MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
KMQ
Series
Downsized, 105℃
KMQ
・Downsized from current standard KMG series
・Solvent resistant type except 160 to 450Vdc
(see PRECAUTIONS AND GUIDELINES)
・RoHS2 Compliant
Downsized
KMG
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-55 to +105℃(6.3 to 100Vdc) -40 to +105℃(160 to 400Vdc) -25 to +105℃(450Vdc)
6.3 to 450Vdc
±20% (M)
6.3 to 100Vdc
I=0.03CV or 4µA, whichever is greater.
(at 20℃, 120Hz)
160 to 450Vdc
CV≦1,000
I=0.1CV+40 max.
CV>1,000
I=0.04CV+100 max.
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃ after 1 minute)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V 63V 100V 160 to 250V 350 to 400V 450V
tanδ(Max.)
0.28 0.24 0.20 0.16 0.14 0.12 0.10 0.08
0.20
0.24
0.24
When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase.
(at 20℃, 120Hz)
Rated voltage (Vdc)
6.3V 10V 16V 25V 35V 50V 63 to 100V 160 to 200V 250V 350V 400V 450V
5
4
3
2
2
2
2
3
3
4
4
6
≦φ8
Z(-25℃)/Z(+20℃)
5
4
3
2
2
2
2
3
3
4
4
6
≧φ10
10
8
6
4
3
3
3
8
10
8
8
≦φ8
Z(-40℃)/Z(+20℃)
(at 120Hz)
8
6
4
3
3
3
4
4
6
6
≧φ10 10
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for 1,000 hours (2,000 hours forφ10 and more) at 105℃.
Capacitance change
≦±20% of the initial value
D.F. (tanδ)
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without
voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4.
Rated voltage
6.3 to 100Vdc
160 to 450Vdc
Capacitance change
D.F. (tanδ)
Leakage current
≦500% of the initial specified value
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
◆DIMENSIONS [mm]
φD'
φd
Sleeve (PET : Brown)
F±0.5
Code : E
F±0.5
● Terminal
15min.
L'
Vent
(except φ5)
4min.
(φ5 to φ10)
(φ12.5 to φ18)
Gas escape end seal
φD
5
φd 0.5
F
2.0
φD'
L'
6.3
0.5
2.5
10 12.5
8
0.6 0.6 0.6
3.5 5.0 5.0
φD+0.5max.
L+1.5max.
16
0.8
7.5
18
0.8
7.5
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E KMQ A A A E A A A A A M A A A N
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 1.0µF:1R0,10µF:100,100µF:101)
Lead forming·taping code
Terminal code
Voltage code (ex. 6.3V:6R3,35V:350,100V:101)
Series code
Category
Please refer to "Product code guide (radial lead type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001U
Downsized, 105℃
KMQSeries
◆STANDARD RATINGS
WV
(Vdc)
6.3
10
16
25
35
50
63
Cap
(µF)
1,000
2,200
3,300
4,700
6,800
10,000
15,000
22,000
220
330
470
1,000
2,200
3,300
4,700
6,800
10,000
15,000
22,000
220
330
470
1,000
2,200
3,300
4,700
6,800
10,000
15,000
100
220
330
470
1,000
2,200
3,300
4,700
6,800
10,000
47
68
100
220
330
470
1,000
2,200
3,300
4,700
6,800
1.0
2.2
3.3
4.7
10
22
33
47
68
100
220
330
470
1,000
2,200
3,300
22
is not solvent resistant.
Rated ripple
current
Case size
tanδ
(mArms/
φD×L(mm)
105℃, 120Hz)
8 ×11.5
10 ×16
10 ×20
12.5× 20
12.5× 25
16 ×25
16 ×31.5
18 ×35.5
5 ×11
6.3×11
6.3×11
10 ×12.5
10 ×16
12.5× 20
12.5× 25
16 ×25
16 ×31.5
16 ×35.5
18 ×40
6.3×11
6.3×11
8 ×11.5
10 ×12.5
10 ×20
12.5× 25
16 ×25
16 ×25
16 ×35.5
18 ×40
5 ×11
6.3×11
8 ×11.5
10 ×12.5
10 ×16
12.5× 25
16 ×25
16 ×25
16 ×35.5
18 ×40
5 ×11
6.3×11
6.3×11
8 ×11.5
10 ×12.5
10 ×16
12.5× 20
16 ×25
16 ×31.5
16 ×35.5
18 ×40
5 ×11
5 ×11
5 ×11
5 ×11
5 ×11
5 ×11
5 ×11
6.3×11
6.3×11
8 ×11.5
10 ×12.5
10 ×16
10 ×20
12.5× 25
16 ×31.5
18 ×35.5
5 ×11
0.28
0.30
0.32
0.34
0.38
0.46
0.56
0.70
0.24
0.24
0.24
0.24
0.26
0.28
0.30
0.34
0.42
0.52
0.66
0.20
0.20
0.20
0.20
0.22
0.24
0.26
0.30
0.38
0.48
0.16
0.16
0.16
0.16
0.16
0.18
0.20
0.22
0.26
0.34
0.14
0.14
0.14
0.14
0.14
0.14
0.14
0.16
0.18
0.20
0.24
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.14
0.16
0.10
390
635
840
1,090
1,350
1,650
1,820
2,280
155
210
250
460
705
1,000
1,260
1,570
1,820
2,050
2,420
190
225
315
500
710
1,170
1,500
1,600
1,930
2,210
125
200
310
380
610
1,090
1,400
1,570
1,850
2,000
93
110
150
270
350
460
810
1,260
1,500
1,780
2,000
13
30
46
68
90
115
150
190
300
410
540
950
1,410
1,770
71
Part No.
