DESCRIPTION OF REVISIONS
COUNT
BY CHKD DATE
Y.K.G C.D.H 18.10.04
C.Y.H C.D.H 23.04.24
RE-5-2033
8
1
RE-5-2988
1
2
APPLICABLE STANDARD
OPERATING TEMPERATURE
1
Oct.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
RANGE
RATING
COUNT
-40℃ ~ +105℃ (note1)
STORAGE TEMPERATURE RANGE
50V [AC(rms) / DC]
CURRENT
1 0.5A [AC(rms) / DC] (note2)
APPLICABLE CABLE
TEST METHOD
CONSTRUCTION
GENERAL EXAMINATION
VISUALLY AND BY MEASURING INSTRUMENT
MARKING
CONFIRMED VISUALLY
RELATIVE HUMIDITY 90% MAX (NOT DEWED)
HUMIDITY RANGE
SPECIFICATIONS
ITEM
DATE
CHKD
-10℃ ~ +50℃(Packed Condition)
OPERATING OR STORAGE
VOLTAGE
BY
FPC/FFC (TYPE A : t=0.3±0.03mm)
(TYPE B : t=0.3±0.05mm)
REQUIREMENTS
QT AT
ACCORDING TO DRAWING
O
O
O
O
O
O
O
O
O
O
O
ELECTRICAL CHARACTERISTICS
CONTACT RESISTANCE
INSULATION RESISTANCE
MATE APPLICABLE FPC/FFC AND APPLY A CURRENT OF
50 mΩ MAX.
AC 20mV MAX, 1mA
INCLUDING FPC/FFC BULK RESISTANCE(L=8mm)
MATE APPLICABLE FPC/FFC AND APPLY A VOLTAGE OF
500 MΩ MIN.
DC 100V
VOLTAGE PROOF
2
NO BREAKDOWN.
AC 150V FOR 1 min.
MECHANICAL CHARACTERISTICS
MEASURE BY APPLICABLE FPC/FFC(t=0.3)
AT INITIAL CONDITION
①HORIZONTAL DIRECTION : 0.4N*n min.
②VERTICAL DIRECTION : 0.3N*n min.
(n = Number of Contacts)(note 3)
MECHANICAL OPERATION
20 TIMES INSERTIONS AND EXTRATIONS
O
VIBRATION
FREQUENCY 10 ~ 55 Hz, TOTAL AMPLITUDE 1.5 mm
AT 2h, IN 3 DIRECTIONS
981m/s2 DIRECTION OF PULSE 6ms AT 3 TIMES
IN 3 DIRECTIONS.
①CONTACT RESISTANCE: 50mΩ MAX
②NO DAMAGE,CRACK AND LOOSENESS OF PARTS
①NO ELECTRICAL DISCONTINUITY OF 1㎲.
②CONTACT RESISTANCE : 50mΩ MAX
③NO DAMAGE,CRACK AND LOOSENESS OF PARTS
O
O
O
O
O
FPC RETENSION FORCE
1
SHOCK
ENVIRONMENTAL CHARACTERISTICS
DAMP HEAT(STEADY STATE)
EXPOSED AT 40±2℃, 90~95 %, 96Hr.
①CONTACT RESISTANCE: 50 mΩ MAX.
RAPID CHANGE OF TEMPERATURE
TEMPERATURE:-40±2→15~35→+105±2→15~35 ℃
②INSULATION RESISTANCE: 50MΩ MIN.
TIME :
③NO DAMAGE, CRACK OR LOOSENESS OF PARTS.
1
30 → 2~3 →
30 → 2~3 min.
UNDER 5 CYCLES.
DAMP HEAT, CYCLE
TEMPERATURE -10→+65
HUMIDITY : 90~95%
10 CYCLE(240Hr)
DRY HEAT
1
COLD
CORROSION SALT SPRAY
EXPOSED AT 105±2℃, 96Hr
①CONTACT RESISTANCE : 50mΩ MAX
O
EXPOSED AT -40±2℃, 96Hr
②NO DAMAGE, CRACK OR LOOSENESS OF PARTS.
O
EXPOSED AT 35±2℃, 5±1% SALT WATER SPRAY FOR 48Hr
①CONTACT RESISTANCE 50mΩ MAX
O
O
O
O
HYDROGEN SULPHIDE
EXPOSED IN 3 PPM FOR 96Hr.
③NO EVIDENCE OF CORROSION WHICH AFFECTS
(TEST STANDARD : JEIDA-38)
TO OPERATION OF CONNECTOR.
RESISTANCE TO
1)REFLOW SOLDERING:
SOLDERING HEAT
PEAK TMP. : 250℃ MAX. TMP. 230℃ MIN FOR 60s
SOLDER ABILITY
1
①NO DEFORMATION OF CASE OF EXCESSIVE
LOOSENESS OF THE TERMINALS.
2)SOLDERING IRONS TMP. : 350±10℃ FOR 5±1s
②NO DAMAGE OF ELECTRICAL PERFORMANCE
SOLDER DIPPING TEMPERATURE 245±5℃
A NEW UNIFORM COATING OF SOLDER
(TEST STANDARD : MIL-STD-202)
SHALL COVER A MINIMUM OF 95% OF
FOR IMMERSION DURATION, 3±0.3 sec.
THE SURFACE BEING IMMERSED.
(note 1)
FOLLOW THE SPECIFICATIONS OF FPC/FFC IF IT’S ALLOWABLE MAXIMUM OPERATING TEMPERATURE
IS BELOW 105℃
1
(note 2)
1
(note 3)
WHEN THE SAME VALUE OF CURRENT ARE APPLIED TO ALL CONTACTS AT THE SAME TIME IN ONCE,
SET THE CURRENT TO THE 70% OF THE RATED CURRENT VALUE.
THERE’S A CASE WHICH FPC/FFC RETENTION FORCE DOESN’T FULFILL THE VALUE,
BECAUSE FPC/FFC SPECIFICATION AFFECTS THE RESULT OF FPC/FFC RETENTION FORCE.
DRAWN
DESIGNED
CONDITIONS FOR TESTING
REMARKS
B.J KIM
UNLESS OTHERWISE SPECIFIED, REFER TO JIS C 5402.
NOTE
QT: QUALIFICATION TEST
CL
18.03.02
APPROVED
D.H CHO
H.C SONG
ENG
18.03.02
23.04.24
DEPT
18.03.02
AT: ASSURANCE TEST O: APPLICABLE TEST
HIROSE KOREA CO.,LTD.
CODE NO.(OLD)
18.03.02
B.J KIM
RELEASED
CHECKED
SPECIFICATION SHEET
DRAWING NO.
ELC4-632346
CODE NO.
PART NO.
TF31-**S-0.5SH (800)
CL 6535-****-*-800
F-1-021(Rev.0)
1
1
TF31-40S-0.5SH(800) 价格&库存
很抱歉,暂时无法提供与“TF31-40S-0.5SH(800)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.00708
- 50+1.64819
- 150+1.49440
- 500+1.23746
- 3000+1.00722
