CD74HC125QM96Q1
CD74HC125QM96Q1
    ROCHESTER(罗切斯特)
    SOIC14_150MIL
    BUS DRIVER
CD74HC125QM96Q1 数据手册
Product Folder Order Now Support & Community Tools & Software Technical Documents CD74HC125-Q1 SCLS579B – APRIL 2004 – REVISED APRIL 2020 CD74HC125-Q1 Automotive Quadruple Buffers with 3-State Outputs 1 Features 3 Description • This device contains four independent buffers with 3state outputs. Each gate performs the Boolean function Y = A in positive logic. 1 • • • • • AEC-Q100 Qualified for automotive applications: – Device temperature grade 1: –40°C to +125°C, TA Buffered inputs Positive and negative input clamp diodes Wide operating voltage range: 2 V to 6 V Supports fanout up to 10 LSTTL loads Significant power reduction compared to LSTTL logic ICs Device Information(1) PART NUMBER CD74HC125QM96G4 Q1 PACKAGE SOIC (14) CD74HC125QPWRQ1 TSSOP (14) BODY SIZE (NOM) 8.70 mm × 3.90 mm 5.00 mm × 4.40 mm (1) For all available packages, see the orderable addendum at the end of the data sheet. 2 Applications • Enable digital signals Functional pinout of the CD74HC125-Q1 1 14 VCC 2 13 4OE 3 4 12 11 4A 2A 5 10 3OE 2Y 6 7 9 8 1OE 1A 1Y 2OE GND 4Y 3A 3Y 1 An IMPORTANT NOTICE at the end of this data sheet addresses availability, warranty, changes, use in safety-critical applications, intellectual property matters and other important disclaimers. PRODUCTION DATA. CD74HC125-Q1 SCLS579B – APRIL 2004 – REVISED APRIL 2020 www.ti.com Table of Contents 1 2 3 4 5 6 7 8 Features .................................................................. Applications ........................................................... Description ............................................................. Revision History..................................................... Pin Configuration and Functions ......................... Specifications......................................................... 1 1 1 2 3 3 6.1 6.2 6.3 6.4 6.5 6.6 6.7 6.8 3 4 4 4 5 5 6 6 Absolute Maximum Ratings ...................................... ESD Ratings.............................................................. Recommended Operating Conditions....................... Thermal Information .................................................. Electrical Characteristics........................................... Switching Characteristics .......................................... Operating Characteristics.......................................... Typical Characteristics .............................................. Parameter Measurement Information .................. 6 Detailed Description .............................................. 8 8.1 Overview ................................................................... 8 8.2 Functional Block Diagram ......................................... 8 8.3 Feature Description................................................... 8 8.4 Device Functional Modes.......................................... 9 9 Application and Implementation ........................ 10 9.1 Application Information............................................ 10 9.2 Typical Application .................................................. 10 10 Power Supply Recommendations ..................... 12 11 Layout................................................................... 12 11.1 Layout Guidelines ................................................. 12 11.2 Layout Example .................................................... 12 12 Device and Documentation Support ................. 13 12.1 12.2 12.3 12.4 12.5 12.6 Documentation Support ........................................ Related Links ........................................................ Community Resources.......................................... Trademarks ........................................................... Electrostatic Discharge Caution ............................ Glossary ................................................................ 13 13 13 13 13 13 13 Mechanical, Packaging, and Orderable Information ........................................................... 13 4 Revision History NOTE: Page numbers for previous revisions may differ from page numbers in the current version. Changes from Revision A (September 2008) to Revision B Page • Updated to new data sheet standards.................................................................................................................................... 