May. 2021 Ver.4.0
TDK Corporation
Multilayer High Pass Filter
For n77,n78,n79, 5-7GHz W-LAN
DEA Series
P/N:
1.6x0.8mm [EIA 0603] TYPE
DEA163300HT-8062A1
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
May. 2021 Ver.4.0
TDK Corporation
DEA163300HT-8062A1
■ SHAPES AND DIMENSIONS
[Top View]
(1)
[Bottom View]
(2)
(3)
(3)
(2)
(1)
Dimensions (mm)
L
W
T
a
b
c
d
e
1.60 0.80 0.65 0.25 0.23 0.40 0.55 0.60
+/-0.10 +/-0.10
Max
+/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10
Terminal functions
Input / Output Port
(1)
GND
(2)
Output / Input Port
(3)
DC Cut
YES. IN and OUT are isolated at DC.
■ TERMINATION FINISH
Material
Ag
May. 2021 Ver.4.0
TDK Corporation
DEA163300HT-8062A1
■ ELECTRICAL CHARACTERISTICS
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +85 °C )
Return Loss@Input (dB)
Return Loss@Output (dB)
Attenuation (dB)
Characteristic Impedance (ohm)
Ta = +25+/-5°C
Frequency (MHz)
3300
4400
5150
5925
3300
4400
5150
5925
3300
4400
5150
5925
3300
4400
5150
5925
450
1427
1710
1910
2300
2400
2500
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
to
4200
5000
5925
7250
4200
5000
5925
7250
4200
5000
5925
7250
4200
5000
5925
7250
960
1710
1910
2200
2400
2500
2690
( Measurement )
TDK Spec
Min. Typ. Max.
0.62 0.80
0.19 0.80
0.26 0.80
0.32 0.80
0.90
0.92
0.97
1.02
10 21.7
10 25.5
10 16.5
10 15.4
10 24.3
10 24.8
10 16.8
10 15.4
25 27.5
20 30.4
20 35.0
20 25.0
20 22.6
20 22.6
20 23.1
50 (Nominal)
May. 2021 Ver.4.0
TDK Corporation
DEA163300HT-8062A1
■ MAXIMUM RATINGS
Parameter
Operating temperature (°C)
Storage temperature (°C)
Power Handling (W) *1
Human Body Model : HBM
Machine Model : MM
Charged Device Model : CDM
TDK Spec
Conditions
–40 to +85 °C
–40 to +85 °C
Frequency (MHz)
CW
Duty 100%
1
3300 to 5000
CW
Duty 100%
1
5150 to 7250
@Each Port (V) +/-1000 100pF / 1500ohm
+/-150
200pF / 0ohm
@Each Port (V)
+/-500
Humidity : 60%RH max
@Each Port (V)
*1 : Refer to 3GPP TS 38.101-1 V15.2.0
May. 2021 Ver.4.0
TDK Corporation
DEA163300HT-8062A1
■ FREQUENCY CHARACTERISTICS
S21 Attenuation
S21 Insertion Loss
Attenuation
450
617
960
1427
1710
1910
2200
2300
2400
2500
2690
5
Attenuation[dB]
10
15
30
35
40
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
Attenuation
31.8
29.7
27.5
30.4
43.5
35.0
25.0
23.4
22.6
23.1
32.7
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
45
3400
3600
3800
4200
4400
5000
5150
5850
5925
7125
7150
7250
0.2
Insertion Loss[dB]
0.6
0.8
1
1.2
1.4
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
0.62
0.52
0.39
0.31
0.22
0.19
0.15
0.15
0.25
0.26
0.28
0.29
0.30
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
50
1000
1500
2000
2500
3000
3500
3000
4000
3500
S11 Return Loss
4500
5000
5500
6000
6500
7000
7500
8000
S11 Smith Chart
10
Return Loss[dB]
4000
Frequency[MHz]
Frequency[MHz]
15
30
