EKXG401ELL330MK251
EKXG401ELL330MK251
    NCC(贵弥功)
    AEC-D12.5X25MM_TM
EKXG401ELL330MK251 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS 160 to 450Vdc long life, 105℃ KXG Series KXJ Downsized ・For electronic ballast circuits and other long life applications ・Endurance with ripple current : 8,000 to 10,000 hours at 105℃ ・Non solvent resistant type ・RoHS2 Compliant KXG ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -40 to +105℃ (160 to 400Vdc) -25 to+105℃ (450Vdc) 160 to 450Vdc ±20% (M) (at 20℃, 120Hz) After 1 minute After 5 minutes CV≦1,000 I=0.1CV+40 I=0.03CV+15 CV>1,000 I=0.04CV+100 I=0.02CV+25 Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) (at 20℃) Rated voltage (Vdc) 160 to 250V 350 to 450V tanδ (Max.) 0.20 0.24 (at 20℃, 120Hz) Rated voltage (Vdc) 160 to 250V 350 & 400V 450V Z(-25℃)/Z(+20℃) 3 5 6 Z(-40℃)/Z(+20℃) 6 6 (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 10,000 hours (8,000 hours forφ10) at 105℃. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦200% of the initial specified value Leakage current ≦500% of the initial specified value Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance Shelf Life ◆DIMENSIONS [mm] F±0.5 Code : E φD' φd Sleeve (PET : Brown) F±0.5 ● Terminal L' Vent 4min. 15min. (φ10) (φ12.5 to φ18) φD φd F φD' L' 10 0.6 5.0 18 12.5 16 0.6 0.8 0.8 5.0 7.5 7.5 φD+0.5max. L+1.5max. Gas escape end seal ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E KXG AAA E AA AAA M AAA S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 6.8µF:6R8,10µF:100,100µF:101) Lead forming·taping code Terminal code Voltage code (ex. 160V:161,450V:451) Series code Category Please refer to "Product code guide (radial lead type)" ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) Frequency(Hz) 6.8 to 82 100 to 330 120 1.00 1.00 1k 1.75 1.67 10k 2.25 2.05 100k 2.50 2.25 The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise. When long life performance is required in actual use, the rms ripple current has to be reduced. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001T MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS 160 to 450Vdc long life, 105℃ KXGSeries ◆STANDARD RATINGS WV (Vdc) 160 200 250 350 400 450 Cap (µF) Case size φD×L(mm) tanδ 10 22 33 47 68 82 100 100 150 220 330 10 22 33 47 68 82 100 150 220 330 10 22 33 47 68 82 100 150 220 6.8 10 22 33 47 68 68 82 100 120 150 6.8 10 15 22 33 47 47 68 82 100 120 150 6.8 10 15 22 33 33 47 68 82 100 10 × 16 10 × 20 10 × 20 10 × 20 12.5 × 20 12.5 × 20 12.5 × 25 16 × 20 16 × 20 16 × 25 18 × 31.5 10 × 16 10 × 20 10 × 20 12.5 × 20 12.5 × 20 16 × 20 16 × 20 16 × 25 18 × 25 18 × 35.5 10 × 20 10 × 20 12.5 × 20 12.5 × 20 16 × 20 16 × 20 16 × 25 18 × 25 18 × 31.5 10 × 16 10 × 20 12.5 × 20 16 × 20 16 × 20 16 × 25 18 × 20 18 × 25 18 × 25 18 × 31.5 18 × 35.5 10 × 16 10 × 20 12.5 × 20 12.5 × 20 16 × 20 16 × 25 18 × 20 18 × 25 18 × 25 18 × 31.5 18 × 35.5 18 × 40 10 × 20 12.5 × 20 12.5 × 25 16 × 20 16 × 25 18 × 20 18 × 25 18 × 31.5 18 × 35.5 18 × 40 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 0.24 Rated ripple current(mArms/105℃) 120Hz 100kHz 125 200 250 300 470 510 620 630 770 1,020 1,390 125 200 260 390 470 550 630 840 1,050 1,430 140 200 320 390 520 550 680 860 1,130 110 140 260 360 430 560 550 610 700 830 960 110 140 220 260 360 470 450 585 610 765 865 985 110 180 240 290 390 380 480 630 715 800 315 500 625 750 1,175 1,275 1,395 1,420 1,735 2,295 3,130 315 500 650 975 1,175 1,375 1,420 1,890 2,365 3,220 350 500 800 975 1,300 1,375 1,530 1,935 2,545 275 350 650 900 1,075 1,400 1,375 1,525 1,575 1,865 2,160 275 350 550 650 900 1,175 1,125 1,465 1,525 1,720 1,945 2,215 275 450 600 725 975 950 1,200 1,575 1,785 1,800 Part No. EKXG161E□□100MJ16S EKXG161E□□220MJ20S EKXG161E□□330MJ20S EKXG161E□□470MJ20S EKXG161E□□680MK20S EKXG161E□□820MK20S EKXG161E□□101MK25S EKXG161E□□101ML20S EKXG161E□□151ML20S EKXG161E□□221ML25S EKXG161E□□331MMN3S EKXG201E□□100MJ16S EKXG201E□□220MJ20S EKXG201E□□330MJ20S EKXG201E□□470MK20S EKXG201E□□680MK20S EKXG201E□□820ML20S EKXG201E□□101ML20S EKXG201E□□151ML25S EKXG201E□□221MM25S EKXG201E□□331MMP1S EKXG251E□□100MJ20S EKXG251E□□220MJ20S EKXG251E□□330MK20S EKXG251E□□470MK20S EKXG251E□□680ML20S EKXG251E□□820ML20S EKXG251E□□101ML25S EKXG251E□□151MM25S EKXG251E□□221MMN3S EKXG351E□□6R8MJ16S EKXG351E□□100MJ20S EKXG351E□□220MK20S EKXG351E□□330ML20S EKXG351E□□470ML20S EKXG351E□□680ML25S EKXG351E□□680MM20S EKXG351E□□820MM25S EKXG351E□□101MM25S EKXG351E□□121MMN3S EKXG351E□□151MMP1S EKXG401E□□6R8MJ16S EKXG401E□□100MJ20S EKXG401E□□150MK20S EKXG401E□□220MK20S EKXG401E□□330ML20S EKXG401E□□470ML25S EKXG401E□□470MM20S EKXG401E□□680MM25S EKXG401E□□820MM25S EKXG401E□□101MMN3S EKXG401E□□121MMP1S EKXG401E□□151MM40S EKXG451E□□6R8MJ20S EKXG451E□□100MK20S EKXG451E□□150MK25S EKXG451E□□220ML20S EKXG451E□□330ML25S EKXG451E□□330MM20S EKXG451E□□470MM25S EKXG451E□□680MMN3S EKXG451E□□820MMP1S EKXG451E□□101MM40S □□ : Enter the appropriate lead forming or taping code. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001T
EKXG401ELL330MK251 价格&库存
很抱歉,暂时无法提供与“EKXG401ELL330MK251”相匹配的价格&库存,您可以联系我们找货
