Taiwan Chinsan Electronic Ind., Co., Ltd.
Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan
http://www.chinsan.com/products/
TEL: +886 2 2995 0535
MJ
Series
For electronic ballast circuits and long life
Low ESR
High ripple current
Load life: 8,000 to 10,000 hours at 105℃
SPECIFICATIONS
Performance Characteristics
Item
Category Temperature Range
-25~ +105℃
Working Voltage Range
160 ~ 450Vdc
Capacitance Range
10 ~ 560 μF
Capacitance Tolerance
Dissipation Factor
(tanδ)
(at 25℃, 120Hz)
±20% (at 25℃ and 120Hz)
Leakage Current
Low Temperature Characteristics
Impedance Ratio(MAX)
Endurance
Shelf Life
Rated Voltage (V)
160 ~ 450
tanδ(Max)
0.15
I=0.03CV + 10μA
I : Leakage current (μA) C : Rated capacitance (μF)
Impress the rated voltage for 2 minutes
Rated voltage (V)
160~250
400
420 ~ 450
Z(-25℃)/Z(+20℃)
3
5
6
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage with
the rated ripple current is applied for 10,000 ( 8,000 hours for Ф 10 ) hours at 105°C.
≦ ±20% of the initial value
Capacitance change
Dissipation factor(tanδ)
≦ 200% of the specified value
Leakage current
≦ specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after the rated voltage applied for
1,000 hours at 105℃ without voltage applied.
Capacitance change
Leakage current
Others
V : Rated voltage (V)
Conforms to JIS-C-5101-4 (1998), characteristic W
DIMENSIONS (mm)
ФD
10
12.5
ФD
J
18
ФD + 0.5 Max
Фd
0.6
0.6
0.8
0.8
F
5.0
5.0
7.5
7.5
L + 1.5 Max
≤ 35 L+1.5Max
≥ 40 L+2.0 Max
a
M
16
PART NUMBER SYSTEM( Example : 250V 220µF )
2 E 2 2 1 M N N 1 8 N 3
Special Request
Size code(18N3 : 18×31.5)
Lead length code
Lead forming Type code
Capacitance tolerance code(M:±20%)
Capacitance code (220μF)
Voltage code(250V)
Series code(MJ)
L + 1.5 Max
Aluminum Electrolytic Capacitor
Customer
Digi-Key
SERIES
Tolerance
No.
CHINSAN
Part No.
Customer Capacitance
Part No.
(uF)
On rated
Working
Capacitance Voltage
(Vdc)
Surge
Voltage
(Vdc)
MJ
NO.:
Rated
Rated
Leakage
Ripple
Ripple
ESR
Impedance
Temp
@ 25℃ Current
Current
Current
@25℃
@20℃
Range
(120Hz)
(Max)
Category
Tanδ
(uA)
2022-03-25
PUBLISH DATE
(mA rms) (mA rms) (mΩ max/ (mΩ max/
(2 min.) @ 105℃ @ 105℃ 120Hz)
120Hz
100kHz
100kHz)
Dimensions (mm)
Endurance
Appearance
@ 105℃
Drawing
(Hours)
DΦ
L
a
d
F
No
1
MJ2G270MNN1220
27 µF
±20%
400 V
-25~+105
360
10000
12.5
2
MJ2G470MNN1620A6
47 µF
±20%
400 V
-25~+105
550
1250
10000
16
3
MJ2W121MNN1835A4EJ
120 µF
±20%
450 V
-25~+105
820
400
10000
18
35
7.5
※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test.
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
Sleeve Color: Black.
很抱歉,暂时无法提供与“MJ2G270MNN1220”相匹配的价格&库存,您可以联系我们找货
