1000 Eaton Boulevard
Cleveland, OH 44122
United States
1500VA 900W Line-Interactive UPS - 8 C13
Outlets, AVR, 230V, 50/60 Hz, USB, DB9, LCD, 2U
Rack/Tower
MODEL NUMBER: SMX1500LCD
Highlights
Protects equipment against
blackouts, brownouts,
overvoltages, surges and line
noise
Keeps AC power running during
blackouts to allow time for file
saves and safe shutdown
Maintains continuous 230V
nominal output during
brownouts and overvoltages
Easy-to-read LCD allows realtime monitoring of voltage,
battery status and other data
High 96% efficiency with low
BTU ratings saves electricity
and lowers your energy costs
Applications
Protect your PC and other
sensitive electronics against
power surges, line noise,
brownouts, overvoltages and
blackouts
Rack-mount UPS offers complete power protection for small network applications, including wiring closets,
security and digital signage.
Operate essential equipment
during short-term power outages
using battery backup power
Features
Shut down desktop PCs and
other equipment without data
loss during long-term power
outages
Connect high-end security
systems, casino gaming
machines or digital signage in a
small network
1.5kVA/900W/230V Battery Backup for PC Networks, Security Systems or Digital Signage
The SmartPro® line-interactive SMX1500LCD UPS system with AVR protection provides reliable battery
backup and AC power protection against blackouts, brownouts, overvoltages, surges and line noise that
can damage valuable electronics or destroy data. The eight-outlet 230V battery backup is ideal protection
for home/office workstations, VoIP systems, small business networks and other professional applications,
including retail, casino and hotel/motel management.
Allows Time to Back Up Critical Files During a Blackout
Backup support allows you to work through short power failures and gives you enough time to safely save
files and shut down your system in case of a prolonged blackout. Backup time varies according to load,
but the line-interactive UPS system should keep an energy-efficient desktop computer with small LCD
monitor powered as long as 60 minutes. During normal operation, incoming utility power keeps the
replaceable internal battery fully charged, so backup power will always be available.
8 C13 Outlets Protect Your Connected Components
Eight IEC 320 C13 outlets provide battery backup, 360 joules of surge protection and voltage regulation
for your computer, monitor and other crucial components.
Automatic Voltage Regulation (AVR) Corrects Low- and High-Voltage Conditions
AVR protects your equipment from incremental hardware damage, data loss and performance problems
caused by brownouts and overvoltages. The SMX1500LCD can correct brownouts as low as 144V and
overvoltages as high as 282V back to nominal 230V power continuously, all while keeping the battery fully
charged and ready to take over in case of power failure.
Combats Line Noise That Can Harm Equipment
EMI (electromagnetic interference) and RFI (radio frequency interference) are common causes of
performance problems and can lead to incremental hardware damage, data corruption and audio/video
transmission problems. The SMX1500LCD filters out this disruptive line noise on the AC line, so that it
won’t affect your equipment.
1/6
Package Includes
SMX1500LCD 1500VA 900W
230V Line-Interactive UPS with
8 Outlets
USB cable
RJ11 cable
(2) C13 to C14 power cables
Tower/rack mounting hardware
Owner’s manual
Cleveland, OH 44122
United States
Designed for High Efficiency to Help You Save Money and Protect the Environment
A 96% efficiency rating reduces BTU emissions, energy consumption and, ultimately, your energy costs.
Alarm and Easy-to-Read LCD Keep You Informed 24/7
The LCD screen indicates input voltage, battery charge level, overload, AVR, on-battery and replace
battery status. It rotates for easy viewing in either rack or tower configuration. The audible alarm sounds
for power failure, low battery and overloads. You may silence it using the built-in switch or disable it
remotely through your PC.
Advanced Communications Ports Allow for Automatic Saves and Shutdowns
RS-232 and HID-compliant USB ports connect to a computer running Tripp Lite’s free downloadable
PowerAlert® software to enable safe unattended file saves and system shutdown in case of a prolonged
power failure. A USB cable is included.
Versatile Installation Options
Hardware is included for mounting the Tripp Lite SmartPro UPS system in 2U of space in an EIA-standard
19-inch 4-post or 2-post rack. It will also stand in a tower position using the included hardware for extra
stability. You can rotate the LCD screen to match the UPS’ orientation. The unit has a C14 power input
that connects to an AC power source with an appropriate cord.
Specifications
OVERVIEW
UPC Code
037332126078
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
4.4A
Nominal Input Voltage(s) Supported
230V AC
UPS Input Connection Type
C14 inlet
UPS Input Connection Description
Chassis mounted C14 inlet accepts user-supplied AC power cord with country specific cordsets
Input Circuit Breakers
5A
Input Frequency
±3Hz
OUTPUT
Output Capacity (VA)
1500
Output Capacity (kVA)
1.5
Output Capacity (Watts)
900
Output Capacity (kW)
0.9
Nominal Voltage Details
230V nominal output in battery mode
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Automatic frequency selection
2/6
Cleveland, OH 44122
United States
Output Voltage Regulation (Line
Mode)
-18%, +8%
Output Voltage Regulation (Battery
Mode)
+/- 5%
Included Output Power Cables
Includes 2 C13 to C14 output power cables.
