1000 Eaton Boulevard
Cleveland, OH 44122
United States
SmartPro 230V 1.5kVA 900W Line-Interactive
Sine Wave UPS, Tower, Network Card Options,
USB, DB9, 8 Outlets
MODEL NUMBER: SMX1500SLT
Highlights
Corrects under- and
overvoltages from 182V to 278V
(230V)
8 C13 outlets
Front-panel LEDs indicate load,
power, voltage and battery
statuses
Add optional WEBCARDLX with
latest version of PADM20 for
enhanced remote management
20 min. runtime at half load; 8
min. at full load
Package Includes
Protects connected mission-critical equipment against damage, downtime and data loss due to blackouts,
brownouts, surges and line noise. Ideal solution for point-of-sale applications, VoIP systems and small
business networks.
Description
The SMX1500SLT SmartPro 230V 1.5kVA 900W Line-Interactive Sine Wave UPS provides battery
backup and AC power protection against blackouts, brownouts, power surges and line noise that can
damage electronics or destroy data. Ideal for backing up point-of-sale applications, VoIP systems and
small business networks, the SMX1500SLT switches to battery mode in milliseconds to keep your
connected equipment running long enough to save files and shut down safely with no data loss.
Featuring eight C13 outlets and a C14 inlet that accepts a user-supplied AC power cord, the
SMX1500SLT has an internal battery that provides 20 minutes of support at half load and eight minutes at
full load. Front-panel LEDs indicate line power, voltage regulation, load level and battery status. An alarm
sounds to indicate power failure or overload.
Automatic voltage regulation (AVR) maintains selectable 220V, 230V or 240V nominal output over an
input range of 174V–266V (220V), 182V–278V (230V) or 190V–290V (240V) without using battery power.
EMI/RFI noise filtering improves your equipment’s performance and prevents damage. A 350-joule surge
suppression rating protects your equipment from harmful power surges. With Tripp Lite’s downloadable
PowerAlert® software, the SMX1500SLT enables safe unattended system shutdown and file saves in
case of a prolonged power failure. Adding an optional Network Managment Card permits remote
management of the UPS.
Features
Protects Mission-Critical Equipment
● Provides fully regulated sine wave AC output for point-of-sale applications, VoIP systems and small
business networks
Audible alarm signals loss of utility power or overload
8 C13 outlets
C14 inlet accepts user-supplied AC power cord with country-specific plug
350-joule surge suppression rating
Reliable Battery Backup
1/6
Sine Wave UPS
USB cable
DB9 cable
(2) IEC-320 C13-to-C14 power
cables
Owner’s manual
Cleveland, OH 44122
United States
Supports half load up to 20 min. and full load up to 8 min.
Internal batteries designed for hot-swap field replacement
Cold-start capability enables turn-on in battery mode during blackouts
Automatic Voltage Regulation (AVR)
● Maintains selectable nominal output without using battery power
Corrects brownouts and overvoltages from 174V–266V (220V), 182V–278V (230V) or 190V–290V
(240V)
EMI/RFI Line Noise Filtering
● Removes electromagnetic and radio frequency interference that can disrupt or damage equipment’s
performance
LED Indicators
● Front-panel LEDs indicate line power, voltage regulation, load level and battery status
Network Management Cards
● Compatible with Tripp Lite UPS management card options WEBCARDLX, SNMPWEBCARD and
RELAYIOCARD
Optional WEBCARDLX (sold separately) with the latest version of PowerAlert Device Manager firmware
(PADM20) provides enhanced remote management capabilities
PADM20 and PowerAlert Element Manager (PAEM) form a powerful tool for expanding maintenance
functions in large installations, including firmware update checks and backup and restoration of device
configurations
Communication Ports
● USB & Serial ports enable data-saving unattended shutdown when used with Tripp Lite's PowerAlert
software, available via FREE download from tripplite.eaton.com/products/power-alert
Telephone/Network Jacks
● Protect against power surges over telephone/DSL or network Ethernet lines
Specifications
OVERVIEW
UPC Code
037332124555
UPS Type
Line-Interactive
INPUT
Input Phase
Single-Phase
Rated input current (Maximum Load)
4.1A (220V),3.9A (230V), 3.8 (240V)
Nominal Input Voltage(s) Supported
220V AC; 230V AC; 240V AC
UPS Input Connection Type
C14 inlet
2/6
Cleveland, OH 44122
United States
UPS Input Connection Description
IEC320-C14 input connection accepts a variety of detachable cordsets to match country or site-specific wall
receptacles
OUTPUT
Output Capacity (VA)
1500
Output Capacity (kVA)
1.5
Output Capacity (Watts)
900
Output Capacity (kW)
0.9
Nominal Voltage Details
230V default (voltage selection via back panel switches)
Frequency Compatibility
50 / 60 Hz
Frequency Compatibility Details
Automatic frequency selection
Output Voltage Regulation (Line
Mode)
-9% / + 5%
Output Voltage Regulation (Battery
Mode)
+/- 5%
Included Output Power Cables
Includes 2 C13 to C14 output power cables
Output AC Waveform (AC Mode)
Sine wave
Output AC Waveform (Battery
Mode)
Pure Sine wave
Nominal Output Voltage(s)
Supported
220V; 230V; 240V
Output Receptacles
(8) C13
Individually Controllable Load Banks
No
BATTERY
Battery Type
Valve Regulated Lead Acid (VRLA)
Runtime Full Load (min.)
