1000 Eaton Boulevard
Cleveland, OH 44122
United States
Cat6 Gigabit Molded Ultra-Slim UTP Ethernet
Cable (RJ45 M/M), Blue, 7 ft. (2.13 m)
MODEL NUMBER: N200-UR07-BL
Highlights
Premium Cat6 cable rated for
high-speed 1 Gbps home/office
communications
Over 50% slimmer than
standard Cat6 cables to
increase airflow in full racks
Easy to route around corners
and through crowded cable
management panels
32 AWG copper wire and 3 µm
gold-plated connectors allow
superior signal transfer
Color-coded blue for fast, easy
identification in a crowded rack
or workstation
Applications
Connect a computer and its
peripherals to a home or office
Gigabit Ethernet network
Connect switches, modems and
servers in a high-density data
center
Replace standard-diameter
cables in crowded racks and
patch panel installations to
improve airflow
Cat6 Ethernet cable, just 2.8 mm thick, connects critical components, such as servers, switches and
routers, in Gigabit networks.
Features
Cat6 Cable Ideal for Connecting Equipment in Your Gigabit Ethernet NetworkThis Cat6 Ethernet
cable with RJ45 connectors is recommended for connecting network components like printers, computers,
copiers, routers, servers, modems and switches in high-density data centers. Designed for fast
transmission and excellent signal quality, this seven-foot cable ensures peak performance throughout
your local area network (LAN).
Special Ultra-Slim Design for Better Airflow and Easier InstallationThe N200-UR07-BL is just 2.8
millimeters in diameter—more than 50% smaller than standard Cat6 cable. This increases airflow in
crowded equipment racks, which helps keep your components cool and properly functioning. The extraslim design also makes the cable easier to install around corners and through cable management panels.
Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThe PVC jacket is colored
blue to allow easy, fast identification in a crowded rack or workstation and help prevent the cable from
becoming inadvertently disconnected.
Premium Construction for Superior PerformanceManufactured from 32 AWG copper wire, the fourpair stranded cable is rated for speeds up to 1 Gbps. The ends feature 3-micron gold plating to help
ensure the most accurate signal transfer possible. Integral strain relief gives the unshielded cable extra
flexibility, reduces stress, and helps the cable move freely without cracking or breaking loose from the
connector.
Specifications
OVERVIEW
UPC Code
037332256942
Technology
Cat6
1/3
Package Includes
N200-UR07-BL Cat6 Ultra-Slim
Ethernet Cable (RJ45 M/M),
Blue, 7 ft.
Cleveland, OH 44122
United States
POWER
Power Over Cable (PoC) Support
No
PHYSICAL
Cable Jacket Color
Blue
Cable Jacket Material
PVC
Cable Shielding
UTP
Cable Outer Diameter (OD)
2.8 mm
Number of Conductors
4 Pair
Conductor Material
Stranded Copper
Conductor Gauge
32 AWG
Cable Length (ft.)
7
Cable Length (m)
2.13
Cable Length (in.)
84
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Weight (kg)
0.03
ENVIRONMENTAL
Operating Temperature Range
14° to 104°F (-10° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Operating Humidity Range
0% to 90% RH, Non-Condensing
Storage Humidity Range
COMMUNICATIONS
Bandwidth per TIA Standard
250 MHz
Maximum Bandwidth as Tested
500 MHz
Network Compatibility
1 Gbps (Gigabit)
IEEE Standards Supported
802.3an
CONNECTIONS
Side A - Connector 1
RJ45 (MALE)
Side B - Connector 1
RJ45 (MALE)
Crossover Wiring
No
Contact Plating
Gold
Connector Type
Molded
Wiring Configuration
EIA/TIA 568B
2/3
Cleveland, OH 44122
United States
Angled Connector
No
FEATURES & SPECIFICATIONS
Antibacterial
No
IP68 Rated
No
Snagless Connector
No
IP20 Rated
No
STANDARDS & COMPLIANCE
Product Compliance
CE (Europe); RoHS; IEEE 802.3an 10GBase-T; REACH; UKCA
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N200-UR07-BL”相匹配的价格&库存,您可以联系我们找货
