Taiwan Chinsan Electronic Ind., Co., Ltd.
Address: No.1, Alley 11, Lane 68, Sec.1, KwangFu Rd., SanChung Dist., New Taipei City 24158, Taiwan
http://www.chinsan.com/products/
TEL: +886 2 2995 0535
MV
Series
High ripple current
Low ESR
Load life 5,000 hours at 105℃
SPECIFICATIONS
Performance Characteristics
Item
Category Temperature Range
-25~ +105℃
Working Voltage Range
160 ~ 450Vdc
Capacitance Range
6.8 ~ 470 μF
Capacitance Tolerance
±20% (at 25℃ and 120Hz)
Dissipation Factor
(tanδ)
(at 25℃, 120Hz)
Leakage Current
Low Temperature Characteristics
Impedance Ratio(MAX)
Rated Voltage (V)
160~ 450
tanδ(Max)
0.15
I=0.03CV + 10μA
I : Leakage current (μA) C : Rated capacitance (μF)
Impress the rated voltage for 2 minutes.
V : Rated voltage (V)
Rated voltage (V)
160~250
400
420 ~ 450
Z(-25℃)/Z(+20℃)
3
5
6
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 25°C after subjected to DC voltage
with the rated ripple current is applied for 5,000 hours at 105°C.
Endurance
Shelf Life
Capacitance change
Dissipation factor(tanδ)
≦ ±20% of the initial value
Leakage current
≦ specified value
The following requirements shall be satisfied when the capacitor are restored to 25℃ after exposing them for 1,000
hours at 105℃ without voltage applied.
Capacitance change
≦ 200% of the specified value
Leakage current
Others
Conforms to JIS-C-5101-4 (1998), characteristic W
DIMENSIONS (mm)
ФD
10
ФD
12.5 L < 35
16
18
ФD +0.5 Max
Фd
0.6
0.6
0.8
0.8
F
5.0
5.0
7.5
7.5
L + 1.5 Max
≤ 35 L+1.5Max
≥ 40 L+2.0 Max
a
PART NUMBER SYSTEM( Example : 350V 100µF )
M V 2 V 1 0 1 M N N 1 8 4 5
Special Request
Size code(1845 : 18×45)
Lead length code
Lead forming Type code
Capacitance tolerance code(M:±20%)
Capacitance code (100μF)
Voltage code(350V)
Series code(MV)
L + 1.5 Max
Aluminum Electrolytic Capacitor
Customer
Digi-Key
SERIES
MV
NO.:
FIG-1
FIG-2
Tolerance
No.
CHINSAN
Part No.
Customer Capacitance
Part No.
(uF)
2022-03-25
PUBLISH DATE
On rated
Working
Capacitance Voltage
(Vdc)
Surge
Voltage
(Vdc)
Rated
Rated
Leakage
Ripple
Ripple
ESR
Impedance
Temp
@ 25℃ Current
Current
Current
@25℃
@20℃
Range
(120Hz)
(Max)
Category
Tanδ
(uA)
(mA rms) (mA rms) (mΩ max/ (mΩ max/
(2 min.) @ 105℃ @ 105℃ 120Hz)
120Hz
100kHz
100kHz)
Dimensions (mm)
Endurance
Appearance
@ 105℃
Drawing
(Hours)
DΦ
L
a
d
F
No
1
MV2C390MNN1212
39 µF
±20%
160 V
-25~+105
200
5000
12.5
12
5
FIG-1
2
MV2G121MNN1830
120 µF
±20%
400 V
-25~+105
735
5000
18
30
7.5
FIG-1
3
MV2S121MNN18N3
120 µF
±20%
420 V
-25~+105
775
500
5000
18
31.5
7.5
FIG-1
4
MV2W101MNN1650
100 µF
±20%
450 V
-25~+105
750
5000
16
50
7.5
FIG-1
5
MV2W121MNN1640
120 µF
±20%
450 V
-25~+105
700
5000
16
40
7.5
FIG-1
6
MV2S101MNN1630A4ER
100 µF
±20%
420 V
-25~+105
900
1400
400
4000
16
30
7.5
FIG-1
7
MV2G101MR51830R
100 µF
±20%
400 V
-25~+105
945
5000
18
30
7.5
FIG-2
8
MV2G680MNN1625A6
68 µF
±20%
400 V
-25~+105
700
600
5000
16
25
7.5
FIG-1
※Test leakage current before testing dissipation factor and capacitance during the electric characteristic test.
REMARKS:
Sleeve Color: Black.
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
Customer
Digi-Key
SERIES
MV
NO.:
2022-03-25
PUBLISH DATE
Unit (mm):
P=12.7±1.0
P0=12.7±0.2
P2=6.35±1.0
F=3.5±0.3
ΦD0=4.0±0.2
t=0.7±0.2
FIG-1
Original
Tolerance
No.
CHINSAN
Part No.
Part No.
(uF)
On rated
MV2W4R7MP308B5A6
4.7 µF
Working
Capacitance Voltage
1
H=18.5±0.5
P1=3.85±0.5
W =18.0±0.5
W0=12.5MIN
Φd=0.6 ±0.05
±20%
(Vdc)
450 V
Surge
Voltage
(Vdc)
Rated
Rated
Leakage
Ripple
Ripple
ESR
Impedance
Temp
@ 25℃ Current
Current
Current
@25℃
@20℃
Range
(120Hz)
(Max)
Category
-25~+105
Tanδ
(uA)
120Hz
100kHz
75
100kHz)
5000
Dimensions (mm)
Endurance
Appearance
@ 105℃
Drawing
(Hours)
DΦ
L
a
d
F
No
6000
8
11.5
3.5
FIG-1
REMARKS:
APPROVED BY
CHECKED BY
PREPARED BY
张洪斌
曾爱娥
梁慧妍
很抱歉,暂时无法提供与“MV2W121MNN1640”相匹配的价格&库存,您可以联系我们找货