EKMQ6R3E□□102MHB5D
EKMQ6R3E□□222MJ16S
EKMQ6R3E□□332MJ20S
EKMQ6R3E□□472MK20S
EKMQ6R3E□□682MK25S
EKMQ6R3E□□103ML25S
EKMQ6R3E□□153MLN3S
EKMQ6R3E□□223MMP1S
EKMQ100E□□221ME11D
EKMQ100E□□331MF11D
EKMQ100E□□471MF11D
EKMQ100E□□102MJC5S
EKMQ100E□□222MJ16S
EKMQ100E□□332MK20S
EKMQ100E□□472MK25S
EKMQ100E□□682ML25S
EKMQ100E□□103MLN3S
EKMQ100E□□153MLP1S
EKMQ100E□□223MM40S
EKMQ160E□□221MF11D
EKMQ160E□□331MF11D
EKMQ160E□□471MHB5D
EKMQ160E□□102MJC5S
EKMQ160E□□222MJ20S
EKMQ160E□□332MK25S
EKMQ160E□□472ML25S
EKMQ160E□□682ML25S
EKMQ160E□□103MLP1S
EKMQ160E□□153MM40S
EKMQ250E□□101ME11D
EKMQ250E□□221MF11D
EKMQ250E□□331MHB5D
EKMQ250E□□471MJC5S
EKMQ250E□□102MJ16S
EKMQ250E□□222MK25S
EKMQ250E□□332ML25S
EKMQ250E□□472ML25S
EKMQ250E□□682MLP1S
EKMQ250E□□103MM40S
EKMQ350E□□470ME11D
EKMQ350E□□680MF11D
EKMQ350E□□101MF11D
EKMQ350E□□221MHB5D
EKMQ350E□□331MJC5S
EKMQ350E□□471MJ16S
EKMQ350E□□102MK20S
EKMQ350E□□222ML25S
EKMQ350E□□332MLN3S
EKMQ350E□□472MLP1S
EKMQ350E□□682MM40S
EKMQ500E□□1R0ME11D
EKMQ500E□□2R2ME11D
EKMQ500E□□3R3ME11D
EKMQ500E□□4R7ME11D
EKMQ500E□□100ME11D
EKMQ500E□□220ME11D
EKMQ500E□□330ME11D
EKMQ500E□□470MF11D
EKMQ500E□□680MF11D
EKMQ500E□□101MHB5D
EKMQ500E□□221MJC5S
EKMQ500E□□331MJ16S
EKMQ500E□□471MJ20S
EKMQ500E□□102MK25S
EKMQ500E□□222MLN3S
EKMQ500E□□332MMP1S
EKMQ630E□□220ME11D
WV
(Vdc)
63
100
160
200
250
350
400
Cap
(µF)
33
47
68
100
220
330
470
1,000
2,200
1.0
2.2
3.3
4.7
10
22
33
47
68
100
220
330
470
1,000
10
22
33
47
68
100
220
330
470
1.0
2.2
3.3
4.7
10
22
33
47
68
100
220
330
3.3
4.7
10
22
33
47
68
100
220
2.2
3.3
4.7
10
22
33
47
68
100
1.0
2.2
3.3
4.7
10
Rated ripple
current
Case size
tanδ
(mArms/
φD×L(mm)
105℃, 120Hz)
6.3 × 11
6.3 × 11
8 × 11.5
8 × 11.5
10 × 16
10 × 20
12.5 × 20
16 × 25
18 × 35.5
5 × 11
5 × 11
5 × 11
5 × 11
5 × 11
6.3 × 11
8 × 11.5
8 × 11.5
10 × 12.5
10 × 16
12.5 × 20
12.5 × 25
16 × 25
18 × 35.5
8 × 11.5
10 × 12.5
10 × 16
10 × 20
12.5 × 20
12.5 × 25
16 × 31.5
18 × 35.5
18 × 40
6.3 × 11
6.3 × 11
6.3 × 11
6.3 × 11
8 × 11.5
10 × 16
10 × 20
12.5 × 20
12.5 × 25
16 × 25
16 × 35.5
18 × 40
6.3 × 11
6.3 × 11
10 × 12.5
10 × 20
10 × 20
12.5 × 20
16 × 25
16 × 25
18 × 35.5
6.3 × 11
8 × 11.5
8 × 11.5
10 × 12.5
12.5 × 20
12.5 × 25
16 × 25
16 × 25
18 × 31.5
6.3 × 11
8 × 11.5
8 × 11.5
10 × 12.5
10 × 16
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.12
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.20
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
0.24
100
120
155
200
335
510
640
930
1,650
15
21
29
32
50
93
130
140
190
240
390
540
715
960
41
92
125
150
250
310
540
705
855
16
25
30
35
57
105
140
195
250
335
500
675
28
35
71
105
140
190
270
310
485
21
30
39
64
130
170
230
285
375
15
27
34
42
64
Part No.
