May. 2021 Ver.3.0
TDK Corporation
Multilayer Diplexer
For LTE
DPX Series
P/N:
2.5x2.0mm [EIA 1008] TYPE
DPX252690DT-5072A1
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
May. 2021 Ver.3.0
TDK Corporation
DPX252690DT-5072A1
■ SHAPES AND DIMENSIONS
[Top view]
(8) (7) (6)
[Bottom view]
(5)
(1) (2) (3)
(4)
Dimensions (mm)
L
W
T
a
b
c
d
2.50 2.00 0.65 0.25 0.25 0.50 0.20
+/-0.15 +/-0.15
Max
+/-0.15 +/-0.15 +/-0.15 +/-0.15
Terminal functions
GND
(1)
GND
(2)
Common Port
(3)
GND
(4)
High-Band Port
(5)
(6)
(7)
(8)
GND
GND
Low-Band Port
■ TERMINATION FINISH
Material
Sn plate
May. 2021 Ver.3.0
TDK Corporation
DPX252690DT-5072A1
■ ELECTRICAL CHARACTERISTICS
( Measurement )
Low-Band
TDK Spec.
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +90 °C )
Return Loss (dB)
( Low-Band Port )
Attenuation (dB)
Characteristic Impedance (ohm)
Ta = +25+/-5°C
Frequency (MHz)
617 to
960
617 to
960
to
617 to
960
to
1427 to 1463
1452 to 1496
1463 to 1496
1496 to 1511
1554 to 1605
1695 to 1710
1710 to 1850
1760 to 1850
1850 to 2108
2109 to 2200
2300 to 2400
2401 to 2496
2496 to 2586
2620 to 2745
3400 to 3800
5150 to 5925
5926 to 12750
Min. Typ. Max.
0.34 0.42
0.52
16
27
22
32
22
32
25
31
22
26
22
25
22
25
22
25
22
26
24
29
25
32
25
33
25
33
25
34
30
39
25
32
10
50 (Nominal)
May. 2021 Ver.3.0
TDK Corporation
DPX252690DT-5072A1
( Measurement )
High-Band
TDK Spec
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +90 °C )
Return Loss (dB)
( High-Band Port )
Attenuation (dB)
Ta = +25+/-5°C
Frequency (MHz)
1452
1710
2010
1452
1710
2010
1452
1710
2010
617
915
3400
3600
3800
5130
5925
to 1496
to 1995
to 2690
to 1496
to 1995
to 2690
to 1496
to 1995
to 2690
to
915
to
960
to 3600
to 3800
to 5130
to 5925
to 12750
Min. Typ. Max.
0.63 0.75
0.42 0.60
0.57 0.70
0.85
0.70
0.85
15
24
12
17
12
17
25
27
24.5 27
28
38
5
50 (Nominal)
May. 2021 Ver.3.0
TDK Corporation
DPX252690DT-5072A1
( Measurement )
Common
Parameter
Isolation (dB)
Return Loss (dB)
( Common Port )
Frequency (MHz)
617
1452
1710
1830
617
1452
1710
2010
Ta = +25+/-5°C
to
to
to
to
to
to
to
to
960
1496
1805
2690
960
1496
1995
2690
TDK Spec
TBD
Min. Typ. Max.
24
26
25
37
24
26
24.5 26
17
22
12
16
12
16
50 (Nominal)
■ MAXIMUM RATINGS
Parameter
Operating temperature (°C)
Storage temperature (°C)
Power Handling (W) *1
Common Port
Low-Band
High-Band
Human Body Model : HBM
Machine Model : MM
Charged Device Model : CDM
TDK Spec
Conditions
–40 to +90 °C
–40 to +90 °C
Frequency (MHz)
Duty 50%
4
617 to
960
CW
2
1452 to 2690
Duty 50%
4
617 to
960
CW
2
1452 to 2690
@Each Port (V) +/-1000 100pF / 1500ohm
+/-150
200pF / 0ohm
@Each Port (V)
+/-500
Humidity : 60%RH max
@Each Port (V)
*1 : Refer to 3GPP TS 38.101-1 V15.2.0
May. 2021 Ver.3.0
TDK Corporation
DPX252690DT-5072A1
■ FREQUENCY CHARACTERISTICS
May. 2021 Ver.3.0
TDK Corporation
DPX252690DT-5072A1
May. 2021 Ver.3.0
TDK Corporation
DPX252690DT-5072A1
May. 2021 Ver.3.0
TDK Corporation
DPX252690DT-5072A1
■ RECOMMENDED LAND PATTERN
04
unit : mm
■ EVALUATION BOARD
4 9
9
unit : mm
Material & Layer
Copper Surface Pattern
FR-4
Inner GND
FR-4
Copper Bottom GND
Thickness
0.035 mm
0.10 mm
0.018 mm
0.30 mm
0.035 mm
* Line width should be designed to match 50 ohm characteristic impedance depending on
PCB material and thickness.
** The position of the throuh hole which have possibility of influence to the prerformance
are indicated by dimension line.
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
May. 2021 Ver.3.0
TDK Corporation
DPX252690DT-5072A1
■ RECOMMENDED REFLOW PROFILE
3oC/sec
or lower
Preheating
Temp.
T1
T2
Time
t1
150°C 200°C 60 to 120sec
6oC/sec
or lower
Soldering
Critical zone (T3 to T4)
Peak
Temp.
Time
Temp.
Time
T3
t2
T4
t3 *
217°C
60 to 120sec 240 to 260°C 30 sec Max
* t3 : Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Note:
Lead free solder is recommended.
Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry)
May. 2021 Ver.3.0
TDK Corporation
DPX252690DT-5072A1
■ PACKAGING STYLE
Reel Dimensions
Carrier Tape
Sprocket hole
K
Loading Direction
E
J
C
D
A
B
B
t
H
Dimensions (mm)
A
B
C
2.2 2.7 8.0
+/-0.05
D
3.5
+/-0.05 +0.3/-0.1 +/-0.05
G
F
E
1.75
F
4.0
G
2.0
H
4.0
J
1.5
+/-0.1
+/-0.1
+/-0.05
+/-0.1
+0.1/-0
K
t
0.85 0.25
MAX
+/-0.05
STANDARD PACKAGE QUANTITY
( pieces/reel )
2,000
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“DPX252690DT-5072A1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.72530
- 10+1.51902
- 30+1.43057
- 100+1.32020
- 500+1.27106
- 1000+1.24157
