ICS-40180
RF-Hardened, Low-Noise Microphone with Bottom Port and Analog Output
GENERAL DESCRIPTION
The ICS-40180 is an analog MEMS microphone with high SNR
and enhanced RF immunity. The ICS-40180 includes a MEMS
microphone element, an impedance converter, and an output
amplifier.
Other high-performance specification include a linear
response up to 124 dB SPL, tight ±1 dB sensitivity tolerance,
and enhanced immunity to both radiated and conducted RF
interference.
The ICS-40180 is available in a small, 3.5 mm × 2.65 mm ×
0.98 mm, surface-mount package.
*Protected by U.S. Patents 7,449,356; 7,825,484; 7,885,423; and 7,961,897.
Other patents are pending.
APPLICATIONS
FEATURES
FUNCTIONAL BLOCK DIAGRAM
Smartphones
Tablet Computers
Wearable Devices
Still and Video Cameras
Bluetooth Headsets
Notebook PCs
Security and Surveillance
High 65 dBA SNR
−38 dBV Sensitivity
±1 dB Sensitivity Tolerance
Non-Inverted Signal Output
Extended Frequency Response from 60 Hz to 20 kHz
Enhanced RF Immunity
124 dB SPL Acoustic Overload Point
Low Current Consumption: 190 µA
Single-Ended Analog Output
High −78 dBV PSR
3.5 × 2.65 × 0.98 mm Surface-Mount Package
Compatible with Sn/Pb and Pb-Free Solder Processes
RoHS/WEEE Compliant
ORDERING INFORMATION
PART
ICS-40180
EV_ICS-40180-FX
OUTPUT
AMPLIFIER
ICS-40180
TEMP RANGE
PACKAGING
−40°C to +85°C
13” Tape and Reel
OUTPUT
POWER
VDD GND
InvenSense reserves the right to change the detail
specifications as may be required to permit improvements
in the design of its products.
InvenSense Inc.
1745 Technology Drive, San Jose, CA 94089 U.S.A
+1(408) 988–7339
www.invensense.com
Document Number: DS-000021
Revision: 1.2
Rev Date: 04/03/2015
ICS-40180
TABLE OF CONTENTS
General Description ..................................................................................................................................................................... 1
Applications ................................................................................................................................................................................. 1
Features ....................................................................................................................................................................................... 1
Functional Block Diagram ............................................................................................................................................................ 1
Ordering Information ................................................................................................................................................................... 1
Table of Contents .................................................................................................................................................................................... 2
Specifications .......................................................................................................................................................................................... 3
Table 1. Electrical Characteristics ................................................................................................................................................ 3
Absolute Maximum Ratings .................................................................................................................................................................... 4
Table 2. Absolute Maximum Ratings ........................................................................................................................................... 4
ESD Caution ................................................................................................................................................................................. 4
Soldering Profile........................................................................................................................................................................... 5
Table 3. Recommended Soldering Profile*.................................................................................................................................. 5
Pin Configuration And Function Descriptions ......................................................................................................................................... 6
Table 4. Pin Function Descriptions............................................................................................................................................... 6
Typical Performance Characteristics....................................................................................................................................................... 7
Applications Information ........................................................................................................................................................................ 8
Codec Connection ........................................................................................................................................................................ 8
Supporting Documents ........................................................................................................................................................................... 9
Evaluation Board User Guide ....................................................................................................................................................... 9
Application Notes ........................................................................................................................................................................ 9
PCB Design And Land Pattern Layout ................................................................................................................................................... 10
PCB Material And Thickness ...................................................................................................................................................... 10
Handling Instructions ............................................................................................................................................................................ 11
Pick And Place Equipment ......................................................................................................................................................... 11
Reflow Solder ............................................................................................................................................................................. 11
Board Wash................................................................................................................................................................................ 11
Outline Dimensions ............................................................................................................................................................................... 12
Ordering Guide .......................................................................................................................................................................... 12
Revision History ......................................................................................................................................................................... 13
Compliance Declaration Disclaimer ...................................................................................................................................................... 14
Revision: 1.2
Page 2 of 14
ICS-40180
SPECIFICATIONS
TABLE 1. ELECTRICAL CHARACTERISTICS
TA = 25°C, VDD = 1.5 to 3.63 V, unless otherwise noted. Typical specifications are not guaranteed.