1 • Changed RθJA for PW package from 113 °C/W to 151.7 °C/W .............................................................................................. 4 • Changed RθJA for D package from 86 °C/W to 133.6 °C/W ................................................................................................... 4 2 Submit Documentation Feedback Copyright © 2004–2020, Texas Instruments Incorporated Product Folder Links: CD74HC125-Q1 CD74HC125-Q1 www.ti.com SCLS579B – APRIL 2004 – REVISED APRIL 2020 5 Pin Configuration and Functions D or PW Package 14-Pin SOIC or TSSOP Top View 1 14 VCC 2 13 4OE 3 4 12 11 4A 2A 5 10 3OE 2Y 6 7 9 8 1OE 1A 1Y 2OE GND 4Y 3A 3Y Pin Functions PIN NAME I/O NO. DESCRIPTION 1OE 1 Input Channel 1, Output Enable, Active Low 1A 2 Input Channel 1, Input A 1Y 3 Output 2OE 4 Input Channel 2, Output Enable, Active Low 2A 5 Input Channel 2, Input A 2Y 6 Output GND 7 — 3Y 8 Output 3A 9 Input Channel 3, Input A 3OE 10 Input Channel 3, Output Enable, Active Low 4Y 11 Output 4A 12 Input Channel 4, Input A 4OE 13 Input Channel 4, Output Enable, Active Low VCC 14 — Channel 1, Output Y Channel 2, Output Y Ground Channel 3, Output Y Channel 4, Output Y Positive Supply 6 Specifications 6.1 Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted) (1) MIN MAX –0.5 7 UNIT VCC Supply voltage IIK Input clamp current (2) VI < –0.5 V or VI > VCC + 0.5 V ±20 mA IOK Output clamp current (2) VO < –0.5 V or VO > VCC + 0.5 V ±20 mA IO Continuous output current VO > –0.5 V or VO < VCC + 0.5 V ±25 mA ±70 mA 150 °C 150 °C Continuous current through VCC or GND TJ Junction temperature Tstg Storage temperature (1) (2) (3) (3) –65 V Stresses beyond those listed under Absolute Maximum Rating may cause permanent damage to the device. These are stress ratings only, which do not imply functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Condition. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. The input and output voltage ratings may be exceeded if the input and output current ratings are observed. Guaranteed by design. Submit Documentation Feedback Copyright © 2004–2020, Texas Instruments Incorporated Product Folder Links: CD74HC125-Q1 3 CD74HC125-Q1 SCLS579B – APRIL 2004 – REVISED APRIL 2020 www.ti.com 6.2 ESD Ratings VALUE V(ESD) (1) Electrostatic discharge Human body model (HBM), per AEC Q100-002 (1) HBM ESD Classification Level 2 ±2000 Charged device model (CDM), per AEC Q100011 CDM ESD Classification Level C6 ±1000 UNIT V AEC Q100-002 indicate that HBM stressing shall be in accordance with the ANSI/ESDA/JEDEC JS-001 specification. 6.3 Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) VCC MIN NOM MAX 2 5 6 Supply voltage VCC = 2 V VIH High-level input voltage VCC = 4.5 V 3.15 V 4.2 VCC = 2 V Low-level input voltage V 1.5 VCC = 6 V VIL UNIT 0.5 VCC = 4.5 V 1.35 VCC = 6 V V 1.8 VI Input voltage 0 VCC V VO Output voltage 0 VCC V Δt/Δv Input transition rise and fall rate VCC = 2 V TA 1000 VCC = 4.5 V 500 VCC = 6 V 400 Operating free-air temperature –40 125 ns °C 6.4 Thermal Information CD74HC125-Q1 THERMAL METRIC PW (TSSOP) D (SOIC) 14 PINS 14 PINS UNIT RθJA Junction-to-ambient thermal resistance 151.7 133.6 °C/W RθJC(top) Junction-to-case (top) thermal resistance 79.4 89.0 °C/W RθJB Junction-to-board thermal resistance 94.7 89.5 °C/W ΨJT Junction-to-top characterization parameter 25.2 45.5 °C/W ΨJB Junction-to-board characterization parameter 94.1 89.1 °C/W RθJC(bot) Junction-to-case (bottom) thermal resistance N/A N/A °C/W 4 Submit Documentation Feedback Copyright © 2004–2020, Texas Instruments Incorporated Product Folder Links: CD74HC125-Q1 CD74HC125-Q1 www.ti.com SCLS579B – APRIL 2004 – REVISED APRIL 2020 6.5 Electrical Characteristics over operating free-air temperature range; typical values measured at TA = 25°C (unless otherwise noted). Operating free-air temperature (TA) PARAMETER TEST CONDITIONS VCC 25°C MIN IOH = -20 µA VOH High-level output voltage VI = VIH or VIL Low-level output voltage -40°C to 125°C MAX MIN 2V 1.9 1.9 4.5 V 4.4 4.4 5.9 5.9 IOH = -6 mA 6V 4.5 V 3.98 3.7 IOH = -7.8 mA 6V 5.48 5.2 IOL = 20 µA VOL TYP VI = VIH or VIL IOL = 20 µA TYP UNIT MAX V 2V 