2162
2162
    ADAFRUIT
    无线电源/充电 电源管理 评估板
2162 数据手册
Universal Qi Wireless Charging Transmitter PRODUCT ID: 2162  Description If you have a modern smart phone you may have noticed that it comes with built in wireless charging capability called 'Qi charging.' Qi is a trademark name for a thin and smart inductive charging system. Many large gadget companies have standardized on Qi, which means it's easy to find a charging dish and we thought it might be cool if your Arduino project can recharge itself wirelessly. We've added a ton of Qi receivers but, until now, we haven't had a charging base. No longer! This is a super simple Qi transmitter. It will work with any standard Qi charger receivers - like the ones we carry here. You just connect the board to a 5v power supply - either through a micro USB port - then put your device w/ Qi receive onto the base. If you want to 'share' the microUSB power connection, you can also connect direct to the USB-A port Maximum output is around 5W which is good for most smart phones, basically 1000mA charge at 5V on the other side of the wireless connection. It has a charging distance of 2-8mm, works with all our Qi charge receivers. You can only use one receiver per transmitter so if you want to charge two Qi devices at once, you'll need 2 transmitters. Note: PCB may come in blue or green!  Technical Details o o o o o o o o Input: 5V Input Current: 2A Maximum output power of 5W Operating Frequency: 100-200kHz Charging Distance: 2-8mm Charging Plate Dimensions: 53mm x 53mm x 4mm / 2.1" x 2.1" x 0.2" PCB Dimensions w/ Components: 55mm x 37mm x 6mm / 2.2" x 1.5mm x 0.2" Weight: 47g        Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“2162”相匹配的价格&库存,您可以联系我们找货
