MBRF2035CT thru MBRF20200CT
Taiwan Semiconductor
CREAT BY ART
FEATURES
Dual Common Cathode Schottky Rectifier
- Low power loss, high efficiency
- Guardring for overvoltage protection
- High surge current capability
- UL Recognized File # E-326243
- Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
- Halogen-free according to IEC 61249-2-21 definition
ITO-220AB
MECHANICAL DATA
Case: ITO-220AB
Molding compound, UL flammability classification rating 94V-0
Base P/N with suffix "G" on packing code - halogen-free
Base P/N with prefix "H" on packing code - AEC-Q101 qualified
Terminal: Matte tin plated leads, solderable per JESD22-B102
Meet JESD 201 class 1A whisker test
with prefix "H" on packing code meet JESD 201 class 2 whisker test
Polarity: As marked
Mounting torque: 5 in-lbs maximum
Weight: 1.7 g (approximately)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted)
MBRF MBRF MBRF MBRF MBRF MBRF MBRF MBRF MBRF
PARAMETER
SYMBOL 2035
2090 20100 20150 20200 UNIT
2045
2050
2060
2080
CT
CT
CT
CT
CT
CT
CT
CT
CT
Maximum repetitive peak reverse voltage
VRRM
35
45
50
60
80
90
100
150
200
V
Maximum RMS voltage
VRMS
24
31
35
42
56
63
70
105
140
V
Maximum DC blocking voltage
VDC
35
45
50
60
80
90
100
150
200
V
Maximum average forward rectified current
IF(AV)
A
Peak repetitive forward current
(Rated VR, Square wave, 20KHz)
IFRM
A
Peak forward surge current, 8.3 ms single half
sine-wave superimposed on rated load
IFSM
150
A
Peak repetitive reverse surge current (Note 1)
IRRM
Maximum instantaneous forward voltage (Note 2)
IF= 10 A, TJ=25℃
IF= 10 A, TJ=125℃
IF= 20 A, TJ=25℃
IF= 20 A, TJ=125℃
Maximum reverse current @ rated VR
TJ=25 ℃
TJ=125 ℃
VF
IR
1
0.5
A
0.80
0.80
0.80
0.85
0.95
0.57
0.70
0.65
0.75
0.85
0.84
0.95
1.00
0.95
1.05
0.72
0.85
0.75
0.85
0.95
5
2
0.1
15
10
30
V
mA
Voltage rate of change (Rated VR)
dV/dt
10000
V/μs
Isolation voltage from
terminals to heatsink with t=1.0 min
VAC
1500
V
Typical thermal resistance
RθJC
Operating junction temperature range
Storage temperature range
1.5
3.5
O
C/W
TJ
- 55 to +150
O
C
TSTG
- 55 to +150
O
C
Note 1: tp = 2.0 μs, 1.0KHz
Note 2: Pulse test with PW=300μs, 1% duty cycle
Document Number: D1308017
Version: N13
ORDERING INFORMATION
PART NO.
AEC-Q101
PACKING CODE GREEN COMPOUND
QUALIFIED
MBRF20xxCT
(Note 1)
PACKAGE
PACKING
ITO-220AB
50 / Tube
CODE
Prefix "H"
C0
Suffix "G"
Note 1: "xx" defines voltage from 35V (MBRF2035CT) to 200V (MBRF20200CT)
EXAMPLE
AEC-Q101
PREFERRED P/N
PART NO.
MBRF2060CT C0
MBRF2060CT
C0
MBRF2060CT C0G
MBRF2060CT
C0
MBRF2060CTHC0
MBRF2060CT
GREEN
PACKING CODE
QUALIFIED
H
DESCRIPTION
COMPOUND
G
Green compound
C0
AEC-Q101 qualified
RATINGS AND CHARACTERISTICS CURVES
FIG.1 FORWARD CURRENT DERATING CURVE
25
AVERAGE FORWARD A
CURRENT (A)
10
RESISTIVE OR
INDUCTIVELOAD
WITH HEATSINK
5
60
70
80
90
100
110
120
130
140
150
PEAK FORWARD SURGE CURRENT (A)
FIG. 2 MAXIMUM NON-REPETITIVE FORWARD SURGE
CURRENT PER LEG
150
8.3ms Single Half Sine Wave
JEDEC Method
125
100
75
50
25
10
CASE TEMPERATURE (oC)
FIG. 3 TYPICAL FORWARD CHARACTERISTICS
PER LEG
FIG. 4 TYPICAL REVERSE CHARACTERISTICS
PER LEG
100
100
TJ=125℃
MBRF2035CT - 2045CT
1
MBRF2050CT - 2080CT
MBRF2090CT - 20100CT
MBRF20150CT - 20200CT
0.1
0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9
FORWARD VOLTAGE (V)
1
1.1 1.2
INSTANTANEOUS REVERSE CURRENT (mA)
INSTANTANEOUS FORWARD CURRENT (A)
Pulse Width=300μs
1% Duty Cycle
10
100
NUMBER OF CYCLES AT 60 Hz
10
1
TJ=75℃
0.1
TJ=25℃
0.01
MBRF2035CT - 2045CT
MBRF2050CT - 20200CT
0.001
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
Version: N13
10000
100
f=1.0MHz
Vsig=50mVp-p
MBRF2035CT - 2045CT
TRANSIENT THERMAL
IMPEDANCE (℃/W)
JUNCTION CAPACITANCE (pF) A
FIG. 6 TYPICAL TRANSIENT THERMAL IMPEDANCE
PER LEG
FIG. 5 TYPICAL JUNCTION CAPACITANCE
PER LEG
1000
100
0.1
1
10
100
10
1
0.1
0.01
0.1
REVERSE VOLTAGE (V)
1
10
100
T-PULSE DURATION(s)
PACKAGE OUTLINE DIMENSIONS
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
4.30
4.70
0.169
0.185
B
2.50
3.16
0.098
0.124
C
2.30
2.96
0.091
0.117
D
0.46
0.76
0.018
0.030
E
6.30
6.90
0.248
0.272
F
9.60
10.30
0.378
0.406
G
3.00
3.40
0.118
0.134
H
0.95
1.45
0.037
0.057
I
0.50
0.90
0.020
0.035
J
2.40
3.20
0.094
0.126
K
14.80
15.50
0.583
0.610
L
4.10
0.161
M
12.60
13.80
0.496
0.543
N
1.80
0.071
O
2.41
2.67
0.095
0.105
MARKING DIAGRAM
P/N
= Specific Device Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: N13
CREAT BY ART
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied,to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or seling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: N13
很抱歉,暂时无法提供与“MBRF20150CTC0”相匹配的价格&库存,您可以联系我们找货
