SWR25C-NREC-S04-ST-WH 数据手册
8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
2006
INITIAL RELEASE
9/17/09
JH
F
F
7.62±0.10 .300±.004
Circuit 1
2.54±0.10 .100±.004
E
E
1.02±0.05 .040±.002
P.C.B LAYOUT
2.54±0.10 .100±.004
7.62±0.20 .300±.008
D
D
5.80±0.25 .228±.010
10.16±0.25 .400±.010
2.54±0.20 .100±.008
C
13.50±0.20 .531±.008
8.00±0.25 .315±.010
C
2.50±0.20 .098±.008
3.50±0.20 .138±.008
B
B
0.64 .025
A
NOTES:
1. INSULATOR MATERIAL: NYLON66, UL94V-0, COLOR: WHITE.
2. CONTACT MATERIAL: BRASS.
3. CONTACT PLATING: TIN OVERALL.
4. CURRENT RATING: 4 AMPS.
5. VOLTAGE RATING: 250V AC/DC.
6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN.
7. CONTACT RESISTANCE: 10 MILLIOHMS MAX.
8. DIELECTRIC WITHSTANDING VOLTAGE: 1000V AC.
9. OPERATING TEMPERATURE: -25° C TO +85° C.
10. MATES WITH SWH25C SERIES SINGLE ROW HOUSING.
8
7
6
UNLESS OTHERWISE SPECIFIED:
Pb
DIMENSIONS ARE IN MM[INCHES]
TOLERANCES:
ANGULAR: 5
.X= .3 [.01]
.XX= .15 [.006]
.XXX= .050 [.0020]
SURFACE FINISH: 63 Ra
REMOVE ALL BURRS AND SHARP EDGES .010 MAX
RoHS COMPLIANT
5
4
DATE
DRAWN
NAME
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT DESCRIPTION
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
PART NUMBER
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
WAFER 2.54mm CC, 1 ROW, ST
SIZE DWG. NO.
REV
C 11321
INTERPRET DIMENSIONS AND GEOMETRIC
TOLERANCING
PER: ANSI Y14.5M-1994
3
9/17/09
A
SCALE: 7:1
2
SHEET 1 OF 1
1
FILE NAME: Z:\ECO PENDING\2006, wafer 25_ series\11321, SWR25C-NREC-S04-ST-WH PRINT: 9/29/2009
A
SWR25C-NREC-S04-ST-WH 价格&库存
很抱歉,暂时无法提供与“SWR25C-NREC-S04-ST-WH”相匹配的价格&库存,您可以联系我们找货
