0.4W TYPE DIMENSIONS Unit: mm Miniature H1 Max. H2 Max. H3 Max. FC0207 10 18.5 8.5 PN TYPE ( Taping Pack ) AV TYPE ( Taping Pack ) TYPE DIMENSIONS Unit: mm TYPE DIMENSIONS Miniature H1 Max. H2 Max. H3 Max. Miniature H1 Max. H2 Max. H3 Max. FC0207 13 21.5 8.5 FC0207 11.5 20 8.5 Unit: mm www.yageo.com Sep. 27, 2023 V.1 9 12 FC0 Through Hole Resistors Product Specification Carbon Film Resistors MARKING 4-BAND-CODE ±2%, ±5% COLOR BLACK BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GREY WHITE GOLD SILVER 1st BAND 0 1 2 3 4 5 6 7 8 9 2nd BAND 0 1 2 3 4 5 6 7 8 9 3rd BAND 0 1 2 3 4 5 6 7 8 9 MULTIPLIER 1Ω 10Ω 100Ω 1KΩ 10KΩ 100K 1MΩ 10MΩ 0.001Ω 0.0001Ω 0.1Ω 0.01Ω TOLERANCE ± 2% (G) ±5% (J) www.yageo.com Sep. 27, 2023 V.1 10 12 FC0 Through Hole Resistors Carbon Film Resistors Product Specification REVISION HISTORY REVISION DATE CHANGE NOTIFICATION DESCRIPTION Version 1 Aug.31, 2023 - - Updated legal disclaimer Version 0 Aug.2, 2021 - - First issue of this specification “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itse lf are unchanged. Any product change will be announced by PCN.” www.yageo.com Sep. 27, 2023 V.1 11 12 FC0 Through Hole Resistors Carbon Film Resistors Product Specification LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YA GEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation special, consequenti al or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly ca use damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data -processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO products could result in personal injury or death, or serious property damage. Particularly YAGEO Corporation and its affiliates do not recommend the use of commercial or automotive grade products for high reliability applications or manned space flight. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as products are u nchanged. Any product change will be announced by PCN. www.yageo.com Sep. 27, 2023 V.1 12 12 FC0
FC0204JT-52-100K 价格&库存
很抱歉,暂时无法提供与“FC0204JT-52-100K”相匹配的价格&库存,您可以联系我们找货
