MICRO-RTU PLUS
MICRO-RTU PLUS
    VISIONARYELECTRONICS
    INPUT MODULE 8 ANALOG 12-48V
MICRO-RTU PLUS 数据手册
Micro-RTU Plus • • • • • • • • • Full Electric Power Industry Compliance Compact Design for Poletop or Substation Applications Protocol Conversions for local IEDs Multiple Protocols for SCADA Master and Local IEDs Historical Data for all I/O Points Units can be Daisy-Chained for Large Point Counts TCP/IP (Ethernet) Interface Also Available in a Plastic Enclosure Custom Applications our Specialty Specifications: • • • • • • • • • • • • Control Sequence: Direct or SBO 4 Relay Contacts: Form C, 2 Amps at 30Vdc (resistive load) 6 Analog Inputs with twelve-bit resolution, pre-scaled to ± 1 VDC with 0.1% accuracy 8 Status Inputs Status Input Voltage: 12Vdc to 35Vdc, positive or negative polarity Input Current: 0.1ma (typical) Isolation: Optical Phase-to-Ground 2000V Input Voltage: 12Vdc to 35Vdc Communication Links: 2 RS-232 Ports, 1 TCP/IP RJ-45 Port Available with DNP 3.0, Modbus, PG&E (Data 2179), or Telegyr 8979 Dimensions: 5.7" x 7" The Micro-RTUs come with a free copy of the VisiCal software suite that allows it to be configured, calibrated, scanned, monitored or programmed with drag-and-drop and pushbutton simplicity.
MICRO-RTU PLUS 价格&库存
很抱歉,暂时无法提供与“MICRO-RTU PLUS”相匹配的价格&库存,您可以联系我们找货