PARAMETER
PERFORMANCE
Directionality
Output Polarity
Sensitivity
Signal-to-Noise Ratio (SNR)
Equivalent Input Noise (EIN)
Dynamic Range
Frequency Response
Total Harmonic Distortion (THD)
Power-Supply Rejection (PSR)
Power Supply Rejection Ratio (PSRR)
POWER SUPPLY
Supply Voltage (VDD)
Supply Current (IS)
OUTPUT CHARACTERISTICS
Output Impedance
CONDITIONS
1 kHz, 94 dB SPL
20 Hz to 20 kHz, A-weighted
Derived from EIN and maximum
acoustic input
Low frequency −3 dB point
High frequency −3 dB point
105 dB SPL
217 Hz, 100 mVp-p square wave
superimposed on VDD = 1.8 V
1 kHz, 100 mVp-p sine wave
10% THD
MIN
TYP
MAX
UNITS
−39
Omni
Non-Inverted
−38
65
29
−37
dBV
dBA
dBA SPL
95
dB
60
>20
0.3
Hz
kHz
−78
dBV
−46
dB
124
dB SPL
1.5
VDD = 1.8 V
VDD = 3.3 V
190
210
Output DC Offset
1
3.63
240
260
V
µA
µA
350
Ω
0.7
V
Maximum Output Voltage
124 dB SPL input
0.398
V rms
Noise Floor
20 Hz to 20 kHz, A-weighted,
rms
−103
dBV
Note 1: See Figure 3 and Figure 4.
Revision: 1.2
Page 3 of 14
NOTES
1
ICS-40180
ABSOLUTE MAXIMUM RATINGS
Stress above those listed as Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only
and functional operation of the device at these conditions is not implied. Exposure to the absolute maximum ratings conditions for
extended periods may affect device reliability.
TABLE 2. ABSOLUTE MAXIMUM RATINGS
PARAMETER
Sound Pressure Level
Mechanical Shock
Vibration
Temperature Range
Biased
Storage
RATING
−0.3 V to +3.63 V
160 dB
10,000 g
Per MIL-STD-883 Method 2007, Test Condition B
−40°C to +85°C
−55°C to +150°C
ESD CAUTION
ESD (electrostatic discharge) sensitive device.
Charged devices and circuit boards can
discharge without detection. Although this
product features patented or proprietary
protection circuitry, damage may occur on
devices subjected to high energy ESD.
Therefore proper ESD precautions should be
taken to avoid performance degradation or
loss of functionality.
Revision: 1.2
Page 4 of 14
ICS-40180
SOLDERING PROFILE
CRITICAL ZONE
TL TO TP
tP
TP
TEMPERATURE
RAMP-UP
TL
tL
TSMAX
TSMIN
tS
RAMP-DOWN
PREHEAT
t25°C TO PEAK TEMPERATURE
TIME
Figure 1. Recommended Soldering Profile Limits
TABLE 3. RECOMMENDED SOLDERING PROFILE*
PROFILE FEATURE
Average Ramp Rate (TL to TP)
Minimum Temperature
(TSMIN)
Minimum Temperature
Preheat
(TSMIN)
Time (TSMIN to TSMAX), tS
Ramp-Up Rate (TSMAX to TL)
Time Maintained Above Liquidous (tL)
Liquidous Temperature (TL)
Peak Temperature (TP)
Time Within +5°C of Actual Peak
Temperature (tP)
Ramp-Down Rate
Time +25°C (t25°C) to Peak Temperature
Sn63/Pb37
1.25°C/sec max
Pb-Free
1.25°C/sec max
100°C
100°C
150°C
200°C
60 sec to 75 sec
1.25°C/sec
45 sec to 75 sec
60 sec to 75 sec
1.25°C/sec
~50 sec
183°C
217°C
215°C +3°C/−3°C
260°C +0°C/−5°C
20 sec to 30 sec
20 sec to 30 sec
3°C/sec max
3°C/sec max
5 min max
5 min max
*The reflow profile in Table 3 is recommended for board manufacturing with InvenSense MEMS microphones. All microphones are
also compatible with the J-STD-020 profile
Revision: 1.2
Page 5 of 14
ICS-40180
PIN CONFIGURATION AND FUNCTION DESCRIPTIONS
3
4
5
GND
GND
OUTPUT
VDD
GND
2
1
Figure 2. Pin Configuration
Top View (Terminal Side Down)
Not to Scale
TABLE 4. PIN FUNCTION DESCRIPTIONS
PIN
NAME
FUNCTION
1
OUTPUT
Analog Output Signal
2
GND
Ground
3
GND
Ground
4
GND
Ground
5
VDD
Power Supply
Revision: 1.2
Page 6 of 14
ICS-40180
15
10
NORMALIZED AMPLITUDE (dB)
TYPICAL PERFORMANCE CHARACTERISTICS
10
5
–5
5
–5
–10
–10
–15
–15
10
1k
100
–20
10k
10
100
1k
10k
FREQUENCY (Hz)
FREQUENCY (Hz)
Figure 4. Typical Frequency Response (Measured)
Figure 3. Frequency Response Mask
