PCM20
Phase Change Material
Features
Naturally tacky and easy to use
Low thermal resistance
Long term reliability
Good thermal conductivity
Customized parts
Maximize the contact area between surfaces
Applications
Electronic components: IC / CPU / MOS
LED/ M/B/ P/S/ Heat Sink/ LCD-TV/ NotebookPC/ PC/ TelecomDevice/
Wireless Hub etc....
Thermal Conductivity 1 ~ 2.5 W/m.K
DDR II Module / DVD Applications / Hand-Set applications etc...
REACH Compliant
RoHS Compliant
PCM20 phase-change thermal interface materials) are desinged to fill air gaps and voids between the heatgenerator
and heatsinks, while at the same time displacing entrapped air between power dissipating components.
The performance of the heat sink benefits a lot from the low heat resistance while improving the microprocessor
performance, DC- DC converter of memory module and the reliability of power module.
PCM20 characteristics:
-At room temperature, PCM20 materials are solid and easy to handle. This allows them to be consistently and cleanly
applied as dry pads to a heat sink or component surface.
-once the temperature reaches to the phase change temperature, the pad will fully change phase and attain minimum
bond-line thickness and maximum surface wetting. This results in practically no thermal contact resistance due to a very
small thermal resistance path.
-These property results in PCM20 material softens as it reaches component operating temperatures. With light clamping
pressure it will readily conform to both mating surfaces.
The material is nonconductive, however, as the material has endured the phase change at high temperature, may make
the metal get to the metal, so the phase change interface material cannot be used as electrical insulating material
PCM20
Property
Unit
PCM20G
Colour
PCM20B
Gray
Black
Thermal conductivity
Phase Changing Temperature
Density
Thickness
Storage temp
Operating Temperature
Shelf life
PCM20Y
Pink
Yellow
0.03
0.05
0.05
2.5
1.0
1.0
50~60
50~60
50~60
2.2
1.3
1.35
0.09
0.127
0.127
<40
<40
<45
<45
-45~125
-45~125
-45~125
-45~125
Carrier
Thermal impedance
PCM20P
Aluminum foil
℃in2/w
W/m·K
g/cm2
mm
Month
0.035
2
50~60
1.2
0.076/0.127
12
24
12
12
Available with an adhesive backing
1.
2.
3.
4.
Part Number
Size X-Y-Z
Adhesivebacking – 0-None, 1A-one side, 2A-two sides
Quantity
Tel:+442081332062 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
PCM20Y-200-150-0.13 价格&库存
很抱歉,暂时无法提供与“PCM20Y-200-150-0.13”相匹配的价格&库存,您可以联系我们找货