8 min. (900W)
Runtime Half Load (min.)
20 min. (450W)
Expandable Runtime
No
DC System Voltage (VDC)
36
Battery Recharge Rate (Included
Batteries)
Less than 8 hours from 10% to 90% (typical, full load discharge)
Battery Access
Battery access door
Internal UPS Replacement Battery
Cartridge
RBC36-SLT
Battery Replacement Description
Hot-swappable, user replaceable batteries
VOLTAGE REGULATION
Voltage Regulation Description
Automatic voltage regulation (AVR) maintains line power operation with an input voltage range of 182 to 278 (230v),
190 to 290 (240v), 174 to 266 (220v)
3/6
Cleveland, OH 44122
United States
Overvoltage Correction
Voltage reduction of 12% applies when input is 244 to 278 (230v), 254 to 290 (240v), 232 to 266 (220v); Voltage
setpoints ±5% tolerance
Undervoltage Correction
Voltage boost of 14% applies when input is 182 to 206 (230v), 190 to 216 (240v), 174 to 198 (220); Voltage
USER INTERFACE, ALERTS & CONTROLS
Switches
2 Switches control off/on power status and alarm-cancel/self-test operation; rear panel protected switches support
nominal voltage selection
Alarm Cancel Operation
Power-fail alarm can be silenced using alarm-cancel switch
Audible Alarm
Audible alarm indicates power failure and overload conditions
LED Indicators
9 LEDs indicate line power, battery power, AVR, overload and replace battery status - with a 3-LED level meter for
load and battery charge level
SURGE / NOISE SUPPRESSION
UPS AC Suppression Joule Rating
350
UPS AC Suppression Response
Time
Instantaneous
UPS Dataline Suppression
1 line TEL/DSL (1 in / 1 out); 10/100Base T Ethernet
EMI / RFI AC Noise Suppression
Yes
PHYSICAL
Primary Form Factor
Tower
Cooling Method
Fan
Installation Form Factors Supported
with Included Accessories
Tower
Primary UPS Depth (mm)
335
Primary UPS Height (mm)
259
Primary UPS Width (mm)
173
Shipping Dimensions (hwd / in.)
18.50 x 10.00 x 13.50
Shipping Dimensions (hwd / cm)
46.99 x 25.40 x 34.29
Shipping Weight (lbs.)
47.30
Shipping Weight (kg)
21.45
UPS Housing Material
Steel
UPS Power Module Dimensions
(hwd, cm)
25.91 x 17.27 x 33.53
(hwd, in.)
10.2 x 6.8 x 13.2
UPS Power Module Weight (kg)
20.41
UPS Power Module Weight (lbs.)
45
Unit Weight (lbs.)
43.5000
Unit Weight (kg)
19.73
4/6
Cleveland, OH 44122
United States
ENVIRONMENTAL
Operating Temperature Range
32° to 104°F (0° to 40°C)
Storage Temperature Range
5° to 122°F (-15° to 50°C)
Relative Humidity
0 to 95%, non-condensing
AC Mode BTU / Hr. (Full Load)
145
Battery Mode BTU / Hr. (Full Load)
585
AC Mode Efficiency Rating (100%
Load)
94%
Audible Noise
Audible Noise < 50 dBA at Front Side 1 Meter
COMMUNICATIONS
SNMPWEBCARD; WEBCARDLX ; RELAYIOCARD
Network Monitoring Port Description
Supports detailed monitoring of UPS and site power conditions
PowerAlert Software
For local monitoring via the UPS’s built-in communication ports, download PowerAlert software at
https://tripplite.eaton.com/products/power-alert
Communications Cable
USB and DB9 cabling included
WatchDog Compatibility
Supports Watchdog application, OS and hard-reboot restart options for remote applications
Description
Network management card optional
Communications Interface
DB9 Serial; Slot for SNMP/Web interface; USB
LINE / BATTERY TRANSFER
Transfer Time
4-8 milliseconds
Low Voltage Transfer to Battery
Power (Setpoint)
174V (220V), 182V (230V) or 190V (240V); Voltage setpoints ±5% tolerance
High Voltage Transfer to Battery
Power (Setpoint)
266V (220V), 278V (230V) or 290V (240V); Voltage setpoints ±5% tolerance
FEATURES & SPECIFICATIONS
Cold Start (Startup in Battery Mode
During a Power Failure)
Cold-start operation supported
High Availability UPS Features
Auto Probe Monitoring (requires WEBCARDLX); Automatic Voltage Regulation (AVR); Hot swappable batteries;
Remote management; Surge/noise protection
STANDARDS & COMPLIANCE
Product Certifications
GOST (Russia)
Product Compliance
RoHS; SASO (Saudi Arabia); CE (Europe); FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
5/6
Cleveland, OH 44122
United States
Product Warranty Period
(International)
2-year limited warranty
Product Warranty Period (Mexico)
Product Warranty Period (Puerto
Rico)
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
6/6
