HARDWARE
GROMMET AND HOLE PLUG KITS
210
Pieces
63
Pieces
Hardware
185
Pieces
HD-4209
Vinyl Grommet Kit
HD-4211
Hole Plug Kit
HD-4210
Rubber Grommet Kit
Kit No. HD-4209
Vinyl Grommet Kit for 1/4”, 5/16”, 3/8”, 7/16”, 1/2” and 5/8” Mount Holes.
Refill
Part No.
G-401
G-402
G-403
G-404
G-405
G-406
Quantity
Per Kit
Description
70
40
25
Vinyl
Vinyl
Vinyl
Vinyl
Vinyl
Vinyl
Grommet
Grommet
Grommet
Grommet
Grommet
Grommet
Mounting Hole
(Inches)
Panel Thickness
(Inches)
Thickness
(Inches)
1/4
5/16
3/8
7/16
1/2
5/8
1/16
1/16
1/16
1/16
1/16
1/16
3/16
7/32
1/4
1/4
1/4
9/32
Inner Diameter
(Inches)
1/8
3/16
1/4
5/16
3/8
1/2
Outer Diameter
(Inches)
11/32
7/16
9/16
5/8
5/8
13/16
Kit No. HD-4210
Rubber Grommet Kit for 1/4”, 5/16”, 3/8”, 1/2”, 5/8” and 3/4” Mount Holes.
Refill
Part No.
11-284-C
G-305
11-292-BU
11-300-BU
11-304-BU
11-308-BU
Quantity
Per Kit
Description
100
40
30
10
Rubber
Rubber
Rubber
Rubber
Rubber
Rubber
Grommet
Grommet
Grommet
Grommet
Grommet
Grommet
Mounting Hole
(Inches)
Panel Thickness
(Inches)
Thickness
(Inches)
1/4
5/16
3/8
1/2
5/8
3/4
1/16
1/16
1/16
1/16
1/16
1/16
3/16
7/32
1/4
1/4
9/32
15/64
Inner Diameter
(Inches)
Kit No. HD-4211
Nickel-plated Snap Button Hole Plug Kit for 1/4”, 3/8”, 1/2”, 3/4” and 1” Mount Holes.
Refill
Part No.
HP-1
HP-2
HP-3
HP-4
HP-5
11-392-C
162
Mounting Hole
(Inches)
Quantity
Description
Per Kit
25
15
10
5
5
3
Nickel-plated
Nickel-plated
Nickel-plated
Nickel-plated
Nickel-plated
Nickel-plated
Hole Plug
Hole Plug
Hole Plug
Hole Plug
Hole Plug
Screen Vent Hole Plug
1/4
3/8
1/2
3/4
1
1
Phone (815)316-9080•Fax (815)316-9081
All quantities are single; BU’s are packages of 10 Unless otherwise noted.
1/8
3/16
1/4
3/8
1/2
9/16
Outer Diameter
(Inches)
11/32
7/16
9/16
5/8
13/16
7/8
HARDWARE
GROMMETS and HOLE PLUGS
Fig. 2
Fig. 1
Grommets
CLAMSHELL
Qty
Part No.
KG-401
KG-402
KG-403
KG-404
KG-405
KG-406
KG-407
Qty
G-302-P
50
G-307-P
50
G-311-P
11-284-BU
11-292-BU
11-300-BU
11-304-BU
11-308-BU
11-312-BU
11-316-BU
25
10
10
10
10
10
10
10
15
10
10
10
10
5
4
BULK
Part No.
Qty
G-300-C
100
G-305H-C
100
G-309-C
100
11-284-C
11-292-C
11-300-C
11-304-C
11-308-C
11-312-C
11-316-C
G-401-C
G-402-C
G-403-C
G-404-C
G-405-C
G-406-C
G-407-C
100
100
100
100
100
100
100
100
100
100
100
100
100
100
N.S.N.
No.
5325-00-975-1803
5325-00-682-2080
5325-00-202-2515
5340-00-814-5884
5325-00-474-7083
5325-00-071-3189
Fig.
No. Description
1 Rubber Grommet
1 Rubber Grommet
1 Rubber Grommet
1 Rubber Grommet
1 Rubber Grommet
1 Rubber Grommet
1 Rubber Grommet
1 Rubber Grommet
1 Rubber Grommet
1 Rubber Grommet
1 Rubber Grommet
1 Rubber Grommet
1 Rubber Grommet
2 Vinyl Grommet
2 Vinyl Grommet
2 Vinyl Grommet
2 Vinyl Grommet
2 Vinyl Grommet
2 Vinyl Grommet
2 Vinyl Grommet
Mount Hole
(Inches)
1/4
1/2
5/16
19/32
15/32
7/8
1/4
3/8
1/2
5/8
3/4
7/8
1
1/4
5/16
3/8
7/16
1/2
5/8
7/8
Panel Thickness Thickness Diameter (Inches)
Outer
Inner
(Inches)
(Inches)
11/32
1/16
1/8
3/16
21/32
1/16
3/8
1/4
7/16
1/16
3/16
3/16
3/4
3/64
7/16
1/4
5/8
1/16
11/32
1/4
1-1/8
1/16
5/8
5/16
11/32
1/16
1/8
3/16
9/16
1/16
1/4
1/4
5/8
1/16
3/8
1/4
13/16
1/16
1/2
9/32
7/8
1/16
9/16
15/64
1-1/8
1/16
5/8
5/16
1-5/16
1/16
11/16
3/8
11/32
1/16
1/8
3/16
7/16
1/16
3/16
7/32
9/16
1/16
1/4
1/4
5/8
1/16
5/16
1/4
5/8
1/16
3/8
1/4
13/16
1/16
1/2
9/32
1-1/8
1/16
5/8
9/32
Fig. 4
Fig. 3
Hole Plugs
CLAMSHELL
Qty
Part No.
KHP-1
KHP-2
KHP-3
KHP-4
KHP-5
8
4
6
5
3
POLYBAG
Part No.
HP-4-P
HP-5-P
Qty
BULK
Part No.
Qty
HP-1-C
HP-2-C
HP-3-C
100
100
100
11-344-C
11-348-C
11-356-C
11-360-C
11-364-C
11-368-C
11-388-C
11-392-C
100
100
100
100
100
100
100
100
N.S.N.
No.
50
25
5340-00-816-3421
5340-00-782-8713
5340-00-816-3423
5340-00-816-3424
5340-00-587-1331
Fig.
No. Description
3 Steel, Nickel Plated Hole Plug
4 Steel, Nickel Plated Screened Vent Hole Plug
For the latest information–www.gcelectronics.com
Mount Hole
(Inches)
1/4
3/8
1/2
3/4
1
1/4
5/16
1/2
5/8
3/4
7/8
1
1
163
Hardware
8
KG-302
POLYBAG
Part No.
很抱歉,暂时无法提供与“HP-1-C”相匹配的价格&库存,您可以联系我们找货