EKMQ630E□□330MF11D
EKMQ630E□□470MF11D
EKMQ630E□□680MHB5D
EKMQ630E□□101MHB5D
EKMQ630E□□221MJ16S
EKMQ630E□□331MJ20S
EKMQ630E□□471MK20S
EKMQ630E□□102ML25S
EKMQ630E□□222MMP1S
EKMQ101E□□1R0ME11D
EKMQ101E□□2R2ME11D
EKMQ101E□□3R3ME11D
EKMQ101E□□4R7ME11D
EKMQ101E□□100ME11D
EKMQ101E□□220MF11D
EKMQ101E□□330MHB5D
EKMQ101E□□470MHB5D
EKMQ101E□□680MJC5S
EKMQ101E□□101MJ16S
EKMQ101E□□221MK20S
EKMQ101E□□331MK25S
EKMQ101E□□471ML25S
EKMQ101E□□102MMP1S
EKMQ161E□□100MHB5D
EKMQ161E□□220MJC5S
EKMQ161E□□330MJ16S
EKMQ161E□□470MJ20S
EKMQ161E□□680MK20S
EKMQ161E□□101MK25S
EKMQ161E□□221MLN3S
EKMQ161E□□331MMP1S
EKMQ161E□□471MM40S
EKMQ201E□□1R0MF11D
EKMQ201E□□2R2MF11D
EKMQ201E□□3R3MF11D
EKMQ201E□□4R7MF11D
EKMQ201E□□100MHB5D
EKMQ201E□□220MJ16S
EKMQ201E□□330MJ20S
EKMQ201E□□470MK20S
EKMQ201E□□680MK25S
EKMQ201E□□101ML25S
EKMQ201E□□221MLP1S
EKMQ201E□□331MM40S
EKMQ251E□□3R3MF11D
EKMQ251E□□4R7MF11D
EKMQ251E□□100MJC5S
EKMQ251E□□220MJ20S
EKMQ251E□□330MJ20S
EKMQ251E□□470MK20S
EKMQ251E□□680ML25S
EKMQ251E□□101ML25S
EKMQ251E□□221MMP1S
EKMQ351E□□2R2MF11D
EKMQ351E□□3R3MHB5D
EKMQ351E□□4R7MHB5D
EKMQ351E□□100MJC5S
EKMQ351E□□220MK20S
EKMQ351E□□330MK25S
EKMQ351E□□470ML25S
EKMQ351E□□680ML25S
EKMQ351E□□101MMN3S
EKMQ401E□□1R0MF11D
EKMQ401E□□2R2MHB5D
EKMQ401E□□3R3MHB5D
EKMQ401E□□4R7MJC5S
EKMQ401E□□100MJ16S
□□ : Enter the appropriate lead forming or taping code.
CAT. No. E1001U
Downsized, 105℃
KMQSeries
◆STANDARD RATINGS
WV
(Vdc)
400
450
Cap
(µF)
22
33
47
68
100
2.2
3.3
Rated ripple
current
Case size
tanδ
(mArms/
φD×L(mm)
105℃, 120Hz)
12.5× 25
16 × 25
16 × 25
16 ×31.5
18 ×35.5
8×11.5
10 ×12.5
0.24
0.24
0.24
0.24
0.24
0.24
0.24
145
195
200
240
310
Part No.
EKMQ401E□□220MK25S
EKMQ401E□□330ML25S
EKMQ401E□□470ML25S
EKMQ401E□□680MLN3S
EKMQ401E□□101MMP1S
EKMQ451E□□2R2MHB5D
EKMQ451E□□3R3MJC5S
WV
(Vdc)
Cap
(µF)
450
4.7
10
22
33
47
68
100
Rated ripple
current
Case size
tanδ
(mArms/
φD×L(mm)
105℃, 120Hz)
10 × 12.5
10 × 20
12.5 × 25
16 × 25
16 × 31.5
18 × 35.5
18 × 40
0.24
0.24
0.24
0.24
0.24
0.24
0.24
32
56
100
125
155
185
200
Part No.
EKMQ451E□□4R7MJC5S
EKMQ451E□□100MJ20S
EKMQ451E□□220MK25S
EKMQ451E□□330ML25S
EKMQ451E□□470MLN3S
EKMQ451E□□680MMP1S
EKMQ451E□□101MM40S
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
Capacitance(µF)
1.0
10
100
2,200
Frequency(Hz)
to 4.7
to 68
to 1,000
to
50
0.65
0.75
0.80
0.85
120
1.00
1.00
1.00
1.00
300
1.35
1.25
1.15
1.03
1k
1.75
1.50
1.30
1.05
10k
2.30
1.75
1.40
1.08
100k
2.50
1.80
1.50
1.08
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
CAT. No. E1001U
