DPX252690DT-5225A1
DPX252690DT-5225A1
    TDK(东电化)
    SMD
    DPX252690DT-5225A1
DPX252690DT-5225A1 数据手册
Oct. 2019 Ver.3.0 TDK Corporation Multilayer Diplexer For LTE DPX Series P/N: 2.5x2.0mm [EIA 1008] TYPE DPX252690DT-5225A1 TDK Technology - Proprietary and Confidential Information of TDK Group Companies Oct. 2019 Ver.3.0 TDK Corporation   DPX252690DT-5225A1 ■ SHAPES AND DIMENSIONS [Top View] (6) (1) [Bottom View] (5) (2) (4) (4) (5) (6) (3) (2) (1) (3) Dimensions (mm) L W T A B C D E F 2.50 2.00 0.80 0.40 0.65 0.75 0.525 0.40 0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 +/-0.10 Terminal functions High-Band Port (1) GND (2) Low-Band Port (3) (4) (5) (6) GND Common Port GND   ■ TEMPERATURE RANGE Operating temperature –40 to +85 °C Storage temperature –40 to +85 °C ■ TERMINATION FINISH Material Au plate • All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies Oct. 2019 Ver.3.0 TDK Corporation   DPX252690DT-5225A1 ■ ELECTRICAL CHARACTERISTICS ( Measurement ) Low-Band Parameter Insertion Loss (dB) Attenuation (dB) Reutrn Loss (dB) Input Power Rating(W) Frequency (MHz) 699 960 1427 1710 1990 2110 2300 2350 2500 699 960 1710 699 960 1710 to to to to to to to to to to to to to to to 960 1427 1710 1990 2110 2170 2350 2500 2690 960 1710 2170 960 1710 2170 TDK Spec Min. Typ. Max. 0.44 0.60 0.54 0.75 0.62 0.85 0.79 1.00 0.91 1.50 1.62 2.50 5 12 10 16 10 14 10 12 8 11 10 15 3 2 1 Ta = +25+/-5°C High-Band Parameter Insertion Loss (dB) Attenuation (dB) Reutrn Loss (dB) Input Power Rating(W) Ta = +25+/-5°C Frequency (MHz) 2300 2350 2500 699 960 1427 1710 1990 2110 2300 2300 to to to to to to to to to to to 2350 2500 2690 960 1427 1710 1990 2110 2170 2690 2690 TDK Spec Min. Typ. Max. 1.54 2.15 0.87 1.50 0.48 0.65 15 18 15 19 12 14 8 11 8 11 5 11 10 16 1 TDK Technology - Proprietary and Confidential Information of TDK Group Companies Oct. 2019 Ver.3.0 TDK Corporation   DPX252690DT-5225A1 ■ ELECTRICAL CHARACTERISTICS ( Measurement ) Common Parameter Return Loss (dB) Isolation (dB) Frequency (MHz) 699 960 1710 2300 699 960 1427 1710 1990 2110 2300 2350 2500 to to to to to to to to to to to to to 960 1710 2170 2690 960 1427 1710 1990 2110 2170 2350 2500 2690 TDK Spec Min. Typ. Max. 10 12 8 11 10 13 10 17 15 17 15 18 12 13 8 11 8 12 5 15 5 13 10 17 10 15 - TDK Technology - Proprietary and Confidential Information of TDK Group Companies Oct. 2019 Ver.3.0 TDK Corporation   DPX252690DT-5225A1 Low band-Port High band-Port 0 10 15 20 MHz MHz MHz MHz MHz MHz 12.10 22.17 16.56 15.01 14.45 14.09 dB dB dB dB dB dB 25 30 35 Attenuation 699 960 1427 1710 1880 1990 2110 2170 5 10 Attenuation[dB] 2300 2400 2500 2570 2620 2690 5 Attenuation[dB] 0 Attenuation 15 20 25 30 40 45 45 dB dB dB dB dB dB dB dB Insertion Loss 2300 MHz 1.54 2400 MHz 0.63 2500 MHz 0.48 2570 MHz 0.46 2620 MHz 0.45 2690 MHz 0.46 dB dB dB dB dB dB 50 50 500 1500 2500 3500 500 4500 1500 Frequency[MHz] 2500 3500 4500 Frequency[MHz] Low band-Port High band-Port Insertion Loss 699 MHz 960 MHz 1427 MHz 1710 MHz 1880 MHz 1990 MHz 2110 MHz 2170 MHz 0.5 1 1.5 0 0.32 0.44 0.54 0.62 0.77 0.79 0.91 1.62 dB dB dB dB dB dB dB dB 2 0.5 Insertion Loss[dB] 0 Insertion Loss[dB] 18.62 19.88 30.41 14.94 11.50 11.97 17.98 11.89 35 40 1 1.5 2 2.5 2.5 3 3 500 1000 1500 2000 2100 2500 2300 Frequency[MHz] 2500 2700 Frequency[MHz] Common Port Return Loss Isolation 0 0 10 15 20 25 30 35 40 500 1500 2500 3500 4500 699 960 1427 1710 1880 1990 2110 2170 MHz MHz MHz MHz MHz MHz MHz MHz 14.34 12.25 11.22 13.31 16.25 19.80 23.79 21.78 dB dB dB dB dB dB dB dB 2300 2400 2500 2570 2620 2690 MHz MHz MHz MHz MHz MHz 17.11 20.49 28.77 29.36 24.58 20.18 dB dB dB dB dB dB 5 10 15 Isolation[dB] 5 Return Loss[dB] MHz MHz MHz MHz MHz MHz MHz MHz 20 25 30 35 40 45 50 500 1500 2500 3500 4500 699 960 1427 1710 1880 1990 2110 2170 MHz MHz MHz MHz MHz MHz MHz MHz 17.9 18.4 32.7 13.6 11.1 12.4 27.5 15.5 dB dB dB dB dB dB dB dB 2300 2400 2500 