电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
CRJ060-1-TH
CRJ060-1-TH
    CUIDEVICES
    模块化连接器 - 插孔 8p8c(RJ45,以太网) 垂直 屏蔽
CRJ060-1-TH 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 08/05/2022 page 1 of 3 MODEL: CRJ060-1-TH | DESCRIPTION: MODULAR JACK FEATURES • 8P8C (RJ45) • shielded • vertical orientation SPECIFICATIONS parameter conditions/description min typ rated voltage rated current withstanding voltage max units 150 Vac 1.5 for 1 minute 1,500 contact resistance 40 insulation resistance 500 storage temperature 6.12 kgf 0 70 °C -40 80 °C life 1,000 flammability rating UL94V-0 RoHS yes packaging carton size: 400 x 303 x 258 mm tray QTY: 120 pcs per tray carton QTY: 1,320 pcs per carton mΩ MΩ insertion/withdrawal force operating temperature A Vac cycles SOLDERABILITY parameter conditions/description wave soldering for maximum 5 seconds min cuidevices.com typ max units 240 °C Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | MODEL: CRJ060-1-TH | DESCRIPTION: MODULAR JACK date 08/05/2022 | page 2 of 3 MECHANICAL DRAWING units: mm tolerance: X ±0.5 mm X.X ±0.38 mm X.XX ±0.25 mm X.XXX ±0.10 mm PCB: ±0.05 mm PCB thickness: 1.6 mm unless otherwise noted ITEM  DESCRIPTION MATERIAL PLATING/COLOR 1 insulator PBT (UL94V-0) black 2 contact terminals phosphor bronze contact area: 6 µ” gold over nickel solder area: tin over nickel 3 shield brass nickel alloy    Recommended PCB Layout Top View cuidevices.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | MODEL: CRJ060-1-TH | DESCRIPTION: MODULAR JACK date 08/05/2022 | page 3 of 3 REVISION HISTORY rev. description date 1.0 initial release 04/16/2021 1.01 updated packaging 10/05/2021 logo, datasheet style update 08/05/2022 1.02 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CRJ060-1-TH 价格&库存
很抱歉,暂时无法提供与“CRJ060-1-TH”相匹配的价格&库存,您可以联系我们找货
  • 型号: 104257-1
  • 品牌: TE
    • 1+ 0.5071 1+ 0
    • 500+ 0.4768 500+ 0
    • 600+ 0.4508 600+ 0
    • 1000+ 0.4283 1000+ 0
    • 2000+ 0.4125 2000+ 0
    库存:737
    • 型号: 104257-4
    • 品牌: TE
      • 1+ 0.586 1+ 0
      • 100+ 0.541 100+ 0
      • 1000+ 0.5184 1000+ 0
      库存:1360
      • 型号: 104257-7
      • 品牌: TE
        • 1+ 0.9016 1+ 0
        • 500+ 0.8452 500+ 0
        • 1000+ 0.7889 1000+ 0
        库存:513
        • 型号: 104257-5
        • 品牌: TE
          • 1+ 0.9016 1+ 0
          库存:1089
          • 型号: 104257-6
          • 品牌: TE
            • 1+ 1.386 1+ 0
            库存:872
            • 型号: 104257-9
            • 品牌: TE
              • 1+ 3.381 1+ 0
              • 10+ 3.0429 10+ 0
              库存:527
              • 型号: 104257-8
              • 品牌: TE
                • 1+ 4.508 1+ 0
                库存:594
                  • 1+ 5.6846 1+ 0
                  库存:81
                    • 1+ 10.083 1+ 0
                    库存:369
                      • 1+ 12.8364 1+ 0
                      • 100+ 12.3231 100+ 0
                      库存:582
                        • 500+ 0.429 500+ 0
                        库存:10877
                          • 500+ 0.5221 500+ 0
                          库存:161417
                            • 100+ 0.5795 100+ 0
                            • 1000+ 0.5554 1000+ 0
                            库存:993
                              • 5+ 0.6754 5+ 0
                              • 50+ 0.5386 50+ 0
                              • 150+ 0.4701 150+ 0
                              • 500+ 0.3872 500+ 0
                              • 2500+ 0.3461 2500+ 0
                              • 5000+ 0.3256 5000+ 0
                              库存:7459
                                • 500+ 0.7233 500+ 0
                                库存:10455
                                  • 5+ 0.7421 5+ 0
                                  • 50+ 0.617 50+ 0
                                  • 150+ 0.5544 150+ 0
                                  • 500+ 0.5075 500+ 0
                                  • 2500+ 0.4699 2500+ 0
                                  库存:3728
                                    • 500+ 0.9695 500+ 0
                                    库存:5409
                                      • 500+ 0.9845 500+ 0
                                      库存:49914
                                        • 500+ 2.3829 500+ 0
                                        库存:9257
                                          • 500+ 2.4039 500+ 0
                                          库存:6684
                                            • 1+ 1.4916 1+ 0
                                            • 5000+ 1.1187 5000+ 0
                                            • 10000+ 0.7458 10000+ 0
                                            库存:784
                                            • 型号: 104257-3
                                            • 品牌: TE
                                              • 30000+ 0.4763 30000+ 0
                                              库存:90989
                                              • 型号: 104257-1
                                              • 品牌: TE
                                                • 30000+ 0.57321 30000+ 0
                                                库存:90835
                                                • 型号: 104257-7
