MIKROE-3982
MIKROE-3982
    MIKRO
    TB67H450FNG 电机控制器/驱动器 电源管理 mikroBUS™ Click™ 平台评估扩展板
MIKROE-3982 数据手册
        DC MOTOR 14 CLICK PID: MIKROE-3982 Weight: 20 g DC MOTOR 14 Click is a PWM chopper type brushed DC motor driver, labeled as TB67H450FNG. This IC includes one channel of motor output block, using a wide range of supply voltages, while delivering reasonably high current to the connected DC motors. Low ON-resistance MOSFETs and a PWM control help the TB67H450FNG exhibit lower heat generation thus efficient motor drive. Furthermore, the TB67H450FNG has two inputs, IN1 and IN2, which allow for selection of the four operation modes; forward (clockwise), reverse (counterclockwise), short brake, and stop modes. The Click board™ is supported by the mikroSDK compliant library, which includes functions that simplify software development. The Click board™ comes as a fully tested product, ready to be used on a system equipped with mikroBUS™. How does it work? The main component of DC MOTOR 14 click is the TB67H450FNG, a PWM chopper-type brushed DC motor driver, produced by Toshiba. This IC uses a proprietary BiCD manufacturing process, allowing this IC to be powered by a wide range of supply voltages, from 4.5 up to 44V. Due to a very low ON resistance of the MOSFETs, it can theoretically deliver up to 3.5A (Peak current is 6.2A (tw
MIKROE-3982 价格&库存
很抱歉,暂时无法提供与“MIKROE-3982”相匹配的价格&库存,您可以联系我们找货
MIKROE-3982
    • 1+135.76520
    • 5+133.04719
    库存:3
