TOL-14584
TOL-14584
    SPARKFUNELECTRONICS
    FILAMENT BLACK PLA 2.85MM 1KG
TOL-14584 数据手册
        PLA Filament 2.85mm - 1kg (Black) TOL-14584   This is a 1kg (2.2lb) reel of 2.85mm black PLA (polylactic acid) plastic filament for 3D printing. PLA is a bioplastic and makes for a great general-purpose filament with smooth surface finish. This filament is very easy to print and is even biodegradable! PLA has minimal warping and shrinking compared with other materials, which makes it ideal for printing objects featuring flat surfaces and hard angles, or requiring tight tolerances for fit. PLA filament has been commonly used in situations that require prototypes, educational and architectural models, and artifact replicas built with ease and alacrity. This filament is also capable of being treated with a variety of post-processing techniques, making it a popular choice for users looking to paint objects after they have been printed, such as costume props and figurines. The material comes on a heavy-duty plastic reel and vacuum sealed to keep out any moisture. Note: PLA is relatively brittle, so it is not recommended for thin, high-strength applications.  FEATURES      Diameter: 2.85mm (0.112 inches) Quantity: 1kg (2.2 pounds) Hot End Temperature: 210°C – 230°C Color: Black        https://www.sparkfun.com/products/14584 3‐8‐18
TOL-14584 价格&库存
很抱歉,暂时无法提供与“TOL-14584”相匹配的价格&库存,您可以联系我们找货
