HRSP
HRSS
Hand Retractable Spring Plungers
Steel
Stainless Steel
Non Lock-Out, with Knurled Handle
Inch
3
Type
ST
STP
NI
NIP
Steel, without patch
Steel, with patch
Stainless steel, without patch
Stainless steel, with patch
Inch table
Dimensions in: inches - millimeters
1
2
d1
d2
d3
l1
l2
l3
l4
Initial
End
.104
2.6
10 x 32
.375
9.5
.400
10.2
.09
2.3
.250
6.4
.13
3.3
.50 lbf
2.22 N
3.00 lbf
13.34 N
.124
3.1
1/4 x 20
.500
12.7
.500
12.7
.13
3.3
.313
8.0
.19
4.8
1.00 lbf
4.45 N
4.00 lbf
17.79 N
.155
3.9
5/16 x 18
.625
15.9
.625
15.9
.19
4.8
.375
9.5
.25
6.4
1.00 lbf
4.45 N
6.00 lbf
26.68 N
.186
4.7
3/8 x 16
.750
19.1
.750
19.1
.22
5.6
.500
12.7
.31
7.9
1.00 lbf
4.45 N
8.00 lbf
35.58 N
.249
6.3
1/2 x 13
1.00
25.4
.875
22.2
.25
6.4
.625
15.9
.38
9.7
1.00 lbf
4.45 N
10.00 lbf
44.48 N
Thread
Spring load ≈
Specification
Information
• HRSP
-- Threaded body
Low carbon steel, zinc plated
-- Plunger pin
Case hardened steel, zinc plated
-- Spring
Steel
HRSP and HRSS hand retractable spring plungers are intended for use in applications requiring a part
to be located or indexed into a particular position and does not require the pin to remain retracted for
long periods of time.
see also...
• List of Indexing Plunger Types
• HRSS
-- Threaded body
Stainless steel
European Standard No. 1.4305 (AISI 303)
-- Plunger pin
Stainless steel
-- Spring
Stainless steel
• RoHS compliant
How to order (Steel)
1
2
3
HRSP-0.104-10X32-ST
How to order (Stainless steel)
1
2
3
HRSS-0.249-1/2X13-NIP
2
| 3.1 Indexing, Locking, Blocking with Pins and Ball-Shaped Elements
1
Pin diameter d1
2
Thread d 2
3
Type
1
Pin diameter d1
2
Thread d 2
3
Type
www.jwwinco.com | phone: 1-800-877-8351
很抱歉,暂时无法提供与“8THR5”相匹配的价格&库存,您可以联系我们找货
