May. 2021 Ver.2.0
TDK Corporation
Multilayer Diplexer
For LTE//n77
DPX Series
P/N:
1.6x0.8mm [EIA 0603] TYPE
DPX164200DT-8202B1
All specifications are subject to change without notice.
TDK Technology - Proprietary and Confidential Information of TDK Group Companies
May. 2021 Ver.2.0
TDK Corporation
DPX164200DT-8202B1
■ SHAPES AND DIMENSIONS
[Top View]
[Bottom View]
(6)
(5)
(4)
(4)
(5)
(6)
(1)
(2)
(3)
(3)
(2)
(1)
Dimensions (mm)
L
W
T
a
b
c
d
1.60 0.80 0.65 0.35 0.22 0.225 0.22
+/-0.10 +/-0.10
Max
+/-0.05 +/-0.05
+/-0.05
Terminal functions
GND
(1)
Common Port
(2)
GND
(3)
+/-0.05
(4)
(5)
(6)
High-Band Port
GND
Low-Band Port
■ TERMINATION FINISH
Material
Ag
May. 2021 Ver.2.0
TDK Corporation
DPX164200DT-8202B1
■ ELECTRICAL CHARACTERISTICS
( Measurement )
Low-Band
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +85 °C )
Return Loss@Low-Band (dB)
Attenuation (dB)
Characteristic Impedance (ohm)
Ta = +25+/-5°C
Frequency (MHz)
617
1166
1710
1805
1930
2300
2496
617
1166
1710
1805
1930
2300
2496
617
3300
3700
3800
4400
5150
5925
to
960
to 1606
to 1785
to 1885
to 1990
to 2496
to 2690
to
960
to 1606
to 1785
to 1885
to 1990
to 2496
to 2690
to 2690
to 3700
to 3800
to 4200
to 5000
to 5925
to 12750
TDK Spec
Min. Typ. Max.
0.11 0.50
0.26 0.50
0.31 0.50
0.34 0.50
0.37 0.50
0.54 0.90
0.68 1.10
0.70
0.70
0.70
0.70
0.70
1.10
1.30
10
15
22
15
23
25
25
10
50 (Nominal)
May. 2021 Ver.2.0
TDK Corporation
DPX164200DT-8202B1
( Measurement )
High-Band
Parameter
Insertion Loss (dB)
Insertion Loss (dB)
( –40 to +85 °C )
Return Loss@High-Band (dB)
Attenuation (dB)
Ta = +25+/-5°C
TDK Spec
Min. Typ. Max.
4200 0.91 1.24
4200 1.50
Frequency (MHz)
3300 to
3300 to
3300
500
1606
2400
2500
2700
4400
4900
5150
6250
6600
8400
9900
13200
to 4200 10
18
15
to 1606 13
14
to 2400 13
17
to 2500 14
18
to 2690 15
to 3150 0.5 2.2
to 4900 0.5 1.1
8.5
to 5150 5
13
to 5925 10
12
to 6550 10
12
to 8400 10
22
to 9000 15
12
to 12660 10
7
to 16800 3
50 (Nominal)
Common
Parameter
Return Loss (dB)
( Common Port )
Ta = +25+/-5°C
TDK Spec
Min. Typ. Max.
2690 10 17.0
4200 10 17.0
50 (Nominal)
Frequency (MHz)
617 to
3300 to
May. 2021 Ver.2.0
TDK Corporation
DPX164200DT-8202B1
( Measurement )
Isolation
Parameter
Isolation (dB)
TDK Spec
Min. Typ. Max.
