74AC11240
OCTAL BUFFER/LINE DRIVER
WITH 3-STATE OUTPUTS
SCAS448A – MAY 1987 – REVISED APRIL 1996
D
D
D
D
D
DB, DW, OR NT PACKAGE
(TOP VIEW)
Flow-Through Architecture Optimizes
PCB Layout
Center-Pin VCC and GND Configurations
Minimize High-Speed Switching Noise
EPIC t (Enhanced-Performance Implanted
CMOS) 1-mm Process
500-mA Typical Latch-Up Immunity at
125°C
Package Options Include Plastic
Small-Outline (DW) and Shrink
Small-Outline (DB) Packages, and Standard
Plastic 300-mil DIPs (NT)
1Y1
1Y2
1Y3
1Y4
GND
GND
GND
GND
2Y1
2Y2
2Y3
2Y4
description
1
24
2
23
3
22
4
21
5
19
7
18
8
17
9
16
10
15
11
14
12
13
1OE
1A1
1A2
1A3
1A4
VCC
VCC
2A1
2A2
2A3
2A4
2OE
This octal buffer/line driver is designed specifically
to improve both the performance and density of
3-state memory address drivers, clock drivers,
and bus-oriented receivers and transmitters. This
device
provides
inverting
outputs
and
symmetrical active-low output-enable (OE)
inputs. This device features high fan-out and
improved fan-in.
The 74AC11240 is organized as two 4-bit buffers/line drivers with separate OE inputs. When OE is low, the
device passes inverted data from the A inputs to the Y outputs. When OE is high, the outputs are in the
high-impedance state.
The 74AC11240 is characterized for operation from –40°C to 85°C.
FUNCTION TABLE
(each buffer)
INPUTS
OUTPUT
Y
OE
A
L
H
L
L
L
H
H
X
Z
logic symbol†
1OE
1A1
1A2
1A3
1A4
24
23
EN
2OE
1
1
22
2
21
3
1Y1
1Y2
2A1
2A2
1Y3
2A3
1Y4
2A4
13
17
EN
1
9
16
10
15
11
14
12
2Y1
2Y2
2Y3
2Y4
† This symbol is in accordance with ANSI/IEEE Std 91-1984 and IEC Publication 617-12.
Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of
Texas Instruments semiconductor products and disclaimers thereto appears at the end of this data sheet.
EPIC is a trademark of Texas Instruments Incorporated.
Copyright 1996, Texas Instruments Incorporated
PRODUCTION DATA information is current as of publication date.
Products conform to specifications per the terms of Texas Instruments
standard warranty. Production processing does not necessarily include
testing of all parameters.
POST OFFICE BOX 655303
• DALLAS, TEXAS 75265
1
74AC11240
logic diagram (positive logic)
1OE
1A1
1A2
1A3
1A4
13
24
2OE
23
1
22
2
21
3
1Y1
2A1
1Y2
2A2
1Y3
2A3
1Y4
2A4
17
9
16
10
15
11
14
12
2Y1
2Y2
2Y3
2Y4
absolute maximum ratings over operating free-air temperature range (unless otherwise noted)†
Supply voltage range, VCC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –0.5 V to 6 V
Input voltage range, VI (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –0.5 V to VCC + 0.5 V
Output voltage range, VO (see Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –0.5 V to VCC + 0.5 V
Input clamp current, IIK (VI < 0 or VI > VCC) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±20 mA
Output clamp current, IOK (VO < 0 or VO > VCC) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±50 mA
Continuous output current, IO (VO = 0 to VCC) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±50 mA
Continuous current through VCC or GND . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ±200 mA
Maximum power dissipation at TA = 55°C (in still air) (see Note 2): DB package . . . . . . . . . . . . . . . . . . 0.65 W
DW package . . . . . . . . . . . . . . . . . . 1.7 W
NT package . . . . . . . . . . . . . . . . . . . 1.3 W
Storage temperature range, Tstg . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . –65°C to 150°C
† Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only, and
functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not
implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability.
NOTES: 1. The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
2. The maximum package power dissipation is calculated using a junction temperature of 150_C and a board trace length of 750 mils,
except for the NT package, which has a trace length of zero.
2
74AC11240
VCC
Supply voltage
VIH
High-level input voltage
VCC = 3 V
VCC = 4.5 V
MIN
NOM
MAX
3
5
5.5
0.9
Low-level input voltage
VI
VO
Input voltage
Output voltage
IOH
High-level output current
∆t/∆v
Input transition rise or fall rate
TA
Operating free-air temperature
V
3.85
VIL
VCC = 4.5 V
VCC = 5.5 V
1.35
V
1.65
VCC
VCC
VCC = 3 V
VCC = 4.5 V
Low-level output current
V
2.1
3.15
VCC = 5.5 V
VCC = 3 V
IOL
UNIT
V
V
–4
–24
VCC = 5.5 V
VCC = 3 V
–24
VCC = 4.5 V
VCC = 5.5 V
24
mA
12
mA
24
OE
Data
–40
85
ns/V
°C
electrical characteristics over recommended operating free-air temperature range (unless
otherwise noted)
PARAMETER
TEST CONDITIONS
IOH = –50 mA
VOH
IOH = –4 mA
IOH = –24
24 mA
IOH = –75 mA{
IOL = 12 mA
IOL = 24 mA
IOZ
II
ICC
Ci
CO
IOL = 75 mA{
VO = VCC or GND
VI = VCC or GND
VI = VCC or GND,
MIN
TA = 25°C
TYP
MAX
3V
2.9
2.9
4.4
4.4
5.5 V
5.4
5.4
3V
2.58
2.48
4.5 V
3.94
3.8
5.5 V
4.94
4.8
VI = VCC or GND
VO = VCC or GND
MAX
UNIT
V
3.85
3V
0.1
0.1
4.5 V
0.1
0.1
5.5 V
0.1
0.1
3V
0.36
0.44
4.5 V
0.36
0.44
5.5 V
0.36
0.44
5.5 V
IO = 0
MIN
4.5 V
5.5 V
IOL = 50 mA
VOL
VCC
V
1.65
5.5 V
±0.5
±5
mA
5.5 V
±0.1
±1
mA
5.5 V
8
80
mA
5V
4
pF
5V
10
pF
† Not more than one output should be tested at a time, and the duration of the test should not exceed 10 ms.