–40
–41
10
–42
THD + N (%)
PSRR (dB)
–43
–44
–45
–46
1
–47
–48
–49
–50
100
1k
0.1
90
10k
100
FREQUENCY (Hz)
Figure 5. PSR vs. Frequency, 100 mV p-p Swept Sine Wave
120
130
Figure 6. Total Harmonic Distortion + Noise (THD+N) vs. Input SPL
-5
1.4
-10
1.2
-15
1.0
-20
OUTPUT (V)
OUTPUT AMPLITUDE (dBV)
110
INPUT (dB SPL)
-25
-30
0.8
0.6
0.4
-35
-45
90
120dB SPL
124dB SPL
128dB SPL
132dB SPL
0.2
-40
110
120
INPUT AMPLITUDE (dB SPL)
1.0
TIME (ms)
Figure 7. Linearity
Revision: 1.2
0.5
Figure 8. Clipping Characteristics
Page 7 of 14
ICS-40180
APPLICATIONS INFORMATION
CODEC CONNECTION
The ICS-40180 output can be connected to a dedicated codec microphone input (see Figure 9) or to a high input impedance gain
stage. A 0.1 µF ceramic capacitor placed close to the ICS-40180 supply pin is used for testing and is recommended to adequately
decouple the microphone from noise on the power supply. A DC blocking capacitor is required at the output of the microphone. This
capacitor creates a high-pass filter with a corner frequency at
fC = 1/(2π × C × R)
where R is the input impedance of the codec.
A minimum value of 2.2 μF is recommended in Figure 9 because the input impedance of some codecs can be as low as 2 kΩ at their
highest PGA gain setting, which results in a high-pass filter corner frequency at 37 Hz. Figure 10 shows the ICS-40180 connected to
an op amp configured as a noninverting preamplifier.
MICBIAS
0.1 µF
VDD
2.2 µF
MINIMUM
ICS-40180
ADC
OR
CODEC
INPUT
OUTPUT
GND
Figure 9. ICS-40180 Connected to a Codec
1.8-3.3 V
GAIN = (R1 + R2)/R1
R2
R1
VREF
0.1µF
VDD
ICS-40180
AMP
1µF
MINIMUM
OUTPUT
GND
10kΩ
VREF
Figure 10. ICS-40180 Connected to an Op Amp
Revision: 1.2
Page 8 of 14
VOUT
ICS-40180
SUPPORTING DOCUMENTS
For additional information, see the following documents.
EVALUATION BOARD USER GUIDE
UG-325, Analog Output MEMS Microphone Flex Evaluation Board
APPLICATION NOTES
AN-100, MEMS Microphone Handling and Assembly Guide
AN-1003, Recommendations for Mounting and Connecting the InvenSense Bottom-Ported MEMS Microphones
AN-1112, Microphone Specifications Explained
AN-1124, Recommendations for Sealing InvenSense Bottom-Port MEMS Microphones from Dust and Liquid Ingress
AN-1140, Microphone Array Beamforming
AN-1165, Op Amps for Microphone Preamp Circuits
AN-1181, Using a MEMS Microphone in a 2-Wire Microphone Circuit
Revision: 1.2
Page 9 of 14
ICS-40180
PCB DESIGN AND LAND PATTERN LAYOUT
Below is the lay out the PCB land pattern for the ICS-40180, at a 1:1 ratio to the solder pads on the microphone package, (see Figure
11.) Take care to avoid applying solder paste to the sound hole in the PCB. Figure 12 shows a suggested solder-paste stencil pattern
layout. The response of the ICS-40180 is not affected by the PCB hole size, as long as the hole is not smaller than the sound port of the
microphone (0.25 mm, or 0.01 inch, in diameter). A 0.5 mm to 1 mm (0.020 inch to 0.040 inch) diameter for the hole is
recommended.
Align the hole in the microphone package with the hole in the PCB. The exact degree of the alignment does not affect the
performance of the microphone as long as the holes are not partially or completely blocked.
0.522x0.725(4X)
Ø1.625
Ø1.025
1.675
0.838
0.822
1.252
Figure 11. Recommended PCB Land Pattern Layout
0.422x0.625(4X)
Ø1.625
Ø1.125
1.675
0.1(4x)
0.822
1.252
Figure 12. Recommended Solder Paste Stencil Pattern Layout
PCB MATERIAL AND THICKNESS
The performance of the ICS-40180 is not affected by PCB thickness. The ICS-40180 can be mounted on either a rigid or flexible PCB.
