.312" MOUNT PANEL LIGHTS
Data Display Products
50 Series
- Mounting Hardware Provided
1 Model
51
53[1]
54
56
561
564
- For Detailed LED Data, See Discrete Section, MODEL 200
TO ORDER, FOLLOW THE EXAMPLE:
Wires
Select one BOLD component from each numbered category in the tables below.
W
(optional)
Model
1
LED
2 -ALP 3
54
-BCR
-BCA
-BCG
2
4
Lens
Diffusion
-C
Voltage/Current
λpk
Iv[2]
Viewing
V/C
Color
(nm)
(mcd)
Angle
Table[3]
RED
AMB
GRN
635
583
565
35
35
24
I
I
I
120
100
80
Design
Max
Vf/If
Vf/If
V/C Table I
5.5V/28mA
5V/22mA
12V/20mA
14V/25mA
15V/24mA
16.5V/28mA
24V/17mA
26V/20mA
28V/16.5mA
30V/18mA
48V/15mA
50V/16mA
60V/9mA
65V/10mA
120VAC/3.5mA
130VAC/4mA
HIGH INTENSITY - WATERCLEAR ENCAPSULATION
λpk
Iv[2]
Viewing
LED
V/C
Color
(nm)
(mcd)
Angle
Table[3]
-NWR
-NWO
-NWA
-NWG
-NWB
-NWW[7]
-NWL[7]
-NKR
-NKO
-NKA
-NKG
-NKB
-NKW[7]
-NKL[7]
RED
ORG
AMB
GRN
BLU
CWHT
WWHT
RED
ORG
AMB
GRN
BLU
CWHT
WWHT
634
605
592
520
465
2800
2000
2800
2400
700
2500
1800
3600
8000
3600
10000
3000
9200
9200
30
30
30
45
45
50
50
15
15
15
15
15
I
I
I
II
II
II
II
I
I
I
II
II
II
II
634
605
592
520
465
3
-RLP[6]
-ALP[6]
-GLP[6]
-LRG[7]
-RAG[7]
-GAR[7]
Bezel
Color
6
A
9
4
Voltage/Current
Design
Max
Vf/If
Vf/If
V/C Table II
5V/15mA
5.5V/23mA
12V/15mA
14V/20mA
15V/15mA
16.5V/18mA
24V/15mA
26V/18mA
28V/15mA
30V/17mA
48V/9.5mA
50V/10mA
60V/7mA
65V/8mA
120VAC/3.5mA
130VAC/4mA
λpk
Iv[2]
Voltage[4]
2
5H
12H
15H
24H
28H
48H
60H
120[5]
Lens
Diffusion
-C
Clear
-N
Diffused
5
SPECIALTY LEDs
LED
5
Lens
Color
➜Part Number 54-ALP2-CA9
MEDIUM INTENSITY - TINTED ENCAPSULATION
2 LED
Voltage
Lens Color
R Red
B Blue
A Amber
W Water
Clear
Y Yellow
-S Smoke[8]
Viewing
V/C
Description
Low Power
Low Power
Low Power
Bi-Color. Red Cathode
Tri-Color, Common Cathode
Tri-Color, Common Anode
Color
(nm)
(mcd)
Angle
Table[3]
RED
AMB
GRN
RED/GRN
RED/AMB/GRN
GRN/AMB/RED
635
583
565
660/565
630/565
635/565
2.3
2.1
2.3
90/40
6/6/6
5/5/5
50
50
50
60
60
50
[3]
[3]
[3]
I
I
I
G Green
6
Bezel
Color
Black
9
White
[1] Model 53 is available with Clear (-C) Lens only.
[2] Iv = typical luminous intensity @ If = 20mA (Ta =25°C). Iv is measured without lenses. For Low
Power LEDs, If = 2mA.
[3] See Voltage/Current table for design specifications. Design current for low power LEDs = 2mA.
[4] Ta = 25°C. Voltage 2 indicates external resistor required. Voltages 5H through 60H are VDC.
For AC operation, insert D after Voltage (e.g. 24HD), D indicates built-in rectifier; not required for 5H
or 120VAC. DC operation not available for 120V. Bi-Color and Tri-Color not available in AC voltages.
52
[5] Select high intensity LEDs only.
[6] Omit H when selecting a voltage (e.g. 51-RLP12-CWO).
[7] Select -CW or -NW lens only. -RAG wire leads: green anode/black cathode/red anode. -GAR wire
leads: green cathode/black anode/red cathode. Common lead is the first lead clockwise from
reference mark on header. Tri-Color 5 or 12 volt, omit H in part number.
[8] Omit Lens Diffusion when selecting smoked lens (e.g. 51-NWA12H-SO).
445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639
ww w.datadisplay.com
© 2005 Data Display Products
50 Series
51
53
54 (flush lens)
56
561
564
TC5 & NW5 Mounting Hardware
Standard Wire Leads:
6.0" total length(nominal)/.50" stripped (nominal), red
anode/black cathode, 24 AWG TPB UL1061 insulation.
Contact factory for other lengths, gauges and colors.
All dimensions are in inches (mm)
Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25)
Specifications are subject to change without notice.
53
很抱歉,暂时无法提供与“54W-NWA28H-CAO”相匹配的价格&库存,您可以联系我们找货