35
Impedance
Return
3300
3400
3600
3800
4200
4400
5000
5150
5850
5925
7125
7150
7250
Loss
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
24.3
24.5
32.1
31.8
25.0
25.0
24.8
23.7
17.3
16.8
17.3
17.3
17.2
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
Return
3300
3400
3600
3800
4200
4400
5000
5150
5850
5925
7125
7150
7250
Loss
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
21.7
22.0
25.5
28.0
26.1
26.1
25.5
24.3
17.0
16.5
20.8
21.2
22.2
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
dB
3300
3400
3600
3800
4200
4400
5000
5150
5850
5925
7125
7150
7250
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
MHz
47.19+-5.27j
45.4+-3.35j
47.64+0.56j
51.96+1.72j
55.92+-0.77j
55.57+-2.07j
53.55+-4.83j
53.48+-5.79j
50.75+-13.79j
50.17+-14.55j
52.84+-13.91j
53.54+-13.76j
55.71+-13.58j
40
3000
3500
4000
4500
5000
5500
6000
6500
7000
7500
8000
Frequency[MHz]
S22 Return Loss
S22 Smith Chart
Return Loss[dB]
10
15
30
35
40
3000
3500
4000
4500
5000
5500
6000
6500
7000
7500
8000
Frequency[MHz]
Impedance
3300 MHz 43.67+-4.32j
3400 MHz 44.49+-5.09j
3600 MHz
47.4+-4.45j
3800 MHz 50.69+-3.94j
4200 MHz
53.35+-3.9j
4400 MHz 53.39+-3.86j
5000 MHz 51.28+-5.23j
5150 MHz 50.35+-6.15j
5850 MHz 44.28+-12.18j
5925 MHz 43.64+-12.54j
7125 MHz 41.65+-0.95j
7150 MHz 42.01+-0.23j
7250 MHz
43.2+2.48j
May. 2021 Ver.4.0
TDK Corporation
DEA163300HT-8062A1
04
■ RECOMMENDED LAND PATTERN
0 5
unit : mm
■ EVALUATION BOARD
05
Material & Layer
Copper Surface Pattern
FR-4
Inner GND
FR-4
Copper Bottom GND
Thickness
0.035 mm
0.10 mm
0.018 mm
0.30 mm
0.035 mm
unit : mm
* Line width should be designed to match 50 ohm characteristic impedance depending on
PCB material and thickness.
** The position of the throuh hole which have possibility of influence to the prerformance
are indicated by dimension line.
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
May. 2021 Ver.4.0
TDK Corporation
DEA163300HT-8062A1
■ RECOMMENDED REFLOW PROFILE
3oC/sec
or lower
Preheating
Temp.
T1
T2
Time
t1
150°C 200°C 60 to 120sec
6oC/sec
or lower
Soldering
Critical zone (T3 to T4)
Peak
Temp.
Time
Temp.
Time
T3
t2
T4
t3 *
217°C
60 to 120sec 240 to 260°C
30 sec Max
* t3 : Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Note:
Lead free solder is recommended.
Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry)
May. 2021 Ver.4.0
TDK Corporation
DEA163300HT-8062A1
■ PACKAGING STYLE
Reel Dimensions
Carrier Tape
K
Sprocket hole
Loading Direction
E
J
C
D
A
B
B
t
H
Dimensions (mm)
A
B
C
0.97 1.8 8.0
+/-0.05
+/-0.05
+/-0.2
G
F
D
3.5
E
1.75
F
4.0
G
2.0
H
4.0
J
1.5
K
0.8
t
0.25
+/-0.05
+/-0.1
+/-0.1
+/-0.05
+/-0.1
+0.1/-0
MAX
+/-0.05
STANDARD PACKAGE QUANTITY
( pieces/reel )
4,000
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“DEA163300HT-8062A1”相匹配的价格&库存,您可以联系我们找货