A flexible PCB with the microphone can be attached directly to the device housing with an adhesive layer. This mounting method
offers a reliable seal around the sound port while providing the shortest acoustic path for good sound quality.
Revision: 1.2
Page 10 of 14
ICS-40180
HANDLING INSTRUCTIONS
PICK AND PLACE EQUIPMENT
The MEMS microphone can be handled using standard pick-and-place and chip shooting equipment. Take care to avoid damage to the
MEMS microphone structure as follows:
• Use a standard pickup tool to handle the microphone. Because the microphone hole is on the bottom of the package, the
pickup tool can make contact with any part of the lid surface.
• Do not pick up the microphone with a vacuum tool that makes contact with the bottom side of the microphone.
Do not pull air out of or blow air into the microphone port.
• Do not use excessive force to place the microphone on the PCB.
REFLOW SOLDER
For best results, the soldering profile must be in accordance with the recommendations of the manufacturer of the solder paste used to
attach the MEMS microphone to the PCB. It is recommended that the solder reflow profile not exceed the limit conditions specified
in Figure 1 and Table 3.
BOARD WASH
When washing the PCB, ensure that water does not make contact with the microphone port. Do not use blow-off procedures or
ultrasonic cleaning.
Revision: 1.2
Page 11 of 14
ICS-40180
OUTLINE DIMENSIONS
Figure 13. 5-Terminal Chip Array Small Outline No-Lead Cavity [LGA_CAV]
3.5 × 2.65 × 0.98 mm Body
Dimensions shown in millimeters
PART NUMBER
PIN 1 INDIC ATION
180
YY XXX
DATE CODE
LOT TR ACEABILITY CODE
Figure 14. Package Marking Specification (Top View)
ORDERING GUIDE
PART
ICS-40180
TEMP RANGE
−40°C to +85°C
PACKAGE
5-Terminal LGA_CAV
QUANTITY
10,000
EV_ICS-40180-FX
Flexible Evaluation Board
Revision: 1.2
Page 12 of 14
PACKAGING
13” Tape and Reel
ICS-40180
REVISION HISTORY
REVISION DATE
REVISION
DESCRIPTION
10/7/2014
1.0
Initial Release
11/17/2014
1.1
Updated General Description information
04/03/2015
1.2
Corrected PSRR spec and replaced Figure 5
Revision: 1.2
Page 13 of 14
ICS-40180
COMPLIANCE DECLARATION DISCLAIMER
InvenSense believes the environmental and other compliance information given in this document to be correct but cannot
guarantee accuracy or completeness. Conformity documents substantiating the specifications and component characteristics are on
file. InvenSense subcontracts manufacturing, and the information contained herein is based on data received from vendors and
suppliers, which has not been validated by InvenSense.
This information furnished by InvenSense is believed to be accurate and reliable. However, no responsibility is assumed by
InvenSense for its use, or for any infringements of patents or other rights of third parties that may result from its use. Specifications
are subject to change without notice. InvenSense reserves the right to make changes to this product, including its circuits and
software, in order to improve its design and/or performance, without prior notice. InvenSense makes no warranties, neither
expressed nor implied, regarding the information and specifications contained in this document. InvenSense assumes no
responsibility for any claims or damages arising from information contained in this document, or from the use of products and
services detailed therein. This includes, but is not limited to, claims or damages based on the infringement of patents, copyrights,
mask work and/or other intellectual property rights.
Certain intellectual property owned by InvenSense and described in this document is patent protected. No license is granted by
implication or otherwise under any patent or patent rights of InvenSense. This publication supersedes and replaces all information
previously supplied. Trademarks that are registered trademarks are the property of their respective companies. InvenSense sensors
should not be used or sold in the development, storage, production or utilization of any conventional or mass-destructive weapons
or for any other weapons or life threatening applications, as well as in any other life critical applications such as medical equipment,
transportation, aerospace and nuclear instruments, undersea equipment, power plant equipment, disaster prevention and crime
prevention equipment.
©2015 InvenSense, Inc. All rights reserved. InvenSense, MotionTracking, MotionProcessing, MotionProcessor, MotionFusion,
MotionApps, DMP, AAR and the InvenSense logo are trademarks of InvenSense, Inc. Other company and product names may be
trademarks of the respective companies with which they are associated.
Revision: 1.2
Page 14 of 14