                                                • 品牌: TE
                                                  • 1+ 0.693 1+ 0
                                                  • 250+ 0.6237 250+ 0
                                                  • 500+ 0.561 500+ 0
                                                  库存:932
                                                  • 型号: 104257-4
                                                  • 品牌: TE
                                                    • 18000+ 0.91839 18000+ 0
                                                    库存:54062
                                                    • 型号: 104257-2
                                                    • 品牌: TE
                                                      • 500+ 0.37296 500+ 0
                                                      库存:3766
                                                      • 型号: 104257-3
                                                      • 品牌: TE
                                                        • 10+ 0.46111 10+ 0
                                                        库存:8593
                                                        • 型号: 104257-1
                                                        • 品牌: TE
                                                          • 10+ 0.54746 10+ 0
                                                          库存:495
                                                          • 型号: 104257-7
                                                          • 品牌: TE
                                                            • 1+ 0.64512 1+ 0
                                                            库存:473
                                                            • 型号: 104257-5
                                                            • 品牌: TE
                                                              • 100+ 0.65856 100+ 0
                                                              库存:668
        • 0+ 0 0+ 0
        库存:291
        • 0+ 0 0+ 0
        库存:473
        库存:764
        库存:788
        • 型号: 104257-7
        • 品牌: TE
        • 1+ 0.67859 1+ 0
        库存:522
        • 型号: 104257-5
        • 品牌: TE
        • 1+ 0.75106 1+ 0
        库存:633
        • 型号: 104257-6
        • 品牌: TE
        • 500+ 0.8085 500+ 0
        库存:1126
        • 型号: 104257-9
        • 品牌: TE
        • 500+ 1.7807 500+ 0
        库存:7397
        • 207+ 3.39097 207+ 0
        • 1500+ 3.36462 1500+ 0
        库存:7294
        • 143+ 5.46676 143+ 0
        • 1000+ 4.85349 1000+ 0
        库存:4094
        • 1+ 7.05504 1+ 0
        • 10+ 5.43083 10+ 0
        • 20+ 5.10622 20+ 0
        • 25+ 5.0104 25+ 0
        • 30+ 4.01143 30+ 0
        • 83+ 3.79343 83+ 0
        库存:960
        • 2+ 7.19279 2+ 0
        • 20+ 6.16388 20+ 0
        • 33+ 3.66527 33+ 0
        • 91+ 3.44966 91+ 0
        库存:1051
        • 82+ 9.49855 82+ 0
        • 410+ 8.54031 410+ 0
        库存:498
        • 1+ 9.90581 1+ 0
        • 25+ 7.73539 25+ 0
        • 26+ 4.70256 26+ 0
        • 71+ 4.44504 71+ 0
        库存:1114
        • 1+ 10.85207 1+ 0
        • 20+ 8.78347 20+ 0
        • 22+ 5.55779 22+ 0
        • 60+ 5.27032 60+ 0
        库存:682
        • 1+ 20.30271 1+ 0
        • 12+ 10.48075 12+ 0
        • 32+ 9.90581 32+ 0
        库存:652
        • 型号: 104257-1
        • 品牌: TE
        • 500+ 2.76452 500+ 0
        • 1000+ 2.70942 1000+ 0
        • 2000+ 2.65432 2000+ 0
        库存:505
        • 型号: 104257-2
        • 品牌: TE
        • 500+ 2.9945 500+ 0
        • 1000+ 2.93461 1000+ 0
        • 2000+ 2.87592 2000+ 0
        库存:981
        • 型号: 104257-3
        • 品牌: TE
        • 10+ 4.19829 10+ 0
        • 250+ 4.10965 250+ 0
        • 1000+ 3.98508 1000+ 0
        • 2500+ 3.88806 2500+ 0
        • 5000+ 3.80421 5000+ 0
        库存:926
        • 型号: 104257-5
        • 品牌: TE
        • 250+ 5.35656 250+ 0
        • 1000+ 5.13736 1000+ 0
        库存:814
        • 型号: 104257-6
        • 品牌: TE
        • 25+ 6.01296 25+ 0
        • 100+ 5.89318 100+ 0
        • 250+ 5.7734 250+ 0
        • 500+ 5.65362 500+ 0
        库存:617
        • 型号: 104257-7
        • 品牌: TE
        • 10+ 7.53776 10+ 0
        • 250+ 7.37845 250+ 0
        • 1000+ 7.15326 1000+ 0
        • 2500+ 6.97838 2500+ 0
        • 5000+ 6.82626 5000+ 0
        库存:838
        • 型号: 104257-2
        • 品牌: TE
        • 500+ 0.37588 500+ 0
        库存:3330
        • 型号: 104257-1
        • 品牌: TE
        • 500+ 0.3811 500+ 0
        库存:2995
        • 型号: 104257-3
        • 品牌: TE
        • 500+ 0.50988 500+ 0
        库存:10988
        • 型号: 104257-4
        • 品牌: TE
        • 500+ 0.68216 500+ 0
        库存:1055
        • 型号: 104257-6
        • 品牌: TE
        • 500+ 2.03255 500+ 0
        库存:1085
        • 型号: 104257-3
        • 品牌: TE
        • 500+ 3.11993 500+ 0
        • 2000+ 3.02049 2000+ 0
        库存:5184
        • 型号: 104257-3
        • 品牌: TE
        库存:3464
        • 型号: 104257-3
        • 品牌: TE
        库存:10726
        • 型号: 104257-3
        • 品牌: TE
        库存:1744
        • 型号: 104257-8
        • 品牌: TE
        • 300+ 3.50526 300+ 0
        • 700+ 3.41825 700+ 0
        • 1400+ 3.30638 1400+ 0
        库存:4344
