DEA162400HT-8053A1
DEA162400HT-8053A1
    TDK(东电化)
    DEA162400HT-8053A1
DEA162400HT-8053A1 数据手册
Oct. 2022 Ver.1.4a TDK Corporation   Multilayer High Pass Filter For 2400-2500MHz DEA Series P/N: 1.6x0.8mm [EIA 0603] TYPE DEA162400HT-8053A1 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies Oct. 2022 Ver.1.4a TDK Corporation   DEA162400HT-8053A1 ■ SHAPES AND DIMENSIONS [Top View] [Bottom View] (4) (1) (4) (3) (3) (2) (1) (2) Dimensions (mm) L W T a b c d e f 1.60 0.80 0.65 0.225 0.30 0.40 0.65 0.22 0.21 +/-0.10 +/-0.10 Max +/-0.05 +/-0.05 +/-0.05 +/-0.05 +/-0.05 +/-0.05 Terminal functions Input Port (1) GND (2) (3) (4) Output Port GND DC Cut YES. IN and OUT are isolated at DC.   ■ TERMINATION FINISH Material Au plate All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies Oct. 2022 Ver.1.4a TDK Corporation   DEA162400HT-8053A1 ■ ELECTRICAL CHARACTERISTICS ( Measurement ) Insertion Loss (dB) 2400 to TDK Spec Min. Typ. Max. 2500 0.47 0.70 Insertion Loss (dB) ( –40 to +90 °C ) Return Loss 2400 to 2500 - - 0.85 2400 to 2500 10 18.2 - Attenuation (dB) 1574 to 1606 30 38.8 - Parameter Frequency (MHz) Characteristic Impedance (ohm) Ta = +25+/-5°C 50 (Nominal) ■ MAXIMUM RATINGS Parameter Operating temperature (°C) Storage temperature (°C) Human Body Model : HBM Machine Model : MM Charged Device Model : CDM TDK Spec Conditions –40 to +90 °C –40 to +90 °C @Each Port (V) +/-1000 100pF / 1500ohm +/-150 200pF / 0ohm @Each Port (V) +/-500 Humidity : 60%RH max @Each Port (V) *1 : Refer to 3GPP TS 38.101-1 V15.2.0 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   Oct. 2022 Ver.1.4a TDK Corporation DEA162400HT-8053A1 ■ FREQUENCY CHARACTERISTICS All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies Oct. 2022 Ver.1.4a TDK Corporation   DEA162400HT-8053A1 ■ RECOMMENDED LAND PATTERN Unit : [mm] ■ EVALUATION BOARD * Line width should be designed to match 50 ohm characteristic impedance depending on PCB material and thickness. ■ ENVIRONMENT INFORMATION RoHS Statement RoHS Compliance All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies Oct. 2022 Ver.1.4a TDK Corporation DEA162400HT-8053A1 ■ RECOMMENDED REFLOW PROFILE 3oC/sec or lower Preheating Temp. T1 T2 Time t1 150°C 200°C 60 to 120sec 6oC/sec or lower Soldering Critical zone (T3 to T4) Peak Temp. Time Temp. Time T3 t2 T4 t3 * 217°C 60 to 120sec 240 to 260°C 30 sec Max * t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. Note: Lead free solder is recommended. Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry) ■ GENERAL TECHNICAL INFORMATION https://product.tdk.com/en/system/files?file=dam/doc/product/rf/rf/filter/general_tech_info/rf_general-technical-info_02_en.pdf All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies Oct. 2022 Ver.1.4a TDK Corporation   DEA162400HT-8053A1 ■ PACKAGING STYLE Reel Dimensions Carrier Tape Sprocket hole K Loading Direction E J C D A B B t H Dimensions (mm) A B C 0.97 1.8 8.0 +/-0.05 +/-0.05 D 3.5 +/-0.2 +/-0.05 E 1.75 +/-0.1 F 4.0 G G 2.0 +/-0.1 +/-0.05 F H 4.0 J 1.5 K 0.8 t 0.25 +/-0.1 +0.1/-0 MAX +/-0.05 STANDARD PACKAGE QUANTITY ( pieces/reel ) 4,000 All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies RF Components REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this catalog are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this catalog. (1) Aerospace/Aviation equipment (2) Transportation equipment (cars, electric trains, ships, etc.) (3) Medical equipment (4) Power-generation control equipment (5) Atomic energy-related equipment (6) Seabed equipment (7) Transportation control equipment (8) Public information-processing equipment (9) Military equipment (10) Electric heating apparatus, burning equipment (11) Disaster prevention/crime prevention equipment (12) Safety equipment (13) Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/ equipment or providing backup circuits, etc., to ensure higher safety. • All specifications are subject to change without notice. • Before using these products, be sure to request the delivery specifications.
DEA162400HT-8053A1 价格&库存
很抱歉,暂时无法提供与“DEA162400HT-8053A1”相匹配的价格&库存,您可以联系我们找货