2690 13
15
4200 18
23
Frequency (MHz)
617 to
3300 to
Ta = +25+/-5°C
■ MAXIMUM RATINGS
Parameter
Operating temperature (°C)
Storage temperature (°C)
Power Handling (W) *1
Low-Band
High-Band
Human Body Model : HBM
Machine Model : MM
Charged Device Model : CDM
TDK Spec
Conditions
–40 to +85 °C
–40 to +85 °C
Frequency (MHz)
GSM signal Duty 50%
4
698 to
960
CW
1
1427 to 2690
CW
1
3300 to 4200
@Each Port (V) +/-1000 100pF / 1500ohm
+/-150
200pF / 0ohm
@Each Port (V)
+/-500
Humidity : 60%RH max
@Each Port (V)
*1 : Refer to 3GPP TS 38.101-1 V15.2.0
May. 2021 Ver.1.2
TDK Corporation
DPX164200DT-8202B1
■ FREQUENCY CHARACTERISTICS
Insertion Loss (Low-Band)
Freq
dB
Freq
dB
617
0.06
1885
0.34
960
0.11
1930
0.35
1166
0.15
1990
0.37
1606
0.26
2300
0.46
1710
0.28
2496
0.54
1785
0.31
2690
0.68
1805
0.31
Freq
dB
3300
19.9
3700
22.3
3800
22.3
4200
25.8
4400
29.6
5000
35.7
5150
33.4
5925
25.0
12750
26.4
Freq
dB
Attenuation (Low-Band)
Return Loss (Low-Band)
Smith Chart (Low-Band)
Freq
r/x
617
21.9
617
52.68/7.8
2690
15.5
2690
69.78/-4.32
May. 2021 Ver.1.2
TDK Corporation
DPX164200DT-8202B1
Insertion Loss (High-Band)
Freq
dB
3300
0.91
4200
0.61
Freq
dB
Freq
dB
Freq
dB
Attenuation (High-Band)
500
24.0
4400
1.07
8400
21.8
1606
14.6
4900
8.47
9000
37.5
2400
16.6
5150
19.7
9900
18.7
2500
18.5
5925
13.2
12660
12.3
2690
31.4
6250
12.1
13200
11.5
2700
33.1
6550
11.9
16800
13.5
3150
2.24
6600
11.9
Freq
dB
Return Loss (High-Band)
Smith Chart (High-Band)
Freq
r/x
3300
26.6
3300
54.65/-1.53
4200
28.2
4200
51.12/3.76
May. 2021 Ver.1.2
TDK Corporation
DPX164200DT-8202B1
Isolation
Freq
dB
617
22.4
2690
24.8
3300
25.9
4200
25.4
Freq
dB
Return Loss (Common)
Smith Chart (Common)
Freq
r/x
617
22.1
617
53.07/7.53
2690
17.2
2690
54.41/-13.94
3300
22.9
3300
57.57/1.3
4200
20.8
4200
53.63/8.74
May. 2021 Ver.2.0
TDK Corporation
DPX164200DT-8202B1
■ RECOMMENDED LAND PATTERN
unit : mm
■ EVALUATION BOARD
Material & Layer
Copper Surface Pattern
FR-4
Inner GND
FR-4
Copper Bottom GND
Thickness
0.035 mm
0.10 mm
0.018 mm
0.30 mm
0.035 mm
* Line width should be designed to match 50 ohm characteristic impedance depending on
PCB material and thickness.
** The position of the throuh hole which have possibility of influence to the prerformance
are indicated by dimension line.
■ ENVIRONMENT INFORMATION
RoHS Statement
RoHS Compliance
May. 2021 Ver.2.0
TDK Corporation
DPX164200DT-8202B1
■ RECOMMENDED REFLOW PROFILE
3oC/sec
or lower
Preheating
Temp.
T1
T2
Time
t1
150°C 200°C 60 to 120sec
6oC/sec
or lower
Soldering
Critical zone (T3 to T4)
Peak
Temp.
Time
Temp.
Time
T3
t2
T4
t3 *
217°C
60 to 120sec 240 to 260°C 30 sec Max
* t3 : Time within 5°C of actual peak temperature
The maximum number of reflow is 3.
Note:
Lead free solder is recommended.
Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry)
May. 2021 Ver.2.0
TDK Corporation
DPX164200DT-8202B1
■ PACKAGING STYLE
Reel Dimensions
Carrier Tape
Dimensions (mm)
A
B
C
0.97 1.8 8.0
+/-0.05
+/-0.05
+/-0.2
D
3.5
E
1.75
F
4.0
G
2.0
H
4.0
J
1.5
K
0.8
t
0.25
+/-0.05
+/-0.1
+/-0.1
+/-0.05
+/-0.1
+0.1/-0
MAX
+/-0.05
STANDARD PACKAGE QUANTITY
( pieces/reel )
4,000
REMINDERS FOR USING THESE PRODUCTS
Before using these products, be sure to request the delivery specifications.
SAFETY REMINDERS
Please pay sufficient attention to the warnings for safe designing when using these products.
REMINDERS
The products listed on this specification sheet are intended for use in general electronic equipment
(AV equipment, telecommunications equipment, home appliances, amusement equipment,
computer equipment, personal equipment, office equipment, measurement equipment,
industrial robots) under a normal operation and use condition.
The products are not designed or warranted to meet the requirements of the applications listed
below, whose performance and/or quality require a more stringent level of safety or reliability,
or whose failure, malfunction or trouble could cause serious damage to society, person or property.
Please understand that we are not responsible for any damage or liability caused by use of the
products in any of the applications below or for any other use exceeding the range or
conditions set forth in this specification sheet.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
Aerospace/Aviation equipment
Transportation equipment (cars, electric trains, ships, etc.)
Medical equipment
Power-generation control equipment
Atomic energy-related equipment
Seabed equipment
Transportation control equipment
Public information-processing equipment
Military equipment
Electric heating apparatus, burning equipment
Disaster prevention/crime prevention equipment
Safety equipment
Other applications that are not considered general-purpose applications
When using this product in general-purpose applications, you are kindly requested to take into
consideration securing protection circuit/equipment or providing backup circuits, etc.,
to ensure higher safety.
很抱歉,暂时无法提供与“DPX164200DT-8202B1”相匹配的价格&库存,您可以联系我们找货
