Sourcekit® PiTray mini
Version: 1.1.0
Language: English, 简体中文
Designer: Shengyuan Fang (方圣源), Weihong Guan
Overview
Sourcekit® PiTray mini is a companion IO board for Raspberry Pi Compute Module 4 (sold
separately). It is designed for use both as a development system for Compute Module 4
(CM4) and as an embedded board integrated into end products.
It provides an excellent way to bring similar development experience of Raspberry Pi 4B to
CM4. So users could upgrade their system or setup from the standard Raspberry Pi 4B to
CM4 seamlessly. With capability to flash OS image to eMMC on CM4, PiTray mini serves
as a budget alternative to Raspberry Pi Compute Module 4 IO Board.
Layout
Features
Compatible with all variants of CM4, no matter whether it uses onboard eMMC or
micro SD card
Capable to flash operation system image to eMMC on CM4 with regular approaches
as same as the official CMIO board, no extra tools required
Same dimensions and mounting holes compared to Model B Raspberry Pi, such as
3B/3B+/4B
Specification
1 CM4 socket
1 set of standard Raspberry Pi HAT connectors
1 Standard HDMI 2.0 connector
1 Gigabit Ethernet RJ45 socket
1 native USB 2.0 connector
1 SD card socket for CM4 variants without eMMC
1 USB Type-C connector for powering and also programming eMMC variants of
CM4
1 Boot Mode Switch for programming mode and normal mode
1 RUN button for easy reset
1 i2c (i2c0) pads
1 Red Power LED
1 Green Activity LED
2 mounting holes for CM4
4 CM4 corner marks for CM4 position guidance
Input power: +5V
Dimensions: 85 mm x 56 mm
PiTray mini Mechanical Drawings
Get started
CM4 without eMMC (Lite)
1. Got a micro SD card ready with operating system compatiable with raspberry pi, like
NOOB, Raspbian or Ubuntu. (See also 1 2 3 4)
2. Insert the Micro SD card into the micro SD socket on PiTray mini.
3. Make sure the eMMC Boot switch is at the ON position.
4. Mount the CM4 without eMMC on PiTray mini. CAUTION: be careful of the CM4
position, align the CM4 layout corner marks and holes, otherwise CM4 or PiTray
would get damaged
5. Plug Other devices you may needed such as HDMI, Ethernet, USB (see below)
Keyboard.
6. Power PiTray with a 15W USB-C power supply. With the power led on, you are good
to go. Enjoy & have fun.
CM4 with eMMC (Flashing Guide)
1. Power Off. Unplug micro SD card from PiTray if any.
2. Mount the CM4 (with eMMC) on PiTray. CAUTION: be careful of the CM4 position,
align the CM4 layout corner marks and holes, otherwise CM4 or PiTray would get
damaged
3. Make sure the eMMC Boot switch is at the OFF position.
4. On PC, install and launch raspberry pi usbboot. (See also: 5)
5. Connect PiTray mini with a USB-A to USB-C cable to the PC. (a USB-C to USB-C
cable may not work)
6. Then an external disk like flash drive, aka USB mass storage, would show up on the
PC, write this disk with OS image with Raspberry Pi Imager, Etcher or dd as the step
1 above.
7. After the image is written and the external drive is umounted from PC, disconnect
PiTray mini from the PC.
8. Turn the eMMC Boot switch to ON.
9. Plug Other devices you may needed such as HDMI, Ethernet, USB (see below)
Keyboard.
10. Power PiTray with a 15W USB-C power supply. With the red led on, you are good to
For CM4 with eMMC that already filled with OS image, just start from Step 8 for
regular usage.
Guides
Hidden Feature: Connect RTC on i2c0
Troubleshooting
USB devices not working
The USB interface is disabled to save power by default on the CM4. To enable it you
need to add dtoverlay=dwc2,dr_mode=host to the config.txt file
As described in Section 4.2 on Compute Module 4 datasheet.
This feature could confuse whoever new to Raspberry Pi Compute Module 4, when the
exact same behavior as regular Raspberry Pi Model A/B/Zero is expected, especially in
case that a USB keyboard is the only approach to interact with the operating system.
To fix that, for CM4 without eMMc, power off CM4, unplug the micro SD card and mounted
on a PC with Micro SD card Reader/Writer. Find config.txt file in the boot partition of the
micro SD card, which looks like a flash drive. Append config.txt with the line
Save it, close the file, umount the micro SD card and mount it back to PiTray mini and try
again.
For CM4 with eMMC, similar to the process to flash the operating system image, power off
PiTray, switch off eMMC Boot, and connect PiTray to a PC with usbboot preloaded, then do
the editing as above. Finally disconnect PiTray from PC then switch on eMMC Boot and try
again.
For experienced raspberry pi users, this step could be done right after the OS image is
written.
For CM4 without eMMC, the OS would launch fine even with eMMC Boot switch at OFF. But
in this case USB devices on this USB 2.0 port would not work because the USB interface is
running at the guest mode. eMMC Boot switch has to be at position ON to enable USB
function in host mode.
Discussion and Show Cases
Forum (Powered by GitHub Discussion)
Prototype release on @BG5USN
neat CM4 projects/accessories - Jeff Geering
Raspberry Pi CM4 Boards arrive! Waveshare PoE and PiTray mini - Jeff
Geering
Alternative Raspberry Pi Compute Module 4 Carrier Board Offers Familiar
Layout - tom's Hardware
PiTray Mini Is a CM4 Companion IO Board for Industrial Applications Hackster.io
RPi CM4 powered PiTray opens at $14.50 as more carriers prep for launch LinuxGizmos.com
Sourcekit PiTray Mini Review: Brings Ports to Raspberry Pi CM4 - tom's
Hardware
The Ultimate Raspberry Pi Compute Module Carrier Board Comparison upswift
Sourcekit PiTray Mini Review - Your Exclusive Cart
See also
Sourcekit PiTray Clip
Raspberry Pi is a trademark of the Raspberry Pi Foundation
Copyright © 2021 Fuzhou Sourcekit Electronics Ltd. Proudly published with docsify.
很抱歉,暂时无法提供与“DFR0827”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+132.401761+17.12971