3
74AC11240
switching characteristics over recommended operating free-air temperature range,
VCC = 3.3 V ± 0.3 V (unless otherwise noted) (see Figure 1)
PARAMETER
FROM
(INPUT)
TO
(OUTPUT)
tPLH
tPHL
A
Y
tPZH
tPZL
OE
Y
tPHZ
tPLZ
OE
Y
MIN
TA = 25°C
TYP
MAX
MIN
MAX
1.5
7.6
10.5
1.5
11.7
1.5
6.3
8.6
1.5
9.5
1.5
8.2
11.6
1.5
12.7
1.5
7.6
10.8
1.5
12
1.5
5.5
7.5
1.5
7.8
1.5
6.7
9.4
1.5
9.8
UNIT
ns
ns
ns
VCC = 5 V ± 0.5 V (unless otherwise noted) (see Figure 1)
PARAMETER
FROM
(INPUT)
TO
(OUTPUT)
tPLH
tPHL
A
Y
tPZH
tPZL
OE
Y
tPHZ
tPLZ
OE
Y
TA = 25°C
MIN
TYP
MAX
MIN
MAX
1.5
5.4
7.5
1.5
8.4
1.5
4.6
6.6
1.5
7.2
1.5
5.7
8.2
1.5
9.2
1.5
5.3
7.7
1.5
8.7
1.5
4.7
6.3
1.5
6.6
1.5
5.2
7.3
1.5
7.7
UNIT
ns
ns
ns
operating characteristics, VCC = 5 V, TA = 25°C
PARAMETER
Cpd
d
4
Power dissipation capacitance per buffer
TEST CONDITIONS
Outputs enabled
Outputs disabled
CL = 50 pF,
pF
f = 1 MHz
TYP
39
12
UNIT
pF
74AC11240
PARAMETER MEASUREMENT INFORMATION
2 × VCC
S1
500 Ω
From Output
Under Test
GND
CL = 50 pF
(see Note A)
Output
Control
(low-level
enabling)
VCC
50% VCC
50% VCC
tPHL
0V
tPLH
VOH
Output
S1
Open
2 × VCC
GND
500 Ω
LOAD CIRCUIT
Input
Open
TEST
tPLH /tPHL
tPLZ /tPZL
tPHZ /tPZH
50% VCC
50% VCC
VOL
VCC
50% VCC
0V
tPZL
[ VCC
tPLZ
Output
Waveform 1
S1 at 2 × VCC
(see Note B)
Output
Waveform 2
S1 at GND
(see Note B)
50% VCC
50% VCC
VOL
tPHZ
tPZH
VOLTAGE WAVEFORMS
20% VCC
50% VCC
80% VCC
VOH
[0V
VOLTAGE WAVEFORMS
NOTES: A. CL includes probe and jig capacitance.
B. Waveform 1 is for an output with internal conditions such that the output is low except when disabled by the output control.
Waveform 2 is for an output with internal conditions such that the output is high except when disabled by the output control.
C. All input pulses are supplied by generators having the following characteristics: PRR ≤ 1 MHz, ZO = 50 Ω, tr = 3 ns, tf = 3 ns.
D. The outputs are measured one at a time with one input transition per measurement.
Figure 1. Load Circuit and Voltage Waveforms
5
PACKAGE OPTION ADDENDUM
www.ti.com
14-Oct-2022
PACKAGING INFORMATION
Orderable Device
Status
(1)
Package Type Package Pins Package
Drawing
Qty
Eco Plan
(2)
Lead finish/
Ball material
MSL Peak Temp
Op Temp (°C)
Device Marking
(3)
Samples
(4/5)
(6)
74AC11240DBR
ACTIVE
SSOP
DB
24
2000
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 85
AE240
Samples
74AC11240DW
ACTIVE
SOIC
DW
24
25
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 85
AC11240
Samples
74AC11240PW
ACTIVE
TSSOP
PW
24
60
RoHS & Green
NIPDAU
Level-1-260C-UNLIM
-40 to 85
AE240
Samples
(1)
The marketing status values are defined as follows:
ACTIVE: Product device recommended for new designs.
LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect.
NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design.
PREVIEW: Device has been announced but is not in production. Samples may or may not be available.
OBSOLETE: TI has discontinued the production of the device.
(2)
RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance
do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may
reference these types of products as "Pb-Free".
RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption.
Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
很抱歉,暂时无法提供与“74AC11240DWR”相匹配的价格&库存,您可以联系我们找货
