DEA105150HT-8044A1
DEA105150HT-8044A1
    TDK(东电化)
    多层高通滤波器
DEA105150HT-8044A1 数据手册
R F C o m p o n e n t s December 2018 Multilayer High Pass Filter For 5150-5950MHz DEA105150HT-8044A1 1.0x0.5mm [EIA 0402]* * Dimensions Code JIS[EIA] RF Components Multilayer High Pass Filter Conformity to RoHS Directive For 5150-5950MHz DEA105150HT-8044A1 SHAPES AND DIMENSIONS 1.00±0.05 [Top view] 0.42max. (3) (1) (2) Marking 0.50±0.05 (4) [Bottom view] 0.10±0.10 0.12±0.07 0.20±0.10 Terminal functions 1 Input / Output Port 2 GND 3 GND 4 Output / Input Port Dimensions in mm 0.30±0.10 RECOMMENDED LAND PATTERN EVALUATION BOARD 0.60 0.20 0.20 0.20 0.30 Dimensions in mm Metal (Cu) Thru-Hole Land DUT Material & Layer Top Resist Copper Surface Pattern FR4 Inner GND FR4 Copper Bottom GND Thickness – 0.035mm 0.10mm 0.018mm 0.30mm 0.035mm Line width should be designed to match 50Ω characteristic impedance, depending on PCB material and thickness. RoHS Directive Compliant Product: See the following for more details related to RoHS Directive compliant products. http://product.tdk.com/en/environment/rohs/ • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20181206 / rf_hpf_dea105150ht-8044a1_en.fm RF Components DEA105150HT-8044A1 ELECTRICAL CHARACTERISTICS Frequency Range (MHz) Item Insertion Loss (dB) Return Loss (dB) (Input/Output Port) Attenuation (dB) 5150 to 5250 5250 to 5350 5500 to 5950 5150 to 5250 5250 to 5350 5500 to 5950 5150 to 5250 5250 to 5350 5500 to 5950 5150 to 5250 5250 to 5350 5500 to 5950 4800 to 4960 4800 to 4960 Power Handling (W) Characteristic Impedance () Min. Typ. Max. — — — — — — 5 10 10 2 7 8 10 6 — 3.93 2.05 0.82 — — — 10 18 22 — — — 15 — — 50 (Nominal) 6.00 3.00 1.10 8.50 (–40 to +90°C) 4.50 (–40 to +90°C) 1.20 (–40 to +90°C) — — — — (–40 to +90°C) — (–40 to +90°C) — (–40 to +90°C) — — (–40 to +90°C) 0.8 ・Ta: +25±5°C TEMPERATURE RANGE Operating temperature (°C) –40 to +90 Storage temperature (°C) –40 to +90 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20181206 / rf_hpf_dea105150ht-8044a1_en.fm RF Components DEA105150HT-8044A1 FREQUENCY CHARACTERISTICS ATTENUATION 0 0 2 10 Attenuation(dB) Insertion Loss(dB) INSERTION LOSS 4 6 30 40 8 10 5000 20 5200 5400 5600 Frequency (MHz) 5800 6000 5400 5600 Frequency (MHz) 5800 6000 50 3000 3500 4000 4500 Frequency (MHz) 5000 5500 6000 RETURN LOSS 0 Return Loss(dB) 10 20 30 40 50 5000 5200 • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20181206 / rf_hpf_dea105150ht-8044a1_en.fm RF Components DEA105150HT-8044A1 RECOMMENDED REFLOW PROFILE Preheating Soldering Peak T4 T: Temperature 3°C/sec or lower 6°C/sec or lower T3 T2 T3 t3 T1 t1 t2 t: Time Preheating Temp. T1 150°C T2 200°C Time t1 60 to 120sec Soldering Critical zone (T3 to T4) Temp. Time T3 t2 217°C 60 to 120sec Peak Temp. T4 240 to 260°C Time t3 30sec max. t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20181206 / rf_hpf_dea105150ht-8044a1_en.fm RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications. 20181206 / rf_hpf_dea105150ht-8044a1_en.fm
DEA105150HT-8044A1 价格&库存
很抱歉,暂时无法提供与“DEA105150HT-8044A1”相匹配的价格&库存,您可以联系我们找货
DEA105150HT-8044A1
    • 1+0.56566
    • 100+0.52744
    • 300+0.48922
    • 500+0.45100
    • 2000+0.43189
    • 5000+0.42042
    库存:100
    DEA105150HT-8044A1
      • 1+0.50710
      • 100+0.43950
      库存:5900
      DEA105150HT-8044A1
        • 5+0.67994
        • 50+0.55596
        • 150+0.49396
        库存:28