0.1 0.1 4.5 V 0.1 0.1 6V 0.1 0.1 IOL = 6 mA 4.5 V 0.26 0.4 IOL = 7.8 mA 6V 0.26 0.4 V II Input leakage current VI = VCC or GND 6V ±0.1 ±1 µA ICC Supply current VI = VCC or GND 6V 8 160 µA IOZ Off-state output current VI = VIL or VIH 6V ±0.5 ±10 µA Ci Input capacitance 10 10 pF CO Output capacitance 20 20 pF IO = 0 mA 2 V to 6 V 3-state 6.6 Switching Characteristics over operating free-air temperature range (unless otherwise noted) Operating free-air temperature (TA) PARAMETER FROM TO CONDITIONS VCC 25°C MIN TYP 2V tpd Propagation delay A Y CL = 50 pF CL = 15 pF Enable time OE Y CL = 50 pF CL = 15 pF Disable time OE Y CL = 50 pF CL = 15 pF tt Transition-time Y CL = 50 pF MIN TYP 150 20 30 6V 17 26 125 190 4.5 V 25 38 6V 21 32 125 190 4.5 V 25 38 6V 21 32 2V 60 90 4.5 V 12 18 6V 10 15 5V 5V 5V Product Folder Links: CD74HC125-Q1 ns 8 ns 10 ns 10 Submit Documentation Feedback Copyright © 2004–2020, Texas Instruments Incorporated UNIT MAX 4.5 V 2V tdis MAX 100 2V ten –40°C to 125°C ns 5 CD74HC125-Q1 SCLS579B – APRIL 2004 – REVISED APRIL 2020 www.ti.com 6.7 Operating Characteristics over operating free-air temperature range; typical values measured at TA = 25°C (unless otherwise noted). PARAMETER Cpd TEST CONDITIONS Power dissipation capacitance per gate No load VCC MIN TYP 5V MAX UNIT 29 pF 6.8 Typical Characteristics TA = 25°C 7 0.15 6 VOH Output High Voltage (V) VOL Output Low Voltage (V) 0.135 0.12 0.105 0.09 0.075 0.06 0.045 0.03 2V 4.5 V 6V 0.015 5 4 3 2 2V 4.5 V 6V 1 0 0 0 0.0009 0.0018 0.0027 0.0036 0.0045 IOL Output Low Current (mA) 0 0.0054 0.001 0.002 0.003 0.004 IOH Output High Current (mA) D001 Figure 1. Output voltage versus output current in low state 0.005 0.006 D002 Figure 2. Output voltage versus output current in high state 7 Parameter Measurement Information • • Phase relationships between waveforms were chosen arbitrarily. All input pulses are supplied by generators having the following characteristics: PRR ≤ 1 MHz, ZO = 50 Ω, tt < 6 ns. The outputs are measured one at a time, with one input transition per measurement. VCC Test Point 90% 10% 10% S1 tr(1) RL From Output Under Test VCC 90% Input CL(1) 90% S2 0V tf(1) VOH 90% Output 10% CL= 50 pF and includes probe and jig capacitance. Figure 3. Load Circuit 6 Submit Documentation Feedback 10% tr(1) tf(1) VOL Figure 4. Voltage Waveforms Transition Times Copyright © 2004–2020, Texas Instruments Incorporated Product Folder Links: CD74HC125-Q1 CD74HC125-Q1 www.ti.com SCLS579B – APRIL 2004 – REVISED APRIL 2020 Parameter Measurement Information (continued) VCC Output Control 50% 50% 0V tPZL (3) tPLZ (4) § 9CC Output Waveform 1 S1 at VLOAD(1) 50% 10% VOL tPZH(3) Output Waveform 2 S1 at GND(2) tPHZ(4) 90% VOH 50% §0V The maximum between tPLH and tPHL is used for tpd. Figure 5. Voltage Waveforms Propagation Delays Submit Documentation Feedback Copyright © 2004–2020, Texas Instruments Incorporated Product Folder Links: CD74HC125-Q1 7 CD74HC125-Q1 SCLS579B – APRIL 2004 – REVISED APRIL 2020 www.ti.com 8 Detailed Description 8.1 Overview This device contains four independent buffers with 3-state outputs. Each gate performs the Boolean function Y = A in positive logic. 8.2 Functional Block Diagram xOE xA xY 8.3 Feature Description 8.3.1 Balanced CMOS 3-State Outputs A balanced output allows the device to sink and source similar currents. The drive capability of this device may create fast edges into light loads so routing and load conditions should be considered to prevent ringing. Additionally, the outputs of this device are capable of driving larger currents than the device can sustain without being damaged. It is important for the output power of the device to be limited to avoid damage due to overcurrent. The electrical and thermal limits defined in the Absolute Maximum Ratings must be followed at all times. The CD74HC125-Q1 can drive a load with a total capacitance less than or equal to 50 pF connected to a highimpedance CMOS input while still meeting all of the datasheet specifications. Larger capacitive loads can be applied, however it is not recommended to exceed 70 pF. If larger capacitive loads are required, it is recommended to add a series resistor between the output and the capacitor to limit output current to the values given in the Absolute Maximum Ratings. 