2570 2620 2690 MHz MHz MHz MHz MHz MHz 13.4 25.2 17.2 15.9 15.6 15.6 dB dB dB dB dB dB 2300 2400 2500 2570 2620 2690 MHz MHz MHz MHz MHz MHz 16.67 19.59 24.36 22.05 19.70 17.19 dB dB dB dB dB dB Frequency[MHz] Frequency[MHz] Low band-Port Return Loss High band-Port Return Loss 0 0 Return Loss[dB] 10 15 20 25 30 MHz MHz MHz MHz MHz MHz MHz MHz 14.70 12.69 11.39 15.61 22.36 28.52 24.63 22.15 dB dB dB dB dB dB dB dB 5 10 Return Loss[dB] 699 960 1427 1710 1880 1990 2110 2170 5 15 20 25 30 35 35 40 40 500 1500 2500 3500 Frequency[MHz] 4500 500 1500 2500 3500 4500 Frequency[MHz] TDK Technology - Proprietary and Confidential Information of TDK Group Companies Oct. 2019 Ver.3.0 TDK Corporation   DPX252690DT-5225A1 ■ RECOMMENDED LAND PATTERN DPX252690DT-5225A1 STD 2012size side PIN Diplexer Unit : [ mm ] ■ ENVIROMENT INFORMATION RoHS Statement RoHS Compliance TDK Technology - Proprietary and Confidential Information of TDK Group Companies Oct. 2019 Ver.3.0 TDK Corporation ■ RECOMMENDED REFLOW PROFILE 3oC/sec or lower Preheating Temp. T1 T2 Time t1 150°C 200°C 60 to 120sec 6oC/sec or lower Soldering Critical zone (T3 to T4) Peak Temp. Time Temp. Time T3 t2 T4 t3 * 217°C 60 to 120sec 240 to 260°C 30 sec Max * t3 : Time within 5°C of actual peak temperature The maximum number of reflow is 3. Note: Lead free solder is recommended. Recommended solder is Sn-3.0Ag-0.5Cu. (M705 by Senju Metal Industry) All specifications are subject to change without notice. TDK Technology - Proprietary and Confidential Information of TDK Group Companies   Oct. 2019 Ver.3.0 TDK Corporation DPX252690DT-5225A1 ■ PACKAGING STYLE Reel Dimensions Carrier Tape STANDARD PACKAGE QUANTITY ( pieces/reel ) 2,000 TDK Technology - Proprietary and Confidential Information of TDK Group Companies TDK Technology - Proprietary and Confidential Information of TDK Group Companies REMINDERS FOR USING THESE PRODUCTS Before using these products, be sure to request the delivery specifications. SAFETY REMINDERS Please pay sufficient attention to the warnings for safe designing when using these products. REMINDERS The products listed on this specification sheet are intended for use in general electronic equipment (AV equipment, telecommunications equipment, home appliances, amusement equipment, computer equipment, personal equipment, office equipment, measurement equipment, industrial robots) under a normal operation and use condition. The products are not designed or warranted to meet the requirements of the applications listed below, whose performance and/or quality require a more stringent level of safety or reliability, or whose failure, malfunction or trouble could cause serious damage to society, person or property. Please understand that we are not responsible for any damage or liability caused by use of the products in any of the applications below or for any other use exceeding the range or conditions set forth in this specification sheet. 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. 11. 12. 13. Aerospace/Aviation equipment Transportation equipment (cars, electric trains, ships, etc.) Medical equipment Power-generation control equipment Atomic energy-related equipment Seabed equipment Transportation control equipment Public information-processing equipment Military equipment Electric heating apparatus, burning equipment Disaster prevention/crime prevention equipment Safety equipment Other applications that are not considered general-purpose applications When using this product in general-purpose applications, you are kindly requested to take into consideration securing protection circuit/equipment or providing backup circuits, etc., to ensure higher safety. TDK Technology - Proprietary and Confidential Information of TDK Group Companies
DPX252690DT-5225A1 价格&库存
很抱歉,暂时无法提供与“DPX252690DT-5225A1”相匹配的价格&库存,您可以联系我们找货
DPX252690DT-5225A1
    • 1+1.52000
    • 10+1.23606
    • 30+1.11435
    库存:4