Hot-Swap PDU options
PDUBHV10 (2U / 8 C13 outlets)
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
PWM sine wave
Nominal Output Voltage(s)
Supported
220V; 230V; 240V
Output Receptacles
(8) C13
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
4.5 min. (900W)
Runtime Half Load (min.)
12 min. (450W)
Expandable Runtime
No
DC System Voltage (VDC)
24
Battery Recharge Rate (Included
Batteries)
4.5 hours from 10% to 90%
Battery Access
Includes battery access door
Internal UPS Replacement Battery
Cartridge
IMPORTANT BATTERY REPLACEMENT INFORMATION > If your SMX1500LCD UPS has no battery
replacement door, please contact a local electronics repair technician to source and install a matching replacement
battery; If your SMX1500LCD UPS is equipped with a battery access door, please order Tripp Lite RBC1500 (quantity 1) replacement battery
Battery Replacement Description
Hot-swappable, user-replaceable internal battery cartridge
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 144 to 282
Overvoltage Correction
Input voltages between 245 and 282 are reduced by 12%
Undervoltage Correction
Input voltages between 177 and 199 are boosted by 14%
Severe Undervoltage Correction
Input voltages between 144 and 176 are boosted by 30%
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Backlighted LCD screen offers detailed UPS status information, configuration options and Error message reporting;
STATUS INFORMATION includes Input Voltage, Output Voltage, Estimated Runtime (minutes), Output Load
Percentage, Output Load Wattage, Battery Charge Percentage, Graphical 5-Bar Battery Charge Level and UPS
Operating Mode Display; CONFIGURATION OPTIONS include Power Sensitivity, LCD Status Information Scrolling,
Alarm Disable, LCD Brightness and Self Test / REPORTED ERROR MESSAGES include Replace-Battery and
Overload conditions; LCD Screen rotates for vertical or horizontal UPS placement
3/6
Cleveland, OH 44122
United States
Switches
ON/OFF/MODE button provides UPS on/off power control (long-press) and advances the LCD screen display (short
tap); MUTE/ENTER button provides temporary alarm cancel, plus selection and confirmation of on-screen
Alarm Cancel Operation
Press the MUTE/ENTER button during a power failure to silence the alarm; Once silenced, alarm will re-sound to
indicate low-battery status
Audible Alarm
Audible alarm indicates power-failure and low-battery status; Alarm can be disabled entirely via front panel LCD
interface (see manual)
LED Indicators
Front panel LCD display
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
360
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet
UPS Dataline Suppression Details
RJ11 telephone cable included
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Rackmount
Rack Height
2U
Cooling Method
Convection
Included Mounting Accessory
Description
Included mounting brackets enable installation in 2 and 4 post racks, plus upright tower configurations; Set of 4
rubber-feet enable no-slip horizontal desktop placement
Installation Form Factors Supported
with Included Accessories
2 post 19 inch rackmount; 2 post front mount; 4 post 19 inch rackmount; Tower
Minimum Required Rack Depth (cm)
35.56
(inches)
14
Primary UPS Depth (mm)
267
Primary UPS Height (mm)
89
Primary UPS Width (mm)
438
Shipping Dimensions (hwd / in.)
7.80 x 15.28 x 21.77
Shipping Dimensions (hwd / cm)
19.81 x 38.81 x 55.30
Shipping Weight (lbs.)
34.55
Shipping Weight (kg)
15.67
UPS Housing Material
ABS
UPS Power Module Dimensions
(hwd, cm)
8.89 x 43.82 x 26.67
(hwd, in.)
3.5 x 17.25 x 10.5
UPS Power Module Weight (kg)
13.34
4/6
Cleveland, OH 44122
United States
UPS Power Module Weight (lbs.)
29.4
Unit Weight (lbs.)
29.400
Unit Weight (kg)
13.34
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
133
Battery Mode BTU / Hr. (Full Load)
542
AC Mode Efficiency Rating (100%
Load)
96%
COMMUNICATIONS
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Network Management Card
Description
Network management not supported
Communications Interface
DB9 Serial; USB (HID enabled)
LINE / BATTERY TRANSFER
Transfer Time
3 milliseconds (AC to battery mode) / 2 milliseconds (battery to AC mode)
Low Voltage Transfer to Battery
Power (Setpoint)
144
High Voltage Transfer to Battery
Power (Setpoint)
282
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Automatic Voltage Regulation (AVR); Hot swappable batteries; Surge/noise protection
Green Energy-Saving Features
Greater than 95% efficiency - GREEN UPS
STANDARDS & COMPLIANCE
Product Certifications
GOST (Russia); EN 62040-1; EN 62040-2
Product Compliance
RoHS; SASO (Saudi Arabia); CE (Europe)
WARRANTY & SUPPORT
5/6
Cleveland, OH 44122
United States
Product Warranty Period
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