3-State outputs can be placed into a high-impedance state. In this state, the output will neither source nor sink current, and leakage current is defined by the IOZ specification in the Electrical Characteristics. A pull-up or pulldown resistor can be used to ensure that the output remains HIGH or LOW, respectively, during the highimpedance state. 8.3.2 Standard CMOS Inputs Standard CMOS inputs are high impedance and are typically modeled as a resistor from the input to ground in parallel with the input capacitance given in the Electrical Characteristics. The worst case resistance is calculated with the maximum input voltage, given in the Absolute Maximum Ratings, and the maximum input leakage current, given in the Electrical Characteristics, using ohm's law (R = V ÷ I). Signals applied to the inputs need to have fast edge rates, as defined by Δt/Δv in the Recommended Operating Conditions to avoid excessive current consumption and oscillations. If a slow or noisy input signal is required, a device with a Schmitt-trigger input should be used to condition the input signal prior to the standard CMOS input. 8 Submit Documentation Feedback Copyright © 2004–2020, Texas Instruments Incorporated Product Folder Links: CD74HC125-Q1 CD74HC125-Q1 www.ti.com SCLS579B – APRIL 2004 – REVISED APRIL 2020 Feature Description (continued) 8.3.3 Clamp Diode Structure The inputs and outputs to this device have both positive and negative clamping diodes as depicted in Figure 6. CAUTION Voltages beyond the values specified in the Absolute Maximum Ratings table can cause damage to the device. The recommended input and output voltage ratings may be exceeded if the input and output clamp-current ratings are observed. Device VCC +IIK +IOK Logic Input -IIK Output -IOK GND Figure 6. Electrical Placement of Clamping Diodes for Each Input and Output 8.4 Device Functional Modes Table 1. Function Table INPUTS OUTPUT OE A Y L H H L L L H X Z Submit Documentation Feedback Copyright © 2004–2020, Texas Instruments Incorporated Product Folder Links: CD74HC125-Q1 9 CD74HC125-Q1 SCLS579B – APRIL 2004 – REVISED APRIL 2020 www.ti.com 9 Application and Implementation NOTE Information in the following applications sections is not part of the TI component specification, and TI does not warrant its accuracy or completeness. TI’s customers are responsible for determining suitability of components for their purposes. Customers should validate and test their design implementation to confirm system functionality. 9.1 Application Information In this application, a buffer with 3-state output is used to disable a data signal as shown in Figure 7. The remaining three buffers can be used for other applications in the system, or the inputs can be grounded and the channels left unused. 9.2 Typical Application System Controller OE Data A Y Output Figure 7. Typical application block diagram 9.2.1 Design Requirements 9.2.1.1 Power Considerations Ensure the desired supply voltage is within the range specified in the Recommended Operating Conditions. The supply voltage sets the device's electrical characteristics as described in the Electrical Characteristics. The supply must be capable of sourcing current equal to the total current to be sourced by all outputs of the CD74HC125-Q1 plus the maximum supply current, ICC, listed in the Electrical Characteristics. The logic device can only source or sink as much current as it is provided at the supply and ground pins, respectively. Be sure not to exceed the maximum total current through GND or VCC listed in the Absolute Maximum Ratings. Total power consumption can be calculated using the information provided in CMOS Power Consumption and Cpd Calculation. Thermal increase can be calculated using the information provided in Thermal Characteristics of Standard Linear and Logic (SLL) Packages and Devices. CAUTION The maximum junction temperature, TJ(max) listed in the Absolute Maximum Ratings, is an additional limitation to prevent damage to the device. Do not violate any values listed in the Absolute Maximum Ratings. These limits are provided to prevent damage to the device. 