UG-325
Analog Output MEMS Microphone Flex Evaluation Board User Guide
GENERAL DESCRIPTION
This user guide applies to the following MEMS microphone
evaluation boards:
Table 1 describes the functions of the three connection wires.
Table 2 describes the functional differences between the
different microphones that are used with this flex circuit.
EVAL-INMP404Z-FLEX
EVAL-INMP405Z-FLEX
EVAL-INMP504Z-FLEX
EVAL-INMP510Z-FLEX
EVAL-INMP801Z-FLEX
EV_ICS-40180-FX
EV_ICS-40310-FX
InvenSense reserves the right to change the detail
specifications as may be required to permit
improvements in the design of its products.
InvenSense Inc.
1745 Technology Drive, San Jose, CA 95110 U.S.A
+1(408) 988–7339
www.invensense.com
Document Number: AN-000013
Revision: 1.3
Rev Date: 09/23/2014
UG-325
TABLE 1. PIN FUNCTION DESCRIPTIONS
EVALUATION BOARD CIRCUIT
Wire
Color
Microphone
Pin
Red
VDD
Power Supply. 1.5 V DC to 3.6 V DC;
(0.9 V DC to 1.3 V DC for ICS-40310
and INMP801)
White
OUTPUT
Analog Output Signal
Figure 1 shows the schematic of the evaluation board, and
Figure 2 shows the flex board layout. See the respective
microphone data sheets for complete descriptions and
specifications of the microphones. Note that the layout for
the EV_ICS-40180-FX differs slightly from what is shown in
Figure 2 because of this part’s different package footprint,
but the routing of the three signals is consistent.
Black
GND
Ground
Description
VDD
TABLE 2. MICROPHONE FUNCTIONAL
DIFFERENCES
0.1µF
OUTPUT
Microphone
Maximum
Supply
Current
Maximum
Output
Voltage
Output
Impedance
DC
Offset
INMP404
250 µA
0.18 V rms
200 Ω
0.8 V
INMP405
250 µA
0.18 V rms
200 Ω
0.8 V
INMP504
225 µA
0.18 V rms
200 Ω
0.8 V
INMP510
250 µA
0.40 V rms
350 Ω
0.7 V
INMP801
23 µA
0.13 V rms
4.5 kΩ
0.57 V
ICS-40180
260 µA
0.40 V rms
350 Ω
0.7 V
ICS-40310
25 µA
0.12 V rms
4.5 kΩ
0.57 V
MICROPHONE
GND
Figure 1. Evaluation Board Schematic
Figure 2. Evaluation Board Layout (Top View)
15mm
3.14mm
Figure 3. Evaluation Board Dimensions in Millimeters (Wires Not
Included)
InvenSense Inc.
+1(408) 988–7339
www.invensense.com
Revision: 1.3
UG-325
EVALUATION BOARD PHOTOGRAPH
Figure 4. Top and Bottom View
InvenSense Inc.
+1(408) 988–7339
www.invensense.com
Revision: 1.3
UG-325
COMPLIANCE DECLARATION DISCLAIMER
InvenSense believes the environmental and other compliance information given in this document to be correct but cannot
guarantee accuracy or completeness. Conformity documents substantiating the specifications and component characteristics are on
file. InvenSense subcontracts manufacturing and the information contained herein is based on data received from vendors and
suppliers, which has not been validated by InvenSense.
This information furnished by InvenSense is believed to be accurate and reliable. However, no responsibility is assumed by
InvenSense for its use, or for any infringements of patents or other rights of third parties that may result from its use. Specifications
are subject to change without notice. InvenSense reserves the right to make changes to this product, including its circuits and
software, in order to improve its design and/or performance, without prior notice. InvenSense makes no warranties, neither
expressed nor implied, regarding the information and specifications contained in this document. InvenSense assumes no
responsibility for any claims or damages arising from information contained in this document, or from the use of products and
services detailed therein. This includes, but is not limited to, claims or damages based on the infringement of patents, copyrights,
mask work and/or other intellectual property rights.
Certain intellectual property owned by InvenSense and described in this document is patent protected. No license is granted by
implication or otherwise under any patent or patent rights of InvenSense. This publication supersedes and replaces all information
previously supplied. Trademarks that are registered trademarks are the property of their respective companies. InvenSense sensors
should not be used or sold in the development, storage, production or utilization of any conventional or mass-destructive weapons
or for any other weapons or life threatening applications, as well as in any other life critical applications such as medical equipment,
transportation, aerospace and nuclear instruments, undersea equipment, power plant equipment, disaster prevention and crime
prevention equipment.
©2014 InvenSense, Inc. All rights reserved. InvenSense, MotionTracking, MotionProcessing, MotionProcessor, MotionFusion,
MotionApps, DMP, AAR, and the InvenSense logo are trademarks of InvenSense, Inc. Other company and product names may be
trademarks of the respective companies with which they are associated.
Revision: 1.3
Page 4 of 4
很抱歉,暂时无法提供与“EV_ICS-40180-FX”相匹配的价格&库存,您可以联系我们找货