9.2.1.2 Input Considerations Unused inputs must be terminated to either VCC or ground. These can be directly terminated if the input is completely unused, or they can be connected with a pull-up or pull-down resistor if the input is to be used sometimes, but not always. A pull-up resistor is used for a default state of HIGH, and a pull-down resistor is used for a default state of LOW. The resistor size is limited by drive current of the controller, leakage current into the CD74HC125-Q1, as specified in the Electrical Characteristics, and the desired input transition rate. A 10-kΩ resistor value is often used due to these factors. 10 Submit Documentation Feedback Copyright © 2004–2020, Texas Instruments Incorporated Product Folder Links: CD74HC125-Q1 CD74HC125-Q1 www.ti.com SCLS579B – APRIL 2004 – REVISED APRIL 2020 Typical Application (continued) The CD74HC125-Q1 has standard CMOS inputs, so input signal edge rates cannot be slow. Slow input edge rates can cause oscillations and damaging shoot-through current. The recommended rates are defined in the Recommended Operating Conditions. Refer to the Feature Description for additional information regarding the inputs for this device. 9.2.1.3 Output Considerations The positive supply voltage is used to produce the output HIGH voltage. Drawing current from the output will decrease the output voltage as specified by the VOH specification in the Electrical Characteristics. Similarly, the ground voltage is used to produce the output LOW voltage. Sinking current into the output will increase the output voltage as specified by the VOL specification in the Electrical Characteristics. Unused outputs can be left floating. Do not connect outputs directly to VCC or ground. Refer to Feature Description for additional information regarding the outputs for this device. 9.2.2 Detailed Design Procedure 1. Add a decoupling capacitor from VCC to GND. The capacitor needs to be placed physically close to the device and electrically close to both the VCC and GND pins. An example layout is shown in the Layout. 2. Ensure the capacitive load at the output is ≤ 70 pF. This is not a hard limit, however it will ensure optimal performance. This can be accomplished by providing short, appropriately sized traces from the CD74HC125Q1 to the receiving device. 3. Ensure the resistive load at the output is larger than (VCC / IO(max)) Ω. This will ensure that the maximum output current from the Absolute Maximum Ratings is not violated. Most CMOS inputs have a resistive load measured in megaohms; much larger than the minimum calculated above. 4. Thermal issues are rarely a concern for logic gates, however the power consumption and thermal increase can be calculated using the steps provided in the application report, CMOS Power Consumption and Cpd Calculation 9.2.3 Application Curves OE Data Output Figure 8. Application timing diagram Submit Documentation Feedback Copyright © 2004–2020, Texas Instruments Incorporated Product Folder Links: CD74HC125-Q1 11 CD74HC125-Q1 SCLS579B – APRIL 2004 – REVISED APRIL 2020 www.ti.com 10 Power Supply Recommendations The power supply can be any voltage between the minimum and maximum supply voltage rating located in the Recommended Operating Conditions. Each VCC terminal should have a bypass capacitor to prevent power disturbance. A 0.1-μF capacitor is recommended for this device. It is acceptable to parallel multiple bypass caps to reject different frequencies of noise. The 0.1-μF and 1-μF capacitors are commonly used in parallel. The bypass capacitor should be installed as close to the power terminal as possible for best results, as shown in Figure 9. 11 Layout 11.1 Layout Guidelines When using multiple-input and multiple-channel logic devices inputs must not ever be left floating. In many cases, functions or parts of functions of digital logic devices are unused; for example, when only two inputs of a triple-input AND gate are used. Such unused input pins must not be left unconnected because the undefined voltages at the outside connections result in undefined operational states. All unused inputs of digital logic devices must be connected to a logic high or logic low voltage, as defined by the input voltage specifications, to prevent them from floating. The logic level that must be applied to any particular unused input depends on the function of the device. Generally, the inputs are tied to GND or VCC, whichever makes more sense for the logic function or is more convenient. 11.2 Layout Example GND VCC Recommend GND flood fill for improved signal isolation, noise reduction, and thermal dissipation 0.1 F Avoid 90° corners for signal lines Bypass capacitor placed close to the device 1OE 1 14 VCC 1A 2 13 4OE 1Y 3 12 4A 2OE 4 11 4Y 2A 5 10 3OE 2Y 6 9 3A GND 7 8 3Y Unused inputs tied to VCC Unused output left floating Figure 9. Example layout for the CD74HC125-Q1 12 Submit Documentation Feedback Copyright © 2004–2020, Texas Instruments Incorporated Product Folder Links: CD74HC125-Q1 CD74HC125-Q1 www.ti.com SCLS579B – APRIL 2004 – REVISED APRIL 2020 12 Device and Documentation Support 12.1 Documentation Support 12.1.1 Related Documentation For related documentation see the following: • HCMOS Design Considerations • CMOS Power Consumption and CPD Calculation • Designing with Logic 12.2 Related Links The table below lists quick access links. Categories include technical documents, support and community resources, tools and software, and quick access to sample or buy. 12.3 Community Resources TI E2E™ support forums are an engineer's go-to source for fast, verified answers and design help — straight from the experts. Search existing answers or ask your own question to get the quick design help you need. Linked content is provided "AS IS" by the respective contributors. They do not constitute TI specifications and do not necessarily reflect TI's views; see TI's Terms of Use. 12.4 Trademarks E2E is a trademark of Texas Instruments. All other trademarks are the property of their respective owners. 12.5 Electrostatic Discharge Caution These devices have limited built-in ESD protection. The leads should be shorted together or the device placed in conductive foam during storage or handling to prevent electrostatic damage to the MOS gates. 12.6 Glossary SLYZ022 — TI Glossary. This glossary lists and explains terms, acronyms, and definitions. 13 Mechanical, Packaging, and Orderable Information The following pages include mechanical, packaging, and orderable information. This information is the most current data available for the designated devices. This data is subject to change without notice and revision of this document. For browser-based versions of this data sheet, refer to the left-hand navigation. Submit Documentation Feedback Copyright © 2004–2020, Texas Instruments Incorporated Product Folder Links: CD74HC125-Q1 13 PACKAGE OPTION ADDENDUM www.ti.com 28-Sep-2021 PACKAGING INFORMATION Orderable Device Status (1) Package Type Package Pins Package Drawing Qty Eco Plan (2) Lead finish/ Ball material MSL Peak Temp Op Temp (°C) Device Marking (3) (4/5) (6) CD74HC125QM96G4Q1 ACTIVE SOIC D 14 2500 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 125 HC125Q CD74HC125QPWRG4Q1 ACTIVE TSSOP PW 14 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 125 HC125Q CD74HC125QPWRQ1 ACTIVE TSSOP PW 14 2000 RoHS & Green NIPDAU Level-1-260C-UNLIM -40 to 125 HC125Q (1) The marketing status values are defined as follows: ACTIVE: Product device recommended for new designs. LIFEBUY: TI has announced that the device will be discontinued, and a lifetime-buy period is in effect. NRND: Not recommended for new designs. Device is in production to support existing customers, but TI does not recommend using this part in a new design. PREVIEW: Device has been announced but is not in production. Samples may or may not be available. OBSOLETE: TI has discontinued the production of the device. (2) RoHS: TI defines "RoHS" to mean semiconductor products that are compliant with the current EU RoHS requirements for all 10 RoHS substances, including the requirement that RoHS substance do not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, "RoHS" products are suitable for use in specified lead-free processes. TI may reference these types of products as "Pb-Free". RoHS Exempt: TI defines "RoHS Exempt" to mean products that contain lead but are compliant with EU RoHS pursuant to a specific EU RoHS exemption. Green: TI defines "Green" to mean the content of Chlorine (Cl) and Bromine (Br) based flame retardants meet JS709B low halogen requirements of
CD74HC125QM96Q1 价格&库存
很抱歉,暂时无法提供与“CD74HC125QM96Q1”相匹配的价格&库存,您可以联系我们找货
